WD2RE01GX809-667G-PQ 数据手册
DDR2-400, 533,667,800
One Rank, x8 Registered SDRAM DIMM Pb-free
512MB - WD2RE512X809
1GB - WD2RE01GX809
2GB - WD2RE02GX809
Features:
Figure 1: Available profiles
240-pin Registered ECC DDR2 SDRAM Dual-In-Line
Memory Module for DDR2-400,533,667 and 800.
JEDEC standard VDD=1.8V (+/- 0.1V) power supply
One rank 512MB, 1GB, and 2GB
Modules are built with 9 x8 DDR2 SDRAM devices in
a FBGA 60-ball Pb-Free package
ECC error detection and correction
Programmable CAS Latency of 3,4,5 and 6; Burst
Length of 4 and 8
Auto Refresh and Self Refresh Mode
OCD (Off-Chip Driver Impedance Adjustment) and
ODT (On-Die Termination)
SPD (Serial Presence Detect) with EEPROM
All input/output are SSTL_18 compatible
All contacts are gold plated
One clock delay for register
ROHS compliant
Standard:
1.181"
Description:
The following specification covers the family of One-Rank Registered ECC DDR2 modules using x8 FBGA
SDRAMs. Please reference Figure 1 for available profiles and the product ordering guide for available options
including speed grade and silicon manufacturer.
Speed Grades:
Speed Grade
-400C
-533E
-667G
-800G
-800I
Data Rate (MHz)
CL3 CL4 CL5 CL6
400
400
533
667
800
800
Clock/Data Rate
Latency
Module Speed
5.0ns/400MHz
3.75ns/533MHz
3ns/667MHz
2.5ns/800MHz
2.5ns/800MHz
3-3-3
4-4-4
5-5-5
5-5-5
6-6-6
PC2-3200
PC2-4200
PC2-5300
PC2-6400
PC2-6400
Address Summary Table:
Module Configuration
Refresh
Device Configuration
Row Addressing
Column Addressing
Bank Address
Module Rank
512MB
64M x 72
8K
64M x 8
(9 components)
A0-A13(16K)
A0-A9 (1K)
BA0-BA2
1
1GB
128M x 72
8K
128M x 8
(9 components)
A0-A13(16K)
A0-A9 (1K)
BA0-BA2
1
2GB
256M x 72
8K
256M x 8
(9 components)
A0-A14 (32K)
A0-A9 (1K)
BA0-BA2
1
*Specifications are for reference purposes only and are subject to change by Wintec without notice.
Green Rev. 1.5 – Mar.’14
Wintec Industries, Inc., reserves the right to change datasheets and/or products without any notice.
2014Wintec Industries, Inc.
1
Pin Configuration:
