APK2N
APK2N
    JST
    CRIMP SEMI AUTO PRESS
APK2N 数据手册
AP-K2N CRIMPING MACHINE OPERATION MANUAL 1 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc PREFACE The AP-K2N semi-automatic crimping machine is easy to operate, and is suitable for mass production of crimped harnesses with chain terminals. Before using the AP-K2N please read this manual to ensure that you are familiar with the features of the machine and the layout of the operating controls. We recommend that you always keep this manual near the machine to use for reference when required. This manual also contains information on maintenance, fault-finding and adjustment of the crimping machine and its associated tooling. For safe operation • THIS MACHINE IS A POWER PRESS AND SHOULD NEVER BE USED WITHOUT THE SAFETY GUARDS FITTED. • If you think that something is wrong with the machine, immediately turn OFF the machine and disconnect the lead from the power supply. Guards must only be removed by an authorised person during setting, adjustment and maintenance. • The maximum measured sound output generated by the Crimping Press is 86 dB. It is recommended that ear defenders are worn whilst operating the machine. • Do not modify or adapt the machine without prior consent of JST. • This crimping machine complies with the CE directive for machinery and has the CE mark affixed to indicate its compliance. • This crimping machine must not be incorporated into other machinery without the consent of JST (ref. The Supply of Machinery (safety) Regulations 1992, S.I 1992/3073). 2 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Table of Contents 1. SPECIFICATIONS................................................................................................4 1 - 1 Crimping Machine Specifications......................................................................4 1 - 2 Applicator Specifications...................................................................................4 2. INSTALLING AND TRANSPORTING THE MACHINE..........................................5 2 - 1 Installation........................................................................................................5 2 - 2 Transporting.....................................................................................................5 3. PREPARATION FOR OPERATION......................................................................6 3 - 1 Mounting the Reel Hanger................................................................................6 3 - 2 Mounting the Applicator....................................................................................6 3 - 3 Mounting the Terminal Reel..............................................................................7 3 - 4 Mounting the Safety Guard...............................................................................8 4. CONTROL BOX CONFIGURATION……………………………………………...…..12 5. OPERATION.......................................................................................................13 5 - 1 Manual Operation...........................................................................................13 5 - 2 Operation under Power...................................................................................14 6. APPLICATOR.....................................................................................................15 6 - 1 Terminal Feed Position Adjustment................................................................15 6 - 2 Bell Mouth Adjustment....................................................................................16 6 - 3 Feed-finger Travel Adjustment........................................................................17 6 - 4 Crimp Adjustment...........................................................................................17 6 - 5 Die Part Replacement.....................................................................................18 6 - 6 Lubrication of Applicator.................................................................................18 7. CRIMPING MACHINE MAINTENANCE..............................................................19 7 - 1 Lubrication......................................................................................................19 7 - 2 Inspection and Repair.....................................................................................21 8. FAULT FINDING.................................................................................................22 9. EXPLODED VIEWS AND PARTS LISTS............................................................26 AP-K2N Crimping Machine Exploded Diagram..... ……….......................................26 MK-L Applicator..........................................................................………...................28 MKS-L Applicator……………....................................................……….....................30 MKF-L Applicator..............................................................................……….............32 MKS-LS Applicator.................................................................................……….......34 3 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 1. SPECIFICATIONS Models MK-L and MKF-L for end feeding terminals, and models MKS-L and MKS-LS for side feeding terminals. The crimping machine utilizes a quick change system thus allowing quick change-over times. The crimping machine is composed of the crimping press and an applicator. There are two basic types of applicators (a total of four models). 