Heat at work.
Professional Tools for Professional Results
Hot Air
Barrel Tools
Pistol Grip
Hot Air Tools
Hot Air
Specials
Precision
Hot Air Tool
Professional
Heat Blower
Hot Air Tool
Accessories
Gas
Torches
Hot-Melt
Adhesive Systems
from page 4
from page 18
from page 36
from page 44
from page 46
from page 50
from page 58
from page 72
HG 2620 E
HG Scan PRO
HG 2220 E
HG 5000 E
HG 2520 E
HG Scan PRO
HG 2320 E / ESD
HL 2020 E
HL 1920 E
HL Scan
HL 1820 S
HL 1620 S
HG 2320 E Kits
HL 2020 E Kits
HL 1920 E Kits
HL 1820 E Kit
HG 350 ESD
HB 1750
Everything for welding floorings, plastics, tarpaulins
and roof sheetings,
removing and shaping,
heat-shrinking, desoldering
and spot heating,
special accessories
Ultimate Butane Kit
TT 270
TT 175
TT 151
TT 30
TS 600 / TS 600 K
TS 550 / TS 550 K
TS 500 / TS 500 K
TH 310
TM 6000
GF 3002
2
3
Hot Air Barrel Tools:
Ideal for roofers and floor layers.
Welding, heat-shrinking, shaping, removing – hot air makes all sorts of jobs
incredibly easy. Jobs that demand precision, high performance and reliability.
That's why professionals prefer barrel-type hot air tools from STEINEL.
Professional Floor Layer
“The STEINEL HG 2620 E is
the best tool for floor laying.”
4
5
The art of understanding heat.
Precision and control on hot air tools is imperative for a wide range of technical applications.
STEINEL only uses top quality, long-lasting components that come from our development
history. This is where our customers benefit from over 30 years of experience in developing
and manufacturing hot air tools to give them a product that has been cleverly engineered in
every last detail, only delivering heat where it is needed.
Digital control system with
LCD information display
Precision-balanced
impeller
Easy-to-change
power cord
1300 °F
3,000 Pa
air pressure
max. 13 cfm
Including fine
dust filter
Hand-wound.
long-life ceramic heater,
easy to change
6
High-performance brushless motor
with a service life
of over 10,000 hours
Sturdy magnesium
guard sleeve
7
Ideal for the trades and industry. Our flagship.
Hot air tool HG 2620 E
If you want the best when it comes to performance and precision: Delivering 1750 W of power,
the HG 2620 E hot air tool is controlled by a toggle in 10 °F steps between 120 - 1300 °F while
letting you set four individually tailored programs. The temperature is indicated on the LCD
information display where it is easy to read at any time. The airflow rate is continuously variable
between 2 – 13 cfm and is easy to adjust. Full air-pressure power is 3,000 Pa. The powerful
brushless motor gives our flagship tool a working life of over 10,000 hours. Thanks to its robust
design as well as the specially protected electronics with fine dust filter, four individually selectable programs and the heavy-duty H07 power cord, it is the safest, most dependable heat
tool on any construction site.
1300 °F
max.
13 cfm
Also available in a convenient carrying case.
Welding linoleum floors.
8
LCD display
always in view
Single-hand
operation
by toggle
Magnesium
guard sleeve,
plug-in heating
element
Residual heat
indicator
Restart
protection
Includes
fine dust filter
Replaceable
power cord
Ergonomic
soft grip handle
Technical specifications
Power: 1750 W
Amps: 14.8 A
Temperature: 120 - 1300 °F ( 50-700 °C )
Airflow rate: 2 - 13 cfm ( +/- 0.5 cfm )
Air pressure: 3,000 Pa
Motor: brushless
Motor life: 10,000 hours
Temperature setting: on display,
in 10 ° F steps by toggle
Heating element: ceramic heating element
Lockable Override Control ( LOC ): yes
Create Preset Customizable Programs: yes
Thermal cutout: yes
Double Insulated: yes
Power Cord: Industrial grade rubber
Nozzle Diameter: 1.26" ( 32.00 mm )
Dimensions ( l × w × h ): 14.10" × 3.60" × 3.70"
Voltage: 120 VAC, 50 / 60 Hz
Weight: 1.85 lbs ( 29.63 oz )
Warranty: One year limited
Ordering details
110025600 ( HG 2620 E in a folding box ), 3.26 lbs ( 52.10 oz )
110047485 ( HG 2620 E in a case ), 5.17 lbs ( 82.65 oz )
Accessories
110033508 HG Scan PRO for HG 2620 E
Professional STEINEL nozzles from page 50
HG Scan
optional
Fits all 1.26"
diameter Industry
Standard Nozzles
DOUBLE INSULATED
HEAT GUN
41HP
9
For safety and precision.
Temperature scanner HG Scan PRO for HG 2620 E
With the HG Scan PRO, you can be sure of the exact temperature at the work piece. It
works in a range of 30 - 570 °F ( 0 - 300 °C ) with absolute precision – and informs you visually
as well as audibly if the temperature exceeds or falls below the level you have set. The integrated laser technology ensures the ideal distance from the work piece. And being perfectly
compatible with our top HG 2620 E and HG 2520 E tools, all relevant data are intelligently
communicated between scanner and hot air tool. The particularly clever way to complement
your set of tools.
Visual warning:
too hot = red
Ideal temperature = green
Visual warning:
too cold = blue
Power supplied from hot air tool
Temperature detection range: 30 - 570 °F ( 0 - 300 °C ),
adjustable in 10 °F steps
Optimum distance from workpiece: 3.94"
Emissivity level: user-selectable,
adjustable from 0.10 to 0.99
Dimensions ( l × w × h ): 3.70" × 3.70" × 6.00"
Weight: 0.26 lbs ( 4.23 oz )
Ideal for all heat-sensitive materials
Film,
sheeting,
foil
Wood
Plastic
Leather
Textiles
Ordering details
110033508 ( folding box ), 0.37 lbs ( 6.00 oz )
Audible
warning
Laser technology
for maintaining
perfect distance
Intelligent data
communication
Hot air and temperature measurement with one hand.
10
11
Slim. Lightweight. Ergonomic.
Hot air tool HG 2220 E
The HG 2220 E weighs only 1.34 pounds ( 610 g ) and has a powerful 1500 W motor that
heats the flow of air across a continuously variable temperature range of 167 - 1166 °F
( 80 - 630 °C ) via an easily adjustable thumbwheel. Nozzles are push-on and simple to
attach. A perfect tool for all professionals with a preference for practical things – and, thanks
to fine dust filter and long-life brush motor, who also want it to give them lasting service.
Professional edgebanding.
12
Two-stage
airflow
Continuously
variable
temperature
setting
Ergonomic soft
grip handle
Replaceable
power cord
Fine dust filter
included
Power: 1500 W
Amps: 12.5 A
Temperature: 120 - 1100 °F ( 50-600 °C )
Airflow rate: 4-7/6-12 cfm ( +/- 0.5 cfm )
Temperature setting: thumbwheel
Thermal cutout: yes
Power Cord: Industrial grade rubber, length: 6ft
Nozzle Diameter: 1.34" ( 34.00 mm )
Dimensions ( l × w × h ): 13.30" × 3.00" × 3.50"
Voltage: 120 VAC, 50/60 HZ
Weight: 1.34 lbs ( 21.51 oz )
Fits all 1.34"
diameter Industry
Standard Nozzles
Ordering details
110025601 ( folding box ), 2.59 lbs ( 41.48 oz )
Accessories
Pressure fit standard nozzles from page 53
DOUBLE INSULATED
HEAT GUN
41HP
13
Our most powerful tool. 3400 W, 28 cfm.
Hot air tool HG 5000 E
Bursting with strength and staying power: with its powerful 3400 W brushless motor rated
for 20,000 hours of service, the HG 5000 E delivers up to 800 litres of air a minute over an
infinitely variable temperature range of 80-1100 °F ( 20-600 °C ). Its generously sized outlet
nozzle reaches a pressure of 3,000 Pa. Making it the ideal tool for working on large surfaces.
From fully electronic temperature and airflow adjustment to intelligent motor and temperature
control and clearly structured LED segment display, it comes with everything that professionals
need for working with hot air in industry. The mains power cord and heater are particularly
easy to change. Changing the screw-on nozzle attachment is just as simple.
LED segment
display
Plug-in heating
element
Replaceable
power cord
Power: 3400 W
Amps: 14.8 A
Temperature: 80 - 1100 °F ( 20 - 600 °C )
Airflow rate: max. 28 cfm ( +/- 0.5 cfm )
Motor: brushless
Motor life: 20,000 hours
Temperature setting: continuiously variable in 10 °F steps
Thermal cutout: yes
Power Cord: Industrial grade rubber ( European Plug )
Nozzle Diameter: 1.97" ( 50.00 mm )
Dimensions ( l × w × h ): 14.50" × 4.30" × 4.30"
Voltage: 230 VAC, 50 HZ
Weight: 2.62 lbs ( 41.98 oz )
Fits Speciality
STEINEL Nozzles
Ordering details
104201504 ( folding box ), 3.70 lbs ( 59.20 oz )
110049782 ( case ), 10.80 lbs ( 172.60 oz )
Overlap welding on a light dome.
14
Accessories
Speciality STEINEL nozzles from page 50
15
Experts in every field.
Summary of applications.
