IR (infrared) Detection Card 950nm - IF 850053 - Industrial Fiber Optics, Inc.
Page 1 of 1
You Are Here: Home > Tools/Test Equipment > Miscellaneous > IR (infrared) Detection Card 950nm
950nm
Credit card size indicator for viewing IR
light.
A IR detection card is a great addition to any technician's tool box
who works with fiber optic systems using infrared Another useful
addition to a technician™s toolbox is our 950 nm IR detection
card. Similar in form and function to the card described above,
this card produces a green glow when exposed to IR light in the
950 nm region.
Conversion ™ the phosphor absorbs IR light and continuously reemits it™s energy in a visible, green wavelength. No need for
charging and recharging with UV light. The phosphor™s peak
sensitivity at 950 nm makes it ideal for detecting the IR output of
consumer electronics remote controls. The card can also be used
to detect a wide range of radiometric power levels, from very low
levels (when observed in a darkened room), to the hundreds of
microwatt power levels output by IR LEDs, to tens of milliwatts of
collimated IR laser outputs. The only constraint is not
overheating the card. The temperature of the card should not
exceed 70° C for extended periods of time. When working with
high powered lasers, the green wavelength emitted by the
phosphor is ideal for use with laser safety goggles which filter the
red and IR parts of the spectrum but are permeable to green.
Part Number: IF 850053
* Spectral bandwidth (S = 10 % of SMAX) 830 - 1100 nm
Copyright 2000-11, All Rights Reserved Industrial Fiber Optics
3/31/2011
很抱歉,暂时无法提供与“IF-850053”相匹配的价格&库存,您可以联系我们找货