1.1 Crimping Machine Specifications Model no: AP-K2N º External dimensions: 280mm Wide x 480mm Long x 560mm High º Weight: 90 Kg º Power supply: 220/240V AC single phase 50/60 Hz º Power consumption: 680VA º Crimping force: 1500 Kg º Ram stroke: 30mm º Ram speed: 260 strokes per minute (60 Hz), and 220 strokes per minute (50 Hz) º Closed height: 160.0 mm ± 0.01 at B.D.C 1.2 Applicator specifications Model no. MKS-L (for side-feeding terminals) º Weight 6.4 Kg º Feed pitch 30mm max. º Crimp height adjustment: Dial type Model no. MK-L (for-end feeding terminals) º Weight 6.8 Kg º Feed pitch 30mm max. º Crimp height adjustment: Dial type Model no. MKF-L (for-end feeding flag terminals) º Weight 6.8 Kg º Feed pitch 30mm max. º Crimp height adjustment: Dial type Model no. MKS-LS (for side feeding terminals) º Weight 4.5 Kg º Feed pitch 30mm max. º Crimp height adjustment: Dial type 4 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 2 INSTALLING AND TRANSPORTING THE MACHINE 2.1 Installation Mount the crimping machine on a solid foundation, place a rubber mat between the machine and foundation to reduce vibration and stabilize the machine. The diagram to the left illustrates the footprint dimensions of the machine. Secure the machine to the foundation with four M8 bolts. The machine should be mounted so that the crimping dies are at the approximate eye level of a seated operator. CAUTION Ensure that the belt cover of the crimping machine does not overhang the edge of the mounting surface. 2.2 Transporting Always mount the handles supplied with the toolbox to move the machine (as shown in the photograph on the left). The machine should always be transported by placing the lifting handles onto the arms of a fork-lift truck. DO NOT ATTEMPT TO LIFT MANUALLY. 5 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Step 3 3. PREPARING FOR OPERATION Place the applicator on the base-plate of the crimping machine. Pull up the applicator ram whilst simultaneously pushing the feed lever in the direction of the arrow shown in the photograph below, so that the collar on the shank slides into the groove on the press ram. Then push the applicator fully back into the press. 3.1 Mounting the Reel Hanger Due to packing considerations, when you receive the machine the reel hanger is not mounted on the machine. Assemble the reel hanger then mount it on the machine as illustrated below. CAUTION ENSURE THAT THE SHANK IS CORRECTLY LOCATED IN THE RAM. THERE IS A DANGER OF MAJOR TOOLING DAMAGE IF THE TOOLING IS NOT LOCATED CORRECTLY (AS IN THE PHOTOGRAPH BELOW). 3.2 Mounting the applicator (All types) Step 1 Loosen bolts A & B with a 5mm hexagon wrench supplied with the tool-kit. Step 4 Step 2 Securely fasten the clamps with the 5 mm hexagon key, and visually check that the tooling is mounted correctly. Remove the protective rubber collar from under the dials on the applicator ram. 6 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 3.3 Mounting the Terminal Reel Mounting the MKS-L or MKS-LS Applicator Mount the terminal reel to the reel hanger so that the terminal barrels are facing the reel guide, then feed the terminals through the terminal guide to the applicator. Step 1 Rotate the wing bolt clockwise to raise the pressure plate. Feed the terminal strip between the guide rails. Mounting the MK-L Applicator Step 2 Step 1 Place the first terminal in position so that the terminal is centralised over the anvil. Rotate the wing bolt counterclockwise to lower the pressure plate so that pressure is applied to the terminal. Push down the tension lever and engage the hook with the feed plate so that the pressure pad rises. Feed the terminal strip between the guide rails. Step 2 Place the first terminal at the correct crimping position. Release the hook from the feed plate to allow the pressure pad to apply pressure on the strip. 7 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Illustration of Terminal reels mounted on the AP-K2N Crimping Machine MK-L MKS-L Step 3 Select the appropriate side guard (JST UK-4), and mount onto the side guard support bracket (JST UK-9), using the countersunk screws supplied. 3.4 Mounting the safety guard For reasons of safety and to comply with legislation, safety guards must always be mounted to the crimping machine. The above photographs illustrate the AP-K2N crimping machine with the safety guards fitted. The following photographs illustrate the different types of guards available for the range of JST applicators. WARNING AN AUTHORISED COMPETENT PERSON MUST ONLY CARRY OUT THE FOLLOWING OPERATIONS. When using the MK-L Applicator. Step 1 Secure the fabricated steel guard (JST UK-7), onto the Applicator using the cap head socket screws supplied. Step 4 Remove the two upper motor fixing screws and clamp the side guard support bracket onto the press utilising these screws. Step 2 Secure the die guard (JST UK-1), onto the applicator using the cap head socket screws supplied. Step 5 Adjust the side guard support to achieve the best relationship between guard and applicator. 