There's a lot you can do with hot air. And take care of all sorts of jobs with ease, reliability and precision.
This is where you will always find the right professional barrel air tool from STEINEL for a virtually unlimited
range of applications in industry and the trades.
Welding linoleum
HG 2620 E
HG 2620 E
HG 2220 E
HG 5000 E
Welding / repairing truck side curtains and advertising banners
Welding / repairing pond liner / landfill membranes, pool construction
+ ( 1 )
+ + + ( 1 )
Car wrapping, window tinting, facade wrapping
Welding plastics in tank and apparatus construction
Smoothing leather
HG 2620 E
Smoothing leather
Welding roof sheeting
Welding floorings
Heat-shrinking
+ + + ( 1 )
Desoldering components from circuit boards
Shaping plastics
Stripping oil-based paints / removing sheeting, films and foils
Woodworking, edgebanding, redecorating work
Refurbishment work, removing tiles
Packaging / shrink-wrapping
Drying and heating
Overlap welding
HG 2620 E
( 1 )
16
Using HG Scan PRO
17
Pistol Grip Hot Air Tool:
Pulling out all the stops at work.
Absolute precision is essential when working with a heat tool. It should fit perfectly in your
hand and let you work without tiring. This is why we have focused on ergonomics when
developing our pistol-type hot air tools. Long life, exact temperature settings, and ease of
operation with just one hand are part of the standard repertoire at STEINEL.
Professional Electrician
“Precision is important in my line
of work, so I need a heat gun that
provides control and accuracy,
so I chose STEINEL.”
18
19
1300 °F
700 °C
max.
10,000 h
13 cfm
More power. More heat. More life time with brushless motor
Hot air tool HG 2520 E
STEINEL's strongest pistol grip hot air tool is equipped with a powerful and extremely durable brushless
motor that produces hot air up to 3,000 Pa with absolute precision. The temperature can be varied by
toggle with one hand in 10 °F steps and read from the clear LCD information display at any time. It's just
as easy to adjust the airflow rate between 2 - 13 cfm and select any of the four individually tailored programs.
Weight in at a mere 1.85 lbs, this professional hot air tool is perfect for construction site use and uses
professional standard nozzles.
Welding plastic in tank and apparatus construction.
Single-hand
operation by
toggle
LCD information
display always
in view
Residual heat
indicator
Plug-in heating
element
Non-slip
standing
surface
Built in hanger
Replaceable
power cord
Power: 1750 W
Amps: 14.8 A
Temperature: 120 - 1300 °F ( 50 - 700 °C )
Motor: brushless
in 10 °F steps by toggle
Thermal cutout: yes
Dimensions ( l × w × h ): 11.20" × 3.80" × 8.20"
Ordering details
110025599 ( HG 2520 E in a Case ), 5.15 lbs ( 82.44 oz )
Accessories
110033594 HG Scan PRO for HG 2520 E
HG Scan
optional
Fits all 1.26"
diameter Industry
Standard Nozzles
DOUBLE INSULATED
HEAT GUN
41HP
21
Absolute precision. From the word go.
Temperature scanner HG Scan PRO for HG 2520 E
Precise, reliable, intelligent: the HG Scan PRO is the ideal addition to the HG 2520 E
hot air tool. Once fitted on the housing you will have complete control of current temperature
and distance from the work surface. Interactive data communication between tool and
scanner as well as audio and visual signals let you keep everything in the optimum range.
To make your work even easier.
Visual warning:
too hot = red
Visual warning:
too cold = blue
Dimensions ( l × w × h ): 3.50" × 2.20" × 3.00"
Weight: 0.19 lbs ( 2.30 oz )
Film,
sheeting,
foil
Wood
Plastic
Leather
Textiles
Ordering details
110033594 ( HG Scan PRO in a folding box ), 0.40 lbs ( 6.49 oz )
Audible
warning
Laser technology
for maintaining
perfect distance
Intelligent data
communication
Smoothing leather with the HG Scan PRO.
22
23
Digital precision.
Heat gun HG 2320 E
Cutting-edge technology for perfect results: The HG 2320 E generates an impressive 1,600 watts
of power and delivers hot air between 120 and 1,200 °F. Temperature is very easy to control via
toggle, giving you absolute precision. Together with the residual heat indicator, the LCD information display ensures additional certainty while the four individually selectable and customizable
programs provide maximum flexibility. At the same time, all tool settings can be locked using the
LOC function to rule out any accidental changes. In conjunction with the various push-on nozzles
from the range of accessories, the HG 2320 E is an excellent choice for working on heat-sensitive
objects. The heat gun is also available in an ESD version for use in electrostatically sensitive areas.
ESD Version
Shrinking cable sleeves in distribution cabinet
24
Two-stage
airflow
Temperature
easy to set with
toggle
LCD display and
programs
Residual heat
indicator
Replaceable
power cord
Optimised
weight balance
Rubber stand
Built in hanger
Power: 1600 W
Amps: 13.5 A
Temperature: 120 - 1200 °F ( 50 - 650 °C )
Airflow rate stage 1: 4-7 ( +/- 0.5 cfm )
stage 2: 8-13 cfm ( +/- 0.5 cfm )
in 10° F steps by toggle
Thermal cutout: yes
Thermostat: yes
Dimensions ( l × w × h ): 10.00" × 3.40" × 7.90"
Weight: 1.66 lbs ( 26.63 oz )
Ordering details
110025598 ( HG 2320 E in a folding box ), 2.60 lbs ( 41.66 oz )
110025697 ( HG 2320 ESD in a folding box ), 2.60 lbs ( 41.66 oz )
Kits see on page 38/39
Accessories
110048403 HL Scan
110028647 fine dust filter
110047650 HL Light
HL Scan
optional
Fits all 1.34"
diameter Industry
Standard Nozzles
HL Light
optional
Fine dust filter
optional
DOUBLE INSULATED
HEAT GUN
41HP
25
Conquers any challenge.
Heat gun HL 2020 E
Experts prefer the sturdy HL 2020 E heat gun. The electronically controlled heat tool delivering
1,600 watts of power is easily operated via toggle, regulates temperature between 120 to
1,150 °F and provides convenient handling with its LCD display. The residual heat indicator
warns the user that the outlet nozzle is still hot. The precision adjustable heat and powerful
blower make the HL 2020 E the ideal choice for virtually any application – heat shrinking
tubes and sleeves onto cables, welding and many other challenging jobs.
Desoldering components from circuit boards with pinpoint accuracy.
26
Three-stage
airflow
Temperature
easy to set with
toggle
LCD display
Residual heat
indicator
Replaceable
power cord
Optimised
weight balance
Rubber
stand
Built in hanger
Power: 1600 W
Amps: 13.3 A
Temperature: 120 - 1150 °F ( 50 - 620 °C )
Airflow rate stage 1: 4 cfm ( +/- 0.5 cfm )
stage 2: 4-8 cfm ( +/- 0.5 cfm )
stage 3: 6-13 cfm ( +/- 0.5 cfm )
Thermal cutout: yes
Thermostat: yes
Weight: 1.94 lbs ( 31.04 oz )
Ordering details
110025597 ( folding box ), 2.60 lbs ( 41.66 oz ) )
Kits see on page 40/41
Accessories
110048403 HL Scan
110047650 HL Light
HL Scan
optional
Fits all 1.34"
diameter Industry
Standard Nozzles
HL Light
optional
Fine dust filter
optional
DOUBLE INSULATED
HEAT GUN
41HP
27
For challenging jobs.
Heat gun HL 1920 E
Finished to a high level of quality with optimum weight balance and long life, the HL 1920 E
heat gun is an absolute “must" for anyone attaching importance to quality. The multi-talented
tool impresses with 1,500 watts of power, infinitely variable temperature adjustment from
120 to 1,150 °F and airflow control in three stages. And if it ever gets too hot when welding
plastic or stripping paint, the automatic cut-out protects the tool from overheating.
Using heat for getting plastic into exactly the right shape.
28
Three-stage
airflow
Continuously
variable
temperature
Rubber
stand
Built in hanger
Optimised
weight balance
Power: 1500 W
Amps: 13.2 A
Airflow rate stage 1: 4 ( +/- 0.5 cfm )
stage 2: 4-8 ( +/- 0.5 cfm )
Temperature setting: in 9 steps by thumbwheel
Thermal cutout: yes
Dimensions ( l × w × h ): 10.00" × 3.30" × 7.90"
Ordering details
110025596 ( folding box ), 2.31 lbs ( 36.93 oz )
Kits see on page 42
Accessories
110048403 HL Scan
110047650 HL Light
HL Scan
optional
Fits all 1.34"
diameter Industry
Standard Nozzles
HL Light
optional
Fine dust filter
optional
DOUBLE INSULATED
HEAT GUN
41HP
29
Hot. But never too hot.
Temperature scanner HL Scan
for HG 2320 E – HL 1820 S
The right solution for every need. And for every tool. To ensure the right working tem
perature on heat-sensitive work pieces at all times, this is why we offer a solution for our
pistol grip hot air tools that is no less intelligent. For practical single-handed operation:
simply fitted to the housing of an HG 2320 E / ESD or HL 2020 E / 1920 E / 1820 S the
HL Scan provides the user with all relevant information: the precision digital display and
audio signals reliably show whether the temperature is too hot, ideal or too cold.
