Top View
2.51in
(63.75mm)
O 2.08in
(52.83mm)
2.08in
(52.83mm)
Z
Y+
X-
Y-
X+
2.89in
(73.41mm)
0.20in
(5.08mm)
0.19in
(4.83mm)
5.47in
(138.94mm)
SPECIFICATIONS
ELECTRICAL
SUPPLY VOLTAGE
CENTER VOLTAGE
SUPPLY CURRENT
OUTPUT CURRENT
EFFECTIVE OUTPUT
OUTPUT TOLERANCE
MECHANICAL
OPERATING TRAVEL
CENTERING
BREAKOUT FORCE
OPERATING FORCE
MAXIMUM FORCE
OPERATING TEMP
LIFE EXPECTANCY
WIRING
RED
BLACK
BLUE
YELLOW
RoHS compliant
5.0V DC
2.5V DC
10mA max/axis
2mA max/axis
0V – 5V DC
±2%
2.58in
(65.53mm)
2.19in
(55.63mm)
0.05in
(1.27mm)
2.13in
(54.10mm)
40° (20° from center)
Single spring,
omnidirectional
0.544Nm
0.653Nm
1.306Nm
-40°C to +85°C
10 million operations
Supply voltage
Ground
X-Axis
Y-Axis
2.51in
(63.75mm)
2.01in
(51.05mm)
2.51in
(63.75mm)
Brass ultraserts 6-32 x 0.25
Screw 6-32 x 7/8 PH PAN s/s
4 places
Bottom View
Note: Actual strain relief position
may vary from specifications.
CH
Products
P/N
DESCRIPTION
MS-23N00S000
REV
A
Series III – 2 Axes, Low Profile, No Button
PROPRIETARY AND CONFIDENTIAL
THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY
OF CH PRODUCTS. ANY REPRODUCTION IN PART OR AS WHOLE WITHOUT
THE WRITTEN PERMISSION OF CH PRODUCTS IS PROHIBITED.
很抱歉,暂时无法提供与“MS-23N00S000”相匹配的价格&库存,您可以联系我们找货
