3216
    HEYCO
3216 数据手册
“Stay Connected” with Liquid Tight Cordgrips ® ® Heyco Original Series-35 Liquid Tight Cordgrips Straight-Thru, PG* Hubs CABLE DIA. RANGE Minimum in. mm. Maximum in. PART NO. Including Nylon Nut** No Nut Black Gray Black DESCRIPTION mm. PART DIMENSIONS A B C E or Clearance Max. O.A. Thread Wrenching Hole Dia. Length Length Nut Flats in. mm. in. mm. in. mm. in. mm. .064 .114 1,6 .210 2,9 .250 5,3 6,4 3444 3207 3445 3208 4754 4752 RLTF 7 LTF 7 .492 12,5 1.17 29,7 .33 8,4 .59 15,0 .069 .181 1,8 .187 4,6 .312 4,7 7,9 3446 3210 3447 3211 4758 4756 RLTF 9 LTF 9 .599 15,2 1.30 33,0 .34 8,6 .75 19,1 .069 .230 1,8 .260 6,6 5,8 .395 10,0 3448 3213 3449 3214 4762 4760 RLTF 11 LTF 11 .733 18,6 1.46 37,1 .39 9,9 .86 21,8 .170 4,3 .450 11,4 3216 3217 4764 LTF 13.5 .804 20,4 1.53 38,9 .41 10,4 .95 24,1 .230 5,8 .546 13,9 3219 3220 4766 LTF 16 .886 22,5 1.66 42,2 .45 11,4 1.05 26,7 .250 6,4 .485 12,3 .450 11,4 .709 18,0 3454 3222 3455 3223 4748 4768 RLTF 21 LTF 21 1.115 28,3 1.87 47,5 .52 13,2 1.30 33,0 .590 15,0 .990 25,1 3225 3226 4770 LTF 29 1.470 37,3 2.23 56,6 .59 15,0 1.66 42,2 Standard colors black and gray. *Steel conduit threads per DIN 40430, see page 3-57 **Nylon locknuts shipped unassembled For No Nut Part Nos. in gray color please visit our Cordgrip product section at heyco.com For larger sizes, see Heyco-Tite Liquid Tight Cordgrips on page 3-3. B A C D*** E SEALING NUT • Wide range of approved cable diameters. • IP 68 rated. • Acme threads on body prevent skipping and speed installation. • For use in clearance or threaded holes. • All nylon construction with TPE sealing gland resists salt water, weak acids, gasoline, alcohol, oil, grease, and common solvents. (This feature is not assessed by UL.) • PG hub threads are steel conduit threads per DIN 40430, see page 3-57. • Multiple sizes for flexible cord diameters ranging from .064˝ (1,6 mm) to .990˝ (25,1 mm). For larger sizes, see Heyco-Tite Liquid Tight Cordgrips on page 3-3. • We recommend using the cordgrip with the smallest maximum diameter that will fit your application. Cable ranges listed are for the maximum IP68 sealing range. Contact Heyco for UL approved 514B cable ranges. • Unassembled Nylon Locknuts INCLUDED. • For Heyco Liquid Tight Threaded Plugs, see page 3-51. • Consult Heyco for cordgrips molded in other colors. SUGGESTED CLEARANCE HOLE FOR NONTHREADED MOUNTING ***Consult Heyco for Wrenching Nut Thickness “D” Material Certifications Flammability Rating Temperature Range IP Rating Nylon 6/6 with TPE Sealing Gland Listed under Underwriters’ Laboratories File E51579 Recognized under the Component Program of Underwriters’ Laboratories File E51579 Certified by Canadian Standards Association File 93876C 94V-2 Static -40°F (-40°C) to 239°F (115°C) Dynamic -4°F (-20°C) to 212°F (100°C) IP 68 (70 PSI, 5 BAR) 1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com Quick Specs 3-20
很抱歉,暂时无法提供与“3216”相匹配的价格&库存,您可以联系我们找货
    • 1500+4.90050
