XL-3215UWC
Technical Data Sheet
haracteristic
* 外观尺寸(L/W/H):3.2*1.25*1.1mm
OutlineDimensions (L / w / h): 3.2 x 1 . 2 5 x 1.1 mm
* 发光颜色及胶体: 高亮度白色/透明胶体
Luminous color and colloid: high brightness White / transparent colloid
* 环保工艺符合ROHS要求
Environmental protection products Complied With RoHS Directive
* EIA规范标准包装
EIA standard packaging
* 适用于SMT贴片自动化生产
Suitable for SMT automatic production
* 适用于回流焊制程
Suitable for reflow soldering process
roduct application
* 医用设备:内窥镜、血氧仪
Medical equipment: endoscope、oximeter
* 汽车电子: 背光按键灯、指示灯
Automotive electronics: backlight key light、 indicator light
* 工业产品:电子仪表盘、工业设备
Industrial products: electronic instrument panel、industrial equipment
* 智能家居: 白色家电、数码管LED
Smart home: white appliances, nixie tube LED
* 通讯产品: 手机按键灯、路由器、电视盒
Communication products: mobile phone button lamp, router
1
Catalogue
Electrical Characteristics............................................................................................................................. 3
Typical Characteristic Curves....................................................................................................................5
Reliability Test Items And Conditions.......................................................................................................9
Outline Dimensions.......................................................................................................................................10
Packaging......................................................................................................................................................11
Guideline for Soldering.............................................................................................................................. 13
Precautions....................................................................................................................................................15
2
(温度=25℃) Absoiute Maximum Ratings
参数名称
符号
数值
Parameter
Symbol
Rating
消耗功率
Consumed power
最大脉冲电流
Pd
Maximum pulse
IFP
current
正向工作电流
单位
Unit
80
mW
100
mA
Forward working
IF
25
mA
反向电压
Reverse voltage
VR
5
V
current
工作环境温度
Topr
-30~+85
°C
Storage ambient
Tstg
-40~+90
°C
焊接条件
Welding conditions
Tsol
Operating ambient
temperature
储存环境温度
temperature
手动焊 : 300°C ,3s
回流焊:260°C,10s
Limit parameters (Temperature=25°C):
* 注: 脉冲宽度≤0.1ms, 占空比≤1/10
* Note: Pulse width≤0.1ms, Duty≤1/10
Electro-Optical Charasteristics (Temperature=25°C):
参数名称
Parameter
光强
Light intensity
半光强视角
Half light angle
正向电压
Forward voltage
反向电流
Reverse current
符号
Symbol
测试条件
Test conditions
IV
2θ1/2
IF=5mA
VF
IR
VR=5V
最小值
Min.
典型值
Typ.
最大值
Max.
单位
Unit
150
350
mcd
120
Deg
2.6
3.2
V
1
μA
3
Brightness grading
Code
Min
Max
Q01
160
192
Q02
192
230
Q03
230
276
Q04
276
330
Code
Min
Max
M15
2.6
2.7
M16
2.7
2.8
M17
2.8
2.9
M18
2.9
3.0
F8
2.7
2.9
F9
2.9
3.1
Code
Min
Max
HW2
6000
8000
HW3
8000
10000
HW4
10000
12000
HW5
12000
14000
HW6
14000
16000
HW7
16000
18000
HW8
18000
20000
Unit
mcd
Test conditions
IF=5mA
Voltage grading