8 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Step 6 Tighten the screws and check that the guards are correctly and securely fitted. Step 4 Remove the two upper motor fixing screws and clamp the side guard support bracket onto the press utilizing these screws. When using the MKS-L Applicator Step 5 Adjust the side guard support to achieve the best relationship between guard and applicator. Step 1 Secure the fabricated steel guard (JST UK-7), to the applicator using the cap head socket screws supplied. Step 2 Secure the die guard (JST UK-6), onto the applicator using the cap head socket screws supplied. Step 6 Tighten the screws and check that the guards are correctly and securely fitted. Step 3 Select the appropriate side guard (JST UK-3), and mount onto the side guard support bracket (JST UK-9), using the countersunk screws provided. 9 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc When using the MKS-L Applicator for SPC or PSL splices Step 4 Remove the two upper motor fixing screws and clamp the side guard support bracket onto the press utilizing these screws. Step 2 Secure the fabricated steel guard (JST UK-135), onto the side face of the applicator using the cap head screws supplied. Step 5 Adjust the side guard support bracket to achieve the best relationship between guard and applicator. Step 3 Select the appropriate side guard (JST UK-3), and mount onto the side guard support bracket (JST UK-9), using the countersunk screws supplied.. Step 6 Tighten the screws and check that the guards are correctly and securely fitted. Step 1 Secure the fabricated steel guard (JST UK-17), to the applicator using the cap head screws supplied. 10 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc When using the MKF-L Applicator Step 4 Adjust the side guard support bracket to achieve the best relationship between guard and applicator. Step 1 Secure the fabricated steel guard (JST UK-35), to the applicator using the cap head screw supplied. Step 2 Select the appropriate side guard (JST UK-95), and mount onto the side guard support bracket (JST UK-9), using the countersunk screws supplied. Step 5 Tighten the screws and check that the guards are correctly and securely fitted. IMPORTANT If the safety guards become damaged or worn they must be replaced immediately. Please contact the JST Technical Department for replacement guards. Step 3 Remove the two upper motor fixing screws and clamp the side guard support bracket onto the press utilizing these screws. 11 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 4. CONTROL BOX CONFIGURATION 7. Operation Light Switch (Ope. Light) This switch controls the Worklamp. Press it to the right to turn the light on, and to the left to turn it off. The lamp-bulb is rated at 40 Watts and is of the ‘Rough Service’ type. Do not exceed 40 Watts because the surface temperature of the worklamp exceeds the maximum recommended temperature. 1. Counter Counts the number of crimped terminations. Reset the counter to 0 to begin counting operations. 2. Reset Push-button Press this button to reset the counter (resets the counter to 0) 1. COUNTER 3. Function Indicator Lamps 2. RESET • Rear Cover The rear cover indicator lamp is lit when the belt-cover is open. Whilst this lamp is lit, the motor does not operate even if the Power On push-button is pushed. 3. FUNCTION INDICATOR LAMPS CAUTION DO NOT OPEN THE BELT COVER WHILST MOTOR IS RUNNING, BECAUSE THE FLYWHEEL CONTINUES TO ROTATE FOR A FEW SECONDS AFTER THE MOTOR IS TURNED OFF DUE TO INERTIA STORED IN THE FLYWHEEL. 4. POWER ON PUSH-BUTTON (GREEN) • Auto Power-Off When the crimping operation stops for a period of approximately 3 minutes or more, for example when you unintentionally leave the motor running after finishing work or temporarily stop the operation, the motor automatically stops and the Auto Poweroff indicator lamp illuminates. 6. CIRCUIT PROTECTOR PUSH-BUTTON 5. POWER OFF PUSH-BUTTON (RED) 7. OPERATION LAMP SWITCH If the Rear Cover indicator illuminates, close the cover and press the Power On push-button to restart. If the Auto Power Off indicator illuminates, just press the Power On push-button to restart. 4. Power On Push-button (green Indicator Lamp) Press this button to turn on the motor. The green indicator lamp illuminates and stays lit whilst the motor is running. 5. Power Off Push-button (Red Indicator Lamp) Press this button to turn off the motor. The red Power Off indicator lamp illuminates. 6. Circuit Protector Push-button (Thermal Overload device) When the crimping machine is overloaded, the Circuit Protector push-button ‘pops out’, and the motor stops. Wait for at least one minute, press the Circuit Protector Push-button in, then press the Power On push-button. Contact the JST Service Department if you think that the Circuit Protector is activated too often because the press may require attention. 12 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Step 3 Place the hand-crank supplied in the press tool-kit on the end of the main shaft and rotate in a counter-clockwise direction to manually cycle the press through one revolution. The ram moves up and down one stroke and crimps the terminal. 5. OPERATION WARNING Disconnect the press from the power supply before operating by hand. Operations by hand whilst guards are removed must only be performed by authorized competent persons. 