18029ACU
18029ACU
    AVENTOOLS(艾文)
    TWEEZER POINTED FINE OC 3.54"
18029ACU 数据手册
Aven Inc. 4595 Platt Rd. Ann Arbor, MI 48108 Phone: 734.973.0099 Email: info@aventools.com • Web Address: www.aventools.com All Categories > Hand Tools > Tweezers and Smart Tweezers > Precision Tweezers > High Precision Tweezers > Item # 18029ACU Item # 18029ACU, Accu-Tek Pattern OC Pattern OC Flat edges, fine tips and short. Length: 3 1/2" (90mm) Stainless Steel, Anti-Magnetic, Anti-Acid larger image Specifications · Note Specifications Tip Style Straight, Fine Pattern OC Quality Grade 4 Star Length 3 1/2 in 90 mm Material SA Weight 0.04 lb Note Made from the finest steels. Perfectly balanced for a superior feel. Light weight with soft tension with accurately finished points. Recommended for work under high power magnification aerospace and micro electronics and in applications where high precision is required. All Accu-Tek precision tweezers are made from anti-acid, anti-magnetic stainless steel.
18029ACU 价格&库存
很抱歉,暂时无法提供与“18029ACU”相匹配的价格&库存,您可以联系我们找货
