SFH876BA402
SFH876BA402
    WISOL(威盛)
    SMD,1.1x0.9mm
    SFH876BA402
SFH876BA402 数据手册
SPECIFICATION Surface Acoustic Wave Filter USER USER PART No. WISOL PART No. SFH876BA4 SFH876BA402 876BA402 DOC. No. SMSSMS-5151-L-SFTSFT-FXFX-90 DATE November 3, 2015 REVISION 000 WISOL Kang, Yeon-shin Byun, Kyung-Su Yang, Jang-Won ISSUED APPROVED APPROVED BY BY (R&D) BY (QC) User ISSUED CHECKED APPROVED BY BY BY WISOL CO., LTD. 531-7, Gajang-ro, Osan-si, Gyeonggi-do, KOREA, 18103 http://www.wisol.co.kr Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 ▶ A TABLE OF CONTENTS CONTENTS 1. REVISION HISTORY..................................................................................................................................... 3 2. DEFINITION .................................................................................................................................................. 4 3. PRECAUTIONS ............................................................................................................................................. 4 4. OUTLINE DRAWING & DIMENSIONS.......................................................................................................... 5 DIMENSIONS 5. MARKING ...................................................................................................................................................... 6 6. PERFORMANCE ........................................................................................................................................... 7 6-1. MAXIMUM RATINGS .......................................................................................................................... 7 6-2. ELECTRICAL CHARACTERISTICS ................................................................................................... 8 7. RELIABILITY ............................................................................................................................................... 10 7-1. ENGINEERING SAMPLE FLOW CHART ......................................................................................... 10 7-2. TEST ITEM & CONDITION ................................................................................................................ 11 8. REFLOW CONDITION ................................................................................................................................ 12 9. RECOMMENDED PCB DIMENSIONS ....................................................................................................... 12 10. CAUTION ................................................................................................................................................... 13 11. PACKING ................................................................................................................................................... 14 11-1. DIMENSIONS.................................................................................................................................. 14 11-2. REELING QUANTITY ..................................................................................................................... 15 11-3. TAPING STRUCTURE .................................................................................................................... 15 11-4. INNER BOX(Reel Packing) STRUCTURE...................................................................................... 16 11-5. OUTER BOX STRUCTURE ............................................................................................................ 17 12. TAPE SPECIFICATIONS .......................................................................................................................... 18 13. RoHS DATA ............................................................................................................................................... 19 SMS-51-L-SFT-FX-90 Page 2/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 1. REVISION HISTORY 000 November 3, 2015 SMS-51-L-SFT-FX-90 All Page Make specification Page 3/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter SFH876BA SFH876BA402 LTE Rx 876MHz Band 26 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 2. DEFINITION 2-1. PART No. S F H 876 B A 4 0 2 ① ② ② ④ ⑤ No. ① ② ③ ④ ⑤ ⑥ ⑥ EXPLANATION SAW Filter Design Type Center Frequency : 876MHz(859 ~ 894) Input:50ohm,Output:50ohm Package size: 1.1×0.9mm² Design Revision (02 : Molding Type) 2-2. APPLICATION : Band-Pass Filter for LTE Rx etc (Band 26) 3. PRECAUTIONS 3-1. This device should not be used in any type of fluid such as water, oil, organic solvent, etc. 3-2. This is a hermetic device. MSL(Moisture Sensitive Level) is the '2a' level. 