5.1 Manual Operation CAUTION When using an applicator for the first time after fitting it in the press, or whenever a die-part is replaced or the applicator is adjusted, ensure that the press is manually cycled at least one revolution. This is a very important operation to ensure that the terminals are crimped correctly and it also allows a degree of ‘feel’ through the crank handle which prevents major tooling damage from occurring if the die-parts have been installed incorrectly. Step 1 Remove the cap head socket screws from the ram cover using the hexagon key supplied with the tool-kit, and open the belt cover. Step 4 Remove the hand-crank, close the belt cover and replace the cap head socket screw in the catch and tighten with the hexagon key. Step 2 Manually operate the solenoid by pushing the clutch lever in a downward direction until the clutch ‘clicks’. CAUTION Ensure that hand-crank is rotated through one complete revolution (until it physically stops). If the press is left part-way through a cycle it will try to complete the cycle when the motor is turned on and this action could result in damage being caused to the tooling. 13 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 5.2 OPERATION Step 1 Connect the power supply cable and the foot-switch cable to the control box using the screw in connectors. Connect the power supply cable to the mains supply and switch on the press. Step 4 Check that neither of the function indicators is illuminated, then press the Power On push-button (green). The motor starts running. NOTE: If a malfunction indicator is illuminated the motor will not start even if you press the Power On push-button. CAUTION Ensure that the power supply cable is routed from the press safely and does not become trapped or chafed by any part of the crimping machine. ON Step 5 Position a wire over the terminal and press the footswitch once to activate it. The terminal is crimped and the next terminal is indexed along over the anvils ready for the next operation. Step 2 Press the Ope. Light to the right to turn on the Operation Light. Step 6 When you finish using the press, turn off the Work-lamp and press the Power Off push-button. Step 3 To count the number of crimped terminations, press the Reset push-button to set the counter display to 0. OFF CAUTION If any problems occur during operations, immediately press the Power Off push-button and investigate the reason If the problem requires the removal of safety guards, contact a person authorised to remove the guards. ON NO ACCOUNT REMOVE SAFETY GUARDS IF YOU ARE NOT AUTHORISED TO DO SO. 14 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 6. APPLICATOR ADJUSTMENT 6.1 Terminal Feed Position Adjustment. CAUTION The following adjustments require the removal of the safety guards and must only be carried out by authorized competent persons. There is a risk of serious crushing injury in tooling exposed by the removal of the safety guards . Ensure that fingers are kept away from the moving parts of the applicator. SCREW COLLAR When using the MK-L Applicator Adjust the terminal feed position to adjust the terminal crimping position. Before making this adjustment be sure that the applicator is mounted in the crimping machine correctly and the press ram is at Top Dead Centre. Loosen the 5mm cap head socket screw and the knurled collar using a small length of silver steel or similar, as indicated on the photograph. With the aid of the silver steel or a flat ended screwdriver rotate the adjustment shaft so that the feed-finger places the terminal in the correct position for crimping. Rotate the shaft counter-clockwise to move the terminal forward, and clock-wise to move it backwards. When the adjustments are completed, tighten the knurled collar first followed by the cap screw. Rotate the press through one revolution manually (see page 10), and check the resultant crimped terminal. If the appearance of the terminal is not correct repeat the above adjustment operation and check again. When a satisfactory result is achieved, replace the guards, connect the crimping machine to the power supply and recommence the crimping operation. When using the MKS-L Applicator Adjust the terminal feed position to adjust the terminal crimping position. Before making this adjustment be sure that the applicator is mounted in the crimping machine correctly and the press ram is at Top Dead Centre. SCREW COLLAR To position a terminal at the centre of the die, follow the procedure below. Loosen the 5mm cap head socket screw and the knurled collar using a small length of silver steel or similar, as indicated on the photograph. With the aid of the silver steel or a flat ended screwdriver rotate the adjustment shaft so that the feed-finger places the terminal in the correct position for crimping. Rotate the shaft counter-clockwise to move the terminal to the right (forwards), and clock-wise to move it to the left (backwards). When the adjustments are completed, tighten the knurled collar first followed by the cap screw. Rotate the press through one revolution manually (see page 10), and check the resultant crimped terminal. If the appearance of the terminal is not correct repeat the above adjustment operation and check again. When a satisfactory result is achieved, replace the guards, connect the crimping machine to the power supply and recommence the crimping operation. 