P138A
P138A
    VECTOR
    TOOL PAD CUTTER W/HANDLE
P138A 数据手册
CATALOG 128_CATALOG 128.qxd 9/24/2018 12:43 PM Page 76 PCB Accessories Tools & Handles Pad Cutters, Insertion Tools Hand Insertion Tools for Push-In Terminals Pad Cutters Part No Terminal P/N Holder Type A13 A13-1 P91A P156 P133A T44 T68 T28 T49 T46 series & K24 - K31 K36 T42-1 T42-1 Shank with removable rubber handle Shank with removable rubber handle Wooden Handle Wooden Handle Shank with removable rubber handle P134 P149A P149 Wooden Handle Wooden Handle Shank with removable rubber handle A13 Shank with removable rubber handle Pad Cutter Shank Type (A13 type) P149 Shank with removable rubber handle P149A - Wooden Handle Type Tools P138A Wooden Handle type Shows pad removal & pad cutter Shank Only P138C Vector Pad Cutters provide an effective method for creating isolated solder pads around holes in copper clad boards. Pilot pin enters hole and rotates, creating a clearance area around the solder pad. Available for boards with .042” diameter holes. Also available without handles for use with manual or power drills. Part Holder No. Type P138A Handle/Shank P138C Shank Only A .040” .040” B C .086” .125” .086” .125” Pull Type Ejector Handle • Extraction/insertion handles • Mounts on front edge of Plugbordtm with single screw or roll-pin • Plastic (FE4) Bus Strips • • • • Flat cold-drawn flat copper wire, 0.017” thick (+/-0.003”) 0.080”W with 0.042” diameter holes on 0.100” centers Hot 100% Tin dipped, fully RoHS compliant Compatible with most Vectorbord® hole patterns Shank Use with Vectorbord® .125” .125” Pattern P, .042: holes Pattern P, .042: holes HA14 Part No. HA14 HA14/C Package Quantity 4 100 T107 Part No. Pkg Qty T107/C T107/10 100 10 Rotation Type Ejector Handle HA9 Dimensional information for HA9 is on Page 44 • Card ejector, corner mounting • Supports up to 40 lbs extraction force • White nylon, (hardware included) 76 www.vectorelect.com Specification subject to change without notice 800-423-5659 Part No. HA9/4 HA9/C Pkg Qty 4 100
P138A 价格&库存
很抱歉,暂时无法提供与“P138A”相匹配的价格&库存,您可以联系我们找货
