D507-8
D507-8
    KLEINTOOLS
    8''ADJUSTABLEWRENCHEXTRA-CAPAC
D507-8 数据手册
Wrenches Klein's line of wrenches are forged from the finest steel and are designed to deliver great strength and long working life. Regardless of the job type, Klein has a wrench that will help the professional complete the task at hand. Wrenches Adjustable Wrenches Precision-machined jaws are individually chosen and assembled by hand for smooth operation Chrome-plated for corrosion resistance Knurl turns smoothly for easy operation Standard and metric scales for faster adjustment Contoured handles for comfortable use Rail is ground for precision fit Minimally protruding jaw shank for greater capacity in tight spaces 4-threaded knurl worm gear for improved balance Adjustable Wrenches - High Capacity Additional Features: Extra capacity allows use of a smaller size wrench to handle bigger jobs, especially in confined spaces Forged heat-treated alloy steel for maximum strength and light weight • • Cat. No. 507-6 507-8 507-10 507-12 D507-6 D507-8 D507-10 D507-12 Handle Finish High-Polish Chrome High-Polish Chrome High-Polish Chrome High-Polish Chrome Plastic-Dipped Plastic-Dipped Plastic-Dipped Plastic-Dipped Handle Color Chrome Chrome Chrome Chrome Transparent Red Transparent Red Transparent Red Transparent Red D507-8 Length 6-3/8" (161.9 mm) 8-1/8" (206.4 mm) 10-1/8" (257.2 mm) 12-1/4" (311.2 mm) 6-1/2" (165.1 mm) 8-1/4" (209.6 mm) 10-1/4" (260.4 mm) 12-3/8" (314.3 mm) Capacity 15/16" (23.8 mm) 1-1/8" (28.6 mm) 1-5/16" (33.3 mm) 1-1/2" (38.1 mm) 15/16" (23.8 mm) 1-1/8" (28.6 mm) 1-5/16" (33.3 mm) 1-1/2" (38.1 mm) Weight 4.6 oz. (130 g) 9.8 oz. (278 g) 15.7 oz. (445 g) 26.4 oz. (748 g) 5.3 oz. (150 g) 10.6 oz. (301 g) 17.8 oz. (503 g) 28.8 oz. (816 g) Adjustable Wrench - Extra-Wide Jaw Additional Features: Extra wide 1-1/2" jaw provides same capacity as a standard 12" adjustable wrench Forged heat-treated alloy steel for maximum strength and light weight • • Cat. No. D509-8 D509-8 Handle Finish Plastic-Dipped Handle Color Solid Blue Length 8-1/2" (215.9 mm) Capacity 1-1/2" (38.1 mm) Weight 12.3 oz. (349 g) Adjustable Wrenches - Standard Capacity Additional Features: Forged heat-treated alloy steel for maximum strength and light weight • 506-15 Cat. No. D506-4 506-15 500-18 500-24 Handle Finish Plastic-Dipped High-Polish Chrome High-Polish Chrome High-Polish Chrome See page 310 for additional information on warnings. Handle Color Transparent Red Chrome Chrome Chrome Length 4-1/2" (114.3 mm) 15-7/8" (403.2mm) 18-1/4" (463.6 mm) 24" (609.6 mm) Capacity 1/2" (12.7 mm) 1-11/16" (42.9 mm) 2-1/16" (52.4 mm) 2-1/2" (63.5 mm) Weight 2.1 oz. (60 g) 2.9 lbs. (1.32 kg) 4.7 lbs. (2.13 kg) 7.8 lbs. (3.54 kg) 93 www.kleintools.com Wrenches Combination Wrenches Corrosion resistant Combination wrenches have the same size opening on each end Forged from the highest quality alloy steel Durable chrome-plated finish Open ends are offset at standard 15° angle for confined working areas Box ends have 15° angle offset to provide clearance over obstructions 7-Piece Combination Wrench Set - SAE Cat. No. 68400 Set Contains Weight 1.2 lbs. (0.54 kg) Cat. No. Size Length Box End Point 68410 68411 68412 68413 68414 68415 68416 1/4" 5/16" 3/8" 7/16" 1/2" 9/16" 5/8" 5-1/8" (130.2 mm) 4-3/8" (111.1 mm) 6-1/8" (155.6 mm) 6-5/8" (168.3 mm) 7-1/8" (181.0 mm) 7-1/2" (190.5 mm) 8-1/2" (215.9 mm) 12 12 12 12 12 12 12 Includes pouch with marked pockets for each wrench. Individual wrenches sold separately. 