DF19 Series
Sep.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board,
Micro-coaxial Cable-to-Board Connectors
Jan. 2022
DF19 Series/1.0mm Pitch, Low Profile Wire-to-Board, FPC-to-Board, Micro-coaxial Cable-to-Board Connectors
Features
1. De Facto Standard for LCD
Panel Connection
DF19 has been accepted as the market standard
for LCD panels ( 12in. or less) due to its high
performance for LVD high speed differential
signals.
Cable Connection
Cable, micro- coaxial type : 1. 5mm thickness
( 1. 6mm Max. )
FPC Type : 1. 7mm Max.
8.2
7.2
DF19G-#P-1H(52)
1.5
1.65
Cable
DF19G-#S-1C(05)
DF19A-2830 / 3032 / 36SCFA
PCB
FPC Connection
8.2
7.2
DF19G-#P-1H(52)
1.65
(1.7)
FPC
DF19G-#S-1F(05)
DF19G-#S-1F-GND(06)
3. Common Header
Cable Type
Header is compatible with the 3 socket types
( discrete wire, FPC and micro- coaxial types) , for
a wide selection of mating combinations.
(1.7)
DF19G-#S-1F(05)
+DF19G-#S-1F-GND(06)
(7.7)
(7.7)
DF19G-#S-1C(06)
DF19-#P-1V(52)
(0.78)
Cable, Micro-coaxial Type
1.3±0.2
DF19G-#S-1SD(06)
+DF19G-#S-1SD-GND
DF19-#P-1V(52)
4. Uniform External Dimensions
External dimensions of each socket type are the
same and can be used in a wide array of
applications.
2
PCB
FPC Type
1.5±0.1
(7.7)
2. Low Profile Design
DF19-#P-1V(52)
5. Wide Varieties
Top-board Mounted
Header is available in top- board, offset, reverse
mount offset and vertical mounted styles to meet
a wide array of application needs.
Discrete Wire
Offset Mounted
FPC
Reverse Offset Mounted
Micro-coaxial Cable
Vertical Mounted
6. Ground Connection with
Outer Shell
Metal shell enables ground connection.
7. Glow Wire Compatible
( IEC60695- 2- 11 Standard)
Applications
Mobile phones, LCD connections, DVC, DSC, PDA, camera modules, and other small equipment
Micro-coaxial
Cable
DF19
FPC
Twisted
pair cable
Notebook PC
DF19
DF19
DF19
3
Product Specifications
Rated
Current
28 AWG
30 AWG
32 AWG
36 AWG
FPC
Micro-coaxial
Cable
40 AWG
1A/pin
0.9A/pin
0.8A/pin
0.5A/pin
0.5A/pin
0.3A/pin
Rated
Voltage
Note
Note
Note
Note
1
2
3
4
Operating Temperature
(Note 1)
-35 to +85℃
Operating Humidity Range
(Note 2)
40 to 80%
Storage Temperature Range
(Note 3)
100V AC/DC
-10 to +60℃
Storage Humidity Range
(Note 3)
40 to 70%
Includes temperature rise due to current flow.
Please use without condensation.
Applicable to unused items in packaged state.
Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part
number shown.
Item
Specification
Conditions
Insulation
Resistance
500M Ω Min.
100V DC
Withstanding
Voltage
No flashover or insulation breakdown.
300V AC for 1 min.
Contact Resistance
30m Ω Max. (50m Ω Max. for FPC)
1mA
Vibration
No electrical discontinuity of 1μ s or more.
Frequency : 10 to 55 Hz, single amplitude of 0.75mm, in 3
direction for 10 cycles
Humidity
(Steady State)
Contact Resistance : 30m Ω Max. (50m Ω
Max. for FPC)
Insulation Resistance : 500M Ω Min.
96 hours at temperature of 40 ± 2℃ and
humidity of 90 to 95%
Temperature Cycle
Max. for FPC)
Temperature : -55℃ → +5 to +35℃ → +85℃ → +5 to +35℃
Time (Minutes) : 30 → 10 → 30 → 10 for 5 cycles
Mating Durability
Max. for FPC)
30 cycles
Soldering Heat
Resistance
No deformation of the insulator parts affecting
performance.
