SMD1206 SERIES
KaiLong electronics
Positive Temperature Coefficient (PTC) Data Sheet
Features
Radial leaded devices.
Over-current protection
High voltage surge capabilities
Flame retardant epoxy polymer insulating material meets UL94 V-0 requirement.
Available in lead-free version.
Meets MSL level 1, per J-STD-020
Operating Temperature: -40℃~+85℃
Applications
IT equipment
Access network equipment
Central office equipment
ISDN and xDSL equipments
Phone set and fax machine
LAN/WAN and VOIP cards
Part Number Code and Making
SMD 1206 K □□□ S
F
Lead-Free
Tin-plated Nickel-Copper
Current Rating
The company LOGO
Series code
Suface mount devices
Revision:
http://www.cattle-ptc.com
SMD1206 SERIES
KaiLong electronics
The company LOGO
SERIES code
Dimensions (Unit: mm)
Part
Number
A
B
C
D
E
MAX
MAX
MAX
MIN
MIN
SMD1206K005SF
3.50
1.80
1.30
0.15
0.10
SMD1206K010SF
3.50
1.80
1.30
0.15
0.10
SMD1206K012SF
3.50
1.80
1.30
0.15
0.10
SMD1206K020SF
3.50
1.80
1.00
0.15
0.10
SMD1206K025SF
3.50
1.80
1.00
0.15
0.10
SMD1206K035SF
3.50
1.80
1.00
0.15
0.10
SMD1206K035SF30V
3.50
1.80
1.60
0.15
0.10
SMD1206K050SF
3.50
1.80
1.00
0.15
0.10
SMD1206K050SF13.2V
3.50
1.80
1.00
0.15
0.10
SMD1206K050SF16V
3.50
1.80
1.40
0.15
0.10
SMD1206K050SF30V
3.50
1.80
1.60
0.15
0.10
SMD1206K075SF
3.50
1.80
0.80
0.15
0.10
SMD1206K075SF16V
3.50
1.80
1.40
0.15
0.10
SMD1206K075SF30V
3.50
1.80
1.60
0.15
0.10
SMD1206K100SF
3.50
1.80
0.80
0.15
0.10
SMD1206K100SF16V
3.50
1.80
1.10
0.15
0.10
SMD1206K110SF
3.50
1.80
0.80
0.15
0.10
SMD1206K150SF
3.50
1.80
1.20
0.15
0.10
SMD1206K150SF13.2V
3.50
1.80
1.40
0.15
0.10
SMD1206K200SF
3.50
1.80
1.40
0.15
0.10
SMD1206K200SF12V
3.50
1.80
1.60
0.15
0.10
SMD1206K250SF
3.60
1.90
1.60
0.15
0.10
SMD1206K260SF
3.50
1.80
1.60
0.15
0.10
SMD1206K300SF
3.50
1.80
1.60
0.15
0.10
Revision:
SMD1206 SERIES
KaiLong electronics
Electrical Characteristics
Part
Number
Vmax
Imax
Ihold
Itrip
Pdmax
MAX TIME TO
TRIP
Resistance
(V)
(A)
(A)
(A)
(W)
(A)
(s)
Rmin(Ω)
R1max
(Ω)
SMD1206K005SF
60
100
0.05
0.15
0.4
0.25
1.50
3.60
50.00
SMD1206K010SF
60
100
0.10
0.25
0.4
0.50
1.00
1.60
15.00
SMD1206K012SF
60
100
0.12
0.29
0.4
0.50
1.00
1.60
15.00
SMD1206K020SF
30
100
0.20
0.46
0.6
1.00
0.60
0.60
2.60
SMD1206K025SF
16
100
0.25
0.50
0.6
8.00
0.08
0.35
2.50
SMD1206K035SF
6
100
0.35
0.75
0.60
8.00
0.10
0.25
1.30
SMD1206K035SF30V
30
100
0.35
0.75
0.60
8.00
0.10
0.25
1.30
SMD1206K050SF
6
100
0.50
1.00
0.60
8.00
0.10
0.15
0.70
SMD1206K050SF13.2V
13.2
100
0.50
1.00
0.60
8.00
0.10
0.15
0.70
SMD1206K050SF16V
16
100
0.50
1.00
0.60
8.00
0.10
0.15
0.70
SMD1206K050SF30V
30
100
0.50
1.00
0.60
8.00
0.10
0.15
0.70
SMD1206K075SF
6
100
0.75
1.50
0.60
8.00
0.20
0.09
0.50
SMD1206K075SF16V
16
100
0.75
1.50
0.60
8.00
0.20
0.09
0.50
SMD1206K075SF30V
30
100
0.75
1.50
0.60
8.00
0.20
0.09
0.50
SMD1206K100SF
6
100
1.00
1.80
0.60
8.00
0.30
0.055
0.27
SMD1206K100SF16V
16
100
1.00
1.80
0.60
8.00
0.30
0.055
0.27
SMD1206K110SF
6
100
1.10
2.20
0.60
8.00
0.30
0.05
0.25
SMD1206K150SF
6
100
1.50
3.00
0.80
8.00
0.30
0.04
0.13
SMD1206K150SF13.2V
13.2
100
1.50
3.00
0.80
8.00
0.30
0.04
0.13
SMD1206K200SF
6
100
2.00
3.50
0.80
8.00
1.50
0.018
0.08
SMD1206K200SF12V
12
100
2.00
3.50
0.80
8.00
1.50
0.018
0.08
SMD1206K250SF
6
35
2.50
5.20
0.80
8.00
2.00
0.01
0.06
SMD1206K260SF
6
100
2.60
5.20
0.80
8.00
2.00
0.015
0.07
SMD1206K300SF
6
100
3.00
6.00
0.80
8.00
4.00
0.01
0.055
Parameter interpretation
·IH = Hold current: maximum current device will pass without tripping in 25℃ still air.