68400 9-Piece Combination Wrench Set - SAE Cat. No. 68402 Set Contains Weight 2.1 lbs. (0.95 kg) Cat. No. Size Length Box End Point 68410 68411 68412 68413 68414 68415 68416 68417 68418 1/4" 5/16" 3/8" 7/16" 1/2" 9/16" 5/8" 11/16" 3/4" 5-1/8" (130.2 mm) 4-3/8" (111.1 mm) 6-1/8" (155.6 mm) 6-5/8" (168.3 mm) 7-1/8" (181.0 mm) 7-1/2" (190.5 mm) 8-1/2" (215.9 mm) 9" (228.6 mm) 9-7/8" (250.8 mm) 12 12 12 12 12 12 12 12 12 Includes pouch with marked pockets for each wrench. Individual wrenches sold separately. 94 www.kleintools.com 68402 See page 310 for additional information on warnings. Wrenches Combination Wrenches 12-Piece Combination Wrench Set - SAE Cat. No. 68404 Set Contains Weight 4.1 lbs. (1.86 kg) Cat. No. Size Length Box End Point 68410 68411 68412 68413 68414 68415 68416 68417 68418 68419 68420 68421 1/4" 5/16" 3/8" 7/16" 1/2" 9/16" 5/8" 11/16" 3/4" 13/16" 7/8" 15/16" 5-1/8" (130.2 mm) 4-3/8" (111.1 mm) 6-1/8" (155.6 mm) 6-5/8" (168.3 mm) 7-1/8" (181.0 mm) 7-1/2" (190.5 mm) 8-1/2" (215.9 mm) 9" (228.6 mm) 9-7/8" (250.8 mm) 10-5/8" (269.9 mm) 11-1/2" (292.1 mm) 12-1/2" (317.5 mm) 12 12 12 12 12 12 12 12 12 12 12 12 68404 Includes pouch with marked pockets for each wrench. Individual wrenches sold separately. 14-Piece Combination Wrench Set - SAE Cat. No. Set Contains 68406 Weight 9.8 lbs. (4.45 kg) Cat. No. Size Length Box End Point 68412 68413 68414 68415 68416 68417 68418 68419 68420 68421 68422 68423 68424 68425 3/8" 7/16" 1/2" 9/16" 5/8" 11/16" 3/4" 13/16" 7/8" 15/16" 1" 1-1/16" 1-1/8" 1-1/4" 6-1/8" (155.6 mm) 6-5/8" (168.3 mm) 7-1/8" (181.0 mm) 7-1/2" (190.5 mm) 8-1/2" (215.9 mm) 9" (228.6 mm) 9-7/8" (250.8 mm) 10-5/8" (269.9 mm) 11-1/2" (292.1 mm) 12-1/2" (317.5 mm) 13-1/4" (336.6 mm) 14-1/4" (362.0 mm) 15-1/2" (393.7 mm) 16-1/4" (412.8 mm) 12 12 12 12 12 12 12 12 12 12 12 12 12 12 68406 Includes pouch with marked pockets for each wrench. Individual wrenches sold separately. Combination Wrenches - SAE 68417 Cat. No. 68421 68418 68412 68410 68415 68420 68413 68411 Size 15/16" 3/4" 3/8" 1/4" 9/16" 7/8" 7/16" 5/16" Length 12-1/2" (317.5 mm) 9-7/8" (250.8 mm) 6-1/8" (155.6 mm) 5-1/8" (130.2 mm) 7-1/2" (190.5 mm) 11-1/2" (292.1 mm) 6-5/8" (168.3 mm) 4-3/8" (111.1 mm) See page 310 for additional information on warnings. Box End Point 12 12 12 12 12 12 12 12 Weight 12.6 oz. (357 g) 7.4 oz. (210 g) 1.6 oz. (45 g) 0.8 oz (23 g) 3.7 oz. (107 g) 10.7 oz. (303 g) 2.2 oz. (62 g) 0.8 oz (23 g) Cat. No. 68423 68414 68422 68417 68425 68419 68416 68424 Size 1-1/16" 1/2" 1" 11/16" 1-1/4" 13/16" 5/8" 1-1/8" Length 14-1/4" (362.0 mm) 7-1/8" (181.0 mm) 13-1/4" (336.6 mm) 9" (228.6 mm) 16-1/4" (412.8 mm) 10-5/8" (269.9 mm) 8-1/2" (215.9 mm) 15-1/2" (393.7 mm) Box End Point 12 12 12 12 12 12 12 12 Weight 1.2 lbs. (0.54 kg) 2.9 oz. (82 g) 14.9 oz. (422 g) 5.9 oz. (167 g) 1.9 lbs. (0.86 kg) 8.5 oz. (241 g) 4.5 oz. (128 g) 1.5 lbs. (0.68 kg) 95 www.kleintools.com Wrenches Combination Wrenches 7-Piece Combination Wrench Set - Metric Cat. No. 68500 Set Contains Weight 1.2 lbs. (0.54 kg) Cat. No. Size Length 68507 68509 68510 68511 68513 68514 68515 7 mm 9 mm 10 mm 11 mm 13 mm 14 mm 15 mm 5-1/8" (130.2 mm) 6-1/8" (155.6 mm) 6-1/2" (165.1 mm) 6-1/2" (165.1 mm) 7-1/8" (181.0 mm) 7-1/2" (190.5 mm) 7-1/2" (190.5 mm) Box End Point 12 12 12 12 12 12 12 Includes pouch with marked pockets for each wrench. Individual wrenches sold separately. 