Pin
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
29
30
Symbol
VREF
VSS
DQ0
DQ1
VSS
DQS0#
DQS0
VSS
DQ2
DQ3
VSS
DQ8
DQ9
VSS
DQS1#
DQS1
VSS
RESET#
NC
VSS
DQ10
DQ11
VSS
DQ16
DQ17
VSS
DQS2#
DQS2
VSS
DQ18
Pin Symbol
31
DQ19
32
VSS
33
DQ24
34
DQ25
35
VSS
36 DQS3#
37
DQS3
38
VSS
39
DQ26
40
DQ27
41
VSS
42
CB0
43
CB1
44
VSS
45 DQS8#
46
DQS8
47
VSS
48
CB2
49
CB3
50
VSS
51 VDDQ
52
CKE0
53
VDD
54
BA2
55 ERR_OUT
56 VDDQ
57
A11
58
A7
59
VDD
60
A5
Pin Symbol
61
A4
62 VDDQ
63
A2
64 VDD
KEY
65 VSS
66 VSS
67 VDD
68 PAR_IN
69 VDD
70 A10/AP
71 BA0
72 VDDQ
73 WE#
74 CAS#
75 VDDQ
76 NC/S1#
77 ODT1
78 VDDQ
79 VSS
80 DQ32
81 DQ33
82 VSS
83 DQS4#
84 DQS4
85 VSS
86 DQ34
87 DQ35
88 VSS
89 DQ40
90 DQ41
Pin Symbol Pin Symbol Pin Symbol
Pin Symbol
Pin
91
VSS
121
VSS
151
VSS
181 VDDQ
211
92 DQS5# 122
DQ4
152
DQ28
182
A3
212
93
DQS5 123
DQ5
153
DQ29
183
A1
213
94
VSS
124
VSS
154
VSS
184
VDD
214
95
DQ42 125 DM0/DQS9 155 DM3/DQS12
KEY
215
96
DQ43 126 NC/DQS9# 156 NC/DQS12# 185
CK0
216
97
VSS
127
VSS
157
VSS
186
CK0#
217
98
DQ48 128
DQ6
158
DQ30
187
VDD
218
99
DQ49 129
DQ7
159
DQ31
188
A0
219
100
VSS
130
VSS
160
VSS
189
VDD
220
101
SA2
131 DQ12
161
CB4
190
BA1
221
102 NC,TEST1 132 DQ13
162
CB5
191 VDDQ
222
103
VSS
133
VSS
163
VSS
192
RAS#
223
104 DQS6# 134 DM1/DQS10 164 DM8/DQS17 193
S0#
224
105 DQS6 135 NC/DQS10# 165 NC/DQS17# 194 VDDQ
225
106
VSS
136
VSS
166
VSS
195
ODT0
226
107 DQ50 137
RFU
167
CB6
196
A13
227
108 DQ51 138
RFU
168
CB7
197
VDD
228
109
VSS
139
VSS
169
VSS
198
VSS
229
110 DQ56 140 DQ14
170 VDDQ
199
DQ36
230
111 DQ57 141 DQ15
171 NC/CKE1 200
DQ37
231
112
VSS
142
VSS
172
VDD
201
VSS
232
113 DQS7# 143 DQ20
173 NC/A15 202 DM4/DQS13 233
114 DQS7 144 DQ21
174 NC/A14 203 NC/DQS13# 234
115
VSS
145
VSS
175 VDDQ
204
VSS
235
116 DQ58 146 DM2/DQS11 176
A12
205
DQ38
236
117 DQ59 147 NC/DQS11# 177
A9
206
DQ39
237
118
VSS
148
VSS
178
VDD
207
VSS
238
119
SDA
149 DQ22
179
A8
208
DQ44
239
120
SCL
150 DQ23
180
A6
209
DQ45
240
210
VSS
Symbol
DM5/DQS14
NC/DQS14#
VSS
DQ46
DQ47
VSS
DQ52
DQ53
VSS
RFU
RFU
VSS
DM6/DQS15
NC/DQS15#
VSS
DQ54
DQ55
VSS
DQ60
DQ61
VSS
DM7/DQS16
NC/DQS16#
VSS
DQ62
DQ63
VSS
VDDSPD
SA0
SA1
NC - No Connect, RFU - Reserved for Future Use
1. The Test pin (Pin 102) is reserved for bus analysis and is not connected on normal memory modules
2. CKE1 and S1# pin are used for dual-rank Registered DIMM
3. A13 (Pin 196) is for 512MB and above DIMM.
Pin Locations:
Front View
64
Pin 1
Pin 240
65
184
185
120
121
Back View
240-pin DIMM
2
Functional Block Diagram:
One Rank 64M x 72 (512MB), 128M x 72 (1GB), and 256M x 72 (2GB) DDR2 Registered SDRAM DIMM (x8
organization)
RCS0#
DQS4
DQS4#
DM4/DQS13