Unit
Test conditions
V
IF=5mA
Unit
Test conditions
K
IF=5mA
Wavelength grading
4
Typical Characteristics Curves
5
色区:
Color zone:
Y
0.4
0.35
E1
E2
E3
D1
E4
D2
E5
D3
C1
0.30
D4
C2
D5
C3
C4
B1
B2
C5
B3
B4
A1
B5
A2
A3
0.25
A4
A5
0.20
0.20
0.25
0.30
0.35
0.40
X
备注:红色部分为主产色区
Note: the red part is the main color producing area
6
Bin Code
A1
A2
A3
A4
A5
CIE-X
CIE-Y
0.2459
Bin Code
CIE-X
CIE-Y
0.259
0.2569
0.2569
0.2785
0.2604
0.273
CIE-X
CIE-Y
0.2785
0.2675
0.2974
0.2675
0.2974
0.2788
0.3175
0.2708
0.2914
0.2817
0.3108
0.2498
0.2541
0.2604
0.273
0.2708
0.2914
0.2459
0.259
0.2569
0.2785
0.2675
0.2974
0.2498
0.2541
0.2604
0.273
0.2708
0.2914
0.2604
0.273
0.2708
0.2914
0.2817
0.3108
0.264
0.2674
0.2741
0.2854
0.2846
0.3041
0.2537
0.2491
0.264
0.2674
0.2741
0.2854
0.2498
0.2541
0.2604
0.273
0.2708
0.2914
0.2537
0.2491
0.264
0.2674
0.2741
0.2854
0.264
0.2674
0.2741
0.2854
0.2846
0.3041
0.2675
0.2619
0.2773
0.2794
0.2874
0.2973
0.2575
0.2441
0.2675
0.2619
0.2773
0.2794
0.2537
0.2491
0.264
0.2674
0.2741
0.2854
0.2575
0.2441
0.2675
0.2619
0.2773
0.2794
0.2675
0.2619
0.2773
0.2794
0.2874
0.2973
0.271
0.2563
0.2806
0.2734
0.2903
0.2906
0.2614
0.2392
0.271
0.2563
0.2806
0.2734
0.2575
0.2441
0.2675
0.2619
0.2773
0.2794
0.2614
0.2392
0.271
0.2563
0.2806
0.2734
0.271
0.2563
0.2806
0.2734
0.2903
0.2906
0.2746
0.2508
0.2839
0.2673
0.2932
0.2839
0.2653
0.2342
0.2746
0.2508
0.2839
0.2673
0.2614
0.2392
0.271
0.2563
0.2806
0.2734
B1
B2
B3
B4
B5
Bin Code
C1
C2
C3
C4
C5
7
Bin Code
D1
D2
D3
D4
D5
CIE-X
CIE-Y
0.2788
Bin Code
CIE-X
CIE-Y
0.3175
0.2898
0.337
0.2898
0.337
0.3007
0.3565
0.2923
0.3297
0.303
0.3486
0.2817
0.3108
0.2923
0.3297
0.2788
0.3175
0.2898
0.337
0.2817
0.3108
0.2923
0.3297
0.2923
0.3297
0.303
0.3486
0.2949
0.3224
0.3052
0.3407
0.2846
0.3041
0.2949
0.3224
0.2817
0.3108
0.2923
0.3297
0.2846
0.3041
0.2949
0.3224
0.2949
0.3224
0.3052
0.3407
0.2974
0.3151
0.3074
0.3328
0.2874
0.2973
0.2974
0.3151
0.2846
0.3041
0.2949
0.3224
0.2874
0.2973
0.2974
0.3151
0.2974
0.3151
0.3074
0.3328
0.3
0.3078
0.3096
0.3249
0.2903
0.2906
0.3
0.3078
0.2874
0.2973
0.2974
0.3151
0.2903
0.2906
0.3
0.3078
0.3
0.3078
0.3096
0.3249
0.3025
0.3005
0.3118
0.317
0.2932
0.2839
0.3025
0.3005
0.2903
0.2906
0.3
0.3078
E1
E2
E3
E4
E5
8
试验项目
Test Items
试验条件
Test Conditions
可焊性试验
焊接温度(Solder Temperature):300℃
焊接时间(Solder Duration):(3.5±0.5)sec.
Solderability
5 次循环
温度快速变化继之以
试验数量
Quantity
判断标准
Judging Criteria
15
上锡面积在 95%以上
湿润良好
Solderable Area
Over 95%
-40℃ → 10 min.
转移
Shift
5 Cycles
(2~3) min.
100℃ → 10 min.
循环湿热
11
C=0 & I**
15
C=0 & I**
1000 hrs.
正向电流: 20mA
Forward Current:20mA
22
C=0 & I*
100℃ → 1000 hrs.
15
C=0 & I*
11
C=0 & I*
Thermal Shock Followed by
High TemperatureAnd High
Humidity Cyclic
25℃~55℃
(90%~95%)RH
2 次循环 48 hrs. ,恢复 2 hrs.
2 Cycles for 48 hrs., Recover for 2 hrs.
红外回流焊法
耐焊接热试验
Resistance For Soldering Heat
Reflow Soldering
电耐久性试验
DC Operating Life
高温贮存试验
High Temperature Storage
25℃~55℃
循环湿热
High Temperature And High
Humidity Cyclic
*1
(90%~95%)RH
6 次循环 144 hrs. ,恢复 2 hrs.