68500 11-Piece Combination Wrench Set - Metric Cat. No. 68502 Set Contains Weight 2.4 lbs. (1.09 kg) Cat. No. Size Length 68507 68508 68509 68510 68511 68512 68513 68514 68515 68517 68519 7 mm 8 mm 9 mm 10 mm 11 mm 12 mm 13 mm 14 mm 15 mm 17 mm 19 mm 5-1/8" (130.2 mm) 5-3/8" (136.5 mm) 6-1/8" (155.6 mm) 6-1/2" (165.1 mm) 6-1/2" (165.1 mm) 7-1/8" (181.0 mm) 7-1/8" (181.0 mm) 7-1/2" (190.5 mm) 7-1/2" (190.5 mm) 9" (228.6 mm) 9-3/4" (247.7 mm) Box End Point 12 12 12 12 12 12 12 12 12 12 12 68502 Includes pouch with marked pockets for each wrench. Individual wrenches sold separately. Combination Wrenches - Metric Cat. No. 68507 68508 68509 68510 68511 68512 68513 68514 68515 68517 68519 Size 7 mm 8 mm 9 mm 10 mm 11 mm 12 mm 13 mm 14 mm 15 mm 17 mm 19 mm Length 5-1/8" (130.2 mm) 5-3/8" (136.5 mm) 6-1/8" (155.6 mm) 6-1/2" (165.1 mm) 6-1/2" (165.1 mm) 7-1/8" (181.0 mm) 7-1/8" (181.0 mm) 7-1/2" (190.5 mm) 7-1/2" (190.5 mm) 9" (228.6 mm) 9-3/4" (247.7 mm) 96 www.kleintools.com Box End Point 12 12 12 12 12 12 12 12 12 12 12 Weight 0.8 oz (23 g) 1.3 oz. (37 g) 1.6 oz. (45 g) 2.1 oz. (60 g) 2.1 oz. (60 g) 2.9 oz. (82 g) 2.6 oz. (74 g) 3.5 oz. (99 g) 3.5 oz. (99 g) 6.2 oz. (176 g) 6.7 oz. (190 g) 68512 See page 310 for additional information on warnings. Wrenches Open-End Wrenches Corrosion resistant Forged from the highest quality alloy steel Ends are offset at 15° angle for clearance over obstructions Different size opening on each end of wrench Durable chrome-plated finish 5-Piece Open-End Wrench Set - SAE Cat. No. 68450 Set Contains Cat. No. Weight 1.1 lbs. (0.50 kg) Small Size Large Size 68460 1/4" 5/16" 68461 3/8" 7/16" 68462 1/2" 9/16" 68463 9/16" 5/8" 68464 11/16" 3/4" Includes pouch with marked pockets for each wrench. Individual wrenches sold separately. Length 4-3/4" (120.7 mm) 6" (152.4 mm) 7" (177.8 mm) 7-1/2" (190.5 mm) 9" (228.6 mm) 68450 7-Piece Open-End Wrench Set - SAE Cat. No. 68452 Set Contains Cat. No. Weight 2.5 lbs. (1.13 kg) Small Size Large Size 68460 1/4" 5/16" 68461 3/8" 7/16" 68462 1/2" 9/16" 68463 9/16" 5/8" 68464 11/16" 3/4" 68465 13/16" 7/8" 68466 15/16" 1" Includes pouch with marked pockets for each wrench. Individual wrenches sold separately. Length 4-3/4" (120.7 mm) 6" (152.4 mm) 7" (177.8 mm) 7-1/2" (190.5 mm) 9" (228.6 mm) 10" (254.0 mm) 11" (279.4 mm) 68452 Open-End Wrenches - SAE Cat. No. 68460 68461 68462 68463 68464 68465 68466 Small Size 1/4" 3/8" 1/2" 9/16" 11/16" 13/16" 15/16" Large Size 5/16" 7/16" 9/16" 5/8" 3/4" 7/8" 1" See page 310 for additional information on warnings. Length 4-3/4" (120.7 mm) 6" (152.4 mm) 7" (177.8 mm) 7-1/2" (190.5 mm) 9" (228.6 mm) 10" (254.0 mm) 11" (279.4 mm) Weight 0.6 oz. (17 g) 1.6 oz. (45 g) 2.7 oz. (77 g) 3.2 oz. (91 g) 5.8 oz. (164 g) 8.8 oz. (249 g) 12.8 oz. (363 g) 68463 97 www.kleintools.com Wrenches Socket Wrench Sets 8-Piece 1/2" Drive Deep-Socket Set 12-Piece 1/2-Inch Drive Socket Wrench Set 65514 Set consists of the following pieces: Eight 12-point deep sockets: 1/2", 9/16", 5/8", 11/16", 3/4", 13/16", 7/8", and 15/16" Hinged metal box • • Cat. No. 65514 Description 1/2" Drive Deep Socket Wrench Set, 8 Pc 65510 Weight 4.5 lbs. (2.04 kg) 16-Piece 1/2" Drive Socket Wrench Set Set consists of the following pieces: Nine 12-point sockets: 7/16", 1/2", 9/16", 5/8", 11/16", 3/4", 13/16", 7/8", and 15/16" One extension: 5" long One spark plug socket: 5/8" One ratchet Hinged metal box • • • • • Cat. No. 65510 Description 1/2" Drive Socket Wrench Set, 12 Pc Weight 5.4 lbs. (2.45 kg) 13-Piece 3/8-Inch Drive Socket Set - Metric 65512 Set consists of the following pieces: Thirteen 12-point sockets: 7/16", 1/2", 9/16", 5/8", 11/16", 3/4", 13/16", 7/8", 15/16", 1", 1-1/16", 1-1/8", and 1-1/4" One extension: 5" long One flex handle: 17" long One ratchet Hinged metal box • • • • • Cat. No. 65512 Description 1/2" Drive Socket Wrench Set, 16 Pc 98 www.kleintools.com Weight 9.6 lbs. (4.35 kg) 65506 Set consists of the following pieces: Thirteen 6-point sockets: 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, and 19 mm Handy, flip-lock tray • • Cat. No. 65506 