Re-flow soldering : At the recommended temperature profile
Manual soldering : Soldering iron temperature 350℃ , 5
seconds
Materials / Finish
Product
Pin Header
Crimp Case
Socket Crimp Contact
FPC Socket
FPC Grounding Plate
Micro-coaxial Socket
Grounding Plate for Micro-Coaxial
Component
Material
Finish / Color
Remarks
Insulator
Polyamide
Black or Beige
Contacts
Phosphor Bronze
Partially Gold Plated
Exterior Shell
Phosphor Bronze
Partially Tin Plated
Insulator
Polyamide
Beige
Exterior Shell
Stainless Steel
Tin Plated
Contact
Phosphor Bronze
Gold Plated
Insulator
Polyamide
Beige
Contact
Phosphor Bronze
Gold Plated
Exterior Shell
Stainless Steel
Tin Plated
Insulator
LCP
Beige
Contact
Phosphor Bronze
Exterior Shell
Phosphor Bronze
Tin Plated
Exterior Shell
Phosphor Bronze
Tin Plated
4
RoHS2
UL94V-0
UL94V-0
UL94V-0
UL94V-0
〇
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
■ Connector
DF19 # - # P - 1 H(52)
❶
❷
❸ ❹
❺ ❻
❽
DF19 # - # S - 1 F - GND
❶
❶
❷
❷
❸ ❹
❺ ❻
❼
Series Name
DF19
❸
No. of Pos.
8, 14, 20, 30 (Note 1)
❹
Connector Type
S : Single Row Socket
P : Single Row Pin Header
❺
Contact Pitch
1.0mm
❻
Mounting Type/
Termination Type
Configuration
Pin Header
G : Top-board Mouted (1.65mm Height)
K : Offset Mounted (1.0mm Height)
L : Offset Mounted (1.1mm Height)
KR : Reverse Offset Mounted Version of
DF19K (1.0mm Height)
Crimp Socket
Blank : No Exterior Shell
G : With Exterior Shell
(EMI Prevention Specification)
FPC Socket
G : With Grounding Plate
Grounding Plate for FPC
Grounding Plate for Micro-coaxial Cable
H:Right Angle SMT
V:Straight SMT
C:Crimp Case
F : FPC, Socket
SD:Micro-coaxial Socket
❼
Attachable Parts
GND : Ground plate (Note 2)
❽
Specification
(52) : Gold plated, tape & reel packaging
Note 1 : The pin count availabilities vary based on connection style.
Note 2 : Grounding plates are required when terminating with the FPC and Micro-coaxial cable.
■ Crimp Contact
DF19A - 2830 SCF A (##)
❶
❷
❸
❹
❶
Conductor Size
2830 : 28-30 AWG
3032 : 30-32 AWG
36 : 36 AWG
❸
Plating
A : Gold Plated
❷
Contact Type/
Packaging
SCF : Socket Contact, Reel
❹
Packaging
Blank : 10,000pcs per reel
(41) : 20,000pcs per reel
5
Right Angle Pin Header (SMT) (Top-Board Mounted Type)
A
2.375
B
P= 1
2.175
4.7
2.45
0.25
2
Contact No. 1 Indicator
C
1.65
1.65
Pictured mounted on board.
Recommended PCB Mounting Pattern
B±0.05
1.85±0.1
1+0.1
P=1±0.05
1.65±0.1
0.55±0.05
+0.1
2.5±0.05
1.1+0.1
5.7
Note : If there is a pattern on the
the ground plate.
portion and resist is not applied, it may come into contact with
Unit : mm
Part No.
HRS No.
No. of
Pos.
A
B
C
DF19G-8P-1H(52)
CL0685-0021-0-52
8
11.55
7.0
11.95
DF19G-14P-1H(52)
CL0685-0004-0-52
14
17.55
13.0
17.95
DF19G-20P-1H(52)
CL0685-0006-6-52
19.0
23.95
DF19G-30P-1H(52)
CL0685-0015-7-52
30
33.55
29.0
33.95
Note : When using in combination with the single row socket (FPC Type), mount on the edge of the PCB.
6
Remarks
Purchase Unit
1.65mm Height
Above Board
1,000pcs per reel
Right Angle Pin Header (SMT) (Offset Mounted Type)
A
2.375
B
2.175
0.25
4.7
2.45
P=1
C
F
6.7
B±0.05
3.175±0.1
2.975±0.1
P=1±0.05
1+0.1
(2.2)
2.5 +0.1
5.3±0.1
0.3
1.5 +0.1
0.55±0.05
5.5±0.1
1
F
1.46
2
DF19K Identification Mark
D+0.2
-0.1
E ±0.1
Unit : mm
Part No.
HRS No.
No. of
Pos.