15 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Slot-head adjustment screws 6.2 Bell Mouth Adjustment When using the MK-L Applicator Adjust the terminal feed position with reference to the bell-mouth position. Refer to section 6.1 When using the MKS-L Applicator (old type) Move the entire feed-plate to obtain the desired bellmouth crimp. First, loosen the feed-finger retaining screw in the feed-finger holder. Next, loosen the two cap head socket screws in the slots on the base of the applicator (see photograph). With the aid of a flat ended screwdriver, rotate the adjusting screw in the front of the adjustment carriage, turn the screw clockwise to increase the bell-mouth (move the guide rails towards the front of the press), and counter-clockwise to decrease the bell-mouth (move the guide rails towards the back of the press). Re-tighten the adjustment screws on the base of the applicator, centralize the feed-finger in the slot in the guide rail and tighten the screw. Feed-finger screw Adjustment screw Check the bell-mouth on the resultant crimp and readjust if necessary. When using the MKS-L Applicator (new type) Move the entire feed-plate to obtain the desired bellmouth crimp. First, loosen the feed-finger retaining screw in the feed-finger holder. Next, loosen the two hexagon-headed bolts situated on the front of the adjustment carriage just above the top surface of the applicator base-plate. With the aid of a 5mm hexagon key, rotate the screw in the front of the adjustment carriage, turn the screw clockwise to decrease the bell-mouth (move the guide rails towards the back of the press), and counter-clockwise to increase the bell-mouth (move the guide rails towards the front of the press). Hexagon nuts Re-tighten the adjustment bolts, centralize the feedfinger in the slot in the guide rail and tighten the screw. Check the resultant crimp and re-adjust if necessary. There is a crimping manual available from the JST Technical Department detailing the points to inspect on a crimped terminal to achieve results as per our specifications. A copy is issued with every AP-K2N Crimping machine supplied to a customer but please contact JST if you require further copies. Adjustment screw 16 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 6.3 Feed-finger travel adjustment INSULATION CRIMP ADJUSTING DIAL Applicators are assembled and adjusted prior to despatch from JST and will not require adjustment by customers. Please contact JST Technical Services Department if you consider there is a problem with the Pitch setting adjustment. CONDUCTOR CRIMP ADJUSTING DIAL 6.4 Crimp Height adjustment The applicator has two dials to adjust the insulation and wire crimp-height. The upper dial, marked with letters A - H, is for the wire (conductor), crimp-height. The lower dial, marked with numbers 1 - 8, is for the insulation crimp height. JST do not advise pad settings for wire sizes, as is the practice of some manufacturers. We believe that the best method to adopt is to specify crimp-heights and adjust the dials until the desired crimpheight is achieved. º Wire crimp-height (conductor) adjustment. Setting the upper dial to graduation A produces the tightest crimp-height (lowest), and graduation H the least tight (highest). The crimp height alters by approximately 0.05mm per graduation, so a total range of adjustment of 0.40mm is attainable. º Insulation crimp-height adjustment. Setting the lower dial to graduation 1 produces the tightest crimp-height (lowest), and graduation 8 the least tight (highest). The crimp-height alters by approximately 0.10mm per graduation, so a total range of 0.80mm is attainable. We do not state insulation crimp-heights due to the large variation of insulation types available. The insulation should be set as per instructed in the JST Crimping Manual supplied with the AP-K2N crimping machine. If you require further copies, please contact the JST Technical Services Department. MK-L MK-L INSULATION CRIMP ADJUSTING DIAL CONDUCTOR CRIMP ADJUSTING DIAL CAUTION When initially installing the applicator in the press, ensure that the dials are set at H - 8 to avoid the possibility of tooling damage. Always check the crimp-height of the terminal by use of a Crimp-height Micrometer because they are designed specifically for the purpose and indicate the true crimpheight. If you require details for the supply of a crimpheight micrometer please contact JST Technical Services Department. If the applicator is not capable of achieving the desired crimp-height by adjusting the dials, please contact the JST Technical Services Department, because there is a range of blocks available to alter the range of crimp heights available. If you specify the blocks currently installed in your applicator (see ‘Exploded view’ supplied with applicator), we can advise you of the part no of the replacement blocks necessary to achieve the desired crimp-height. Do not adjust the crimp-height by altering the shut-height of the AP-K2N press, because it is factory set and should only require occasional adjustment when serviced by the JST Service Engineer. MKS-L 17 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc .5 Die Part Replacement The crimping dies are consumable parts. When a die part becomes worn and requires replacement, check the part number engraved on the die part, or consult the ‘exploded view’ drawing supplied with every applicator and order a new part from JST technical Services Department. CAM If you consider that the replacement process is too difficult, or the tooling has sustained damage, please contact JST to either send back the tooling for repair or alternatively a JST Service Engineer can visit your company to repair the tool on site. 6.6 Lubrication of Applicator Periodically lubricate the surfaces indicated on the photographs with grease. A general purpose grease obtainable from Garages or car accessory shops is suitable. Remove the ram from the applicator body and apply the grease to the cam surface. CAM-ROLLER Apply grease to the surface of the cam-roller. APPLY GREASE HERE Apply grease to the four faces of the applicator ram. CAUTION Apply grease sparingly because excess grease attracts dirt and scrap insulation etc. 18 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc MAIN SHAFT BEARING GREASING LOCATION 7. CRIMPING MACHINE MAINTENANCE CAUTION Disconnect the Power Cable from the mains supply before carrying out any maintenance operations on the Crimping Press. 