Description 3/8" Drive Socket Set, Metric, 13 Pc Weight 1.3 lbs. (0.59 kg) See page 310 for additional information on warnings. Wrenches Socket Wrench Sets 8-Piece 3/8" Drive Deep-Socket Set 12-Piece 3/8" Drive Socket Wrench Set 65502 Set consists of the following pieces: Eight 6-point deep sockets: 3/8", 7/16", 1/2", 9/16", 5/8", 11/16", 3/4", and 13/16" Hinged metal box • • Cat. No. 65502 Description 3/8" Drive Deep Socket Wrench Set, 8 Pc Weight 2.7 lbs. (1.22 kg) 20-Piece 3/8" Drive Socket Wrench Set Set consists of the following pieces: Four 6-point sockets: 3/8", 7/16", 1/2", and 9/16" Four 12-point sockets: 5/8", 11/16", 3/4", and 13/16" One spark plug socket: 5/8" Two extensions: 1-3/4" and 6" long One ratchet Hinged metal box • • • • • • Cat. No. 65504 Description 3/8" Drive Socket Wrench Set, 12 Pc 65504 Weight 3.6 lbs. (1.63 kg) 13-Piece 1/4" Drive Socket Wrench Set 65508 Set consists of the following pieces: Four 6-point sockets: 3/8", 7/16", 1/2", and 9/16" Five 12-point sockets: 5/8", 11/16", 3/4", 13/16", and 7/8" Eight 6-point deep sockets: 3/8", 7/16", 1/2", 9/16", 5/8", 11/16", 3/4", and 13/16" Two extensions: 1-3/4" and 3" long One ratchet Hinged metal box • • • • • • Cat. No. 65508 Description 3/8" Drive Socket Wrench Set, 20 Pc See page 310 for additional information on warnings. Set consists of the following pieces: Nine 6-point sockets: 3/16", 7/32", 1/4", 9/32", 5/16", 11/32", 3/8", 7/16", and 1/2" One spinner handle Two extensions: 2" and 6" long One ratchet Hinged metal box • • • • • Weight 5.4 lbs. (2.45 kg) Cat. No. 65500 65500 Description 1/4" Drive Socket Wrench Set, 13 Pc Weight 2.1 lbs. (0.95 kg) 99 www.kleintools.com Wrenches Socket Wrenches 1/4-Inch Drivers and Extensions 1/4" Drive Sockets 65620 65604 Cat. No. Size Weight 3/16" 7/32" 1/4" 9/32" 5/16" 11/32" 3/8" 7/16" 1/2" 0.3 oz. (8.5 g) 0.3 oz. (8.5 g) 0.3 oz. (8.5 g) 0.3 oz. (8.5 g) 0.3 oz. (8.5 g) 0.5 oz. (14 g) 0.6 oz. (17 g) 0.6 oz. (17 g) 0.8 oz. (23 g) Standard — 6-Point 65621 65622 65623 Cat. No. 65620 65621 65622 65623 Description 4-3/4" Ratchet Spinner Handle 2" Extension 6" Extension Weight 5.1 oz. (145 g) 3.0 oz. (86 g) 0.8 oz. (23 g) 2.2 oz. (64 g) 65600 65601 65602 65603 65604 65605 65606 65607 65608 3/8" Drive Sockets 3/8" Drivers and Extensions 65702 Cat. No. Size Weight 3/8" 7/16" 1/2" 9/16" 0.8 oz. (23 g) 0.8 oz. (23 g) 1 oz. (27 g) 1 oz. (27 g) Standard — 6-Point 65720 65721 65722 65723 Cat. No. 65720 65721 65722 65723 65724 Description 7-1/2" Ratchet 1-1/2" Extension 3" Extension 6" Extension 3/8" Socket Size 5/8" Spark Plug Socket 3/8" Drive 65724 Weight 11.7 oz. (331 g) 1.4 oz. (41 g) 2.4 oz. (68 g) 4.8 oz. (136 g) 3.4 oz. (96 g) 65700 65701 65702 65703 Standard Deep — 6-Point 65710 65711 65712 65713 65714 65715 65716 65717 3/8" 7/16" 1/2" 9/16" 5/8" 11/16" 3/4" 13/16" 1.4 oz. (41 g) 1.6 oz. (45 g) 2.1 oz. (59 g) 2.4 oz. (68 g) 3.5 oz. (99 g) 4.3 oz. (122 g) 4.5 oz. (128 g) 5.4 oz. (153 g) 5/8" 11/16" 3/4" 13/16" 7/8" 1.3 oz. (37 g) 1.8 oz. (50 g) 1.9 oz. (54 g) 2.4 oz. (68 g) 3.0 oz. (86 g) 7 mm 8 mm 9 mm 10 mm 11 mm 12 mm 13 mm 14 mm 15 mm 16 mm 17 mm 18 mm 19 mm 0.6 oz. (17 g) 0.6 oz. (17 g) 0.8 oz. (23 g) 0.8 oz. (23 g) 0.8 oz. (23 g) 1.0 oz. (27 g) 1.1 oz. (31 g) 1.3 oz. (37 g) 1.6 oz. (45 g) 1.4 oz. (41 g) 1.6 oz. (45 g) 1.8 oz. (50 g) 2.2 oz. (64 g) Standard — 12-Point 65704 65705 65706 65707 65708 1/2" Drivers and Extensions Metric — 6-Point 65820 65821 65823 Cat. No. 65820 65821 65823 Description 10-1/2" Ratchet 5" Extension 5/8" Spark Plug Socket 1/2" Drive 100 www.kleintools.com Weight 1.3 lbs. (0.59 kg) 7.2 oz. (204 g) 2.9 oz. (82 g) 65907 65908 65909 65910 65911 65912 65913 