DF19K-20P-1H(52)
CL0685-0008-1-52
19.0
26.55
24.15
25.15
1.0
DF19K-30P-1H(52)
CL0685-0032-6-52
30
33.55
29.0
36.55
34.15
35.15
1.0
DF19L-14P-1H(52)
CL0685-0003-8-52
14
17.55
13.0
20.55
18.15
19.15
1.1
A
B
C
D
E
F
Remarks
1.0mm Height
Above Board
DF19L-20P-1H(52)
CL0685-0019-8-52
19.0
26.55
24.15
25.15
1.1
DF19L-30P-1H(52)
CL0685-0016-0-52
30
33.55
29.0
36.55
34.15
35.15
1.1
7
Purchase Unit
1,000pcs per reel
1.1mm Height
Above Board
Right Angle Pin Header (SMT) (Reverse Offset Mounted Type)
A
2.375
B
2.175
0.25
2
4.7
2.45
P=1
6.7
1
C
1
1.46
1
3.175±0.1
2.975±0.1
B±0.05
P=1±0.05
1+0.1
0.55±0.05
D
(2.2)
0.3
5.3±0.1
2.5
+0.1
1.5 +0.1
5.5±0.1
+0.2
-0.1
E±0.1
Unit : mm
Part No.
HRS No.
No. of
Pos.
DF19KR-20P-1H(52)
CL0685-0023-5-52
A
B
C
D
E
Remarks
Purchase Unit
23.55
19.0
26.55
24.15
25.15
1.0mm Height
Above Board
1,000pcs per reel
8
1.12
1.07
Straight Pin Header (SMT)
P=1
0.95
0.25
B
1.3
1.56
5.22
A
1.96
C
1
3.8
0.25
+0.1
+0.1
0.65
2.5 0
2.2±0.05
0.65±0.05
P=1±0.05
注1
0.55±0.05
(E)
(F)
1.7+0.1
+0
1.45
注1
+0.1
D±0.05
1.5+0
1.46±0.05
A
2
G±0.05
0.8±0.05
the ground plate.
Unit : mm
Part No.
HRS No.
No. of
Pos.
A
B
C
D
E
F
G
Purchase Unit
1,000pcs
per reel
DF19-14P-1V(52)
CL0685-0036-7-52
14
17.9
13.0
15.25
14.95
6.675
6.325
13.0
DF19-20P-1V(52)
CL0685-0037-0-52
19.0
21.25
20.95
9.675
9.325
19.0
9
Single Row Socket (Cable Type)
DF19G-#S-1C(06)
DF19-#S-1C
A
A
B
P=1
Mark Every 5 Contacts
1.5
1.5
A
A
Shown with terminated and installed contacts
B
6.1
6.1
P=1
14
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
Purchase Unit
DF19-8S-1C
CL0685-0029-1-00
8
11.5
7.0
DF19-14S-1C
CL0685-0012-9-00
14
17.5
13.0
DF19-20S-1C
CL0685-0011-6-00
19.0
DF19-30S-1C
CL0685-0013-1-00
30
33.5
29.0
With Exterior Shell (EMI Prevention Specification)
Part No.
HRS No.
Unit : mm
No. of Pos.
A
B
DF19G-8S-1C(06)
CL0685-0022-2-06
8
11.5
7.0
DF19G-14S-1C(06)
CL0685-0005-3-06
14
17.5
13.0
DF19G-20S-1C(06)
CL0685-0007-9-06
19.0
DF19G-30S-1C(06)
CL0685-0014-4-06
30
33.5
29.0
10
100pcs per bag
Purchase Unit
100pcs per bag
Socket Crimp Contacts
0.63
0.9
0.5
2
5.1
0.7
t=0.15
Part No.
HRS No.
DF19A-2830SCFA(##)
CL0685-0048-6-##
DF19A-3032SCFA(##)
CL0685-0046-0-##
DF19A-36SCFA(##)
CL0685-0047-3-##
Purchase Unit
(##) : Blank
Purchase Unit
(##) : (41)
10,000pcs per reel
20,000pcs per reel
Applicable Wire (Tin Plated Annealing Copper Wire)
Part No.