Visual warning:
too hot = red
Visual warning:
too cold = blue
Temperature detection range: 32 - 572 °F ( 0-300 °C )
Work area marking: by LED light beam
Optimum distance from workpiece: 5.90"
Dimensions ( l × w × h ): 5.77" × 2.00" × 1.70"
Voltage: 9 V battery
Special features: adjustable emissivity leveles and tolerance ranges
Weight: 0.36 lbs ( 5.82 oz )
Film,
sheeting,
foil
Wood
Plastic
Leather
Textiles
Ordering details
110048403 ( folding box ), 0.58 lbs ( 9.28 oz )
Audible
warning
Ideal for carwrapping.
30
TESTING EQUIPMENT
4VR8
31
Multi-purpose heat gun.
Heat gun HL 1820 S
On the HL 1820 S, the temperature not only adjusts from 120 to 750 to 1,100 °F in three
stages – the airflow does too ( 4, 7 and 13 cfm ). The optimized weight balance virtually
rules out fatigue while working. The ergonomically shaped hangle with soft inlay ensures
optimum handling and the intagrated thermal cut-out prevents over heating. The tool can
be used with all industry standard nozzles, making all sorts of different applications even
easier – for example, de-icing, drying, shaping, heat shrinking and much more.
Three-stage
airflow
Thawing frozen pipes.
32
Optimised
weight balance
Power: 1400 W
Amps: 12 A
Temperature stage 1: 120 °F ( 50 °C )
stage 2: 750 °F ( 400 °C )
stage 3: 1100 °F ( 600 °C )
stage 2: 7 cfm ( +/- 0.5 cfm )
stage 3: 13 cfm ( +/- 0.5 cfm )
Temperature setting: 3 stages
Thermal cutout: yes
Weight: 1.76 lbs ( 28.22 oz )
Ordering details
110025541 ( folding box ), 2.18 lbs ( 34.92 oz )
Kit see on page 43
Accessories
110048403 HL Scan
110047650 HL Light
HL Scan
optional
Fits all 1.34"
diameter Industry
Standard Nozzles
HL Light
optional
Fine dust filter
optional
DOUBLE INSULATED
HEAT GUN
41HP
33
Entry level, big advantages.
Heat gun HL 1620 S
Drying plaster work, heat shrinking tubes and sleeves onto cables, thawing frozen water
or stripping paint – the HL 1620 S makes light work of any job, with it’s weight of just
1.48 pounds. Adjustable in two stages of heat and airflow ( 575 or 950˚F, 8 or 13 cfm )
the HG 1620 S comes with an optimized weight balance for fatigue free working as well
as integrated thermal cut-out.
Two-stage
airflow
Optimised
weight balance
Power: 1300 W
Amps: 10.9 A
Temperature stage 1: 575 °F ( 300 °C )
stage 2: 950 °F ( 500 °C )
Airflow rate stage 1: 8 cfm ( +/- 0.5 cfm )
stage 2: 13 cfm ( +/- 0.5 cfm )
Heating element: micanite heating element
Thermal cutout: yes
Weight: 1.48 lbs ( 23.63 oz )
Fits all 1.34"
diameter Industry
Standard Nozzles
Ordering details
110023455 ( folding box ), 2.06 lbs ( 32.98 oz )
Accessories
Stickers are easy to remove with hot air.
34
DOUBLE INSULATED
HEAT GUN
41HP
35
For car mechanics and auto body.
What once had to be repaired or completely replaced at great expense and painstaking
effort can now be returned to perfect shape. Hot air provides the key. STEINEL has the
right technology with high-quality tools that fit perfectly in your hand. Engineered to meet
all the needs of automotive an auto body mechanics. STEINEL provides the right accessory
for a one stop shop for precision results every time.
Car Mechanic
“STEINEL offers a full line of precision
tools which end up in quality work.”
36
37
HG 2320 E Kits.
Auto Body Welding Kit
with Temp Scanner
Deluxe Plastic Welding Kit
with Temp Scanner
Electronics Kit
Multi Purpose Kit
HG 2320 E Heat Tool
HL Scan
Welding Iron
Reduction Nozzle 9mm
Reduction Nozzle 20mm
2 pcs Wire Mesh
16 pcs ThermoFlexx Welding Rod
Temperature Guard
Auto Body Repair Guide
Auto Body Welding DVD
Catalog
Heavy Duty Carrying Case
HG 2320 E Heat Tool
Welding Iron
2 pcs Wire Mesh
Temperature Guard
Catalog
HG 2320 E Heat Tool
HL Scan
TS 600 Soldering Iron
TS 600 Welding Iron
Welding Iron
2 pcs Wire Mesh
Temperature Guard
Deluxe Auto Body Repair Guide
Catalog
HG 2320 E Heat Tool
Welding Iron
2 pcs Wire Mesh
Temperature Guard
Catalog
HG 2320 E Heat Tool
Reflector Nozzle 9mm
Reflector Nozzle 14mm
Reflector Nozzle 39mm
Catalog
HG 2320 E Heat Tool
Welding Nozzle
Plastic Welding Rod Assortment
Plastic Welding Booklet
Catalog
Ordering details
110051530
Ordering details
110051531
Ordering details
110051536
Ordering details
110051533
Ordering details
110051534
Ordering details
110051535
38
39
HL 2020 E Kits
Automotive Kit
with Temp Scanner
Automotive Kit
Plastic Welding Kit
Silver Kit
Platinum Kit
Multi Purpose Kit
HL 2020 E Heat Tool
HL Scan
Window Nozzle 75mm
Welding Nozzle
PP Plastic Welding Rods
Catalog
HL 2020 E Heat Tool
Window Nozzle 75mm
Welding Nozzle
Catalog
HL 2020 E Heat Tool
Welding Nozzle
Lap Welding Slit Nozzle 20mm
2 pcs Wire Mesh
Catalog
HL 2020 E Heat Tool
Spreader Nozzle 75mm
Welding Nozzle
Shrink Tubes
Catalog
Silver Case
HL 2020 E Heat Tool
Shrink Tubes
Catalog
Silver Case
HL 2020 E Heat Tool
Welding Nozzle
Catalog
Ordering details
110051550
40
Ordering details
110051537
Ordering details
110051538
Ordering details
110051541
Ordering details
110051542
Ordering details
110051539
41
HL 1920 E Kits
HL 1820 S
Industrial Kit
Platinum Kit
Classic Kit
Multi Purpose Kit
General Purpose Kit
HL 1920 E Heat Tool
Catalog
HL 1920 E Heat Tool
Shrink Tubes
Catalog
Silver Case
HL 1920 E Heat Tool
Catalog
Silver Case
HL 1820 S Heat Tool
Window Nozzle 75mm
Catalog
Ordering details
110051543
Ordering details
110051545
HL 1920 E Heat Tool
Welding Nozzle
Catalog
Ordering details
110051546
Ordering details
110051547
Ordering details
110051544
42
43
Making easy work of soldering, de-soldering,
heat-shrinking.
Heat gun HG 350 ESD
The high-tech HG 350 ESD heat gun impresses with maximum precision and optimized
ergonomics. The temperature can reach 750 °F as well as 930 °F when using a reduction
nozzle. A temperature indicator shows whether the outlet tube is too hot to touch, this tool
also comes with an integrated LED light that always provides optimum illumination and perfect visibility. The tool is also ESD-safe, also making it suitable for use in electrostatically
sensitive areas. This tool is compact and includes a lightweight design.
Integrated LED
work light
Optimised
weight balance
Ergonomically
shaped softgrip handle
Power: 300 W
Amps: 2.5 A
Temperature: 750 - 930 °F ( 400-500 °C )
Airflow rate: 3.5 cfm
Nozzle Diameter: 0.75" ( 19 mm )
Dimensions ( l × w × h ): 9.00" × 11.50" × 3.00"
Weight: 1.50 lbs ( 24.00 oz )
Ordering details
109964900 ( folding box ), 2.05 lbs ( 32.80 oz )
110049739 ( Precision Heat Gun Kit ), silver case, including Reduction Nozzle
7 mm, Reducer with Guard 5 mm, Reflector Nozzle 10 mm, Precision Reflector
Nozzle, Reflector Nozzle 40 mm, Solder Dispenser, Shrink Tube Assortment
Off / cold / hot
Ideal for desoldering
44
Built in hanger
Accessories
Push-on nozzles on page 52
HEAT GUN
41HP
45
More is better.
Heat blower HB 1750
Maximum power for perfect results: The HB 1750 delivers almost 30 percent more air
than conventional heat blowers. This makes particularly fast and efficient work of any job –
whether drying paint, shaping plastic, heating shrink film or heat shrinking tubes and
sleeves onto cables. Five interchangeable color coded keys can be used for selecting the
perfect temperature for any job from 100 to 1,200 °F. Comes complete with an adjustable
support stand, this extremely quiet tool is suitable for stationary use. The support stand
also provides a practical place to keep the color coded keys that are not being used.
The soft grip handle guarantees maximum comfort even after long periods of use.
Adju
stab
90°
le
Adjustable
Stand
Simple change
of temperature
keys
Drying plasterwork faster with hot air.