DQS0
DQS0#
DM0/DQS9
DQS9#
NU/
DM/ CS# DQS# DQS
RDQS# RDQS
U0
DQ[0:7]
8
DQS5
DQS5#
DM5/DQS14
NU/
DM/ CS# DQS# DQS
RDQS# RDQS
U5
DQ[40:47]
8
DQS6
DQS6#
DM6/DQS15
8
DQS2
DQS2#
DM2/DQS11
NU/
DM/ CS# DQS# DQS
RDQS# RDQS
U6
DQ[48:55]
8
DQS7
DQS7#
DM7/DQS16
8
DQS3
DQS3#
DM3/DQS12
NU/
DM/ CS# DQS# DQS
RDQS# RDQS
DQS16#
U3
DQ[24:31]
8
VDDSPD
NU/
DM/ CS# DQS# DQS
RDQS# RDQS
To SPD
To U0 - U8
To U0 - U8
To U0 - U8
VDD/VDDQ
VREF
Vss
U8
CB[0:7]
NU/
DM/ CS# DQS# DQS
RDQS# RDQS
U7
DQ[56:63]
8
DQS8
DQS8#
DM8/DQS17
DQS17#
NU/
DM/ CS# DQS# DQS
RDQS# RDQS
DQS15#
U2
DQ[16:23]
DQS12#
NU/
DM/ CS# DQS# DQS
RDQS# RDQS
DQS14#
U1
DQ[8:15]
DQS11#
U4
DQ[32:39]
8
DQS1
DQS1#
DM1/DQS10
DQS10#
NU/
DM/ CS# DQS# DQS
RDQS# RDQS
DQS13#
8
SERIAL PD
SCL
PAR_IN
BA0-BA2
A0-A13
RAS#
CAS#
WE#
CKE0
ODT0
CS0#*
RESET#
ERR_OUT
R
E
G
I
S
T
E
R
RBA0-RBA2 -> BA0-BA2 to U0 - U8
RA0-RA13 -> A0-A13 to U0 - U8
RRAS# -> RAS# to U0 - U8
RCAS# -> CAS# to U0 - U8
RWE# -> WE# to U0 - U8
RCKE0 -> CKE0 to U0 - U8
RODT0 -> ODT0 to U0 - U8
RS0# -> CS0# to U0 - U8
CK0
CK0#
RESET#
SDA
A0
A1
A2
SA0
SA1
SA2
P
L
L
CK to U0 - U8
CK# to U0 - U8
CK to all registers
CK# to all registers
Note:
1. *) CS0# connects to DCS# of Register 1 and CSR# of Register 2;
CSR# of Register 1 and DCS# of Register 2 connects to VDD
2. DQ/DM/DQS, address and control resistor values are 22 Ohms.
3
Absolute Maximum Ratings:
Exposure to stresses greater than these absolute maximum rating conditions for extended periods may affect
reliability of the module.
Symbol
VDD
VDDQ
VDDL
VIN, VOUT
TSTG
TOPR
TCASE
IIL
IOL
Parameter
VDD supply voltage relative to VSS
VDDQ supply voltage relative to VSS
VDDL supply voltage relative to VSS
Voltage on any pin relative to VSS
Storage temperature
Operating Temperature (Ambient)
DRAM Component Case Temperature
Input Leakage Current; Any input 0V VIN 0.95V
Output Leakage Current; 0V VOUT VDDQ; DQS and ODT are disabled
Min
Max Units
-1.0
-0.5
-0.5
-0.5
-55
-5
2.3
2.3
2.3
2.3
+100
+70
+95
5
5
V
V
V
V
C
C
C
A
A
DC Operating Conditions:
Parameter
Supply Voltage
VDDL Supply Voltage
I/O Supply Voltage
I/O Reference Voltage
I/O Termination Voltage (system)
Symbol
Min
Nom
Max
VDD
VDDL
VDDQ
VREF
VTT
1.7
1.7
1.7
0.49 x VDDQ
VREF - 40
1.8
1.8
1.8
0.50 x VDDQ
VREF
1.9
1.9
1.9
0.51 x VDDQ
VREF + 40
Units Notes
V
V
V
V
mV
1
4
4
2
3
NOTE:
1. VDD and VDDQ must keep track of each other. VDDQ cannot exceed the value of VDD
2. VREF is expected to equal VDDQ/2 of the transmitting device and to track variations in the DC level of the same
3. VTT is not applied directly to the device. VTT is a system supply for signal termination resistors, is expected to