6 Cycles for 144 hrs., Recover for 2 hrs.
Criteria For Judging Damage
测试项目
失效判断标准 I*
失效判断标准 I**
Items
符号
测试条件
Symbol
Test Conditions
Criteria For Judging Damage I*
Criteria For Judging Damage I**
正向电压
VF
IF=20mA
≥USL×1.2
≥USL
IR
VR=5V
≥USL×2.0
≥USL
IV
IF=20mA
≤LSL×0.5
≤LSL
Forward Voltage
反向电流
Reverse Current
光强
Luminous Intensity
* USL:标准值上限值,LSL:标准值下限值
* USL: Upper Standard Level, LSL: Lower Standard Level
9
Outline Dimension
注: 1. 单位 : 毫米(mm) Unit: mm
2. 公差 :如无特别标注则为± 0.1 mm
Tolerances: ± 0.1 mm if unmarked.
10
1
Packaging (1)
Carrier Tape
单位: mm ,未注公差: ±0. 1 mm
All dimensions in mm, tolerances unless mentioned is ±0. 1 mm.
Details Of Carrier Tape
前进方向 Progressive Direction
A:盖带,300 mm;B:引导,空带,200mm;C:编载产品 3000 只; D:尾部,空带,200mm
A: Top Cover Tape, 300mm; B: Leader, Empty, 200mm; C:3000 Lamps Loaded; D: Trailer, Empty, 200mm.
Reel Dimension
11
2
Packaging (2)
12
1
Guideline for Soldering (1)
1.
Hand Soldering
推荐使用功率低于 20W 的烙铁,焊接时烙铁的温度必须保持在 300℃以下,且每个电极只能进行一次焊
接,每次焊接的持续时间不得超过 3 秒。
人手焊接过程中的不慎操作易引起 LED 产品的损坏,应当小心谨慎。
A soldering iron of less than 20W is recommended to be used in Hand Soldering. Please keep the temperature of
the soldering iron under 300℃ while soldering. Each terminal of the LED is to go for less than 3 second and for one
time only.
Be careful because the damage of the product is often started at the time of the hand soldering.
2.
推荐使用以下无铅回流焊接温度图进行。
Reflow Soldering: Use the conditions shown in the under Figure ofPb-Free Reflow Soldering.
有铅制程Lead process
无铅制程Lead free
· 回流焊接最多只能进行两次。
Reflow soldering should not be done more than two times.
· 在回流焊接升温过程中,请不要对 LED 施加任何压力。
Stress on the LEDs should be avoided during heating in soldering process.
· 在焊接完成后,待产品温度下降到室温之后,再进行其他处理。
After soldering, do not deal with the product before its temperature drop down to room temperature.
13
2
Guideline for Soldering (2)
3.
Cleaning
在焊接后推荐使用酒精进行清洗,在温度不高于 30℃的条件下持续 3 分钟, 不高于 50℃的条件下持续 30
秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部分造成损伤。
超声波清洗也是有效的方法,一般最大功率不应超过 300W ,否则可能对 LED 造成损伤。请根据具体的
情况预先测试清洗条件是否会对 LED 造成损伤。
It is recommended that alcohol be used as a solvent for cleaning after soldering. Cleaning is to go under 30℃ for
3 minutes or 50℃ for 30 seconds. When using other solvents, it should be confirmed beforehand whether the solvents
will dissolve the package and the resin or not.
Ultrasonic cleaning is also an effective way for cleaning. But the influence of Ultrasonic cleaning on LED
depends on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W. Before
cleaning, a pretest should be done to confirm whether any damage to LEDs will occur.
此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响,
请根据特定的PCB设计和焊接设备来确定焊接方案。
Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment.
The technics in practise is influenced by many factors, it should be specialized base on the PCB designs
and configurations of the soldering equipment..
14
1
Precautions (1)
1.
Storage
· 本产品使用密封防潮抗静电袋包装,并附有干燥剂,未开封的产品有一年的保存时间。
Moisture proof and anti-electrostatic package with moisture absorbent material is used, to keep moisture to a
minimum.
· 开封前,产品须存放在温度不高于 30℃,湿度不高于 60%RH 的环境中。
Before opening the package, the product should be kept at 30℃ or less and humidity less than 60% RH, and be
used within a year.