46
Baffle Adjusts
Air and Temperature within
Range
Cool Air Stage
Quick and easy
field changeable
element
Power: 1750 W
Amps: 14.6 A
Temperature: 200° - 1200 °F ( 95° - 650 °C ) all 5 keys
Airflow rate: up to 23 cfm, adjustable with baffle
Nozzle Diameter: 1.70" ( 43.50 mm )
Dimensions ( l × w × h ): 10.80" × 5.80" × 9.50"
Weight: 2.90 lbs ( 46.40 oz )
Ordering details
109486800 HB 1750 with all 5 keys ( folding box ), 3.60 lbs ( 57.60 oz )
110049973 HB 1750 with blue key ( folding box )
110049974 HB 1750 with gray key ( folding box )
110049975 HB 1750 with yellow key ( folding box )
110049976 HB 1750 with orange key ( folding box )
110049977 HB 1750 with red key ( folding box )
110049745 HB 1750 Kit ( case, including Quick Lock Stand,
5 Temperature Keys, Large Reflector, Spare Element )
Accessories
on page 53
HB 1750
200 - 1200 °F ( 95 - 650 °C )
HB 1750 B
200 - 300 °F ( 95 - 150 °C )
HB 1750 G
300 - 500 °F ( 150 - 260 °C )
HB 1750 Y
500 - 750 °F ( 260 - 400 °C )
HB 1750 O
750 - 1000 °F ( 400 - 540 °C )
HB 1750 R
1000 - 1200 °F ( 540 - 650 °C )
DOUBLE INSULATED
HEAT GUN
41HP
47
Professional down to every last detail.
HG 2520 E
Welding water tank
HG 2320 E
STEINEL has the right pistol grip hot air tool for every need, whichever
you choose: its only really complete with the right accessories.
This is where we can give you a virtually unlimited range of options.
HG 2520 E
HG 2320 E/ESD
HL 2020 E
HL 1920 E
HL1820S
HL 1620 S
Window tinting
+++( 2 )
+++( 3 )
+++( 3 )
+( 1,3 )
+++( 2 )
+++( 3 )
+++( 3 )
++( 3 )
Welding floorings
Heat Shrink Tubing / Solder Sleeves
Drying and heating
Desoldering and Soldering components from circuit boards
Shaping plastics / Prosthetics
Heat atcivated Adhesives ( with HG Scan Pro )
Composites
Inflatable Repair
Medical / Clean Room Applications
Vehicle wrapping, wrapping facades
Welding plastics in tank and apparatus construction,
Smoothing & Repairing leather / Vinyl ( with HG Scan PRO )
( 1 )
HG 350 ESD
HB 1750
Version with 7.5 m mains power cord, ( 2 ) using HG Scan PRO, ( 3 ) using HL Scan
48
49
Accessories for HG 2620 E, HG 2520 E
Welding floorings or spot heating
For welding roof membranes,- sheetings and -tarpaulins
Speed Welding Nozzle
3 mm
4 mm
5 mm
Flat Angled Nozzle
20x2 mm
Flat Angled Nozzle
20x2 mm, straight
Flat Angled Nozzle
20x2 mm, 100°
Flat Angled Nozzle
30x2 mm, 60°
110038331
110038332
110038333
110049713
110037580
106934900
110039176
( Pushes onto round nozzle 5mm )
Speed Welding Nozzle,
3 mm, with narrow air slot
4 mm, with narrow air slot
5 mm, with narrow air slot
110038676
110039076
110039166
Flat Nozzle
40x2 mm perforated
Flat Nozzle
60x2 mm for bitumen
Fillet Weld Feeder
Flat Angled Nozzle
40x2 mm
Tarpaulin Scissors
110038728
110039165
110049712
110038670
110038674
Round Nozzle
5 mm
Round Nozzle,
extended 5 mm
Round Nozzle
10 mm
Quarter Moon Knife
Weld Slide
110014089
110049703
Pressure Roller Ø 45 mm
Pressure Roller Ø 35 mm
Pressure Roller Ø 50 mm
Pressure Roller Ø 33 mm
110048652
110038668
110048653
110049584
110031646
110038455
110048203
( with ball bearing, single arm,
silicone roller )
silicone roller )
rubber roller )
teflon roller )
Heat-shrinking sleeves on cables, joints and mouldings
Jointing Plane, including
replacement blade
Scriber
110049706
110038478
Diamond Sharpener
110049705
50
Pressure Roller Ø 30 mm
Brass roller
110048202
ABS Plastic Welding
Rods 16 pcs
PP Plastic Welding
Rods 16 pcs
HDPE Plastic Welding
Rods 16 pcs
PVC Plastic Welding
Rods 16 pcs
110048756
110048757
110048753
110048754
Soldering Reflector Nozzle
Reflector Nozzle 20mm
Reflector Nozzle 35mm
110039169
110039167
110039168
Sieve Reflector Nozzle
35x20mm
50x35mm
110038726
110038725
Shell Reflector Nozzle
150x25mm
110039170
( After use, the hot air tool must be securely placed in a holder with nozzle attached )
51
Accessories for HB 1750
Temperature scanner
Drying and heat-shrinking
Temperature Scanner
HG Scan PRO
Temperature Scanner
HG Scan PRO
110033594
110033508
( HG 2520 E )
( HG 2620 E )
Accessories for HG 5000 E
Heat-shrinking plastics
Reducer 7mm
Spreader 200mm
Large Reflector 50mm
Small Reflector 20mm
Key Set ( 5 pcs )
110049693
110049696
110049694
110049695
110050796
Blue Key
Gray Key
Yellow Key
Orange Key
Red Key
110050525
110050526
110050527
110050528
110050529
Accessories for HG 2220 E, HG 2320 E/ESD,
HL 2020 E, HL 1920 E, HL 1820 S, HL 1620 S
Removing, shaping and heat-shrinking
Flat Nozzle 70x10mm
Flat Angled Nozzle 74x3mm
110049715
110049716
85 x 85 mm
Hinged Reflector Nozzle
72 x 70 mm
250 x 45 mm
110039174
110039171
110039175
Special accessories
Heavy Duty Metal Case
Metal Heat Gun Stand
103944400
110049032
Spreader Nozzle
50 mm
Spreader Nozzle
75 mm
Window Nozzle
50 mm
Window Nozzle
75 mm
20 mm
110048643
110048644
110048750
110048749
110048649
Reduction Nozzle
20 mm
Reflector Nozzle
75 mm
Reflector Nozzle
39 mm
110048751
110048650
110048645
Accessories for HG 350 ESD
Soldering, de-soldering and spot heating
Reducer with
Guard 5 mm
Reflector Nozzle
40 mm
Reflector Nozzle
10 mm
110048651
110049699
110049698
52
Precision Reflector Nozzle
110049697
Reduction Nozzle
7 mm
110050181
53
Accessories for HG 2220 E, HG 2320 E/ESD, HL 2020 E, HL 1920 E
Soldering, spot heating and heat-shrinking
Auto Body repair accessories
Reduction Nozzle 6 mm
Set Reduction + Reflector Nozzle 9 mm
Reduction Nozzle 14 mm
110037033
110048646
110048647
Temperature Guard
Wire Mesh
Welding Iron
110049677
110049676
110049675
110050171
Reduction Nozzle
9mm
110037435
Special accessories
Pinpoint Reducer
110049668
Reflector Nozzle
14 mm
50 x 35 mm
110048752
110038724
Welding plastics, tarpaulins and sheetings
Temperature Scanner
HL Scan
HL Light
Fine Dust Filter
110047650
110028647
110048403
( HG 2320 E, HL 2020 E, HL 1920 E,
HL 1820 S )
Plastic Hanger
110045172
HL 1820 S )
Welding Nozzle
Welding Nozzle
Angle Slit Nozzle 40 mm
Wide-Slit Nozzle
110048648
110048747
110048748
102270901
( Pushes onto Reduction Nozzle 9 mm )
Hot Air Tool Stand
with Magnetic Base
HL 1820 S )
110049586
110049588
HL 1820 S, HL 1620 S )
Wire Protection Tube
110049790
110049032
110049678
( Pushes onto Reduction Nozzle 14mm )
110049584
110031646
110038455
110048203
silicone roller )
silicone roller )
rubber roller )
teflon roller )
ABS Plastic Welding
Rods 16 pcs
PP Plastic Welding
Rods 16 pcs
Rods 16 pcs
PVC Plastic Welding
Rods 16 pcs
110048756
110048757
110048753
110048754
54
Hot Air Tool Stand
with Suction Base
Tarpaulin Scissors
110038728
55
Products at a glance
Hot air tools
HG 2620 E
HG 2220 E
HG 5000 E
HG 2520 E
HG 2320 E / ESD
HL 2020 E
HL 1920 E
HL 1820 E
HL 1620 E
HG 350 ESD
HB 1750
1750 W
1500 W
3400 W
1750 W
1600 W
1600 W
1500 W
1400 W
1300 W
300 W
1750 W
120 - 1300 °F
( 50-700 °C )
120 - 1100 °F
( 50-600 °C )
80-1100 °F
( 20-600 °C )
120 - 1300 °F
( 50-700 °C )
120 - 1200 °F
( 50-650 °C )
120 - 1150 °F
( 50-620 °C )
120 - 1100 °F
( 50-600 °C )
120/750/1100 °F
( 50/400/600 °C )
575/950 °F
( 300/500 °C )
750 - 930 °F
( 400-500 °C )
200° - 1200 °F
3.5 cfm
23 cfm
Air pressure
3,000 Pa
3,000 Pa
3,000 Pa
Motor
brushless
brushless
brushless
ceramic
ceramic
ceramic
ceramic
ceramic
ceramic
ceramic
ceramic
ceramic
ceramic
Motor life
10,000 hours
20,000 hours
10,000 hours
Cool air stage
120 °F ( 50 °C )
80 °F ( 20 °C )
120 °F ( 50 °C )
120 °F ( 50 °C )
120 °F ( 50 °C )
120 °F ( 50 °C )
120 °F ( 50 °C )
Temperature setting
9-stage
9-stage
3-stage
2-stage
2-stage
5 coded keys
Airflow setting
2-stage
3-stage
3-stage
3-stage
2-stage
2-stage
1.66 lbs 26.63 oz )
Industrial Grade
Rubber
Industrial Grade
Rubber, length: 6ft
Industrial Grade
Rubber ( European Plug )
Industrial Grade
Rubber
Industrial Grade
Rubber
Industrial Grade
Rubber
Industrial Grade
Rubber, length: 6ft
Industrial Grade
Rubber, length: 6ft
Industrial Grade
Rubber, length: 6ft
Industrial Grade
Rubber, length: 6ft
Industrial Grade
Rubber, length: 6ft
Power cord replacement
Plug-in heating element
Residual heat indicator
LOC function for saving settings
Four memory programs
Restart protection
Suitable for construction site use
Thermal cut-out
Power
Temperature
Max. airflow rate
Heating element
Weight without power cord
Power cord
Overheating protection
Professional STEINEL Nozzles
Pressure Fit Standard Nozzles
56
57
Gas Torches:
Red-hot perfection.
