HSBA3052
N-Ch 30V Fast Switching MOSFETs
Description
Product Summary
The HSBA3052 is the high cell density Trench
MOSFET, which provide excellent RDSON and
gate charge for DC/DC converters application.
The HSBA3052 meet the RoHS and Green
Product requirement, 100% EAS guaranteed with
full function reliability approved.
100% EAS Guaranteed
Green Device Available
Super Low Gate Charge
Low RDS(ON)
Advanced high cell density Trench
technology
VDS
30
V
RDS(ON),TYP
5
mΩ
ID
52
A
PRPAK5X6 Pin Configuration
Absolute Maximum Ratings
Symbol
Parameter
Rating
Units
VDS
Drain-Source Voltage
30
V
VGS
Gate-Source Voltage
±20
V
ID@TC=25℃
Continuous Drain Current, VGS @ 10V1
52
A
ID@TC=100℃
33
A
ID@TA=25℃
25
A
ID@TA=70℃
10V1
A
125
A
28.8
mJ
24
A
24
W
IDM
EAS
IAS
PD@TC=25℃
Pulsed Drain
Current2
Single Pulse Avalanche
Energy3
Avalanche Current
Total Power
Dissipation4
TSTG
Storage Temperature Range
-55 to 150
TJ
Operating Junction Temperature Range
-55 to 150
Thermal Data
Symbol
Parameter
RθJA
Thermal Resistance Junction-Ambient
RθJC
Thermal Resistance Junction-Case1
www.hs-semi.cn
Ver 2.0
Typ.
1
Max.
Unit
50
℃/W
4.6
℃/W
1
HSBA3052
Electrical Characteristics (TJ=25 ℃, unless otherwise noted)
Symbol
Parameter
BVDSS
Drain-Source Breakdown Voltage
RDS(ON)
Static Drain-Source On-Resistance 2
VGS(th)
IDSS
Gate Threshold Voltage
Drain-Source Leakage Current
Conditions
Min.
Typ.
Max.
Unit
VGS=0V , ID=250uA
30
V
VGS=10V , ID=20A
5
6.3
VGS=4.5V , ID=15A
6.9
9
VGS=VDS , ID =250uA
1.2
2.5
VDS=24V , VGS=0V , TJ=25℃
1
VDS=24V , VGS=0V , TJ=55℃
5
±100
nA
m
V
uA
IGSS
Gate-Source Leakage Current
VGS=±20V , VDS=0V
gfs
Forward Transconductance
VDS=5V , ID=20A
67
S
Rg
Gate Resistance
VDS=0V , VGS=0V , f=1MHz
1.7
Qg
Total Gate Charge (4.5V)
8
Qgs
Gate-Source Charge
2.4
Qgd
Gate-Drain Charge
3.2
Turn-On Delay Time
7.1
Td(on)
Tr
Td(off)
Tf
Ciss
VDS=15V , VGS=4.5V , ID=15A
Rise Time
VDD=15V , VGS=10V , RG=3.3
40
Turn-Off Delay Time
ID=15A
15
6
814
498
41
Fall Time
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VDS=15V , VGS=0V , f=1MHz
nC
ns
pF
Diode Characteristics
Symbol
Min.
Typ.
Max.
Unit
Continuous Source Current 1,6
VG=VD=0V , Force Current
30
A
VSD
Diode Forward Voltage 2
VGS=0V , IS=1A , TJ=25℃
1
V
trr
Reverse Recovery Time
IF=20A , di/dt=100A/µs ,
15
nS
Qrr
Reverse Recovery Charge
TJ=25℃
25
nC
IS
Parameter
Conditions
Note :
1.The data tested by surface mounted on a 1 inch 2 FR-4 board with 2OZ copper.
2.The data tested by pulsed , pulse width ≦ 300us , duty cycle ≦ 2%
3.The EAS data shows Max. rating . The test condition is V DD=25V,VGS=10V,L=0.1mH,IAS=24A
4.The power dissipation is limited by 150℃ junction temperature
5.The data is theoretically the same as ID and I DM , in real applications , should be limited by total power dissipation.
www.hs-semi.cn
Ver 2.0
2
HSBA3052
Typical Characteristics
Fig.1 Typical Output Characteristics
Fig.2 On-Resistance vs G-S Voltage
Fig.3 Source Drain Forward Characteristics
Fig.4 Gate-Charge Characteristics
1.8
Normalized On Resistance
1.8
1.4
Normalized VGS(th)
1.4
1.0
1
0.6
0.6
0.2
0.2
-50
100
150
-50
100
TJ ,Junction Temperature (℃ )
TJ , Junction Temperature (℃)
Fig.5 Normalized VGS(th) vs TJ
Fig.6 Normalized RDSON vs TJ
www.hs-semi.cn
Ver 2.0
150
3
HSBA3052
Fig.7 Capacitance
Fig.8 Safe Operating Area
Normalized Thermal Response (RθJC)
1
DUTY=0.5
0.2
0.1
0.1
0.05
0.02
0.01
P DM
0.01
T ON
T
D = TON/T
SINGLE
TJpeak = TC+P DMXRθJC
0.001
0.00001
0.0001
0.001
0.01
0.1
1
t , Pulse Width (s)
Fig.9 Normalized Maximum Transient Thermal Impedance
EAS=
VDS
90%
BVDSS
1
L x IAS2 x
2
BVDSS
BVDSS-VDD
VDD
IAS
10%
VGS
Td(on)
Tr
Ton
Td(off)
Tf
Toff
VGS
Fig.10 Switching Time Waveform
www.hs-semi.cn
Fig.11 Unclamped Inductive Switching Waveform
Ver 2.0
4
很抱歉,暂时无法提供与“HSBA3052”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.83938
- 2500+0.73332