65914 65915 65916 65917 65918 65919 See page 310 for additional information on warnings. Wrenches Socket Wrench Sets 1/2" Drive Sockets Cat. No. Size Weight 7/16" 1/2" 9/16" 5/8" 11/16" 3/4" 13/16" 7/8" 15/16" 1" 1-1/16" 1-1/8" 1-1/4" 1.9 oz. (54 g) 1.9 oz. (54 g) 1.9 oz. (54 g) 1.9 oz. (54 g) 2.4 oz. (68 g) 3.2 oz. (91 g) 3.2 oz. (91 g) 3.2 oz. (91 g) 4.0 oz. (113 g) 4.8 oz. (136 g) 5.6 oz. (159 g) 6.4 oz. (181 g) 8.0 oz. (227 g) 65800 Standard — 12-Point 65800 65801 65802 65803 65804 65805 65806 65807 65808 65809 65810 65811 65812 Cat. No. 65829 Size Weight Standard Deep — 12-Point 65825 65826 65827 65828 65829 65830 65831 65832 1/2" 9/16" 5/8" 11/16" 3/4" 13/16" 7/8" 15/16" Ratcheting Box Wrenches 4.8 oz. (136 g) 5.0 oz. (142 g) 3.8 oz. (108 g) 5.1 oz. (145 g) 5.8 oz. (164 g) 6.6 oz. (187 g) 6.6 oz. (187 g) 8.8 oz. (249 g) For use in confined spaces and on long studs Different size opening on each end Corrosion resistant Durable chrome-plated finish Laminated construction for greater strength Reverse ratcheting action by simply turning wrench over 7-Piece Ratcheting Box Wrench Set Additional Features: Ratcheting box wrenches in vinyl roll-up pouch Wrenches flip over to reverse ratchet • • Cat. No. Set Contains 68222 Weight 2.7 lbs. (1.22 kg) Cat. No. Point Size Length 68200 68201 68202 68203 68204 68205 68206 12 12 12 12 12 12 12 1/4" x 5/16" 3/8" x 7/16" 1/2" x 9/16" 5/8" x 11/16" 5/8" x 3/4" 11/16" x 3/4" 13/16" x 7/8" 4-3/8" (111.1 mm) 5-1/2" (139.7 mm) 6-7/8" (174.6 mm) 8-1/4" (209.6 mm) 8-1/4" (209.6 mm) 9-1/4" (235.0 mm) 9-1/4" (235.0 mm) See page 310 for additional information on warnings. 68222 101 www.kleintools.com Wrenches Ratcheting Box Wrenches 5-Piece Ratcheting Box Wrench Set Additional Features: Ratcheting box wrenches in vinyl roll-up pouch Wrenches flip over to reverse ratchet • • Cat. No. Set Contains 68221 Weight 1.5 lbs. (0.68 kg) Cat. No. Point Size Length 68200 68201 68202 68203 68204 12 12 12 12 12 1/4" x 5/16" 3/8" x 7/16" 1/2" x 9/16" 5/8" x 11/16" 5/8" x 3/4" 4-3/8" (111.1 mm) 5-1/2" (139.7 mm) 6-7/8" (174.6 mm) 8-1/4" (209.6 mm) 8-1/4" (209.6 mm) 68221 Ratcheting Box Wrenches Cat. No. 68200 68201 68202 68203 68204 68205 68206 Point 12 12 12 12 12 12 12 Size 1/4" x 5/16" 3/8" x 7/16" 1/2" x 9/16" 5/8" x 11/16" 5/8" x 3/4" 11/16" x 3/4" 13/16" x 7/8" Length 4-3/8" (111.1 mm) 5-1/2" (139.7 mm) 6-7/8" (174.6 mm) 8-1/4" (209.6 mm) 8-1/4" (209.6 mm) 9-1/4" (235.0 mm) 9-1/4" (235.0 mm) Weight 2.1 oz. (60 g) 2.9 oz. (82 g) 4.6 oz. (130 g) 6.9 oz. (196 g) 6.7 oz. (190 g) 8.3 oz. (235 g) 11.0 oz. (312 g) 68201 Ratcheting Offset Box Wrenches 5-Piece Fully Reversible Ratcheting Offset Box Wrench Set • Set of offset reversible ratchet box wrenches in vinyl roll-up pouch Cat. No. Set Contains 68245 Weight 1.6 lbs. (0.73 kg) Cat. No. Point Size Length 68234 68236 68238 68240 68242 6 6 6 12 12 1/4" x 5/16" 3/8" x 7/16" 1/2" x 9/16" 5/8" x 11/16" 3/4" x 7/8" 4-3/8" (111.1 mm) 5-1/2" (139.7 mm) 6-3/4" (171.5 mm) 8-1/8" (206.4 mm) 9-1/8" (231.8 mm) 68245 3-Piece Fully Reversible Ratcheting Offset Box Wrench Set • Set of offset reversible ratchet box wrenches in vinyl roll-up pouch Cat. No. 68244 Set Contains Weight 9.8 oz. (278 g) Cat. No. Point Size Length 68234 68236 68238 6 6 6 1/4" x 5/16" 3/8" x 7/16" 1/2" x 9/16" 4-3/8" (111.1 mm) 5-1/2" (139.7 mm) 6-3/4" (171.5 mm) 102 www.kleintools.com 68244 See page 310 for additional information on warnings. Wrenches Ratcheting Offset Box Wrenches Fully Reversible Ratcheting Offset Box Wrenches • Both ends are offset 25° for more convenient use in confined spaces • Quick-flip reversing lever for instant ratchet reversal • Laminated