Professionals know how important the right tool is. But we don’t just want to offer you a tool
for the job you are doing – we want to offer you the best one. This is why we are working on
making our gas torches even more powerful, efficient and convenient to use. The consistent
use of innovative technologies and high-quality materials lets us make sure that you can rely
on the portable torches from STEINEL in any situation. Whether for the odd minor repair or
for everyday use in industry
58
59
Ready for anything.
Ultimate Butane Kit.
The ultimate solution for any conceivable challenge: The kit includes no fewer than three
professional tools as well as a wide range of accessories. The cordless TT 175, TT 30 and
TS 550 gas torches reach their respective operating temperatures within a maximum of just
20 seconds and are suitable for virtually any application – from soldering or de-soldering
to working on foam and heating heat-shrinkable tubing. Providing maximum flexibility, the
kit contains a wide selection of attachments that can be changed quickly and easily. Also
included in the Ultimate Butane Kit are two gas bottles, cleaning tools and a selection of
heat-shrinkable tubes – all perfectly packed in a high-quality tool case.
Available in a convenient carrying case.
Temperature: TS 550: 480 - 1000 °F ( 250 - 550 °C ) soldering tip
2400 °F ( 1316 °C ) torch
1400 °F ( 750 °C ) flamesless heat
TH 310: Catalytic Tip 1400 °F ( 750 °C )
TT 175: 2400 °F ( 1316 °C )
TT 30: 2400 °F ( 1316 °C )
Operation Time: T
S 550: 160 min
TT 175: 120 min
TT 30: 30 min
Fuel Capacity: TS 550: 25 ml
TT 175: 60 ml refillable fuel tank
TT 30: 5 ml refillable see-trough fuel tank
Fuel Type: Standard butane fuel
Dimensions ( l × w × h ): 12.60" × 4.20" × 12.30"
Weight: 4.80 lbs ( 76.80 oz )
Heat Chemicals with the ThermaTorch™ 270
60
Ordering details
110049879 ( silver case, including TT 175 Torch, TT 30 Torch, TS 550 Soldering Iron,
TS 21 Conical Tip ( installed ), 2 - 1 oz Butane Canisters, TH 310 Flameless
Catalytic Tip, TS 20 Deflector, TS 25 Hot Knife, TS 23 Chisel, TS 27 Heat Blower,
TS 29 Spare Orifice, Hands-Free Stand, Tip Cleaning Sponge, Solder Dispenser,
Shrink Tube Assortment )
61
Top model for the most
exacting of demands.
Gas torch TT 270
Preferred choice for
hundreds of applications.
Gas torch TT 175
The ThermaTorch™ 270 keeps even the most extreme of
temperatures perfectly under control: It produces a 2,500 °F
flame that burns steadily and evenly all the time. The flame
intensity can be infinitely varied. Featuring a refillable tank
holding 60 milliliters of butane gas, the TT 270 can be
operated continuously for up to 120 minutes. This makes
it the ideal tool for challenging jobs whenever maximum
performance is required.
From automotive repairs and plumbing jobs to industrial
use, the ThermaTorch™ 175 makes very easy work of
heating, soldering and de-soldering. The steady flame
reaches a temperature of 2,400 °F and, like the airflow rate,
can be adjusted to suit any application. In addition to
its exceptional quality finish, the tool also leaves no
margin of doubt with its 60-milliliter tank that enables
over 120 minutes of uniterrupted use.
Temperature: 2500 °F ( 1300 °C )
Operation Time: Up to 120 min ( 90 min at mid setting )
Fuel Capacity: 60 ml refillable fuel tank
Ignition: Water proof piezo electronic system
Dimensions ( l × w × h ): 6.25" × 4.70" × 2.50"
Weight: 0.64 lb ( 10.24 oz )
Solder joints on copper piping
62
Temperature: 2400 °F ( 1316 °C )
Operation Time: 120 min continuous use
Dimensions ( l × w × h ): 5.25" × 4.00" × 1.50"
Weight: 0.59 lb ( 9.44 oz )
Butane
optional
Ordering details
110049861 ( folding box )
Single Sell Pack Dimensions: 9.50" × 5.60" × 3.00"
Single Sell Pack Weight: 0.87 lb ( 13.92 oz )
Ordering details
110049860 ( folding box )
Single Sell Pack Dimensions: 7.40" × 5.50" × 1.75"
Single Sell Pack Weight: 0.78 lb ( 12.48 oz )
Accessories
110049855 BT 01 Triple filtered Butane 1 oz ( 28.4 gm )
110049856 BT 05 Triple filtered Butane 5 oz ( 142 gm )
Accessories
Butane
optional
Repair, bend and mold prosthetics
63
More ergonomics, less weight.
Gas torch TT 151
Mini-tool providing
maximum performance.
Gas torch TT 30
The ThermaTorch™ 151 weighs in at a mere 0.3 pounds but
is still packed with powerful advantages: The temperature
of the butane flame reaches 2,400 °F and can be adjusted
in any way to suit the job in hand. In addition its compact
size, the multi-purpose tool impresses with its ergonomically designed grip handle and stable standing surface. The
refillable butane gas tank holds 20 milliliters and produces
approximately 60 minutes of work with a medium flame.
Small, practical, reliable – the ThermaTorch™ 30 not only fits
into any pocket, it also does a great job even under difficult
conditions. The flame even burns in strong winds at an
adjustable temperature of up to 2,400 °F. The ignition system
is watertight. And the self-closing cap protects the tool from
soiling. This makes the TT 30 a great helper in the field –
whether for professional or personal use.
Operation Time: 60 min at mid setting
Fuel Capacity: 20 ml refillable fuel tank
Dimensions ( l × w × h ): 5.50" × 4.00" × 2.50"
Weight: 0.31 lb ( 4.96 oz )
Operation Time: 30 min
Fuel Capacity: 5 ml refillable see-through fuel tank
Dimensions ( l × w × h ): 0.88" × 0.63" × 1.50"
Weight: 0.11 lb ( 1.76 oz )
Butane
optional
Ordering details
110049857 ( blister )
Single Sell Pack Dimensions: 6.00" × 4.00" × 1.63"
Single Sell Pack Weight: 0.15 lb ( 2.40 oz )
Ordering details
Single Sell Pack Dimensions: 8.00" × 4.88" × 2.63"
Single Sell Pack Weight: 0.50 lb ( 8.00 oz )
Accessories
Accessories
Caramelize Crème Brule easily
64
Butane
optional
Thaw Frozen Locks with a wind proof flame.
65
The authority in its field.
Gas soldering iron
TS 600 / TS 600 K
One tool – countless options.
Gas soldering iron
TS 550 / TS 550 K
The ThermaSolder™ 600 lets you get more done. Its tank has
a capacity of 38 milliliters, providing an amazing 200 minutes
of use. But these are not the only top specifications the gas
soldering iron can offer. It also produces a powerful output
of 30 to 125 watts as well as temperatures of up to 2,400 °F.
The wide range of accessories makes it ideal for countless
applications. The TS 600 K kit contains a heat blower tip that
generates flameless heat of 1,400 °F, a soldering tip that can
be heated to 1,000 °F and many other attachments for getting
virtually any job done professionally and quickly.
Prepared for anything: The powerful and quality-crafted Therma
Solder™ 550 gas soldering iron delivers a temperature of 2,400 °F –
and top results in numerous applications. The TS 550 Kit features
accessories that are ideal for soldering at up to 1,000 °F, cutting
foam, repairing jewelry and working on many other materials with
ease. The gas soldering iron can be used continuously for approximately 160 minutes on a single butane gas filling of 25 milliliters.
It generates an output of 30 to 125 watts – without any power cords to
get in the way. As with the TS 600, it features a reliable piezo igniter
and reaches its optimum operating temperature in a mere 15 seconds.