UL
DF19A-2830SCFA(##)
DF19A-3032SCFA(##)
1571
(Thin Type)
DF19A-36SCFA(##)
Wire Size
Stranded Wire Structure
Sectional
Area
28 AWG
30 AWG
7/0.127mm
7/0.1mm
0.089mm2
0.055mm2
30 AWG
32 AWG
7/0.1mm
7/0.08mm
0.055mm2
0.035mm2
36 AWG
7/0.05mm
0.014mm2
Jacket Diameter
φ 0.5-0.6mm
Strip Length
1.2-1.9mm
φ 0.27mm
Note 1 : Please contact a Hirose sales representative when using cables other than those specified.
Note 2 : Contact your Hirose sales representative when using 36 AWG.
Applicable Tools
Type
Part No.
HRS No.
Applicator
AP105-DF19S
CL0901-4571-3-00
Press Unit
CM-105C
CL0901-0001-0-00
Note
Note
Note
Note
1
2
3
4
Applicable Contact
DF19A-2830SCFA(##)
DF19A-3032SCFA(##)
Please conduct crimping work according to the "Crimping Quality Standard" (ETAD-H0945-00)" and "Crimping Condition Table".
Issues with non-Hirose specified tools are outside the scope of warranty.
When non-authorized tools are used, please consult with Hirose sales representative about provision of the drawing of the crimping tool.
11
Single Row Socket (FPC Type)
Note : Socket and grounding plate is required
A
B
C
5.95
P=1
A
1.2
Contact Mark Indicator
Shown terminated with FPC.
D±0.08
0.45±0.3
0.2±0.1
2.2±0.05
0.2±0.15
0.7±0.03
t=0.145±0.03
グランド面< :はんだめっ
き1~5μm>
Ground
Area
: Solder Plating 1 to 5μm thickness.
.2
.05
±0
0.05
0.05
0.3±0.15
R0.1
0.35±0.03
E±0.05
R0
0.4±0.05
( 0.35)
XR
MA
MAXR0
.2
0.2
3.6
2 ±0.15
P=1±0.03
1.85±0.25
C±0.05
.2
0.35±0.25
0.3±0.15
R0
CAV No.
Signal信号面< :はんだめっ
Area
: Solderき
Plating
1 to 5μm thickness.
1~5μm>
Unit : mm
Part No.
HRS No.
No. of
Pos.
A
B
C
D
E
DF19G-14S-1F(05)
CL0685-0017-2-05
14
17.5
17.1
13.0
15.6
14.0
DF19G-20S-1F(05)
CL0685-0009-4-05
23.1
19.0
21.6
20.0
DF19G-30S-1F(05)
CL0685-0033-9-05
30
33.5
33.1
29.0
31.6
30.0
Note : When using in combination with the right angle pin header (Top Board Type), mount on the edge of the PCB.
12
Purchase Unit
100pcs per bag
Ground Plate for FPC
A
B
4.1
No. of Pos. Indicator
SIGNAL
1
4
1.5
C
D
Unit : mm
Part No.
HRS No.
No. of
Pos.
A
B
C
D
DF19G-14S-1F-GND(06)
CL0685-0018-5-06
14
15.75
14.35
17.5
14.4
DF19G-20S-1F-GND(06)
CL0685-0010-3-06
20.35
23.5
20.4
DF19G-30S-1F-GND(06)
CL0685-0034-1-06
30
31.75
30.35
33.5
30.4
Purchase Unit
100pcs per bag
Applicable Assembly Tools
Type
Part No.
HRS No.
Desktop tool (for 14pos.)
DF19G-14S/PR-MD2
CL0902-4514-6-00
Desktop tool (for 20pos.)
DF19G-20S/PR-MD2
CL0902-4513-3-00
Desktop tool (for 30pos.)
DF19G-30S/PR-MD2
CL0902-4518-7-00
Note : Issues caused by tools other than those specified for Hirose are outside the scope of warranty.
13
6.1
Contact
端子NO.1マ-ク
No. 1 Indicator
1.33
C±0.2
D±0.15
P=1±0.1
Inner
conductor
内部導体
Insulator
誘電体
Grounding
bar
金属バ-
スズコ-
ト1.2MIN
Solder Coat
1.2 Min.
P=1
A
B
3±0.1
0.7±0.05
0.9MAX
Single Row Socket (Micro-coaxial)
外部導体
Outer Conductor
ジ
ャケット
Jacket
Shown terminated with micro-coaxial cable.
Note 1 : The pitch misalignment prevention tape can be connected without cutting, but please use a
durable material.
Note 2 : The inner conductor must be soldered in advance.
Note 3 : When using a two position coaxial line, there are some pin arrangements that cannot be used
due connector protrusion. Please check the official specifications.
Unit : mm
Part No.
