RS0101YC6
RS0101YC6
    RUNIC(润石)
    SOT363
    1位双向电压电平转换器,用于开漏和推挽应用
RS0101YC6 数据手册
RS0101 1-Bit Bidirectional Voltage-Level Translator for Open-Drain and Push-Pull Application FEATURES • • • • • • • DESCRIPTION No Direction-Control Data Rates 24Mbps (Push-Pull) 2Mbps (Open-Drain) 1.65V to 5.5V on A ports and 2.3V to 5.5V on B Ports (VCCA≤VCCB) VCC Isolation: If Either VCC is at GND, Both Ports are in the High-Impedance State No Power-Supply Sequencing Required: Either VCCA or VCCB can be Ramped First IOFF: Supports Partial-Power-Down Mode Operation Extended Temperature: -40°C to +85°C APPLICATIONS • • • I2C/ SMBus UART GPIO This 1-bit non-inverting translator is a bidirectional voltagelevel translator and can be used to establish digital switching compatibility between mixed-voltage systems. It uses two separate configurable power-supply rails, with the A ports supporting operating voltages from 1.65V to 5.5V while it tracks the VCCA supply, and the B ports supporting operating voltages from 2.3V to 5.5V while it tracks the VCCB supply. This allows the support of both lower and higher logic signal levels while providing bidirectional translation capabilities between any of the 1.8V, 2.5V, 3.3V and 5V voltage nodes. When the output-enable (OE) input is low, all I/Os are placed in the high-impedance state, which significantly reduces the power-supply quiescent current consumption. OE has an internal pull-down current source, as long as VCCA is powered. To ensure the high-impedance state during power up or power down, OE should be tied to GND through a pulldown resistor; the minimum value of the resistor is determined by the current-sourcing capability of the driver. The RS0101 is available in Green SOT23-6 、 SOT363(SC70-6) and DFN1.45x1.0-6L packages. It operates over an ambient temperature range of -40°C to +85°C. Functional Block Diagram VCCB VCCA OE One Shot Accelerator One Shot Accelerator Gate Bias 10KΩ 10KΩ A REV A.3 B 1 / 20 www.run-ic.com RS0101 Revision History Note: Page numbers for previous revisions may different from page numbers in the current version. VERSION A.1 Change Date 2020/09/02 A.2 2020/09/10 A.3 2021/01/09 Change Item Initial version completed Fix mistake in PACKAGE/ORDERING INFORMATION. Order number value from RS0101YUTDV8 to RS0101YUTDV6 Add Moisture Sensitivity Level information 2 / 20 www.run-ic.com RS0101 PIN CONFIGURATIONS VCCA 1 6 VCCB GND 2 5 OE A 3 4 B VCCB 1 6 VCCA OE 2 5 GND B 3 4 A DFN1.45X1.0-6L SOT23-6/SOT363(SC70-6) PIN DESCRIPTION PIN SOT23-6/ SOT363(SC70-6) DFN1.45x1.06L NAME TYPE (1) 1 6 VCCA P A Port Supply Voltage.1.65V ≤ VCCA ≤ 5.5V and VCCA ≤ VCCB. 2 5 GND ‒ Ground. 3 4 A I/O Input/output A. Reference to VCCA. 4 3 B I/O Input/output B. Reference to VCCB. 5 2 OE I Output Enable (Active High). Pull OE low to place all outputs in 3-state mode. Referenced to VCCA. 6 1 VCCB P B Ports Supply Voltage.2.3V ≤ VCCB ≤ 5.5V. FUNCTION (1) I=input, O=output, I/O=input and output, P=power 3 / 20 www.run-ic.com RS0101 SPECIFICATIONS Absolute Maximum Ratings Over operating free-air temperature range (unless otherwise noted) (1) SYMBOL PARAMETER MIN MAX UNIT VCCA Supply Voltage Range -0.3 6.0 V VCCB Supply Voltage Range -0.3 6.0 V VI(2) A port -0.3 6.0 Input Voltage Range B port -0.3 6.0 Voltage range applied to any output in the highimpedance or power-off state A port -0.3 6.0 B port -0.3 6.0 Voltage range applied to any output in the high or low state A port -0.3 VCCA+0.3 B port -0.3 VCCB+0.3 IIK Input clamp current VI
RS0101YC6 价格&库存
很抱歉,暂时无法提供与“RS0101YC6”相匹配的价格&库存,您可以联系我们找货
RS0101YC6
    • 5+1.68600
    • 50+1.29790
    • 150+1.13160
    • 500+0.92400
    库存:4490
    RS0101YC6
    • 1+0.83999
    • 30+0.80999
    • 100+0.77999
    • 500+0.72000
    • 1000+0.69000
    • 2000+0.67200
    库存:5