Create an even seal on solder sleeves
66
Soldering Iron Tip: 480 - 1000 °F ( 250 - 550 °C )
Torch: 2400 °F ( 1316 °C )
Flameless Heat: 1400 °F ( 750 °C with available
hot air blower tip )
Operation Time: 200 min
Fuel Capacity: 38 ml refillable fuel tank
Butane
optional
Ignition: Piezo electronic system with 15 sec. heat-up
Dimensions ( l × w×h ): 9.75" × 1.20" × 1.25"
Weight: 0.34 lbs ( 5.44 oz )
Kit Contents: TS 600 Soldering Iron, Heat Blower Tip, Reflector Tip,
Hot Knife Tip, Chisel Tip, Soldering Tip, Spare Orifice,
Solder with Dispenser, Tip Cleaning Sponge, Protective Cap and Case
Operation Time: 160 min
Fuel Capacity: 25 ml refillable fuel tank
Butane
optional
Dimensions ( l × w × h ): 9.00" × 1.20" × 1.22"
Weight: 0.20 lb ( 3.20 oz )
Kit Contents: TS 550 Soldering Iron, Heat Blower Tip, Reflector Tip,
Ordering details
TS 600: 110049875 ( blister )
TS 600 K: 110049876 ( case )
Single Sell Pack Dimensions: TS 600 12.00" × 4.00" × 1.25"
TS 600 K 12.00" × 6.60" × 2.00"
Single Sell Pack Weight: TS 600 0.50 lb ( 8.00 oz )
TS 600 K 1.47 lbs ( 23.52 oz )
Ordering details
TS 550: 110049873 ( blister )
TS 550 K: 110049874 ( case )
Single Sell Pack Dimensions: TS 550 12.00" × 4.00" × 1.35"
TS 550 K 13.50" × 5.70" × 2.10"
Single Sell Pack Weight: TS 550 0.35 lb ( 5.60 oz )
TS 550 K 1.41 lbs ( 22.56 oz )
Accessories
Jewelry repair and fine detailed work
Accessories
67
A whole raft of benefits.
Gas soldering iron
TS 500 and TS 500 K
STEINEL quality to take with you.
Gas torch TH 310
Heat up for 20 seconds – work for 120 minutes: The cordless
ThermaSolder™ 500 has a 20-milliliter butane tank that enables
uninterrupted use of the gas soldering iron even over prolonged
periods. The gas soldering iron flame reaches a temperature
of 2,400 °F while producing an output of 25 to 80 watts.
The medium-sized TS 500 K contains the most important extras
for professional soldering or de-soldering, for modeling plastics,
cutting foam, fitting plug connectors and more. As with the
TS 600 K and TS 550 K, all parts come in a practical case that
ensures space-saving and safe storage.
Whether in the workshop or in the field, the portable highperformance ThermaHeat™ 310 gas torch is always handy
and reaches an operating temperature of 1,400 °F in just
15 seconds. It generates flameless heat that can be used
for all manner of applications. The TH 310 comes with a
convenient piezo igniter and a butane gas tank with a
capacity of 38 milliliters, and can be operated for a full
120 minutes on a single tank. It also comes with an attach
able deflector for working with heat-shrinkable tubing.
Including deflector
Soldering Iron Tip: 410 - 850 °F ( 210 - 450 °C )
Butane
optional
Ignition: Manual ignition
Dimensions ( l × w × h ): 8.50" × 1.00" × 1.00"
Weight: 0.14 lb ( 2.24 oz )
Kit Contents: TS 500 Soldering Iron, Heat Blower Tip, Reflector Tip,
Hot Knife Tip, Blow Torch Tip, Soldering Tip, Tip Cleaning Sponge,
Flameless Heat: 1400 °F ( 750 °C )
Operation Time: Up to 120 min continuous use
Dimensions ( l × w × h ): 8.75" × 1.20" × 1.25"
Weight: 0.23 lb ( 3.68 oz )
Ordering details
110049877 ( blister including deflector )
Single Sell Pack Dimensions: 12.00" x 4.00" × 1.50"
Single Sell Pack Weight: 0.30 lb ( 4.80 oz )
Accessories
Ordering details
TS 500: 110049871 ( blister )
TS 500 K: 110049872 ( case )
Single Sell Pack Dimensions: TS 500 10.00" × 4.00" × 1.10"
TS 500 K 10.75" × 10.40" × 1.90"
Single Sell Pack Weight: TS 500 0.23 lb ( 3.68 oz )
TS 500 K 0.87 lbs ( 13.92 oz )
Desolder and solder circuit boards with precision
68
Accessories
Butane
optional
Work on dental products with accuracy
69
Gas Torches
TT270
TS 500
TT 270
TT 175
TT 151
TT 30
TS 600
TS 550
TS 500
TH 310
2500 °F ( 1300 °C )
2400 °F ( 1316 °C )
2400 °F ( 1316 °C )
2400 °F ( 1316 °C )
Soldering Iron Tip
480° - 1000 °F ( 250 - 550 °C )
410° - 850 °F ( 210 - 450 °C )
Torch
2400 °F ( 1316 °C )
2400 °F ( 1316 °C )
2400 °F ( 1316 °C )
Flamesless Heat
1400 °F ( 750 °C )
with availabele hot air blower tip
1400 °F ( 750 °C )
1400 °F ( 750 °C )
1400 °F ( 750 °C )
60 ml refillable
60 ml refillable
20 ml refillable
38 ml refillable
25 ml refillable
20 ml refillable
38 ml refillable
Up to 120 min
30 min
200 min
160 min
120 min
Water proof automatic
ignition system
Manual ignition
0.87" ( 22.1 mm )
0.78" ( 19.8 mm )
0.79" ( 20.0mm )
0.66" ( 16.75 mm )
0.06" ( 1.52 mm )
0.06" ( 1.52 mm )
0.06" ( 1.52 mm )
0.78" ( 19.9 mm )
0.88 × 0.63" × 1.50"
9.75" × 1.200" × 1.25"
Weight
0.59 lb ( 9.44 oz )
0.31 lb ( 4.96 oz )
0.11 lb ( 1.76 oz )
0.34 lb ( 5.44 oz )
0.20 lb ( 3.20 oz )
0.14 lb ( 2.24 oz )
0.23 lb ( 3.68 oz )
Warranty
One year limited
One year limited
One year limited
One year limited
One year limited
One year limited
One year limited
One year limited
Adjustable airflow setting
yes
Adjustable flame control
yes
yes
yes
Adjustable heat output
yes
Temperature
Fuel Capacity fuel tank
Operation Time
Fuel Type
Ignition
Nozzle Diameter / Tip Dimensions
70
71
The declaration of independence for professionals.
Hot-melt glue applicator TM 6000
Full freedom of movement rather than an annoying cable: Operating on butane gas, the
TM 6000 requires no electrical power source which means it can be used virtually anywhere. The extremely sturdy hot-melt glue applicator reaches its operating temperature in
just 3 minutes. Its fuel cells are based on innovative LEC™ technology. The cells can be
quickly changed in just a few seconds and enable continuous use for up to 100 minutes.
At the same time, the TM 6000 impresses with a fast, even flow of glue during use – and
stops the glue from flowing immediately afterwards. This reduces dripping to a minimum.
The professional tool is suitable for glue cartridges with a diameter of 1/2 inch and a melting
temperature of 320 to 464 °F.
Instant Glue
Flow Cut-Off
Sturdy Metal
Stand
LEC™ Fuel Cell
Ignition Button
Melt Temperature: 320 °F - 464 °F ( 160 °C - 240 °C )
Operating Time: 100 min
Fuel Type: standard butane fuel
Nozzle Diameter: 0.08" ( 2 mm )
Dimensions ( l × w × h ): 9.00" × 7.50" × 2.00"
Weight: 0.75 lbs ( 12.00 oz )
Ordering details
110049878 ( blister ), 1.30 lbs ( 43.52 oz )
Single Sell Pack Dimensions: 12.50" × 12.50" × 2.20"
Single Sell Pack Weight: 1.30 lbs ( 43.52 oz )
Accessories
Glue sticks with 1/2" diameter on page 76
Glue packaging with ease and efficiency.
72
73
Combines simplicity and high-tech.
Hot-melt glue applicator GF 3002
Designed for making gluing work even easier: The GlueFix™ 3002 weighs just 0.7 pounds,
impresses with intuitive operation and enables fatigue-free working over long periods. It produces a constant, precision flow of glue which is instantly interrupted by the anti-drip nozzle
after use. Made of die-cast aluminum, the heating chamber stores heat to optimize throughput. At the same time, the unique PTC ( positive temperature control ) electronic heating
system constantly ensures the ideal gluing temperature – throughout the entire period of
use. Given its exceptional level of performance, the GF 3002 is appreciated both in industry
as well as in the trades where it is used for bonding all kinds of materials.
Ready for use in
7 min
Interchangeable
gluing nozzles
Melt Temperature: 400 °F ( 204 °C )
Melting Capacity: High 7.5 gm / minute
Warm Up Time: Quick 7 minutes
Nozzle Diameter: 0.08" ( 2mm )
Dimensions ( l × w × h ): 8.00" × 7.00" × 1.85"
Weight: 0.71 lb ( 11.36 oz )
Ordering details
110049902 ( folding box )
Single Sell Pack Dimensions: 10.25" × 6.75" × 1.75"
Single Sell Pack Weight: 1.10 lbs ( 17.60 oz )
Accessories
Interchangeable nozzles and glue sticks: 1/2" diameter on page 76
Glue woodwork with precision
74
75
Better gluing results with the right glue.
