BZT52C2V0 THRU BZT52C75
SILICON PLANAR ZENER DIODES
VOLTAGE RANGE
2. 0to 75 Volts
FEATURES
* Ideal for surface mount applications
* Easy pick and place
500mW
* High temperature soldering guaranteed:
260 C / 10 seconds at terminals
SOD123
MECHANICAL DATA
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Absolute Maximum Ratings (Ta = 25℃)
Parameter
Symbol
Value
Unit
Power Dissipation
Ptot
500
mW
Junction Temperature
TJ
150
Storage Temperature Range
Tstg
- 65 to + 150
Symbol
Max.
Unit
RthA
340
℃/W
VF
0.9
V
Characteristics at Ta = 25℃
Parameter
Thermal Resistance Junction to Ambient Air
Forward Voltage
at IF = 10 mA
REV 1.0 2017 JAN
PAGE:1/3
Breakdown characteristics
Tj = constant (pulsed)
mA
50
Iz
Tj=25o C
3V9
2V7
6V8
4V7
3V3
40
8V2
5V6
30
Test current Iz
5mA
10
2
3
4
5
6
7
9
8
10 V
Vz
mA
30
Tj=25 oC
10
12
Iz
15
22
27
Test current Iz
5mA
10
33
40 V
Vz
Power Dissipation: Ptot (mW)
0.6
0.5
0.4
0.3
0.2
0.1
50
75
125
100
150
Ambient Temperature: Ta ( C)
O
Power Dissipation vs Ambient Temperature
REV 1.0 2017 JAN
PAGE:2/3
Maximum Zener (3)
Impedance
Zener Voltage Range (2)
Type
Marking
V ZT(at I ZT)
I ZT
Min(V) Nom(V) Max(V) (mA)
1)
Reverse Current
Z ZT@I ZT
I ZT
Z ZK@I ZK
I ZK
IR
@V R
(Ω)
(mA)
(Ω)
(mA)
μA
V
BZT52C2V0
WY
1.91
2.0
2.09
5
100
5
600
1
150
1.0
BZT52C2V4
WX
2.2
2.4
2.6
5
100
5
600
1
50
1.0
BZT52C2V7
W1
2.5
2.7
2.9
5
100
5
600
1
BZT52C3V0
W2
2.8
3.0
3.2
5
95
5
600
1
10
1.0
BZT52C3V3
W3
3.1
3.3
3.5
5
95
5
600
1
5.0
1.0
BZT52C3V6
W4
3.4
3.6
3.8
5
90
5
600
1
5.0
1.0
BZT52C3V9
W5
3.7
3.9
4.1
5
90
5
600
1
3.0
1.0
BZT52C4V3
W6
4
4.3
4.6
5
90
5
600
1
3.0
1.0
BZT52C4V7
W7
4.4
4.7
5
5
80
5
500
1
3.0
2.0
BZT52C5V1
W8
4.8
5.1
5.4
5
60
5
480
1
2.0
2.0
BZT52C5V6
W9
5.2
5.6
6
5
40
5
400
1
1.0
2.0
BZT52C6V2
WA
5.8
6.2
6.6
5
10
5
150
1
3.0
4.0
BZT52C6V8
WB
6.4
6.8
7.2
5
15
5
80
1
2.0
4.0
BZT52C7V5
WC
7
7.5
7.9
5
15
5
80
1
1.0
5.0
BZT52C8V2
WD
7.7
8.2
8.7
5
15
5
80
1
0.7
5.0
BZT52C9V1
WE
8.5
9.1
9.6
5
15
5
100
1
0.5
6.0
BZT52C10
WF
9.4
10
10.6
5
150
1
0.2
7.0
BZT52C11
WG
10.4
11
11.6
5
150
1
0.1
8.0
BZT52C12
WH
11.4
12
12.7
5
25
5
150
1
0.1
8.0
BZT52C13
WI
12.4
13
14.1
5
30
5
170
1
0.1
8.0
BZT52C15
WJ
13.8
15
15.6
5
30
5
200
1
0.1
10.5
BZT52C16
WK
15.3
16
17.1
5
40
5
200
1
0.1
11.2
BZT52C18
WL
16.8
18
19.1
5
45
5
225
1
0.1
12.6
BZT52C20
WM
18.8
5
55
5
225
1
0.1
14.0
20.8
22
23.3
5
55
5
250
1
0.1
15.4
1
0.1
16.8
0.5
0.1
18.9
BZT52C22
WN
BZT52C24
WO
22.8
24
25.6
5
70
5
250
BZT52C27
WP
25.1
27
28.9
2
80
2
300
BZT52C30
WQ
28
30
32
2
80
2
300
0.5
0.1
21.0
BZT52C33
WR
31
33
35
2
80
2
325
0.5
0.1
23.1
BZT52C36
WS
34
36
38
2
90
2
350
0.5
0.1
25.2
BZT52C39
WT
37
39
41
2
130
2
350
0.5
0.1
27.3
BZT52C43
6A
40
43
46
2.5
130
2
500
1
2
33
BZT52C47
6B
44
47
50
2.5
150
2
500
1
2
36
BZT52C51
6C
48
51
54
2.5
180
2
500
1
1
37
BZT52C56
6D
52
56
60
2.5
180
2
500
1
1
43
58
62
66
2.5
200
2
500
1
0.2
47
2.5
250
2
500
1
0.2
52
2.5
300
2
500
1
0.2
57
BZT52C62
6E
BZT52C68
6F
64
68
72
BZT52C75
6H
70
75
79
(2)
VZT is tested with pulses (20 ms).
REV 1.0 2017 JAN
PAGE:3/3
很抱歉,暂时无法提供与“BZT52C5V1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.07658
- 200+0.06170
- 600+0.05344
- 3000+0.04561
- 9000+0.04131
- 30000+0.03900