·IT = Trip current: minimum current at which the device will trip in 25℃ still air.
·VMAX = Maximum voltage device can withstand without damage at rated current.
·IMAX = Maximum fault current device can withstand without damage at rated voltage.
·RMAX = Maximum resistance of device in initial (un-soldered) state.
·RMIN = Minimum resistance of device in initial (un-soldered) state.
·Pd typ. = Typical power dissipation from device when in the tripped state at 25℃ still air.
Polymeric PTC Selecting Guide
■ Determine the following operating parameters for the circuits:
·Normal operating current (Ihold)
·Maximum interrupt current (Imax)
Revision:
SMD1206 SERIES
KaiLong electronics
·Maximum circuit voltage (Vmax)
·Normal operating temperature surrounding device (min℃/max℃)
■ Select the device from factor and dimension suitable for the application
■ Compare the maximum rating for Vmax and Imax of the PPTC device with the circuit in application and make sure
the circuit’s requirement does not exceed the device rating.
■ Check that PPTC device’s trip time (time-to-trip) will protect the circuit.
■ Verify that the circuit operating temperature is within the PPTC device’s normal operating temperature range.
■ Verify that performance and suitability of the chosen PPTC device in the application.
WARNING
■ Mechanical Stress
·PPTC devices will undergo a thermal expansion during fault condition. If PPTC devices are installed or placed in an application
where the space between PPTC devices and the surrounding materials (e.g., covering materials, packaging materials, encapsulate
materials and the like) is insufficient, it will cause an inhibiting effect upon the thermal expansion. Pressing, twisting, bending and
other kinds of mechanical stress will also adversely affect the performance of the PPTC devices, and shall not be used or applied.
■ Chemical Pollutants
·Silicone-based oils, oils, solvents, gels, electrolytes, fuels, acids, and the like will adversely affect the properties of PPTC devices,
■ Electronic and Thermal Effect
·PPTC devices are secondary protection devices and are used solely for sporadic, accidental over-current or over-temperature
error condition, and shall NOT be used if or when constant or repeated fault conditions (such fault conditions may be caused by,
among others, incorrect pin-connection of a connector) or over-extensive trip events may occur.
·PPTC devices are different from fuses and, when a fault condition occurs, will go into high-resistance state and do not open
circuit, in which case the voltage at such PPTC devices may reach a hazardous level.
·Operation over the maximum rating or other forms of improper use may cause failure, arcing, flame and/or other damage to
the PPTC devices.
·Conductive material contamination, such as metal particle, may induce shortage, flame or arcing.
·Due to the inductance, the operation circuits may generate a circuit voltage (Ldi/dt) above the rated voltage of PPTC devices,
which shall not be used under such circumstances.
■ General
·Customers shall evaluate and test the properties of PPTC devices independently to verify and ensure that their individual
applications will be met.
·The performance of PPTC devices will be adversely affected if they are improperly used under electronic, thermal and/or
mechanical procedures and/or conditions non-conformant to those recommended by manufacturer.
·Customers shall be responsible for determining whether it is necessary to have back-up, failsafe and/or fool-proof protection
To avoid or minimize damage that may result from extra-ordinary, irregular function or failure of PPTC devices.
·Any and all responsibilities and liabilities are disclaimed if any item under this notice of warning is not complied with.
Revision:
KaiLong electronics
SMD1206 SERIES
Thermal Derating Curve
Storage Recommendations
Storage Temperature: -10℃~+40℃
Relative Humidity: ≤80%RH
Keep away from corrosive atmosphere and sunlight.
Period of Storage: 1 year.
Revision:
很抱歉,暂时无法提供与“SMD1206K010SF60V”相匹配的价格&库存,您可以联系我们找货