construction for greater strength • Chrome-plated for rust resistance • Different size openings at each end Cat. No. 68238 68236 68242 68240 68234 Point 6 6 12 12 6 Size 1/2" x 9/16" 3/8" x 7/16" 3/4" x 7/8" 5/8" x 11/16" 1/4" x 5/16" Length 6-3/4" (171.5 mm) 5-1/2" (139.7 mm) 9-1/8" (231.8 mm) 8-1/8" (206.4 mm) 4-3/8" (111.1 mm) 68236 Weight 4.8 oz. (136 g) 2.9 oz. (82 g) 8.0 oz. (227 g) 7.4 oz. (210 g) 2.1 oz. (60 g) Ratcheting Refrigeration Wrenches • Fully reversible for refrigeration-packing gland nuts, valve stem sockets and beam-clamp installation • Compact in size, with clearly marked sockets for four nut sizes • Quick-flip reversing lever permits instant ratchet reversal • Ruggedly built with polished chrome finish for smooth edges for comfort Cat. No. 68309 68310 Socket Size 3/16" and 1/4" Sq. x 1/2" and 9/16" Hex 3/16" and 5/16" Sq. x 1/4" and 3/8" Sq. Length ​ ​ 68310 Weight 6.9 oz. (196 g) 3.2 oz. (91 g) Specialty Wrenches Can Wrench • Two tools in one saves space in your pouch • One end opens telephone box fasteners, the other end tightens nuts on binding-post terminals • The 7/16" socket has a black finish and the 3/8" socket has a silver finish are 1-1/4" (32 mm) deep to fit over long binding posts and are thin-walled for easy access • Sockets into tight areas • Socket ends are color-coded for quick identification of socket sizes Cat. No. Size • Hex-socket design enables using a wrench to obtain extra torque 68005 3/8" and 7/16" Hex Nut • High-impact, break-resistant handle for long and dependable service • Sockets are heat-treated, alloy steel 68005 Length 7" (177.8 mm) Handle Diameter 1" (25.4 mm) Lineman's Wrenches • Forged from special bar steel and heat-treated for long life • Each end has two different size openings • Hole is provided at larger end for turning-in standard pole steps • Wrench is suited for use on heavy three-bolt guy clamps on which clearance is limited • Small end is painted silver on Cat. No. 3146A • Cat. No. 3146B features end openings sized to NEMA hardware specifications Cat. No. 3146 3146A 3146B Application 5/8" (15.9 mm) Hardware 3/4" (19.1 mm) Hardware Bell System Type See page 310 for additional information on warnings. Large End Opening 29/32" and 1-3/32" 1-1/16" and 1-5/16" 1-1/16" and 1-3/16" Small End Opening 5/8" and 13/16" 5/8" and 7/8" 11/16" and 7/8" Weight 5.6 oz. (159 g) 3146 3146B Color Dark Blue Dark Blue Silver Length 13" (330.2 mm) 13" (330.2 mm) 13" (330.2 mm) Weight 1.9 lbs. (0.86 kg) 1.7 lbs. (0.77 kg) 1.8 lbs. (0.82 kg) 103 www.kleintools.com Wrenches Specialty Wrenches Lineman's Ratcheting Wrenches • Bolt-through design allows bolts to pass through the socket features side ridges that provide a better grip and • KT152T includes 13/16" square socket size and 1" x 1-1/8" combination square socket sizes for • 3/4" most common utility hardware • Bright yellow socket for easy visibility on most common utility pole hardware, such as lag • Works bolts, "C" clamps and suspension bolts and KT155HD also offer two popular 12-point • KT155T wrench sizes: 9/16" and 3/4" Cat. No. KT151T KT152T KT155HD KT155T Description Lineman's Ratcheting Wrench Lineman's Slim Ratcheting Wrench 5-in-1 Lineman's Wrench, Heavy Duty 5-in-1 Lineman's Wrench Length 13" (330.2 mm) 13-1/4" (336.6 mm) 12" (304.8 mm) 9-3/8" (238.1 mm) KT152T KT155HD Weight 2.1 lbs. (0.95 kg) 2.1 lbs. (0.95 kg) 2.1 lbs. (0.95 kg) 1.4 lbs. (0.64 kg) Lineman's Box Wrenches • Chrome plated finish resists corrosion • 1/2", 9/16", 5/8" and 3/4" sizes in one tool; 12-point sockets • Reverse ratcheting action by reversing switches on each end of the wrench • "See-through" insulating handle