be set equal to VREF and must track variations in the DC level of VREF
4. VDDQ must tracks VDD; and VDDL tracks VDD
4
Electrical Characteristics and AC Timings:
VDD = +1.8V ± 0.1V, VDDQ = +1.8V ± 0.1V, VREF = VSS, f =100MHz, 0°C≤TCASE ≤+85°C, VOUT (DC) = VDDQ/2
-5
DDR2-400
MIN
MAX
-600
+600
-3.75
DDR2-533
MIN
MAX
-500
+500
-3
DDR2-667
MIN
MAX
-450
+450
-2.5
DDR2-800
MIN
MAX
-400
+400
ps
DQS output access time from CK/ CK tDQSCK
-500
+500
-450
+450
-400
+400
-350
+350
ps
CK high-level width
CK low-level width
tCH
tCL
0.55
0.55
0.48
0.48
0.52
0.52
tCK
tCK
ps
CL=3
CL=4
tCK
CL=5
CL=6
tDH
tDS
tIPW
8,000
8,000
8,000
8,000
0.48
0.48
MIN
(tCH,
tCL)
5,000
3,750
3,000
175
100
0.6
0.52
0.52
tHP
0.45
0.45
MIN
(tCH,
tCL)
5,000
3,750
225
100
0.6
0.55
0.55
CK half period
0.45
0.45
MIN
(tCH,
tCL)
5,000
5,000
275
150
0.6
8,000
8,000
8,000
5,000
3,750
2,500
2,500
125
50
0.6
8,000
8,000
8,000
8,000
ps
ps
ps
ps
ps
ps
tCK
tDIPW
0.35
0.35
0.35
0.35
tCK
tHZ
tACmax
tACmax
tACmax
X
tLZ
tACmin
tACmax
tACmin
tACmax
tACmin
tACmax
tACmin
tACmax
ps
350
300
240
x
200
ps
tHPtQHS
WL-0.25
450
tHPtQHS
WL0.25
0.35
400
ps
ps
WL0.25
0.35
tHPtQHS
WL-0.25
300
WL+
0.25
340
tHPtQHS
WL+0.
25
Parameter
DQ output access time from CK/ CK
Clock cycle time
DQ and DM input hold time
DQ and DM input setup time
Control & Address input pulse width
for each input
DQ and DM input pulse width for
each input
Data-out high-impedance time from
CK/ CK
Data-out low-impedance time from
CK/ CK
DQS-DQ skew for DQS and
associated DQ signals
Data hold skew factor
Data output hold time from DQS
Symbol
tAC
tDQSQ
tQHS
tQH
Write command to 1st DQS latching
transition
DQS input low/high pulse width
tDQSS
tDQSL/H
0.35
WL+
0.25
DQS falling edge to CK setup time
tDSS
0.2
0.2
0.2
DQS falling edge hold time from CK
tDSH
0.2
0.2
2
2
0.40
0.9
0.4
45
55
105
15
15
0.60
1.1
0.6
70,000
0.40
0.9
0.4
45
60
105
15
15
Mode register set command cycle time tMRD
Write preamble setup time
Write preamble
Write postamble
Read preamble
Read postamble
Active to Precharge command
Active to Active command period
Refresh to Refresh command interval
Active to Read/Write delay
Precharge command period
tWPRES
tWPRE
tWPST
tRPRE
tRPST
tRAS
tRC
tRFC
tRCD
tRP
min
(tCH, tCL)
ps
tCK
0.35
WL+
0.25
0.2
tCK
0.2
0.2
tCK
2
2
tCK
0.60
1.1
0.6
70,000
0.4
0.9
0.4
45
60
105
15
0.6
1.1
0.6
70,000
15
0.40
0.9
0.4
45
57.5/60
0.60
1.1
0.6
70,000
ps
tCK
tCK
tCK
tCK
ns
ns
ns
ns
ns
105
12.5/15
12.5/15
5
Units
tCK
Parameter
Active bank A to Active bank B
command
CAS A to CAS B command period
Write recovery time
Auto Precharge write recovery +
Precharge time
Internal Write to Read command delay
