CFT2-2SC4-AW
CFT2-2SC4-AW
    NIDEC(尼得科)
    Toggle Switch DPDT Through Hole, Right Angle
CFT2-2SC4-AW 数据手册
CFT2 ■ Terminal Pins : Straight ■ Actuator Color : Gray Washable Ultra-Miniature Toggle Switch RoHS Compliant ■Features ■ Specifications 1. Ultra-miniature toggle switch for high density mounting. 2. Washable. 3. Terminal pin pitch: 2.54 mm. 4. Independent detent mechanism ensures light operational feel. 5. Clip contact mechanism for long-term contact reliability. 6. Gold-plated contacts. Rating Max. 28VDC 0.4VA max. Min. 1μ A 20mVDC Initial contact resistance Dielectric strength 250VAC 1 minute Insulation resistance 500MΩ min. Electrical life Mechanical life Operating temperature range Storage temperature range ■Part Numbering CFT2 - 1 Code Type T Toggle C4 Switching function Terminal style 1 pole Switching function Fig. Terminal style C PC Straight Number of poles Fig. Number of poles 1 1 pole E ONーOFF ー ON C4 Right angle G (ON)ーOFFー(ON) C6 Vertical mounting H ONーOFFー(ON) 0.3 0.5 2.54 C4端子形状 2.54 A W Actuator shape Code Actuator shape A Packaging spec Code Packaging spec W Standard Tray C6端子形状 3.5 0.3 2.54 ON −40℃∼+85℃ Terminal style of c4(Style:R/A Terminal) Terminal style of c6(Style:V/M Terminal) 3.2 Terminal C端子形状style of c(Style:PC Terminal) ON ー −40℃∼+85℃ - D (250VDC) 10,000 cycles at max. rating. 50,000 cycles at min. rating. (D.E.N.P type) 30,000 cycles at min. rating. (F.G.H.R.S.T type) D.E.N.P type 50,000 cycles F.G.H.R.S.T type 30,000 cycles 3 Series Actuator D (1.5mA 200μVAC) 100mΩ max. 0.5 0.3 0.5 2.54 2.54 2.54 2.54 2.54 (ON) :Momentary. CFT2 SPDT 4.5 φ4 1.6 3.8 0.5 (4) 30゚ 2.54 (1) Part No. (5) 2.54 7 Switching function Part number marking side 3.2 φ1.9 PC Straight (14) 5.4 (3) Key Way 0.5 (6) MARKING 2.54 2.54 5-φ0.6~0.8 Terminal numbers are not shown on the switch. − OFF OFF OFF ON ON (ON) (ON) Connecting terminals 5−6 − 5−4 3.8 (11.3) 5.4 1.6 − OFF OFF OFF ON ON (ON) (ON) − 5−4 Switching function Part number marking side 0.5 4.5 φ4 (4) (5) 30゚ 7 ON ON (ON) ON (Topview) PC hole Layouts φ 1.9 Right Angle Terminal (6) (6) 0.5 Key Way MARKING t=0.3 (2.45) 0.5 5.08 Terminal numbers are not shown on the switch. ※ The above PC hole layout is a view from the switch installation side. (4) 2.54 5-φ0.6~0.8 (5) 2.54 5.08 ☆:Semi-standard products. (ON) :Momentary. Part No. 2.54 3.5 3 (5) 2.54 SPDT (4) (3) 2.54 2.54 0.3 (1)  CFT2-1DC-AW  CFT2-1EC-AW ☆CFT2-1GC-AW ☆CFT2-1HC-AW (6) 0.3 (Topview) PC hole Layouts  CFT2-1DC4-AW ON ON  CFT2-1EC4-AW ☆CFT2-1GC4-AW (ON) ON ☆CFT2-1HC4-AW Connecting terminals 5−6 CFT2 SPDT Vertical mounting terminal 5.6 4.5 3.8 1.6 Switching function 5.4 Part number marking side Part No. 7 φ4 30゚ (4)  CFT2-1DC6-AW ON ON  CFT2-1EC6-AW ☆CFT2-1GC6-AW (ON) ON ☆CFT2-1HC6-AW (5) (6) Key Way (2.5) 0.5 2.54 2.54 0.5 2.54 0.3 5.08 2.54 2.54 Connecting terminals 5-φ0.8 5−6 − 4−5 0.3 φ1.9 5.08 ON ON (ON) (ON) (6) Terminal numbers are not shown on the switch. (5) (4) 2.54 3 MARKING 0.4 − OFF OFF OFF (Topview) PC hole Layouts ※ The above PC hole layout is a view from the switch installation side. ■Soldering Specifications ⑴Manual Soldering Device:Soldering iron 350℃, Max.; 3 seconds, Max. ⑵Auto Soldering Device:Jet wave type or dip type 260℃, Max.; 3 to 5 seconds (One time) Total dip time within 10 sec. ・Pre-heating should be done at temperatures ranging from 80℃ to 120℃ and within 120 sec. Pre-heating ■ Flux Cleaning ⑴Solvent : Fluorine or Alcohol type. ⑵Cleaning after soldering should be done after the PC board is exposed to room temperature (30℃ or below) for 1 to 2 hours. ⑶Do not use ultrasonic cleaning. ■Packaging Specifications within 120sec Plastick Pack 100 pcs/pack 15 KU SO SO 231 JI JI FU FU Soldering KU 196 ⑶When soldering two or more terminals to the common land, use the solder resist to solder them independently. (ON) :Momentary. ☆:Semi-standard products.
CFT2-2SC4-AW 价格&库存
很抱歉,暂时无法提供与“CFT2-2SC4-AW”相匹配的价格&库存,您可以联系我们找货