7.1 Lubrication MAIN SHAFT BEARING Lightly grease the main-shaft bearing once a year using a general purpose grease, eg Castrol LM. RAM SECTION Remove the cap head socket screws from the ram cover and add a few drops of machine oil to the felt pads in the three oiling holes once a week. RAM SECTION OILING LOCATIONS CLUTCH SECTION Remove the cap head socket screws from the belt-cover catch and open the cover. Add a few drops of oil to the oiling points indicated on the photograph. CLUTCH SECTION OILING LOCATIONS NOTE: The frequency of lubrication is dependant on the use of the machine. Do not apply excessive lubrication because the oil may drip through onto the applicator and contaminate the terminals. ROLLER CLUTCH Step 1 Slowly rotate the fly-wheel whilst pulling the V-belts to the side to remove them. CAUTION ENSURE THAT FINGERS DO NOT BECOME TRAPPED BETWEEN THE V-BELT AND THE FLY-WHEEL Step 2 With the aid of a pair of internal circlip pliers, remove the circlip retaining the fly-wheel. 19 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Step 3 Firmly grip the fly-wheel on both sides and pull off the end of the shaft. There are seven ‘stick rollers’ inside the clutch and they may fall out when the fly-wheel is pulled off the shaft, so take care not to lose any. Step 4 Remove any traces of old grease from all components of the clutch mechanism and sparingly lubricate all the clutch components with fresh grease. Specified Grease: Multemp PS no.1 manufactured by Kyodo Yushi Co Ltd. Do not use general purpose grease because the clutch will not function correctly. Contact JST Technical Services Department for details of grease stockists. Step 5 Assemble the clutch ensuring that the clutch lever is engaged correctly with the clutch cam, as in photo A. PHOTO A If the clutch is assembled as in photo B, it will not be possible to re-mount the flywheel onto the shaft. PHOTO B ` 20 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 7.2 Inspection and Repair RAM STABILITY Approximately every six months physically check that the ram is not loose. To check the ram, remove the screws from the catch and open the cover. Grip the ram firmly and try to move the ram from side to side. It is also possible to detect whether the ram is loose by the noise it makes when crimping, and also the measured crimp height of the terminal may become unstable. º Adjustment Procedure Step 1 Remove the two dome-nuts from the side wall of the ram. Step 2 Loosen the three cap head screws on the right hand side of the adjustable ram guide. Step 3 Fasten the grub screws on the ram guide finger-tight so that you can manually move the ram up and down by hand, but it does not drop under its own weight. Next, check that the ram does not wobble and that it moves smoothly. Make a final check check that the ram is stable and the screws are secure. Replace cap head screws in ram cover. 21 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc º Positioning of the Solenoid Bracket Once a year remove the cap head screws from the catch on the belt cover and open the cover. Check that the clearance is correct as shown on the photograph. The clearance should be 6 - 7mm, if it varies from this dimension adjust the bracket in the following manner:- Clearance 6 - 7mm Loosen the two cap head screws holding the bracket to the press casting and move the solenoid up or down until the correct clearance is obtained. Tighten the cap head screws on the retaining bracket, close the belt cover and replace the socket screws in the bracket. 8. FAULT-FINDING → The Motor runs → Press the FootSwitch once → → → 1. The Power Cord is disconnected 1.The Ram moves 1 cycle (up and down) 2. The Ram does not move → → 2. The power cord is broken → Press the Power On push-button 3. A solder joint on the Power Cord metal plug is bad → 4. The Thermal Trip is activated → The Motor does not run 3. The Ram ‘clunks’ several times 5. The Clutch is engaged 6. Emergency Stop switch is activated → 4. The Ram ‘clunks’ many times → 7. Belt Cover is open → 22 5. The Ram moves too slowly, or stops at Bottom Dead Centre → OK 1. The connecting pin is broken 2. A solder joint on the foot-switch metal plug is bad 3. The foot-switch cord is damaged 4. The clutch spring has become slack or has broken 5. control box is faulty 1. A spring has become slack 2. The clutch lever or stopper is worn out 3. The solenoid is defective 4. The control box is defective 1. The solenoid is defective 2. A spring has become slack 3. The control box is defective 1. A stick roller is worn 2. Grease is applied incorrectly, or the wrong grease is applied to the roller clutch 3. The applicator is seized H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 1. The Motor does not run (1) The Power cord is disconnected reconnect the power cord. (2) The Power cord is damaged replace the power cord (3) A solder joint on the Power Cord metal plug is bad Resolder the joint (4) The Thermal Trip is activated Press in the thermal trip push-button. If the thermal trip has activated, wait one minute or more before resetting. Consult the JST Technical Department if the thermal trip activates frequently. (5) The Emergency Stop switch is activated Reset by turning the switch clockwise (6) The Belt Cover is open Close the belt cover and re-secure the catch with the cap head socket screws. 