RS0104
4-Bit Bidirectional Voltage-Level Translator for
Open-Drain and Push-Pull Applications
FEATURES
No Direction-Control
Data Rates
24Mbps (Push-Pull)
2Mbps (Open-Drain)
1.65V to 5.5V on A ports and 2.3V to 5.5V
on B Ports (VCCA≤VCCB)
VCC Isolation: If Either VCC is at GND, Both
Ports are in the High-Impedance State
No Power-Supply Sequencing Required:
Either VCCA or VCCB can be Ramped First
IOFF: Supports Partial-Power-Down Mode
Operation
Extended Temperature: -40°C to +85°C
APPLICATIONS
Handset
Smartphone
Tablet
Desktop PC
DESCRIPTION
This 4-bit non-inverting translator is a bidirectional voltagelevel translator and can be used to establish digital
switching compatibility between mixed-voltage systems. It
uses two separate configurable power-supply rails, with the
A ports supporting operating voltages from 1.65V to 5.5V
while it tracks the VCCA supply, and the B ports supporting
operating voltages from 2.3V to 5.5V while it tracks the VCCB
supply. This allows the support of both lower and higher
logic signal levels while providing bidirectional translation
capabilities between any of the 1.8V, 2.5V, 3.3V and 5V
voltage nodes.
When the output-enable (OE) input is low, all I/Os are
placed in the high-impedance state, which significantly
reduces the power-supply quiescent current consumption.
OE has an internal pull-down current source, as long as
VCCA is powered.
To ensure the high-impedance state during power up or
power down, OE should be tied to GND through a pulldown resistor; the minimum value of the resistor is
determined by the current-sourcing capability of the driver.
The RS0104 is available in Green QFN3.5x3.5-14L,
QFN2x2-12L and TSSOP-14 packages. It operates over an
ambient temperature range of -40°C to +85°C.
REV A.2
1 / 23
www.run-ic.com
RS0104
Functional Block Diagram
Figure 1.Block Diagram
2 / 23
www.run-ic.com
RS0104
Revision History
Note: Page numbers for previous revisions may different from page numbers in the current version.
VERSION
A.1
A.2
Change Date
2020/11/03
2021/01/09
Change Item
Initial version completed
Add Moisture Sensitivity Level information
3 / 23
www.run-ic.com
RS0104
PIN CONFIGURATIONS
VCCA
VCCB
(TOP VIEW)
1
14
13
B1
A2
3
12
B2
A3
4
11
B3
A4
5
10
B4
NC
6
9
NC
7
8
OE
2
GND
A1
QFN3.5x3.5-14L
PIN DESCRIPTION
PIN
QFN3.5x3.514L
1
NAME
TYPE (1)
FUNCTION
VCCA
P
A Port Supply Voltage.1.65V ≤ VCCA ≤ 5.5V and VCCA ≤ VCCB.
2
A1
I/O
Input/output A1. Reference to VCCA.
3
A2
I/O
Input/output A2. Reference to VCCA.
4
A3
I/O
Input/output A3. Reference to VCCA.
5
A4
I/O
Input/output A4. Reference to VCCA.
6
NC
No internal connection.
7
GND
8
OE
I
9
NC
Ground.
Output Enable (Active High). Pull OE low to place all outputs
in 3-state mode. Referenced to VCCA.
10
B4
I/O
Input/output B4. Reference to VCCB.
11
B3
I/O
Input/output B3. Reference to VCCB.
12
B2
I/O
Input/output B2. Reference to VCCB.
13
B1
I/O
Input/output B1. Reference to VCCB.
B Ports Supply Voltage.2.3V ≤ VCCB ≤ 5.5V.
Exposed pad should be soldered to PCB board and
Thermal Pad
connected to GND or left floating.
(1) I=input, O=output, I/O=input and output, P=power
14
VCCB
P
4 / 23
www.run-ic.com
RS0104
PIN CONFIGURATIONS
(TOP VIEW)
QFN2x2-12L
PIN DESCRIPTION
PIN
NAME
TYPE (1)
1
A1
I/O
2
A2
I/O
3
A3
I/O
4
A4
I/O
5
GND
6
OE
I
7
B4
I/O
Ground.
8
B3
I/O
9
B2
I/O
10
B1
I/O
11
VCCB
P
QFN2x2-12L
FUNCTION
Exposed Pad
GND
(2) I=input, O=output, I/O=input and output, P=power
12
VCCA
P
5 / 23
www.run-ic.com
RS0104
PIN CONFIGURATIONS
(TOP VIEW)
VCCA
1
14
VCCB
A1
2
13
B1
A2
3
12
B2
A3
4
11
B3
A4
5
10
B4
NC
6
9
NC
GND
7
8
OE
TSSOP-14
PIN DESCRIPTION
PIN
NAME
TYPE (1)
1
VCCA
P
2
A1
I/O
3
A2
I/O
4
A3
I/O
5
A4
I/O
6
NC
7
GND
8
OE
I
9
NC
Ground.
10
B4
I/O
11
B3
I/O
12
B2
I/O
13
B1
I/O
TSSOP-14
FUNCTION
14
VCCB
P
(3) I=input, O=output, I/O=input and output, P=power
6 / 23
www.run-ic.com
RS0104
SPECIFICATIONS
Absolute Maximum Ratings
Over operating free-air temperature range (unless otherwise noted) (1)
SYMBOL
PARAMETER
MIN
MAX
UNIT
VCCA
Supply Voltage Range
-0.3
6.0
V
VCCB
-0.3
6.0
V
A port
-0.3
6.0
B port
-0.3
6.0
OE
-0.3
6.0
Voltage range applied to any output in the highimpedance or power-off state
A port
-0.3
6.0
B port
-0.3
6.0
Voltage range applied to any output in the high or
low state
A port
-0.3
VCCA+0.3
B port
-0.3
VCCB+0.3
Input clamp current
VI
很抱歉,暂时无法提供与“RS0104YQ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.65760
- 100+1.33280
- 1000+1.18720
- 2000+1.11660
- 4000+1.06290
- 国内价格
- 1+2.97990
- 10+2.44860
- 30+2.18290
- 100+1.95200
- 500+1.89420
- 1000+1.85960
- 国内价格
- 1+1.36499
- 10+1.26000
- 30+1.23900
- 100+1.17600