Internal Read to Precharge command
delay
Exit precharge power down to any nonRead command
Exit Self-Refresh to Read command
Exit Self-Refresh to non-Read
command
CKE minimum high and low pulse
width
Average periodic refresh interval
OCD drive mode output delay
CKE low to CK, CK uncertainty
Symbol
tRRD
-5
DDR2-400
MIN
MAX
7.5
tCCD
tWR
tDAL
2
15
WR+tRP
tWTR
tRTP
tXP
tXSRD
tXSNR
-3.75
DDR2-533
MIN
MAX
7.5
2
15
WR+tRP
10
7.5
2
-3
DDR2-667
MIN MAX
7.5
2
15
WR+tRP
7.5
7.5
7.5
7.5
2
2
200
200
200
tRFC+10
tRFC+10
tRFC+10
tCKE
3
3
3
tREFI
tOIT
tDELAY
12
12
tIS+tCK
+tIH
tIS+tCK
+tIH
-2.5
DDR2-800
MIN
MAX
7.5
2
15
WR+tR
P
7.5
7.5
2
tCK
ns
tCK
ns
ns
tCK
tCK
ns
200
tRFC +
10
3
tCK
7.8
7.8
tIS+tCK
+tIH
tIS+tCK
+tIH
6
ns
Note: These parameters are applicable for all 3 chip manufacturers, Micron, Hynix, and Samsung.
Units
s
ns
ns
Physical Dimensions – Standard:
1.181" Height DDR2 Registered DIMM
One physical rank, 9 components x8 organised
240
185
184
Pin 121
BACK
0.106/(2.7) Max
5.250/(133.35±0.15)
5.171/(131.35)
Register
0.1575/(4.0)
1.181/(30.0)
PLL
0.10/(2.54)
0.118/(3.0)
Pin 1
0.25/(6.35)
2.55/(64.77)
64
0.039/
(1.0)
65
0.05/
(1.27)
1.95/(49.5)
5.014/(127.35)
FRONT
120
0.050±0.004/
(1.27±0.1)
SIDE
Note:
1. Dimensions are in inches/(mm)
2. Outline dimensions and tolerances are in accordance with the JEDEC standard
7
Ordering Guide:
DDR2-400, 533, 667, 800MHz, One-Rank x8, Registered ECC DIMM
WD2RE512X809
WD2RE01GX809
WD2RE02GX809
x – yyyy(j) – ZZZ
x: Profile
Naming Guide:
yyyy: Speed
(Blank)
= Std. (1.18")
V
= VLP. (0.72")
400C
= DDR2-400@CL3
533E
= DDR2-533@CL4
667G
= DDR2-667@CL5
800G
= DDR2-800@CL5
800I
= DDR2-800@CL6
(Blank)
ZZZ: DRAM/Die/Register
= Std.
C
= Hynix
A = A die
E = E die
P
= Samsung
B = B die
F = F die
H
= Micron
C = C die
G = G die
D = D die
Q = Q die
I
= Inphi
D
= IDT
(Call for additional DRAM options and latest die-revision)
Configuration/Availability:
Density
PT #
Profile
Speed
400C, 533E, 667G, 800G/I
512MB
WD2RE512X809
(Std), V
1-GB
WD2RE01GX809
(Std), V
2-GB
WD2RE02GX809
(Std), V
DRAM/Die
ZZZ
Example: WD2RE01GX809-400C-QB
1GB DDR2-400 REG/ECC Infineon B-Die using 128Mx8 Config
Contact Us:
Wintec Industries OEM Group
675 Sycamore Drive
Milpitas, CA 95035
Ph: 408-856-0663
Fax: 408-856-0518
oemsales@wintecind.com
http://www.wintecind.com/oem
8
Revision History:
Revision 1.0 (December 2004)
Initial Release
Revision 1.1 (August 2005)
ROHS version
Added DRAM Case temperature TCASE
Revision 1.2 (Sept 2007)
Added 800MHz speed grade
Revision 1.3 (Jan 2010)
1GB row address mapping updated
Revision 1.4 (Nov 2013)
Updated the Ordering Guide
Revision 1.5 (Mar 2014)
9