2. The Ram does not move (1) The Connecting Pin is broken Replace the connecting pin with a new one. Connecting pin AP-K2N CRIMPING MACHINE JST 23 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc (2) A solder joint on the Foot-Switch metal plug is bad Resolder the joint (3) The Foot-Switch cord is damaged Replace the Foot-Switch cord with a new one. Connect the micro-switch to the plug as per the illustration. (4) The Clutch Spring has become slack or has broken Replace the spring with a new one. (5) The Control Box is faulty The Control Box requires repair. Contact the JST Technical Services Department for assistance. 3. The Ram ‘clunks’ several times (1) A Spring has become slack Replace the spring with a new one. (2) The Clutch Lever or Stopper is worn out Replace parts with new ones. 24 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc (3) The Solenoid is defective Adjust the relationship between the solenoid piston and cylinder by moving the solenoid cylinder back or forth on the solenoid bracket. (4) The Control Box is defective The control box requires repair. Contact the JST Technical Services Department for assistance. 4. The Ram ‘clunks’ many times (1) The Solenoid is defective Refer to 3-(3) above. (2) A Spring has become slack Replace the spring with a new one, see 3-(1). (3) The Control Box is defective The control requires repair. Contact JST Technical Services Department for assistance. 5. The Ram moves too slowly, or stops at Bottom Dead Centre (1) A Stick Roller is worn out Replace the stick rollers with new ones. Always replace the rollers as a set of seven. Oversize rollers are available from JST to extend the service life of the clutch. Please contact the Technical Services Department for details. (2) Grease is applied incorrectly, or the wrong grade of grease has been used Clean the clutch and reapply the correct grade of grease. See section 7 for details of grease specification. (3) The Applicator is seized Contact the JST Technical Services Department for assistance. (4) Part of the Clutch assembly is missing Check that all the Stick Rollers are assembled. 25 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 9. EXPLODED VIEWS AND PARTS LISTS AP-K2N Crimping Machine 26 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 27 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc 28 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Parts list for the applicator MK-L No. 101 102 Part Name Part No. No. Part Name Part No. Body MA02-101 133 Hex. Nut M4 type-1 Slider MA02-210 134 Stroke adj. Shaft MA01-331 MA01-332 103 Copper bar (3.8 x2mm) 135 Stroke adj. Bearing 104 Positioning spring MA01-214 136 Stroke adj. Plate MA02-330 105 Positioning pin MA01-213 137 Hex. Nut MA01-333 106 Insulation disk MA01-215 138 Stroke adj. Screw MA01-334 107 Spring MA01-216 139 Hook MA01-475 108 Steel ball 140 Hook pin MA01-476 109 Wire disk 141 Release lever MA01-473 110 Shank MA01-217 142 Release lever pin MA01-474 111 Cam MA02-335 143 Pressure pad pin MA01-472 112 Spring cap MA01-477 144 Pressure pad MA01-470 113 Spring block MA01-479 145 Feed plate 114 Spring MA01-480 146 Spring anchor MA01-350 115 Support pin MA01-343 147 Die block MA01-105 116 Stripper hanger MA02-481 148 Die plate MA02-104 117 Plate (L) MA02-102 149 Side block MA02-107 118 Plate (R) MA02-103 150 Wire block 119 Feed shaft MA01-338 151 Insulation block 120 Ring nut MA01-341 152 Block ring 121 E-shaped ret. ring (6 ) 153 Crimper (A) 122 Lever block MA01-340 154 Crimper (B) 123 Adj. Bolt MA01-339 155 Die holder ring 124 Cam roller MA01-308A 156 Stripper 125 Cam roller shaft MA01-337A 157 Guide plate (R) 126 Feed lever (A) MA01-342 158 Guide plate (L) 127 Feed lever pin MA01-344 159 Shear blade anvil (A) 128 Feed lever (B) MA01-345 160 Shear blade anvil (B) 129 Feed finger pin MA01-347 161 Crimper anvil (A) 130 Feed finger spring MA01-348 162 Crimper anvil (B) 131 Feed finger 163 Shear blade 132 Returning spring 164 Spacer MA01-211 MA01-349 29 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc MA01-225 30 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Parts list for the applicator MKS-L Part No. No. Body MA03-101 135 Stroke adj. Bearing MA01-332 102 Slider MA03-210 136 Stroke adj. Plate MA03-330 103 Copper bar (3.8 x2mm) 137 Hex. Nut MA01-333 104 Positioning spring 138 Stroke adj. Screw MA01-334 105 Positioning pin MA01-213 139 Spring anchor pin MA03-352 106 Insulation disk MA01-215 140 Spring anchor MA03-350 107 Spring MA01-216 141 Pressure plate 108 Steel ball (3 ) 142 Pressure spring 109 Wire disk MA01-211 143 Returning spring 110 Shank MA01-217 144 Feed finger 111 Cam MA03-335 145 Feed finger holder 112 Die block MA03-105 146 Stripper bracket 113 Die plate MA03-104 147 Stripper 114 Side block MA03-107 148 Stripper screw 115 Support pin MA01-343 116 Feed plate base MA03-106 150 Guide plate (R) 117 Adj. Plate MA03-108 151 Guide plate (L) 118 Adj. Screw MA03-109 152 Feed plate 119 Feed shaft MA01-338 153 Spacer 120 Ring nut MA01-341 154 Crimper (A) 121 E-shaped ret ring (6 ) 155 Spacer 122 Lever block MA01-340 156 Crimper (B) 123 Adj. Screw