70
Accessories
Pins, Terminals and Solder Washers
K36, K24
T42-1
Inbord Pins for holes- .025”(.6mm) & .042”dia.
Push-In Terminals for .042” diameter holes
K36
K24
• Press-in pins provide excellent solder
points
• Installation tools available separately
• Available in several sizes
• Plating note: Tin plated. Gold plating
available on K24 & K31 styles. Add “A”
suffix to numeric portion of part number.
Swage
• Wiring terminals for mounting leads
or wires horizontally or vertically
(through board hole)
• Connectors require no staking for
most applications
• Horizontal slot holds up to seven
wires, depending upon thickness of
wire
Diamond
knurl (K24 only)
“P” Pattern
Vectorbord®
Use P133A Insertion Tool
Part No. Pkg Hole A
Qty Size
K24A/M*
K24A/C
K24C/M*
K24C/C
K30C/M
K30C/C
K31C/M
K31C/C
K36C/M
K36C/C
1000
100
1000
100
1000
100
1000
100
1000
100
.042”
.042”
.042”
.042”
.042”
.042”
.042”
.042”
.025”
.025”
.650”
.650”
.650”
.650”
.550”
.550”
.375”
.375”
.705”
.705”
B
C
D
E
F
.255”
.255”
.255”
.255”
.255”
.255”
.160”
.160”
.293”
.293”
.375”
.375”
.375”
.375”
.305”
.305”
.195”
.195”
.400”
.400”
.073”
.073”
.073”
.073”
.085”
.085”
.075”
.075”
.040”
.040”
.080”
.080”
.080”
.080”
.060”
.060”
.060”
.060”
.050”
.050”
.039”
.039”
.039”
.039”
.040”
.040”
.040”
.040”
.023”
.023”
T42-1
Micro-Klip
Use P149A (handle type)
or P149 (shank type)
Insertion tool
T28
*Use in G-10 epoxy glass board only as knurled shoulder may split CEM-1 composite material
R32
Socket Pins for .042” diameter holes
• Low profile wire-wrap socket pins
• Pressfit mounting
• Four-finger contacts, tapered sockets for
easy insertion
• Accepts .015-.025 diameter leads
• Gold-plated contact surfaces
Use P158 Insertion Tool
D9 Die Point
Part No. Pkg A
Qty
R32/C
R32/M
B
C
D
E Male Pin
Depth
100 .745” .500” .072” .155” .075”
1000 .745” .500” .072” .155” .075”
.13”
.13”
Push-In Terminals for .062” diameter holes
• Wiring terminals for mounting leads or
wires horizontally or vertically (through
board hole)
• Vertical (longitudinal) slot holes .025”
diameter leads or .22 gauge wires
• Includes .018” diameter tab hole which
accepts transistor wires, can be used
to hold an anchoring wire
Use P91A Insertion tool
Part No. Pkg Qty
T28/C
T28/M
100
1000
R30, R31, R53
Socket Pins for .055” diameter holes
R30
• Low profile,pressfit pins, for hand or dip
solder applications
• Solder post is 0.110” long, extends 0.19”
below and 0.030” above board surface
R31
• Low profile wire wrap
• Four-finger contacts, tapered socket for
easy insertion
R52
• Two level wire wrap
• Tin-plated contact surfaces
R53
• 3-level wire-wrap pins, .025” sq. posts
• Six-finger contacts, low insertion force sockets
Part No. Pkg Qty A
R30/C
R30/M
R31/C
R52/C
R52/M
R53/C
R53/M
A Fine Technology Group
100
1000
100
100
1000
100
1000
.110”
.110”
.500”
.370”
.370”
.500”
.500”
B
C
.286”
.286”
.703”
.570”
.570”
.700”
.700”
.072”
.072”
.072”
.072”
.072”
.062”
.062”
D Male Pin Depth
.030”
.030”
.031”
.031”
.15”
.15”
.17
.15-.22”
.15-.22”
Specifications subject to change without notice.
A
B
.437” .237”
.437” .237”
T124
Solder Washers - 3 Sizes in Package
Multi-functional solder washer kits, with
three sizes of washers. Different sizes
provided to fit over sockets and tails of
most Vector socket pins and wiring terminals. Ideal tools for committing pins to
voltage and ground planes in Vectorbord®
patterns, such as Voltage/Ground Plane
and Vectorbord plus TM , that have clearance area isolating holes from planes.
T124/M (Includes 3 sizes)
Qty
I.D. O.D. Application
500
500
1000
.078”
.058”
.040”
.110” Vcc Side
.103” GND Side
.106” Connector
T124-040/500
Qty
500
.040”
.106” Connector
很抱歉,暂时无法提供与“R32/M”相匹配的价格&库存,您可以联系我们找货