The right stick for any demand.
1/2" dia. glue sticks for TM 6000 and GF 3002
Interchangeable nozzles for GF 3002
G 200 C - Clear Glue Sticks
GF 14 - Carton Glue Sticks
GF 23 - Wood Glue Sticks
110049649, 1 lb
110049794, 1 kg
110049643, 1 lb
110049644, 11 lbs
110049637, 1 lb
110049638, 11 lbs
Nozzle 2 mm
Ideal for all normal gluing jobs
110049583
GF 213 - Laminate Glue Sticks
GF 232 - General Purpose Glue Sticks
GF 260 - High Strength Glue Sticks
110049640, 1 lb
110049641, 11 lbs
110049634, 1 lb
110049635, 11 lbs
110049646, 1 lb
110049647, 11 lbs
2.8 mm Fine Tip Nozzle
Precision metering at
hard-to-reach places
1 mm Nozzle
Exact metering for high-precision
gluing applications
110049582
110019581
12 mm Spreader Nozzle
Wide nozzle for carton sealing
110049580
Application Glue Guide
Open TIme
ABS
PP / PC /
HDPE / LDPE
Polystyrene
PVC
Glass Reinforced
Plastic
Aluminum Stainless
Steel
EPS Foam
Wood
Sand Mold
Glass
Cardboard
Medium
GF 14 Carton
Fast
GF 23 Wood
Long
GF 213 Laminate
Long
HG 260 Hi Strength
Long
GF 232 General
+ Poor
76
++ Fair
+++ Good
++++ Very Good
77
Summary of order numbers
Precision Hot Air Tool
Heat gun HG 350 ESD........................................................... 109964900 ( folding box )........................................................ 45
Heat gun HG 350 ESD .......................................................... 110049739 ( Precision Heat Gun Kit )....................................... 45
Professional Heat Blower
HG 2620 E............................................................................. 110025600 ( folding box )........................................................... 9
HG 2620 E............................................................................. 110047485 ( case )..................................................................... 9
Temperature scanner HG Scan PRO for HG 2620 E.............. 110033508 ( folding box )......................................................... 11
HG 2220 E............................................................................. 110025601 ( folding box )......................................................... 13
HG 5000 E............................................................................. 104201504 ( folding box )......................................................... 15
HG 5000 E............................................................................. 110049782 ( case )................................................................... 15
Heat blower HB 1750............................................................. 109486800 HB 1750 with all 5 keys ( folding box )................... 47
Heat blower HB 1750 ............................................................ 110049973 HB 1750 with blue key ( folding box )..................... 47
Heat blower HB 1750 ............................................................ 110049974 HB 1750 with gray key ( folding box )..................... 47
Heat blower HB 1750 ............................................................ 110049975 HB 1750 with yellow key ( folding box ).................. 47
Heat blower HB 1750 ............................................................ 110049976 HB 1750 with orange key ( folding box )................. 47
Heat blower HB 1750 ............................................................ 110049977 HB 1750 with red key ( folding box )....................... 47
Heat blower HB 1750 ............................................................ 110049745 HB 1750 Kit ( case )............................................... 47
Hot Air Tool Accessories
HG 2520 E............................................................................. 110025599 ( case )................................................................... 21
Temperature scanner HG Scan PRO for HG 2520 E.............. 110033594 ( folding box )......................................................... 23
HG 2320 E............................................................................. 110025598 ( folding box )......................................................... 25
HG 2320 E ESD..................................................................... 110025697 ( folding box )......................................................... 25
HL 2020 E.............................................................................. 110025597 ( folding box )......................................................... 27
HL 1920 E.............................................................................. 110025596 ( folding box )......................................................... 29
Temperature scanner HL Scan for HG 2320 E – HL 1820 S... 110048403 ( folding box )......................................................... 31
HL 1820 S.............................................................................. 110025541 ( folding box )......................................................... 33
HL 1620 S.............................................................................. 110023455 ( folding box )......................................................... 35
Speed Welding Nozzle 3 mm.................................................. 110038331.............................................................................. 50
Speed Welding Nozzle 4 mm.................................................. 110038332............................................................................. 50
Speed Welding Nozzle 5 mm.................................................. 110038333............................................................................. 50
Speed Welding Nozzle, 3 mm, with narrow air slot................. 110038676.............................................................................. 50
Speed Welding Nozzle, 4 mm, with narrow air slot................. 110039076.............................................................................. 50
Speed Welding Nozzle, 5 mm, with narrow air slot................. 110039166.............................................................................. 50
Round Nozzle 5 mm............................................................... 110048652.............................................................................. 50
Round Nozzle, extended 5mm............................................... 110038668............................................................................. 50
Round Nozzle 10 mm............................................................. 110048653............................................................................. 50
Quarter Moon Knife ............................................................... 110014089.............................................................................. 50
Weld Slide ............................................................................. 110049703.............................................................................. 50
Jointing Plane, including replacement blade........................... 110038478.............................................................................. 50
Scriber................................................................................... 110049706.............................................................................. 50
Pressure Roller Ø 30 mm Brass roller..................................... 110048202.............................................................................. 50
Diamond Sharpener............................................................... 110049705.............................................................................. 50
ABS Plastic Welding Rods 16 pcs.......................................... 110048756.............................................................................. 50
PP Plastic Welding Rods 16 pcs............................................ 110048757.............................................................................. 50
HDPE Plastic Welding Rods 16 pcs........................................ 110048753.............................................................................. 50
PVC Plastic Welding Rods 16 pcs.......................................... 110048754.............................................................................. 50
Flat Angled Nozzle 20x2 mm.................................................. 110049713.............................................................................. 51
Flat Angled Nozzle 20x2 mm, straight.................................... 110037580.............................................................................. 51
Flat Angled Nozzle 20x2 mm, 100°........................................ 106934900............................................................................. 51
Flat Angled Nozzle 30x2 mm, 60°.......................................... 110039176.............................................................................. 51
Flat Angled Nozzle 40x2 mm ................................................. 110049712 ............................................................................. 51
Flat Nozzle 40x2 mm perforated............................................ 110038670.............................................................................. 51
Flat Nozzle 60x2 mm for bitumen........................................... 110038674.............................................................................. 51
Tarpaulin Scissors ................................................................. 110038728.............................................................................. 51
Fillet Weld Feeder .................................................................. 110039165.............................................................................. 51
Hot Air Tool Specials
HG 2320 E Auto Body Welding Kit with Temp Scanner.......... 110051530.............................................................................. 38
HG 2320 E Auto Body Welding Kit......................................... 110051531.............................................................................. 38
HG 2320 E Deluxe Plastic Welding Kit with Temp Scanner.... 110051535.............................................................................. 38
HG 2320 E Deluxe Plastic Welding Kit.................................... 110051536.............................................................................. 39
HG 2320 E Electronics Kit...................................................... 110051533.............................................................................. 39
HG 2320 E Multi Purpose Kit.................................................. 110051534.............................................................................. 39
HL 2020 E Automotive Kit with Temp Scanner ...................... 110051550.............................................................................. 40
HL 2020 E Automotive Kit ..................................................... 110051537.............................................................................. 40
HL 2020 E Plastic Welding Kit ............................................... 110051538.............................................................................. 40
HL 2020 E Silver Kit............................................................... 110051541.............................................................................. 41
HL 2020 E Platinum Kit ......................................................... 110051542.............................................................................. 41
HL 2020 E Multi Purpose Kit ................................................. 110051539.............................................................................. 41
HL 1920 E Industrial Kit.......................................................... 110051543.............................................................................. 42
HL 1920 E Platinum Kit.......................................................... 110051545.............................................................................. 42
HL 1920 E Classic Kit ............................................................ 110051546.............................................................................. 42
HL 1920 E Multi Purpose Kit ................................................ 110051544.............................................................................. 43
HL 1820 S General Pupose Kit............................................... 110051547.............................................................................. 43
78
79
Pressure Roller Ø 45 mm....................................................... 110049584............................................................................. 51
Pressure Roller Ø 35 mm....................................................... 110031646.............................................................................. 51
Pressure Roller Ø 50 mm....................................................... 110038455............................................................................. 51
Pressure Roller Ø 33 mm....................................................... 110048203.............................................................................. 51
Soldering Reflector Nozzle..................................................... 110039169.............................................................................. 51
Reflector Nozzle 20mm.......................................................... 110039167.............................................................................. 51
Reflector Nozzle 35mm.......................................................... 110039168.............................................................................. 51
Sieve Reflector Nozzle 35x20mm........................................... 110038726.............................................................................. 51
Sieve Reflector Nozzle 50x35mm........................................... 110038725.............................................................................. 51
Shell Reflector Nozzle 150x25mm.......................................... 110039170.............................................................................. 51
Temperature Scanner HG Scan PRO for HG 2520 E.............. 110033594............................................................................. 52
Temperature Scanner HG Scan PRO for HG 2620 E.............. 110033508............................................................................. 52
Flat Nozzle 70x10mm............................................................. 110049715.............................................................................. 52
Flat Angled Nozzle 74x3mm................................................... 110049716.............................................................................. 52
Sieve Reflector Nozzle 85x85mm........................................... 110039174.............................................................................. 52
Hinged Reflector Nozzle 72x70mm........................................ 110039171.............................................................................. 52
Shell Reflector Nozzle 250x45mm.......................................... 110039175.............................................................................. 52
Heavy Duty Metal Case.......................................................... 103944400............................................................................. 52
Metal Heat Gun Stand ........................................................... 110049032............................................................................. 52
Reducer with Guard 5mm...................................................... 110048651.............................................................................. 52
