LEG SERIES
RAYEX ELEC.
FEATURES
·10A cube relay
·1 Form C ( 1PDT) contact arrangement
·Plastic material applied in high temperature and better
chemical solution.
·Sealed type for washing procedure
UL FILE NO. : E126157
CUL FILE NO. : E126157
TUV FILE NO. : R9754097
·Using at home appliances, office machines, audio
equipment, coffee pot , control units, etc.
ORDERING INFORMATION
LEG 1A
1
12 H
2
3
4
1. Type
2. Contact Arrangement
Nil : 1 Form C(1PDT)
1A : 1 Form A(1PST-NO)
3. Coil Nominal Voltage
4 Nil:10A
H: 5A
COIL DATA(0.36W, at 25 )
Maximum
Pick Up
Voltage (V)
Minimum
Drop Out
Voltage (V)
Coil Nominal
Voltage
(VDC)
Resistance Tol. ± 10%
(Ohms )
Nominal Current
(mA)
3
25
120
2.1
0.3
5
70
72
3.5
0.5
6
100
60
4.2
0.6
9
225
40
6.3
0.9
12
400
30
8.4
1.2
24
1,600
6,400
15
16.8
2.4
33.6
4.8
48
7.5
CONTACT RATING
UL
Resistive (Cos.q
= 1)
AC 240V / DC 24V
10A
Inductive (Cos.q
= 0.4 )
AC 240V
AC 120V
AC 240V / DC 24V
AC 240V
5A
Resistive (Cos.q
= 1)
TUV
Inductive (Cos.q
= 0.4 )
10A
7A
3A
DIMENSIONS(±0.2mm)
15
4
15
19
0.3
12
1.0-2(P)
0.6-2(P)
WIRING DIAGRAM
(BOTTOM VIEW)
1A
6
15
12
1C
P.C.B LAYOUT
(BOTTOM VIEW)
5-Ø1. 3
2
12.2
3.65
GENERAL DATA
Insulation Resistance
Dielectric Strength
Contact Material
Contact Resistance
Shock Resistance
Vibration Resistance
Operation Time
Release Time
Temperature Range
100 MW
Min. (DC 500V)
750 VAC, 50/60Hz between contact.
1,500 VAC, 50/60Hz between all elements.
Ag alloy.
100 milliohms max. ( initial value )
Malfunction: 10G(11ms) ; Destructive: 100G(6ms)
Malfunction: 10 to 55 Hz. at Double Amplitude of 1.5 mm
Destructive: 10 to 55 Hz. at Double Amplitude of 1.5 mm
8 ms max.
5 ms max.
- 25 oC ~ + 80 oC
Expected Life
With operation rate 30/min.
Mechanical - 10,000,000 operations min.
Electrical - 100,000 operations min. at rated load.
Weight
9 grams
很抱歉,暂时无法提供与“LEG-12”相匹配的价格&库存,您可以联系我们找货