MA03-339 157 Punch 124 Cam roller MA01-308A 158 Shear blade 125 Cam roller shaft MA01-337A 159 Shear blade spring 126 Feed lever (A) MA01-342 160 Shear blade supporter 127 Feed lever pin MA01-344 161 Shear blade base 128 Feed lever (B) MA01-345 162 Crimper anvil (B) 129 Feed finger pin MA01-347 163 Crimper anvil (A) 130 Feed finger spring MA01-348 164 Spacer 131 Plate (L) MA03-102 165 Scrap cover 132 Plate (R) MA03-103 166 Wire block 133 Hex. Nut (M4, type-1) 167 Insulation block 134 Stroke adj. shaft 168 Block ring No. 101 Part Name MA01-214 MA01-331 31 Part Name H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Part No. MA03-349 MA01-225 32 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Parts list for the applicator MKF-L Part Name Part No. No. No. 101 Body NF-2101 138 102 Slider NF-3118 Part Name Part No. Stroke adj. Screw MA01-334 139 Punch NF-4122 NF-3149 103 Copper bar (3.8 x2mm) 140 Die plate 104 Positioning spring MA01-214 141 Bracket NF-4133 105 Positioning pin MA01-213 142 Spring post NF-4159 106 Insulation disk NF-4121 143 Returning spring MA03-349 107 Spring MA01-216 144 Spring NF-4126N 108 Steel ball (3 ) 109 Wire disk MA01-211 146 Keep plate NF-4125 110 Shank MA01-217 147 Crimper anvil base NF-4105 111 Cam NF-4168 148 Feed plate NF-2129* 112 Guide shoe NF-4140 149 Support pin NF-4163 113 Tension spring NF-4117 150 Needle bearing K12x15x13 NF-B164 114 Fulcrum bolt NF-4115 151 Collar NF-4154 115 Support pin MA01-343 152 E-shaped ret.ring (9 ) 116 Spring post NF-4116 153 Guide block NF-4165 117 Plate (L) NF-4114 154 Holder block NF-4147 118 Plate (R) MA02-103 155 Pressure plate 119 Feed shaft MA01-338 156 Guide plate (R) 120 Ring nut MA01-341 157 Guide plate (L) 121 E-shaped ret.ring (6 ) 158 Pin 122 Lever block MA01-340 159 Feed finger 123 Adj. Bolt MA01-339 160 Shear blade 124 Cam roller MA01-308A 161 Shear blade anvil (A) 125 Cam roller shaft MA01-337A 162 Shear blade anvil (B) 126 Feed lever (A) MA01-342 163 Tension spring NF-4110 127 Feed lever pin MA01-344 164 Spring post NF-4108 128 Feed lever (B) NF-4138 165 Spring post NF-4111 129 Feed finger pin MA01-347 166 Wire block 130 Feed finger spring MA01-348 167 Insulation block 131 Feed adj. Plate NF-4137 168 Block ring 132 Spring post NF-4139 169 Crimper (A) 133 Hex. Nut (m4,type-1) 170 Crimper (B) 134 Stroke adj. Shaft MA01-331 171 Die holder ring 135 Stroke adj. Bearing MA01-332 172 Crimper anvil (A) 136 Hook NF-4113 173 Crimper anvil (B) 137 Hex. Nut MA01-333 174 Finger holder 33 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc NF-4109 MA01-225 34 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Parts list for the applicator MKS-LS Part No. No. Part Name 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 Body Plate Slider Positioning spring Positioning pin Block ring Cam Shank Wire disk Insulation disk Die plate Feed plate base Die block Retaining bolt Feed shaft Cam roller Pin Feed lever Feed lever pin Adj. Screw Feed finger spring Feed finger pin Hook Name plate Protection rubber Hex. Socket head bolt (M6x18) Key (6x6x25 round ends) Spring washer (5) Button head screw (M5x12) Hex. Socket head bolt (M5x18) Hex. Socket head bolt (M5x10) Hex. Socket head bolt (M4x8) Pin (2x4) Hex. Socket head bolt (M3x6) Hex. Socket head bolt (M5x50) Rivet (1.5 x5) Hex. Nut (M6, type-1) Spring washer (6) Compressed coil spring Tension spring Ball plunger Hex. Socket head screw (M4x10) 35 LS-2301 LS-4302 LS-3303 MA01-214 MA01-213 MA01-223 LS-4307 LS-4308 LS-4309 LS-4310 LS-3311 LS-4312 LS-4313 LS-4314 LS-4315 LS-4316 LS-4317 LS-4318 LS-4319 112-223 MA01-348 LS-4322 LS-4323 LS-4324 LS-4325 LS-B331 LS-B343 LS-B344 LS-B345 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Notes: 36 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc Offices World-Wide HEAD OFFICE: J.S.T. MFG. CO., LTD. 2-6-8, Shigino-nishi, Joto-ku, Osaka, 536-0014 JAPAN. Phone: (06) 6968-6855 / Int' l 81-6-6968-6855Fax: (06) 6964-2085 / Int' l 81-6-6964-2085 Tel: U.K. 44 \ 0 \ 1986 87 4131 Tel: 32 \ 0 \ 1660 0525 Fax: 32 \ 0 \ 1660 5877 Tel: 49 \ 0 \ 7181 4007 0 Fax: 49 \ 0 \ 7181 4007 21 Belgium Fax: 44 \ 0 \ 1986 87 4276 Tel: 33 \ 3 \ 2672 4503 France Germany Fax: 33 \ 3 \ 2672 1088 Italy Tel: Fax: 39 \ 02 \ 9390 0418 39 \ 02 \ 9390 0421 Spain Tel: Fax: 34 \ 93 \ 564 2120 34 \ 93 \ 564 8266 Singapore Tel: Fax: 65 \ 743 0405 65 \ 746 1787 [G4] Thailand Tel: Fax: 66 \ 2 \ 693 2905 66 \ 2 \ 693 2906 Tel: Fax: Tel: Fax: 60 \ 0 \ 3 755 4620 60 \ 0 \ 3 758 3802 60 \ 0 \ 4 226 7258 60 \ 0 \ 4 226 7269 Indonesia #1 Indonesia #2 Tel: Fax: Tel: Fax: 62 \ 0 \ 7 7061 1685 62 \ 0 \ 7 7061 1684 62 \ 0 \ 21 575 0816 62 \ 0 \ 21 575 0803 Honk Kong Tel: Fax: 85 2 \ 2413 7979 85 2 \ 2411 1193 China Tel: Fax: 86 \ 21 5866 3418 86 \ 21 5866 3421 Korea Tel: Fax: 8 \ 0 \ 2 2527 3334/3335 8 \ 0 \ 2 2527 3336 Taiwan Tel: Fax: 886 \ 0 \ 2 2531 8500 886 \ 0 \ 2 2531 8485 U.S.A. Tel: Tel: Fax: 1 \ 847 \ 473 1957 1 \ 800 947 1110 (toll free) 1 \ 847 \ 473 0144 [G4] Australia Tel: Fax: 61 \ 0 \ 3 9877 6444 61 \ 0 \ 3 9877 6395 Malaysia #1 Malaysia #2 For full up to date address details go to: www.jst-mfg.com/e00com/e31com.html In line with a policy of continual development JST reserves the right to change the specifications of the goods described in this manual at any time and without prior notice. 37 H:\0 - Quality Documents\2 Department\Tech Serv\Application tooling\Presses\AP-K2N\TS010-00 AP-K2N Operation Manual.doc
APK2N 价格&库存
很抱歉,暂时无法提供与“APK2N”相匹配的价格&库存,您可以联系我们找货