3-3. Ultrasonic cleaning shall be avoided. 3-4. Isopropyl Alcohol and Ethyl Alcohol can be used for cleaning. Contact us before using other cleaning solvents than above 3-5. This is an electrostatic sensitive device. Please avoid static voltage during operation and storage. 3-6. Sudden change of temperature shall be avoided, deterioration of the characteristics can occur. 3-7. If any malfunction due to designing or manufacturing which is out of specification occurs within one year after the products have been delivered, the maker should exchange the defective products. SMS-51-L-SFT-FX-90 Page 4/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 4. OUTLINE DRAWING & DIMENSIONS [Unit: mm] 4UX O X SMS-51-L-SFT-FX-90 Page 5/25 No. Function 2, 3, 5 Ground 1 Unbalanced Input 4 UnBalanced Output November 3, 2015 Surface Acoustic Acoustic Wave Filter SFH876BA SFH876BA402 LTE Rx 876MHz Band 26 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 5. MARKING 4UX O X 5-1. 4 U X st nd - The 1 2 character '4U' indicates the model name of SAW Filter SFH876BA402. rd - The 3 character 'X' indicates the year and the month of manufacture. Month Year 1 2 3 4 5 6 7 8 9 10 11 12 2014 2014 1 2 3 4 5 6 7 8 9 A B C 2015 2015 D E F G H I J K L M N O 2016 2016 P Q R S T U V W X Y Z a 2017 2017 1 2 3 4 5 6 7 8 9 A B C ※ This rotates by the 3 years. - The 5-2. th 4 character 'X' indicates Lot No. ○ - This symbol indicates input pin 1. - This indicates the producing center ○: China 5-3. Marking : Laser Marking SMS-51-L-SFT-FX-90 Page 6/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 6. PERFORMANCE 6-1. MAXIMUM RATINGS CHARACTERISTICS RATINGS UNITS DC Permissive Voltage 5 V Maximum Input Power 15 dBm Operating Temperature Range -30 ~ +85 Storage Temperature Range -40 ~ +85 SMS-51-L-SFT-FX-90 Page 7/25 ℃ ℃ November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 6-2. ELECTRICAL CHARACTERISTICS 6-2-1. TABLE -30 ~ +85℃ Ta = SPECIFICATION FREQUENCY RANGE [MHz] UNIT Insertion Loss 859 ~ 894 Inband Ripple Item Min. Typ. (25 ) Max. dB - 2.0 3.2 859 ~ 894 dB - 1.0 2.0 Input VSWR 859 ~ 894 - - 1.8 2.3 Output VSWR 859 ~ 894 - - 1.8 2.3 1 ~ 447 dB 40 43 - 45 dB 45 62 - 814 ~ 849 dB 38 45 - 849 ~ 854 dB 2.2 7 - 909 ~ 979 dB 22 30 - 1710-1785 dB 38 46 - 1850-1915 dB 37 45 - 1920-1980 dB 36 44 - 2400-2500 dB 30 38 - 2577-2682 dB 28 36 - 4900-5950 dB 20 29 - Absolute Attenuation ℃ Input: Unbalanced 50 ohm Output: Unbalanced 50 ohm Termination Impedance 6-2-2. TEST FIXTURE [X—Ray Top View] SMS-51-L-SFT-FX-90 Page 8/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter SFH876BA SFH876BA402 LTE Rx 876MHz Band 26 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 6-2-3. GRAPH NearBand 0 -10 [dB] -20 -30 -40 -50 -60 -70 0.726 0.776 0.826 0.876 0.926 Frequency (GHz) 0.976 1.026 5 6 Fullband 0 -10 [dB] -20 -30 -40 -50 -60 -70 0 SMS-51-L-SFT-FX-90 1 2 3 4 Frequency (GHz) Page 9/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 7. RELIABILITY 7-1. ENGINEERING SAMPLE FLOW CHART Initial Characteristics Electrical Parametric Data@25 ℃ Preconditioning (MSL 2a) (JESD22-A113) (n=191) HTS (n=23) ESD(HBM) (n=9) Board Level Drop (n=11) LTS (n=23) ESD(HBM) LIMIT (n=3) Bending (n=11) uHAST (n=23) ESD(MM) (n=9) Solder Heat (n=11) THS (n=23) ESD(CDM) (n=6) Solderability (n=11) Temp. Drift (n=5) TC (n=23) Final Electrical Data (n=115) SMS-51-L-SFT-FX-90 Final Electrical Data (n=27) Page 10/25 Final Electrical Data (n=49) November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 7-2. TEST ITEM & CONDITION CATEGORY TEST ITEM Preconditioning TEST CONDITION REMARK Bake + Soak(MSL or above) + 3X Reflow duration ( Soak 60 60% 120HR) ℃ JESD22-A113 TEST ITEM REMARK TEST CONDITION Duration HTS (High Temperature Storage) JESD22-A103 condition A 125(-0/+10)℃ 1000hr LTS (Low Temperature Storage) JESD22-A119 A -40(-10/+0)℃ 1000hr uHAST (Unbiased HAST) JESD22-A118 130℃ /85% /33.3psi 96hr THS (Temperature Humidity Storage) JESD22-A101 85℃ /85% RH 1000hr TC (Temperature Cycle) JESD22-A104 Condition G (-40℃ /125℃) 1000cycle ESD(HBM) JESD22-A114 250V or above - ESD(HBM) LIMIT - 300V or above - ESD(MM) JESD22-A115 No spec butneed data - ESD(CDM) JESD22-C101 500V or above - Board Level Drop Test JESD22-B111 1500G