confirms metal ends are not connected (Cat. No. KT223X4-INS) • Textured grooves in handle prevent slipping (Cat. No. KT223X4-INS) • Solid, one piece design (Cat. No. KT223X4) NOT INSULATED Cat. No. KT223X4 KT223X4-INS KT223-INS Description Lineman's Ratcheting 4-in-1 Box Wrench Lineman's Insulating 4-in-1 Box Wrench Lineman's Insulating Box Wrench Size 1/2", 9/16" 5/8", 3/4" 1/2", 9/16", 5/8", 3/4" 9/16", 3/4" Length 9" (228.6 mm) 9" (228.6 mm) 8-1/4" (209.6 mm) KT223X4-INS KT223X4 Weight 11.2 oz. (318 g) 11.2 oz. (318 g) 10.00 lbs. (4.54 kg) Impact Socket Wrenches and Adapters • Features three square socket sizes: 3/4", 1", and 1-1/8" • Fine-tuned ball detent provides improved retention, minimizing drops • Long hollow shaft allows use on long threaded bolts • 7/16'' hex quick-change adapter included • Adapters extend or retract head for easy access to the size you need • Do not exceed 200 ft./lbs. of torque NRHD NRHD3 Cat. No. NRHD NRHD3 NRHDA NRHDA3 Description 3-in-1 Impact Socket Wrench Single Ended Impact Socket Wrench Impact Socket Adapter for NRHD Impact Socket Adapter for NRHD3 104 www.kleintools.com Size 3/4", 1", 1-1/8" to 1-1/8" (28.6 mm) Square 7/16" 1/2" Length 7-3/4" (196.9 mm) 10" (254.0 mm) 4-29/32" (124.6 mm) 2-15/32" (62.7 mm) Weight 2.0 lbs. (0.91 kg) 2.1 lbs. (0.95 kg) 5.8 oz. (164 g) 2.9 oz. (82 g) NRHDA NRHDA3 See page 310 for additional information on warnings. Wrenches Construction Wrenches Adjustable-Head Construction Wrenches • Eliminates the need for carrying several fixed-size wrenches from select alloy steel with continuous taper handle for • Forged aligning bolt and/or rivet holes • Industrial black finish for corrosion resistance • Includes lanyard hole for easy tool tethering Cat. No. 3227 3239 3239 Max. Size Capacity 1-5/16" (33.3 mm) 1-1/2" (38.1 mm) Overall Length 11" (279.4 mm) 16" (406.4 mm) 1/2"-Drive Ratcheting Construction Wrench • Accepts 1/2" (12.7 mm) square-drive hex socket • Reversible ratchet • Eliminates the need for carrying several fixed-size wrenches from select alloy steel with continuous taper handle for aligning • Forged bolt and/or rivet holes • Industrial black finish for corrosion resistance Weight 1.2 lbs. (0.54 kg) 2.4 lbs. (1.09 kg) 3238 Cat. No. 3238 Overall Length 15" (381.0 mm) Erection Wrenches • Forged from select alloy steel to withstand high-leverage and heavy loads • Extra-heavy-duty head area gives maximum strength and durability taper of handle makes lining-up bolt holes easy and works on a • Continuous range of bolt-hole sizes without binding • Extra-large hub area works on larger diameter holes better than other wrenches number, bolt size and nominal opening size are stamped on every • Catalog wrench for easy identification • American Bridge design • Cat. Nos. 3212TT, 3213TT, and 3214TT feature tether hole for working at height Cat. No. 3210 3211 3212 3213 3214 3219 3220 3221 3222 3223 3224 3231 3232 Nut Type U.S. Heavy U.S. Heavy U.S. Heavy U.S. Heavy U.S. Heavy U.S. Regular U.S. Regular U.S. Regular U.S. Regular U.S. Regular U.S. Regular Utility Utility Bolt Size 1/2" (12.7 mm) 5/8" (15.9 mm) 3/4" (19.1 mm) 7/8" (22.2 mm) 1" (25.4 mm) 1/2" (12.7 mm) 1/2" (12.7 mm) 5/8" (15.9 mm) 3/4" (19.1 mm) 7/8" (22.2 mm) 1" (25.4 mm) 5/8" (15.9 mm) 3/4" (19.1 mm) Weight 2.1 lbs. (0.95 kg) 3231 NEW! 3214TT Nominal Opening 7/8" (22.2 mm) 1-1/16" (27.0 mm) 1-1/4" (31.8 mm) 1-7/16" (36.5 mm) 1-5/8" (41.3 mm) 3/4" (19.1 mm) 13/16" (20.6 mm) 1" (25.4 mm) 1-1/8" (28.6 mm) 1-5/16" (33.3 mm) 1-1/2" (38.1 mm) 15/16" (23.8 mm) 1-1/16" (27.0 mm) Head Width 2-1/4" (57.2 mm) 2-1/4" (57.2 mm) 2-1/2" (63.5 mm) 3" (76.2 mm) 3-5/8" (92.1 mm) 2-1/4" (57.2 