HRS No.
No. of
Pos.
A
B
C
D
Purchase Unit
DF19G-14S-1SD(06)
CL0685-0026-3-06
14
17.4
13.0
14.8
13.0
DF19G-20S-1SD(06)
CL0685-0025-0-06
19.0
20.8
19.0
100pcs per bag
Applicable Cable (Micro-coaxial Cable)
Wire Size (Core Wire Configuration)
Jacket Diameter
40 AWG (7 / 0.03mm)
φ 0.3-0.4mm
14
4.36
1.27
A
Unit : mm
Part No.
HRS No.
No. of Pos.
A
DF19G-14S-1SD-GND
CL0685-0028-9-00
14
17.5
DF19G-20S-1SD-GND
CL0685-0027-6-00
15
Purchase Unit
100pcs per bag
Embossed Carrier Tape Dimensions (JIS-C-0806 Standard)
● DF19G-#P-1H(52)
● DF19K-#P-1H(52)
● DF19L-#P-1H(52)
12±0.1
2±0.1 4±0.1
G-G
1.75±0.15
t=0.3±0.1
G
2±0.5
φ1.5 Feed
Hole Depth
C±0.1
Part Number Label
φ2
H
H
H-H
E
+2
F
G
2.5±0.15
(2.3)
1
B±0.1
A±0.3
D±0.3
φ13
φ80
+0
0 .1
φ330
1.5
1.75±0.1
φ
Unreeling Direction
7.8±0.3
Unit : mm
No. of
Pos.
A
B
C
D
E
F
8
24.0
11.5
16.1
24.4
30.4
DF19G-14P-1H(52)
14
44.0
40.4
20.2
22.1
44.4
50.4
DF19G-20P-1H(52)
40.4
20.2
28.1
44.4
50.4
DF19G-30P-1H(52)
30
56.0
50.2
26.2
38.1
56.4
62.4
DF19K-20P-1H(52)
40.4
20.2
28.1
44.4
50.4
DF19K-30P-1H(52)
30
56.0
52.4
26.2
38.1
56.4
62.4
DF19L-14P-1H(52)
14
44.0
40.4
20.2
22.1
44.4
50.4
DF19L-20P-1H(52)
40.4
20.2
28.1
44.4
50.4
DF19L-30P-1H(52)
30
56.0
52.4
26.2
38.1
56.4
62.4
Part No.
DF19G-8P-1H(52)
16
Remarks
Top-board Mounted
(1.65mm Height)
Offset Mounted
(1.0mm Height)
Offset Mounted
(1.1mm Height)
● DF19KR-20P-1H(52)
0 .1
1.75±0.15
t=0.3±0.1
2±0.5
C±0.1
G
D±0.3
φ2
1
H
E
G
2.85±0.15
+2
F
Unreeling Direction
H-H
(2.3 )
7.8±0.3
Unit : mm
Part No.
No. of
Pos.
A
B
C
D
E
F
40.4
20.2
28.1
44.4
50.4
DF19KR-20P-1H(52)
Remarks
Reverse type of DF19K
Offset Mounted(1.0mm Height)
4±0.1
H
G
Ø13
1
H
φ1.5 Feed
Hole Depth
Unreeling Direction
t=0.4±0.1
φ80
φ380±2
3.7±0.2
2±0.5
E+20
F
Ø2
4±0.2
G
Part Number
Label
D±0.2
12±0.1
C±0.1
B±0.1
A±0.3
.1
+0 0
5
1.
2±0.1
1.75±0.1
● DF19-#P-1V(52)
φ
Øφ13
φ 80
B±0.1
A±0.3
H
φ1.5 Feed
Hole Depth
Part Number Label
φ330
12±0.1
.5 +0
G-G
1.75±0.1
Ø1
Unit : mm
Part No.
No. of Pos.
A
B
C
D
E
F
DF19-14P-1V(52)
14
32.0
28.4
14.2
18.2
32.4
38.4
DF19-20P-1V(52)
40.4
20.2
24.2
44.4
50.4
17
Remarks
Straight Type
Crimping Precautions
■ Items Required Prior to Crimping
The work- related documents shown below are required before starting harness assembly.
( The ● mark represents required documents. )
Please contact your Hirose sales representative if you do not have these documents.
Document Title
Description
Automatic
Crimping
Machine
Hand
Crimping
Tool
Remarks
Bundled with purchase of main
press machine unit.