Duration 0.5ms 150cycle Bending Test 0.5㎜/sec 3times (1mm distance) Solder Heat Resistance 260℃ 10sec Solderability 235℃ 3sec Temp Drift -40℃ → +25℃ → +125℃ Per conditions 2HR SMS-51-L-SFT-FX-90 Page 11/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 8. REFLOW CONDITION 9. RECOMMENDED PCB DIMENSIONS [unit : mm] [SAW, X-ray Top view] SMS-51-L-SFT-FX-90 [PCB, X-ray Top view] Page 12/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 10. CAUTION Moisture Sensitivity Device Caution (MSL LEVEL=2a) 1. Calculated shelf life in sealed bag : 12 month at 〈40 and 〈90% relative Humidity(RH) 2. Peak package body temperature : 260 3. After bag is opened, devices that will be subjected to reflow solder or other high temperature process must be (a) Mounted within : 672 hours of factory conditions ≤30 /60% RH, or (b) Stored per J-STD-033 4. Device require bake, before mounting, if : (a) Humidity Indicator Card reads 〉60% when read at 23±5 (b) 3(a) or 3(b) are not met 5. If baking is required, refer to IPC/JEDEC J-STD-033 for bake procedure Note : Level and body temperature defined by IPC/JEDEC J-STD-020 ℃ ℃ ℃ ℃ Aluminum Pack (310mmΧ370mm) HIC(Humidity Indication Card) 10 to 60% RH SMS-51-L-SFT-FX-90 Page 13/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter SFH876BA SFH876BA402 LTE Rx 876MHz Band 26 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 11. PACKING 11-1. DIMENSIONS - Carrier Tape [Unit: mm] A B D0 D1 E F P0 P1 P2 t1 t2 W 1.08 +0.05 -0.05 1.23 +0.05 -0.05 Ø1.50 +0.10 -0.00 Ø0.50 +0.01 1.75 +0.10 -0.10 3.50 +0.05 -0.05 4.00 +0.05 -0.05 4.00 +0.05 -0.05 2.00 +0.05 -0.05 0.23 +0.05 -0.05 0.70 +0.05 -0.05 8.00 +0.30 -0.10 - Reel [Unit: mm] A B C D E F G H t1 t2 W Ø258.0 +1.0 -0.5 Ø81.0 +1.0 -1.0 Ø13.0 +0.5 -0.5 50.0 +0.8 -0.8 2.2 +0.3 -0.3 7.0 +0.5 -0.5 30.0 +0.8 -0.8 35.0 +1.0 -1.0 1.8 +0.5 -0.5 1.5 +0.5 -0.5 9.0 +1.0 -0.5 - The product shall be packed properly not to damaged during transportation and storage. SMS-51-L-SFT-FX-90 Page 14/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 11-2. REELING QUANTITY 10 inch reel : 10,000 pcs/reel 11-3. TAPING STRUCTURE 11-3-1. The tape shall be wound around the reel in direction shown below. 4UX O X 4UX O X 11-3-2. BAR CODE LABEL ① MODEL NAME BARCODE ② Model Name ③ Reel number ④ Quantity / Marking SMS-51-L-SFT-FX-90 Page 15/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 1-3-3. Leader part and vacant position specifications. 11-4. INNER BOX(Reel Packing) STRUCTURE Material: Polycarbonate Material : Polyethylene + Aluminium 2 Size : 310×370mm Material Size: : Paper 3 (D)260×(W)37×(H)265mm SMS-51-L-SFT-FX-90 Page 16/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter SFH876BA SFH876BA402 LTE Rx 876MHz Band 26 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 11-5. OUTER BOX STRUCTURE Material : Paper SIZE(mm) a b c Inner Box # 270 240 275 6 boxes TYPE A SIDE ① SIDE ② MODEL Q'TY EA USER DATE . . - SIDE is the same as front side. SMS-51-L-SFT-FX-90 Page 17/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 12. TAPE SPECIFICATIONS 12-1. Tensile Strength of Carrier Tape: 4.4N/mm width 12-2. Top Cover Tape Adhesion (See the below figure) - pull of angle: 0~15 degree - speed: 300mm/min. - force: 20~70g SMS-51-L-SFT-FX-90 Page 18/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Version : 000 13. RoHS DATA SMS-51-L-SFT-FX-90 Page 19/25 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SMS-51-L-SFT-FX-90 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Page 20/25 Version : 000 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SMS-51-L-SFT-FX-90 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Page 21/25 Version : 000 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SMS-51-L-SFT-FX-90 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Page 22/25 Version : 000 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SMS-51-L-SFT-FX-90 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Page 23/25 Version : 000 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SMS-51-L-SFT-FX-90 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Page 24/25 Version : 000 November 3, 2015 Surface Acoustic Acoustic Wave Filter LTE Rx 876MHz Band 26 SMS-51-L-SFT-FX-90 SFH876BA SFH876BA402 3 3 1.1× 1.1×0.9× 0.9×0.5mm 0.5mm 5pin laylay-out Page 25/25 Version : 000 November 3, 2015
SFH876BA402 价格&库存
很抱歉,暂时无法提供与“SFH876BA402”相匹配的价格&库存,您可以联系我们找货
SFH876BA402
    • 116+1.02150
    • 200+0.93630
    • 500+0.85130
    库存:14487
