SUR CONNECTOR
Emboss Tape
SUR CONNECTOR
0.8mm pitch/Disconnectable Insulation displacement connectors
SUR/SIDE
SUR CONNECTOR
Specifications
• Current rating: 0
.5 A AC, DC (AWG #32)
0.2 A AC, DC (AWG #36)
• Voltage rating: 30 V DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 20 mΩ max.
After environmental tests / 40 mΩ max.
• Insulation resistance: 100 MΩ min.
• Withstanding voltage: 200 VAC/minute
• Applicable wire: Conductor size/ AWG #32, #36
Conductor/ 7 strands,
tin-coated copper alloy
Insulation O.D./ 0.39 mm
The world's first 0.8 mm pitch wire-to-board
insulation displacement connector.
Side entry type is only 3.9 mm depth and
1.75 mm height after mounting on the PC
board, and top entry type is only 2.2 mm
depth and 3.9 mm height.
Compared to the conventional 1.0 mm pitch
SSR connector, occupation space on the
board is reduced by 34% (side entry type).
3-point grip construction
Super fine wires are applicable
Shrouded header
Twin U-slot insulation displacement section
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
Standards
Recognized E60389
Certified LR20812
PC board layout and Assembly layout
Top entry type
Side entry type
2.25
±0.1
0.8 ±0.05
3.9
0.5 ±0.05
±0.1
1.2
1
1
1.7 ±0.1
0.7±0.1
1.2 ±0.1
±0.1
Header outline
0.35
1.1
Note: 1
. The above figure is the figure viewed from the connector mounting side.
2. Tolerances are non-cumulative: ± 0.05 mm for all centers.
3. Dimensions above should serve as a guideline. Contact JST for details.
1.75
1.7
±0.1
0.8±0.05
±0.1
3.95
0.5±0.05
±0.1
±0.1
2.3
0.7
0.3
Header
outline
±0.1
2
SUR CONNECTOR
Socket
No. of
circuits
2
3
4
5
Circuit No.1
6
1.25
1.45
1.65
8
10
12
H JST 5
14
1.7
0.8
0.8
A
15
2.9
16
17
B
Model No.
Dimensions (mm)
#36(Lemon yellow)
#32(Natural)
A
B
02SUR-36L
03SUR-36L
04SUR-36L
05SUR-36L
06SUR-36L
08SUR-36L
10SUR-36L
12SUR-36L
14SUR-36L
15SUR-36L
16SUR-36L
17SUR-36L
20SUR-36L
22SUR-36L
02SUR-32S
03SUR-32S
04SUR-32S
05SUR-32S
06SUR-32S
08SUR-32S
10SUR-32S
12SUR-32S
14SUR-32S
15SUR-32S
16SUR-32S
17SUR-32S
20SUR-32S
22SUR-32S
Q'ty /box
0.8
2.4
2,000
1.6
3.2
2,000
2.4
4.0
2,000
3.2
4.8
2,000
4.0
5.6
2,000
5.6
7.2
2,000
7.2
8.8
2,000
8.8
10.4
2,000
10.4
12.0
2,000
11.2
12.8
2,000
12.0
13.6
2,000
12.8
14.4
2,000
15.2
16.8
2,000
16.8
18.4
2,000
Material and Finish
Contact: Copper alloy, tin-plated (reflow treatment)
Housing: PA, UL94V-0
RoHS compliance
Shrouded header
No. of
circuits
Top entry type
2
B
2
3
4
2.7
5
6
8
10
0.6
A
12
1
14
15
Side entry type
16
17
B
Circuit No.1
A
0.8
22
2.7
Dimensions (mm)
Model No.
A
B
Top entry type
Side entry type
0.8
3.8
BM02B-SURS-TF SM02B-SURS-TF
4.6
1.6
BM03B-SURS-TF SM03B-SURS-TF
5.4
2.4
BM04B-SURS-TF SM04B-SURS-TF
3.2
6.2
BM05B-SURS-TF SM05B-SURS-TF
4.0
7.0
BM06B-SURS-TF SM06B-SURS-TF
8.6
5.6
BM08B-SURS-TF SM08B-SURS-TF
10.2
7.2
BM10B-SURS-TF SM10B-SURS-TF
8.8
11.8
BM12B-SURS-TF SM12B-SURS-TF
13.4
BM14B-SURS-TF SM14B-SURS-TF 10.4
14.2
BM15B-SURS-TF SM15B-SURS-TF 11.2
15.0
BM16B-SURS-TF SM16B-SURS-TF 12.0
15.8
BM17B-SURS-TF SM17B-SURS-TF 12.8
18.2
BM20B-SURS-TF SM20B-SURS-TF 15.2
19.8
SM22B-SURS-TF 16.8
Q'ty/reel
Top entry type Side entry type
2,500
3,500
2,500
3,500
2,500
3,500
2,500
3,500
2,500
3,500
2,500
3,500
2,500
3,500
2,500
3,500
2,500
3,500
2,500
3,500
2,500
3,500
2,500
3,500
2,500
3,500
3,500
Material and Finish
1.75
Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA, UL94V-0, natural
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
1
0.2
1
0.45
RoHS compliance This product displays (LF)(SN) on a label.
Note: These products listed above are supplied on embossed-tape.
Model number allocation
Socket
Shrouded header
SM 02 B - SUR S - TF
02 SUR- 32 S
Shape of assembled product:
BM…SMT top entry type
SM…SMT side entry type
No. of circuits:
Top entry type…2 to 6, 8, 10, 12, 14 to 17, 20
Side entry type…2 to 6, 8, 10, 12, 14 to 17, 20, 22
No. of circuits: 2 to 6, 8, 10, 12, 14 to 17, 20, 22
Part name: Shrouded header
Series name
Series name
Applicable wire range: 32…AWG #32, 36…AWG #36
Color: S…Natural
Color: S…Natural, L…Lemon yellow
Packaging style: TF…Embossed-taping
2