① Crimping Machine Main
Unit Instruction Manual
Explanation of main press unit
② Applicator Instruction
Manual
Crimp Method
③ Applicator Spare Parts List
Applicator Installation Instruction
④ Crimp Conditions
Crimp height,
tensile strength standard value
⑤ Crimp Quality Standards
Various standards for crimping
conditions
⑥ Hand Tool Operating
Instructions
Crimp method, crimp height and
tensile height standard value
hand tool.
⑦ Cable Assembly
Cable assembly
Contact a Hirose sales
representative.
applicator.
■ Tools
・Use tools designated by Hirose when crimping.
・Crimping performed using tools other than those specified is outside the scope of warranty.
・The operating instructions are available for the crimping machine and the applicator. Be sure to carefully
read the operating instructions manual before beginning work.
■ Applicable Cables
Check that the cables to be used are within the applicable range.
If you intend to use a cable other than those recommended, contact a sales representative.
[ Precautions]
• Cables applicable to crimping connectors are tin- plated stranded soft- copper wire.
• Avoid crimping solid wire, wires with polyester threads or tin coated wires.
• Avoid crimping two cables together.
• The crimp height setting values ( Note) may vary between tin- plated and gold- plated terminals even if the
same electric wires are used.
• The crimp height setting values ( Note) may vary depending on the difference in the core wire configuration
even if the computed cross- sectional area is the same.
Note : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value
for the crimp height with high precision, thereby ensuring optimal setup values.
18
Precautions
1. Recommended
Temperature Profile
Temperature (℃)
250℃
220
200℃
180
150℃
Preheating
Soldering
250℃
10s Max.
220℃ Min. 60s Max.
60 to 120s
100℃
50℃
30
50
100
150
200
Time(S)
Note 1 : Up to 2 cycles of reflow soldering are possible under the same conditions,
provided that there is a return to normal temperature between the first and second cycle.
Note 2 : The temperature profile indicates the temperature of the surface of the connector lead.
Note 3 : The color of the grounding plate may change color, although this does not affect
the product performance.
2. Recommended Manual
Soldering Conditions
Manual soldering : 350±10℃ for 5 seconds
3. Recommended
Metal Mask Thickness
0.15mm
4. Board Warpage
Maximum of 0.03mm at the connector center, with both ends of the connector as
reference points.
5. Cleaning Conditions
Refer to “Wire-to-Board Connector Use Handbook.”
6. Termination Conditions
7. Cautions
■ Excessive prying during mating and unmating may result in damage.
8. Handling
Please refer to the following documents when handling the product.
■ Crimp Quality Standard(ETAD-H9045-00)
■ Wire-to-Board Connector Use Handbook
■ Cable Assembly Procedure (ETAD-H0963-00)
19
Single Row Socket (FPC Type) Assembly Method
Insert the FPC diagonally from the top surface of the grounding plate.
Pass the FPC through the grounding plate.
Step1
After passing the FPC through lower downwards.
Signal Surface
Step2
Ground Surface
Extend the FPC out and fully insert into the socket.
Step3
Step4
Assembly point: Slightly raise the FPC to an angle of about 30 degrees,
and then insert the grounding plate over the socket.
Using the dedicated installation tool, insert the
grounding plate.
1.7
Final
completion
Note 1 : The grounding plate and the socket are supplied as separate components.
Note 2 : Dedicated assembly tools are required for assembly.
Note 3 : When temporarily inserting the ground plate, the FPC can be easily inserted by lightly lifting the FPC up to 30°
and designing a self- alignment guide.
However, if excessive force ( bending, twisting, etc. ) is applied to the FPC, the FPC ( edge of the cover film)
copper foil may crack.
Note 4 : If the ground plate cannot be inserted, make sure it is aligned parallel to the socket and do not force it in.
Note 5 : To protect the FPC, insert and remove the connector parallel to the mating surface.
Note 6 : To protect the FPC, do not apply excessive tension.
Note 7 : Refer to the FPC manufacture recommended bending radius and other specifications. Distance should be allowed
for bending as shown below.
MIN 5
SIGNAL
MIN 10
Temporarily insert the grounding plate into the socket.
Note 8 : When terminating the FPC there is a risk of misuse of the tools, or injury from the ridge on the metal part of the
connector, etc. Follow the terminal tools instruction manual to ensure proper termination.
While Taking into Consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the Drawing and Product Specifications sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public
infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com
※ The contents of this catalog are current as of date of 1/ 2022. Contents are subject to change without notice for the purpose of improvements.
21