mm) 2-1/4" (57.2 mm) 2-1/4" (57.2 mm) 2-1/2" (63.5 mm) 3" (76.2 mm) 3-5/8" (92.1 mm) 2-1/4" (57.2 mm) 2-1/2" (63.5 mm) Taper Diameter 7/8" to 3/16" (22.2 to 4.8 mm) 7/8" to 3/16" (22.2 to 4.8 mm) 1" to 1/4" (25.4 to 6.4 mm) 1-1/8" to 9/32" (28.6 to 7.1 mm) 1-1/8" to 1/4" (28.6 to 6.4 mm) 7/8" x 1/2" (22.2 to 12.7 mm) 7/8" to 3/16" (22.2 to 4.8 mm) 7/8" to 3/16" (22.2 to 4.8 mm) 1" to 1/4" (25.4 to 6.4 mm) 1-1/8" to 9/32" (28.6 to 7.1 mm) 1-1/8" to 1/4" (28.6 to 6.4 mm) 7/8" to 3/16" (22.2 to 4.8 mm) 1" to 1/4" (25.4 to 6.4 mm) Overall Length 14-3/4" (374.7 mm) 14-3/4" (374.7 mm) 16-5/8" (422.3 mm) 17-3/8" (441.3 mm) 18" (457.2 mm) 14-3/4" (374.7 mm) 14-3/4" (374.7 mm) 14-3/4" (374.7 mm) 16-5/8" (422.3 mm) 17-3/8" (441.3 mm) 18" (457.2 mm) 14-3/4" (374.7 mm) 16-5/8" (422.3 mm) Weight 1.4 lbs. (0.64 kg) 1.3 lbs. (0.59 kg) 2.0 lbs. (0.91 kg) 2.7 lbs. (1.22 kg) 3.4 lbs. (1.54 kg) 1.4 lbs. (0.64 kg) 1.4 lbs. (0.64 kg) 1.3 lbs. (0.59 kg) 2.0 lbs. (0.91 kg) 2.9 lbs. (1.32 kg) 3.4 lbs. (1.54 kg) 1.3 lbs. (0.59 kg) 2.0 lbs. (0.91 kg) 1-1/4" (31.8 mm) 1-7/16" (36.5 mm) 1-5/8" (41.3 mm) 2-1/2" (63.5 mm) 3" (76.2 mm) 3-5/8" (92.1 mm) 1" to 1/4" (25.4 to 6.4 mm) 1-1/8" to 9/32" (28.6 to 7.1 mm) 1-1/8" to 1/4" (28.6 to 6.4 mm) 16-5/8" (422.3 mm) 17-3/8" (441.3 mm) 18" (457.2 mm) 2.0 lbs. (0.91 kg) 2.7 lbs. (1.22 kg) 3.4 lbs. (1.54 kg) Erection Wrenches with Tether Hole 3212TT NEW! U.S. Heavy 3213TT NEW! U.S. Heavy 3214TT NEW! U.S. Heavy 3/4" (19.1 mm) 7/8" (22.2 mm) 1" (25.4 mm) See page 310 for additional information on warnings. 105 www.kleintools.com Wrenches Strap Wrenches Grip-It® Strap Wrenches • Completely adjustable strap wrench • Works in the tightest quarters high-strength belting attached to lightweight, • Urethane-covered, I-beam handle • Cam-action design permits uniform, high-torque application normal conditions, will not scratch, damage or deform • Under polished pipe and fittings, plastic pipe and fittings, oil and water • S12H filters, glass pipe, PVC conduit, or polished shafts Also works on alternator belts, flywheels, and propeller assemblies Cat. No. S-6H S-12H S-18H Handle Length 6" (152.4 mm) 12" (304.8 mm) 18" (457.2 mm) Diameter Capacity O.D. 1-1/2" to 5" (38.1 mm to 127.0 mm) 1-1/2" to 5" (38.1 mm to 127.0 mm) 1-1/8" to 8" (28.6 to 203.2 mm) Weight 3.2 oz. (91 g) 12.0 oz. (340 g) 2.8 lbs. (1.27 kg) Torque Wrenches Micro-Adjustable Torque-Sensing Wrenches with Square-Drive Ratchet Head • Micro-adjustable for increased accuracy • Easy to read and adjust with quick release lever • Stainless steel handle provides improved, more comfortable grip • N.I.S.T. traceable calibration certificate meeting the ASME standard of ±4% Cat. No. 57000 57005 57010 Drive Size 3/8" (9.5 mm) 3/8" (9.5 mm) 1/2" (12.7 mm) Range 10 - 100 ft. lb. (13.6 - 135.6 Nm) 30 - 250 in. lb. (40.7 - 338.9 Nm) 30 - 250 ft. lb. (40.7 - 338.9 Nm) 57005 Length 14-1/8" (358.8 mm) 10-5/8" (269.9 mm) 24-1/4" (616.0 mm) Weight 2.0 lbs. (0.91 kg) 1.2 lbs. (0.54 kg) 3.7 lbs. (1.68 kg) Master Electrician's Torque Tool Kit • Two micrometer-adjustable torque wrenches • Nine hex-wrench bits • Two 7/16" hex-wrench extensions • One 7/16" female hex-wrench adapter coupler • One hex-to-square adapter for wrenches and one adapter for screwdrivers • One adjustable torque screwdriver • Seven screwdriver bits; five slotted, two Phillips • Hinged metal box • Additional torque screwdrivers available in screwdriver section Cat. No. 57060 Description Master Electrician's Torque Kit 25 Pc Weight 9.6 lbs. (4.35 kg) 57060 106 www.kleintools.com See page 310 for additional information on warnings.
D507-8 价格&库存
很抱歉,暂时无法提供与“D507-8”相匹配的价格&库存,您可以联系我们找货
