RJ74C6B1100
RJ74C6B1100
    THUNDER(盛雷城)
    AXIAL_D3.3X9MM_TM
    金属膜电阻 AXIAL_D3.3X9MM_TM 110Ω ±0.25% 1/2W
RJ74C6B1100 数据手册
APPROVAL SHEET RJ SERIES PRECISION METAL FILM RESISTORS PRODUCE CHECK AND APPROVE ACCEPTED BY EM CE HONORABLE CUSTOMER Edison Chen Charles Chen Oct. 18, 2022 Oct. 19, 2022 www.thunder-resistor.com sales@thunder-resistor.com Page 1 of 9 1. PRODUCT: METAL FILM PRECISION RESISTORS TYPE 2. PART NUMBER: Part number of the precision metal film resistor is identified by the series, power rating and size code, tolerance, temperature coefficient, packing type and resistance value. Example: RJ Series Name 73 Power Rating B Resistance Tolerance 3 Temperature Coefficient T Packing Type (1) Style: RJ series precision metal film resistors (2) Power Rating: see electrical characteristics (3) Tolerance: 1004 Resistance Value B=±0.1%; C=±0.25%; D=±0.50%; F=±1.0%; G=±2.0%; J=±5.0%; (4) T.C.R.: 7=5ppm/oC; 6=10ppm/oC; 5=15ppm/oC; 4=20ppm/ oC; 3=25ppm/ oC; 2=50ppm/ oC; 1=100ppm/ oC; 0>100ppm/ oC; (5) Packaging Type: B=BULK/BOX; T=Tape on Box Packing; F type and M type forming are available upon request (6) Resistance Value: 1R00、20R0、1000、1001、1002、3303、1004……… (7) The part number of jumper is RJ**00T0000 with resistance lower than 15mΩ. 3. Standard applied: Thunder Enterprise standard: Q/SLC005-2011 Thunder Enterprise standard: Q/SLC006-2011 www.thunder-resistor.com sales@thunder-resistor.com Page 2 of 9 4. COLOR BAND-CODE: COLOR 1st 2nd 3rd multiple tolerance TCR black 0 0 0 1 brown 1 1 1 10 F(±1.0%) 100ppm/℃ red 2 2 2 102 G(±2.0%) 50ppm/℃ orange 3 3 3 103 15ppm/℃ yellow 4 4 4 104 25ppm/℃ green 5 5 5 105 D(±0.50%) 15ppm/℃ blue 6 6 6 106 C(±0.25%) 10ppm/℃ purple 7 7 7 B(±0.10%) 5ppm/℃ gray 8 8 8 white 9 9 9 golden 10-1 J(±5.0%) silver 10-2 K(±10%) Five or six color code rings designate the resistance value and tolerance and temperature coefficient in accordance with IEC 60062. Temperature coefficient marked for small TCR on request as the sixth ring in accordance with IEC 60062. Digital marking is available upon request. www.thunder-resistor.com sales@thunder-resistor.com Page 3 of 9 5. ELECTRICAL CHARACTERISTICS Unless otherwise specified, all values are tested at the following condition: Temperature: 21℃ to 25℃; Relative humidity: 45% to 70% RJ**00R0000 is the part number of jumpers with resistance lower than 15mΩ. 6. DERATING CURVE For resistors working at an ambiance temperature of 70℃ or above, the power shall be derated in accordance with the curve. www.thunder-resistor.com sales@thunder-resistor.com Page 4 of 9 7. DIMENSION There are two kind of ceramic cores for RJ72, RJ73S and RJ74M so the tolerance of the dimension of these three type is 3mm instead of 1mm. The customer will get only one size products from the very beginning order and so on. The inner dimension of taping for type size could be adjusted upon the request of customers. www.thunder-resistor.com sales@thunder-resistor.com Page 5 of 9 8. ENVIRONMENTAL CHARACTERISTICS (1) Insulation Resistance IEC 60115-1, 4.6: in V-block for 60 seconds, the test resistance should be high than 10,000 M Ohm. (2) Dielectric Withstanding Voltage IEC 60115-1 4.7: Place resistors in V-block for 60 Seconds, no breakdown or flashover. (3) Temperature Coefficient Test IEC 60115-1, 4.8: Test of resistors at room temperature and 60°C or 100°C on request above room temperature. Then measure the resistance. The Temperature Coefficient is calculated by the following equation and its value should be within the range requested. Re sistor Temperature Coefficient  R R0 t t0 R  R0 1   10 6 R0 t  t0 = Resistance value under the testing temperature = Resistance value at the room temperature = the 2nd testing temperature = Room temperature (4) Short Time Overload Test IEC60115-1 4.13: At 2.5 times rated voltage or 2 times the maximum working voltage whichever is lower for 5 seconds, the resistor should be free from defects. The change of the resistance value should be within ±(0.10%+0.05Ω) as compared with the value before the test. www.thunder-resistor.com sales@thunder-resistor.com Page 6 of 9 (5) Solderability IEC 60115-1, 4.17: 235±5°C for 3±0.5 Seconds, there are at least 95% solder coverage on the termination. (6) Resistance to soldering heat: IEC 60115-1, 4.18: 260±3°C for 10±1 Seconds, immersed to a point 3±0.5mm from the body. The change of the resistance value should be within ±(0.15%+0.05 Ω) as compared with the value before the test. (7) Climatic sequence IEC 60115-1, 4.19: -55°C to Room Temp. to +155°C to Room Temp. (5 cycles). The change of the resistance value shall be within ±(0.50%+0.05 Ω) as compared with the value before the test. (8) Damp Heat Steady State IEC 60115-1, 4.24: 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV or the maximum working voltage whichever is lower. The change of the resistance value should be within ±(0.50%+0.05 Ω) for tighten tolerance resistors and ±(1%+0.05 Ω) for tighten tolerance resistors and ±(1%+0.05 Ω) for normal tolerance resistors and small size and tiny size resistors.as compared with the value before the test. www.thunder-resistor.com sales@thunder-resistor.com Page 7 of 9 (9) Load Life Test IEC 60115-1, 4.25: 70±2°C at RCWV or the maximum working voltage whichever is lower for 1,000+48/-0 Hr. (1.5Hr. on, 0.5Hr. off). The resistors shall be arranged not much effected mutually by the temperature of others and the excessive ventilation shall not be performed. The change of the resistance value should be within ±(0.50%+0.05 Ω) for tighten tolerance resistors and normal tolerance resistors and small size and tiny size resistors and ±(2%+0.05 Ω) for normal tolerance resistors and small size and tiny size resistors.as compared with the value before the test. (10) Accidental Overload Test IEC 60115-1, 4.26: 4 times RCWV for 1 Minute. No evidence of flaming or arcing (11) Intermittent Overload Test . Apply 4 times rated voltage or 2 times the maximum working voltage whichever is lower to the resistor at the 1 second on and 2.5 seconds off cycle for 1000 cycles. The change of the resistance shall be within ±(1.0%+0.05Ω) for tighten tolerance resistors and ±(2%+0.05 Ω) for normal tolerance resistors and small size and tiny size resistors. www.thunder-resistor.com sales@thunder-resistor.com Page 8 of 9 (12) Surge Pulse Overload IEC 60115-1, 4.28: Apply 10 pulses with 10 times rated voltage or 2 times the maximum working voltage whichever is lower to the resistor, the pulses parameter is 10μs/700μs. The change of the resistance shall be within ± (0.5%+0.05Ω) for tighten tolerance resistors and ±(1%+0.05 Ω) for normal tolerance resistors and small size and tiny size resistors. (13) Resistance to Solvent IEC 60115-1, 4.30: IPA for 5±0.5 Min. with ultrasonic. No deterioration of coating and color code occurred. Disclaimer All products, product specifications and data are subject to change without notice to improve reliability, function or design or otherwise. Thunder Precision Resistors makes no warranty, representation or guarantee regarding the suitability of the products for any particular purpose or the continuing production of any product to the maximum extent permitted by applicable law. www.thunder-resistor.com sales@thunder-resistor.com Page 9 of 9
RJ74C6B1100 价格&库存
很抱歉,暂时无法提供与“RJ74C6B1100”相匹配的价格&库存,您可以联系我们找货
RJ74C6B1100
  • 5+1.42680
  • 20+1.29630
  • 100+1.16580
  • 500+1.03530
  • 1000+0.97440
  • 2000+0.93090
库存:21
