IKH series
Surface mount half pitch DIP switches
• 1,27 mm (.050) terminal to terminal pitch
• Overall height from PCB : 1,6 mm (.063) only
• Very small PCB space requirement
• Process compatible - withstand IR and vapor phase reflow soldering
• Washable (tape seal standard)
IKH0404000
IKH0403000 (75)
4
6,31 (.248)
IKH0604000
IKH0603000 (54)
6
8,85 (.348)
IKH0804000
IKH0803000 (40)
8
11,39 (.448)
IKH1004000
IKH1003000 (33)
10
13,93 (.548)
0.60
PAS 1.27
(.024)
(.050) PITCH
6.70
0.40
(.264)
(.016)
A
1.27x(P-1)
(.050x(P-1))
PAS 1.27
(.050) PITCH
6.15
ON
Supplied with all poles in “ON” position.
Switches without tape seal : on request.
1 2 3 4 5 6 7 8
TAPE AND REEL PACKAGING
SPECIFICATIONS
• Max. current/voltage rating :
- switching : 25mA 24VDC
- non switching : 100mA 50VDC
• Initial contact resistance : 100 mΩ max.
• Insulation resistance : 100 MΩ min. at 500VDC
• Dielectric strength : 300 Vca min.
• Electrical life : 1.000 cycles
• Travel : 0,60 mm (.024)
• Operating temperature : -20°C to +70°C
• Storage temperature : -40°C to +85°C
Unrolling direction
12.00
(.472)
L
Tape dim. “L”
Reel dim. “A”
2
12,00 (.472)
12,40 (.488)
4
16,00 (.629)
16,40 (.646)
6
16,00 (.629)
16,40 (.646)
8
24,00 (.944)
24,40 (.960)
10
24,00 (.944)
24,40 (.960)
Ø100.00 mini
FICHIER:CIKHB
Echelle:1
(3.937 DIA MIN)
(12.992 DIA MAX)
ø330.00 Maxi
ON
1 2 3 4 5 6 7 8
Pos.
le 11/04/02
0.76
(0.30)
7.40
3,77 (.148)
(.291)
2
4.90
IKH0203000 (125)
(.193)
IKH0204000
4.50
(.177)
(.242)
Dimension “A”
(.060)
No
pos.
0.10
IC tubes (Qty)
(.004)
Tape & reel
1.50
➞ Tape
F
MATERIALS
• Case and cover : high temperature thermoplastic UL 94-V0, black
• Actuator : high temperature thermoplastic UL 94-V0, white
• Contacts : phosphor bronze, gold plated, over nickel barrier
• Terminals : tin plated
• Tape seal : polyimide
Antistatic packaging - standard packaging units
• Reels of 4.000 pieces
Tape meeting international standard IEC - Publication 286-3 (EIA481A)
• IC tubes : see above.
Ø13.00±0.25
(.511 DIA±.009)
APEM
3.00
(.118)
A
Dimensions in mm and inches.
www.apem.com
F-17
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Apem:
IKH0203000 IKH0403000 IKH0603000 IKH0803000 IKH1003000 IKH0407000 IKH0404000 IKH0604000
IKH0804000 IKH1004000
很抱歉,暂时无法提供与“IKH0603000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+15.82904
- 15+15.58327