Reflector Nozzle 40mm.......................................................... 110049699............................................................................. 52
Reflector Nozzle 10mm.......................................................... 110049698............................................................................. 52
Precision Reflector Nozzle...................................................... 110049697.............................................................................. 52
Reduction Nozzle 7mm.......................................................... 110050181.............................................................................. 52
Reducer 7mm........................................................................ 110049693............................................................................. 53
Spreader 200mm................................................................... 110049696............................................................................. 53
Large Reflector 50mm............................................................ 110049694............................................................................. 53
Small Reflector 20mm............................................................ 110049695............................................................................. 53
Key Set ( 5 pcs )...................................................................... 110050796.............................................................................. 53
Blue Key 200 - 300 °F ( 95 - 150 °C )......................................... 110050525.............................................................................. 53
Gray Key 300 - 500 °F ( 150 - 260 °C )....................................... 110050526.............................................................................. 53
Yellow Key 500 - 750 °F ( 260 - 400 °C ).................................... 110050527.............................................................................. 53
Orange Key 750 - 1000 °F ( 400 - 540 °C )................................ 110050528.............................................................................. 53
Red Key 1000 - 1200 °F ( 540 - 650 °C ).................................... 110050529.............................................................................. 53
80
Accessories for HG 2220 E, HG 2320 E/ESD, HL 2020 E, HL 1920 E, HL 1820 S, HL 1620 S
Spreader Nozzle 50mm......................................................... 110048643............................................................................. 53
Spreader Nozzle 75mm.......................................................... 110048644............................................................................. 53
Window Nozzle 50mm........................................................... 110048750.............................................................................. 53
Window Nozzle 75mm........................................................... 110048749.............................................................................. 53
Lap Welding Slit Nozzle 20mm............................................... 110048649............................................................................. 53
Reduction Nozzle 20mm........................................................ 110048751.............................................................................. 53
Reflector Nozzle 75mm.......................................................... 110048650............................................................................. 53
Reflector Nozzle 39mm.......................................................... 110048645............................................................................. 53
Reduction Nozzle 6mm.......................................................... 110037033.............................................................................. 54
Set Reduction + Reflector Nozzle 9mm ................................. 110048646............................................................................. 54
Reduction Nozzle 14mm........................................................ 110048647.............................................................................. 54
Pinpoint Reducer................................................................... 110049668............................................................................. 54
Reflector Nozzle 14mm.......................................................... 110048752.............................................................................. 54
Sieve Reflector Nozzle 50x35mm........................................... 110038724.............................................................................. 54
Welding Nozzle ..................................................................... 110048648............................................................................. 54
Welding Nozzle...................................................................... 110048747.............................................................................. 54
Angle Slit Nozzle 40 mm........................................................ 110048748.............................................................................. 54
Wide-Slit Nozzle..................................................................... 102270901............................................................................. 54
Pressure Roller Ø 45 mm....................................................... 110049584............................................................................. 54
Pressure Roller Ø 35 mm....................................................... 110031646.............................................................................. 54
Pressure Roller Ø 50 mm....................................................... 110038455............................................................................. 54
Pressure Roller Ø 33 mm....................................................... 110048203.............................................................................. 54
ABS Plastic Welding Rods 16 pcs.......................................... 110048756.............................................................................. 54
PP Plastic Welding Rods 16 pcs............................................ 110048757.............................................................................. 54
HDPE Plastic Welding Rods 16 pcs........................................ 110048753.............................................................................. 54
PVC Plastic Welding Rods 16 pcs.......................................... 110048754.............................................................................. 54
Tarpaulin Scissors.................................................................. 110038728.............................................................................. 54
Temperature Guard................................................................ 110049677.............................................................................. 55
Wire Mesh.............................................................................. 110049676.............................................................................. 55
ThermoFlexx Welding Rod..................................................... 110049675.............................................................................. 55
Welding Iron .......................................................................... 110050171.............................................................................. 55
Reduction Nozzle 9mm ......................................................... 110037435.............................................................................. 55
Temperature Scanner HL Scan.............................................. 110048403............................................................................. 55
HL Light................................................................................. 110047650.............................................................................. 55
Fine Dust Filter....................................................................... 110028647.............................................................................. 55
Hot Air Tool Stand with Suction Base..................................... 110049586............................................................................. 55
Hot Air Tool Stand with Magnetic Base.................................. 110049588............................................................................. 55
Plastic Hanger........................................................................ 110045172.............................................................................. 55
Heavy Duty Carrying Case..................................................... 110049790.............................................................................. 55
Metal Heat Gun Stand............................................................ 110049032............................................................................. 55
Wire Protection Tube.............................................................. 110049678.............................................................................. 55
81
Gas Torches
Ultimate Butane Kit................................................................ 110049879 ( silver case ).......................................................... 61
TT 270.................................................................................... 110049861 ( folding box )......................................................... 62
TT 175 ................................................................................... 110049860 ( folding box )......................................................... 63
TT 151.................................................................................... 110049860 ( folding box )......................................................... 64
TT 30 .................................................................................... 110049857 ( blister ) ................................................................ 65
TS 600................................................................................... 110049875 ( blister )................................................................. 66
TS 600 K................................................................................ 110049876 ( case )................................................................... 66
TS 550................................................................................... 110049873 ( blister )................................................................. 67
TS 550 K................................................................................ 110049874 ( case )................................................................... 67
TS 500................................................................................... 110049871 ( blister )................................................................. 68
TS 500 K................................................................................ 110049872 ( case )................................................................... 68
TH 310................................................................................... 110049877 ( blister including deflector )................................... 69
Gas Torches Accessories
Triple filtered Butane 1 oz ( 28.4 gm )....................................... 110049855
Triple filtered Butane 5 oz ( 142 gm )........................................ 110049856
Hot-Melt Adhesive Systems
Hot-melt glue applicator TM 6000 ......................................... 110049878 ( blister )................................................................. 73
Hot-melt glue applicator GF 3002 ......................................... 110049902 ( folding box ) ........................................................ 75
Hot-Melt Adhesive Systems Accessories
G 200 C - Clear Glue Sticks, 1 lb............................................ 110049649............................................................................. 76
G 200 C - Clear Glue Sticks, 1 kg........................................... 110049794.............................................................................. 76
GF 14 - Carton Glue Sticks, 1 lb.............................................. 110049643............................................................................. 76
GF 14 - Carton Glue Sticks, 11 lbs........................................... 110049644............................................................................. 76
GF 23 - Wood Glue Sticks, 1 lb............................................... 110049637.............................................................................. 76
GF 23 - Wood Glue Sticks, 11 lbs............................................ 110049638............................................................................. 76
GF 213 - Laminate Glue Sticks, 1 lb........................................ 110049640............................................................................. 76
GF 213 - Laminate Glue Sticks, 11 lbs..................................... 110049641.............................................................................. 76
GF 232 - General Purpose Glue Sticks, 1 lb............................ 110049634............................................................................. 76
GF 232 - General Purpose Glue Sticks, 11 lbs......................... 110049635............................................................................. 76
GF 260 - High Strength Glue Sticks, 1 lb................................. 110049646............................................................................. 76
GF 260 - High Strength Glue Sticks, 11 lbs ............................. 110049647.............................................................................. 76
Nozzle 2 mm.......................................................................... 110049583............................................................................. 77
2.8 mm Fine Tip Nozzle ......................................................... 110049582.............................................................................. 77
1 mm Nozzle ......................................................................... 110019581.............................................................................. 77
12 mm Spreader Nozzle ........................................................ 110049580............................................................................. 77
82
Quality and service.
STEINEL Brand
STEINEL Customer Service
• STEINEL has been brand leader in
hot air tools for over 30 years
• German engineering
• Produced in Europe
• Phone: ( 952 ) 888-5950
( 800 ) 852-4343
• Fax: ( 952 ) 888-5132
• Monday – Friday 7 a.m. – 5 p.m.
www.steinel.net
Certified Quality
All products from STEINEL comply with
European safety standards. Despite
involving a huge effort and not always
easy from a technical point of view,
we're never deterred. Because it's all
worth it. So you get certified quality –
every step of the way.
• Product overview
• Operating instructions
for downloading
• Product videos
STEINEL Replacement Parts Service
• Availability guaranteed for genuine
STEINEL parts
STEINEL Warranty
Our management system holds certification
under Quality Standard DIN EN ISO 9001
and Environmental Management Systems
Standard DIN EN ISO 14001. The warranty
for STEINEL heat tools is one year from the
date of original purchase.
83
Steinel America, Inc. | 9051 Lyndale Ave. South | Bloomington, MN 55420 | USA
Support: ( 800 ) 852-4343 | Office: ( 952 ) 888-5950 | Fax:( 952 ) 888-5132
sales@steinel.net | www.steinel.net
110051509 09/2016 6700 Subject to technical modifications
Adresse?