· 开封后,产品须存放在温度不高于 30℃,湿度不高于 10%RH 的环境中,且应该在 168 小时(7 天) 内使
用完。建议工作环境为温度不高于 30℃,湿度不高于 60%RH。
After opening the package, the product should be stored at 30℃ or less and humidity less than 10%RH, and be
soldered within 168 hours (7 days). It is recommended that the product be operated at the workshop condition of
30℃ or less and humidity less than 60%RH.
· 对于尚未焊接的 LED,如果吸湿剂或包装失效,或者产品没有符合以上有效存储条件,烘焙可以起到一定
的性能恢复效果。烘焙条件: (60±5)℃,持续 24 小时。
If the moisture absorbent material has fade away or the LEDs have exceeded the storage time, baking treatment
should be performed based on the following condition: (60±5)℃ for 24 hours.
2.
Static Electricity
静电和电涌会导致产品特性发生改变,例如正向电压降低等,如果情况严重甚至会损毁产品。所以在使用时必须采
取有效的防静电措施。
所有相关的设备和机器都应该正确接地,同时必须采取其他防止静电和电涌的措施。
使用防静电手环,防静电垫子,防静电工作服、工作鞋、手套,防静电容器,都是有效的防止静电和电涌的措施。
Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristic such
as the forward voltage becomes lower, or the LEDs do not light at the low current. even not light.
All devices, equipment and machinery must be properly grounded. At the same time, it is recommended that wrist
bands or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs.
15
2
Precautions (2)
3.
Design Consideration
设计电路时,通过 LED 的电流不能超过规定的最大值,同时,还需使用保护电阻,否则,微小的电压变
化将会引起较大的电流变化,可能导致产品损毁。
建议使用以下(A)电路,该电路能够很好的调节通过每个 LED 的电流; 不推荐使用(B)电路,该电路
在持续的电压驱动下,LED 的正向电压(VF )发生变化,电流会随之而发生变化,可能使某些 LED 承受高于
规定的电流值。
In designing a circuit, the current through each LED must not exceed the absolute maximum rating specified for
each LED. In the meanwhile, resistors for protection should be applied, otherwise slight voltage shift will cause big
current change, burn out may happen.
It is recommended to use Circuit A which regulates the current flowing through each LED rather than Circuit B.
When driving LEDs with a constant voltage in Circuit B, the current through the LEDs may vary due to the variation
in Forward Voltage (VF) of the LEDs. In the worst case, some LED may be subjected to stresses in excess of the
Absolute Maximum Rating.
(A)
(B)
LED 的特性容易因为自身的发热和环境的温度的改变而发生改变。温度的升高会降低 LED 的发光效率、
影响发光颜色等,所以在设计时应充分考虑散热的问题。
Thermal Design is paramount importance because heat generation may result in the Characteristics decline,
such as brightness decreased, Color changed and so on. Please consider the heat generation of the LEDs when
making the system design.
16
3
Precautions (3)
4.
Others
直接用手拿取产品不但会污染封装树脂表面,也可能由于静电等因素导致产品性能的改变。过度的压力也
直接影响封装内部的管芯和金线,因此请勿对产品施加过度压力,特别当产品处于高温状态下,例如在回
可能
流焊接过
程中。
When handling the product, touching the encapsulant with bare hands will not only contaminate its surface, but
also affect on its optical characteristics. Excessive force to the encapsulant might result in catastrophic failure of the
LEDs due to die breakage or wire deformation. For this reason, please do not put excessive stress on LEDs, especially
when the LEDs are heated such as during Reflow Soldering.
LED 的环氧树脂封装部分相当脆弱,请勿用坚硬、尖锐的物体刮、擦封装树脂部分。在用镊子夹取的时
候也应当小心注意。
The epoxy resin of encapsulant is fragile, so please avoid scratch or friction over the epoxy resin surface. While
handling the product with tweezers, do not hold by the epoxy resin, be careful.
5.
Safety Advice For Human Eyes
LED 发光时,请勿直视发光光源,特别是对于一些光强较高的 LED ,强光可能伤害你的眼睛。
Viewing direct to the light emitting center of the LEDs, especially those of great Luminous Intensity, will cause
great hazard to human eyes. Please be careful.
17
很抱歉,暂时无法提供与“XL-3215UWC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.15000
- 100+0.14000
- 300+0.13000
- 500+0.12000
- 2000+0.11500
- 5000+0.11200
