CAT-HT-310-1012-14
CAT-HT-310-1012-14
    SAMTEC(申泰)
    CATTOOLING
CAT-HT-310-1012-14 数据手册
Instruction Sheet STS-M-310-1012-14 Straight Action Hand Tool CAT-HT-310-1012-14 Rev A 21 OCT 14 PROPER USE GUIDELINES Cumulative Trauma Disorders can result from the prolonged use of manually powered hand tools. Hand tools are intended for occasional use and low volume applications. A wide selection of powered application equipment for extended use production operations may be available. crimping of the contact. Once engaged, the ratchet will not release until the dies have been fully closed. 3. CRIMPING PROCEDURE Do NOT cut or nick the wire strands during wire stripping. 1. Select the desired terminal listed in the Figure 3. 2. Push the wire stop lever on the side of the hand tool to raise the wire stop up before inserting the terminal in the hand tool. See Figure 2. 3. With the wire stop lever pushed in, load the terminal into the proper nest opening marked with the wire gauge on the hand tool. See Figure 2. 4. Next release the wire stop lever, allowing the wire stop to return to the crimping position. 1. INTRODUCTION Figure 1 5. Close the tool handle until the first ratchet position engages. Straight Action Hand Tool CAT-HT-310-1012-14 (Figure 1) was designed to crimp CC10L, CC10R and CC10M Series contacts for the PESS series. 6. Insert the properly stripped wire through the terminal and against the wire stop. See Figure 2. The wire crimper bottoms against the anvil before the ratchet releases. This is a design feature that assures maximum electrical and tensile performance of the crimp. Do NOT readjust the ratchet. Dimensions in these instructions are in metric units [with inches in brackets]. Figures are for reference only and are not drawn to scale. For recalibrations, or locator replacements please contact Samtec Application Tooling Group. 2. DESCRIPTION The front of the tool is marked with the tool part number. The tool features a fixed die (crimper), a movable die (anvil), a locator wire stop, and a ratchet. The locator positions the contact and the wire stop limits the insertion distance of the stripped wire into the contact. The ratchet assures full CUSTOMER SERVICE +1-800-726-8329 (+1-812-944-6733) Figure 2 1 of 3 Straight Action Hand Tool CAT-HT-310-1012-14 Contact Number CC10L CC10R CC10M Wire Size mm2 [AWG] Insulation Diameter 5.26 [10] 4.50 - 4.65 [.177 - .183] 3.31 [12] 3.94 - 4.09 [.155 - .161] STS-M-310-1012-14 Strip Length Crimp Height See Application Tooling Section of Samtec Website See Application Tooling Section of Samtec Website Figure 3 7. Crimp the terminal by squeezing the tool handles until the ratchet mechanism cycle has been completed. Release the handles to open the jaws. 8. Push the wire stop lever in to raise the wire stop up and remove the crimped terminal from the locator by lifting up and then pulling the wire out. 9. Visually inspect the crimped terminal for proper crimp location. Damaged contacts should not be used. If a damaged contact is evident, it should be cut from the wire and replaced with a new one. 3. Make certain all pins; pivot points and bearing surfaces are protected with a thin coat of high quality machine oil. Do not oil excessively. The tool was engineered for durability but like any other equipment it needs cleaning and lubrication for a maximum service life of trouble free crimping. Light oil (such as 30 weight automotive oil) used at the oil points, every 1,000 crimps or 3 months, will significantly enhance the tool life. See Figure 4. 4. Wipe excess oil from hand tool, particularly from crimping area. Oil transferred from the crimping area onto certain terminations may affect the electrical characteristics of an application. 5. When tool is not in use, keep the handles closed to prevent objects from becoming lodged in the crimping dies, and store the tool in a clean, dry area. 4. MAINTENANCE AND INSPECTION PROCEDURE It is recommended that a maintenance and inspection program be performed periodically to ensure dependable and uniform terminations. Frequency of inspection depends on: • The care, amount of use, and handling of the hand tool, • The presence of abnormal amounts of dust and dirt, • Your own established standards. The hand tool is inspected before being shipped; however, it is recommended that the tool be inspected immediately upon its arrival at your facility to ensure that the tool has not been damaged during shipment. Figure 4 4.1 DAILY MAINTENANCE 1. Remove dust, moisture, and other contaminants with a clean brush, or soft, lint free cloth. 2. Do not use any abrasive materials that could damage the tool. CUSTOMER SERVICE +1-800-726-8329 (+1-812-944-6733) 2 of 3 Straight Action Hand Tool CAT-HT-310-1012-14 STS-M-310-1012-14 4.2. CRIMP HEIGHT INSPECTION 4.3 MISCRIMPS OR JAMS This inspection requires the use of micrometer with a modified anvil as shown in Figure 5. Should this tool ever become stuck or jammed in a partially closed position, do Not force the handles open or closed. The tool will open easily by pressing up on the ratchet release lever in the movable handle. See Figure 6. Proceed as follows: 1. Select a contact and wire (maximum size) for each crimp section. 2. Refer to Section 3 and crimp the contact(s). 3. Using a crimp height comparator, measure wire barrel crimp as shown in Figure 5. If the crimp height conforms to applicable specifications, the tool is considered dimensionally correct. Figure 6 Figure 5 5. TOOL DIMENSIONS Refer to Figure 7 for tool dimensions Figure 7 CUSTOMER SERVICE +1-800-726-8329 (+1-812-944-6733) 3 of 3
CAT-HT-310-1012-14 价格&库存
很抱歉,暂时无法提供与“CAT-HT-310-1012-14”相匹配的价格&库存,您可以联系我们找货
