Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
Applicable standard 2
Voltage
3
2
Current
3
UL : UL1977,
RATING
2
C-UL : CSA22.2 No.182.3-M1987,
250 V AC/DC(UL/C-UL)
150V AC/DC(TÜV)
20 A (AMBIENT TEPM 25℃)
13 A (UL/C-UL)
15 A (TÜV)
TÜV : EN61984:2009
Operating
Temperature Range
Operating
Humidity Range
Storage
Temperature Range
(3)
-55 C
to
105 C
(1)
Relative Humidity 85% max
(Not dewed)
Storage Humidity Range
-10 C
to
60 C
40 %
to
70 %
(2)
(2)
SPECIFICATIONS
ITEM
CONSTRUCTION
TEST METHOD
General Examination
Marking
REQUIREMENTS
Visually and by measuring instrument.
Confirmed visually.
QT AT
According to drawing.
2 mΩMAX.
1000 MΩMIN.
No flashover or breakdown.
Insertion Force:
25 N MAX.
Withdrawal Force:
1.0 N MIN.
① Contact Resistance: 5 mΩMAX.
② No damage, crack and looseness of parts.
① No electrical discontinuity of 1 s.
ELECTRIC CHARACTERISTICS
Contact Resistance
Insulation Resistance
Voltage Proof
10 mA(DC or 1000Hz)
250 V DC.
750 V AC for 1 min.
4
4
MECHANICAL CHARACTERISTICS
Insertion and
Withdrawal Forces
Mechanical Operation
Measured by applicable connector.
Vibration
Frequency 10 to 55 to 10Hz, approx 5min
Single amplitude : 0.75 mm, 10 cycles
for 3 axial directions.
490 m/s2 , duration of pulse 11 ms,
3 times to both directions in 3 axial directions.
100 times insertions and extractions.
Shock
ENVIRONMENTAL CHARACTERISTICS
90 ~ 95 %,
96 ±4h.
① Contact Resistance: 5mΩ MAX.
② Insulation Resistance: 1000 M MIN.
③ No damage, crack and looseness of parts.
Damp Heat
(Steady State)
Exposed at 40±2 C,
Rapid Change of
Temperature
Temperature -55 → +105 C
Time
30 →
30
min.
under 5 cycles.
(Relocation time to chamber: within 2~3 MIN)
Dry heat
Exposed at +105±2℃ for 96±4h.
Cold
Exposed at -55±2℃ for 96±4h.
Sulfur Dioxide
Exposed at 25±2℃, 75±5%RH,
25 PPM for 96h±4h.
Resistance to
Soldering Heat
Solder bath : Solder temperature 260±5℃
for immersion, duration 10±1sec.
Soldering irons : 380℃ MAX. for 10 sec.
② No defect such as corrosion which impairs
the function of connector.
No deformation of case of excessive looseness
of the terminal.
A new uniform coating of solder shall cover a
minimum of 95 % of the surface being immersed.
1
Solderability
Soldered at solder temperature 240±3℃
for immersion, duration 3 sec.
COUNT
DESCRIPTION OF REVISIONS
4
2
DIS-F-00002346
REMARKS (1) Include temperature rise caused by current-carrying.
DESIGNED
TS.OONO
“Storage” means a long-term storage state
for the unused product before assembly to PCB.
(3)
Pollution degree:2 type of terminals :dip solder contacts.
Note
QT:Qualification Test
FORM HD0011-2-1
AT:Assurance Test X:Applicable Test
PART NO.
CODE NO.
HT.YAMAGUCHI
17.05.12
HS.OKAWA
13.03.07
CHECKED
KI.HIROKAWA
13.03.07
DESIGNED
DK.AIMOTO
13.03.07
DRAWN
DK.AIMOTO
13.03.07
DRAWING NO.
SPECIFICATION SHEET
DATE
APPROVED
(2)
Unless otherwise specified, refer to JIS-C-5402,IEC60512.
CHECKED
ELC4-347267-00
FX30B-5P-3.81DSA30
CL570-3303-0-00
4
1/2
3
FX30B 水平 5芯 (通常 - 通常)
FX30B Horizontals 5-contacts
軽減曲線(ディレーティングカーブ)
Derating curve
40.00
35.00
carrying [A]
Current通電電流[A]
30.00
25.00
20.00
15.00
10.00
5.00
0.00
40
50
Ambient
60
周囲温度[℃]
temperature
70
80
90
100
110
120
80
90
100
110
120
FX30B Horizontal 5-contacts
温度上昇曲線
Temperature
rise curve
40.00
35.00
30.00
carrying [A]
Current
通電電流[A]
[REFERENCE]
25.00
20.00
15.00
10.00
5.00
0.00
40
50
60
70
Temperature
rise [℃]
温度上昇[℃]
(note 4) Derating curve takes manufacturing tolerances into consideration as well as uncertainties
in temperature measurement and the measuring set up and is derived from the base curve
multiplied by 0.8 calculation.
(note 5) The value of rated current differs depending on the ambient temperature.
it is recommended to use the product within the derating curve zone.
if used under UL or TUV standard, please use within the standard specification.
(note 6) Measurement method of derating curve is shown below.
・Test Specimen:used FX30B-5P-3.81DS.
used FX30B-5S-3.81DS.
・Test condition:Turn on electricity under the static state and measure.
(Test report # TR570E-20627)
Note
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC4-347267-00
FX30B-5P-3.81DSA30
CL570-3303-0-00
4
2/2
很抱歉,暂时无法提供与“FX30B-5P-3.81DSA30”相匹配的价格&库存,您可以联系我们找货
