Data sheet | Item number: 233-503
PCB terminal block; push-button; 0.5 mm²; Pin spacing 2.54 mm; 3-pole;
CAGE CLAMP®; 0,50 mm²; orange
www.wago.com/233-503
i
Picture differs from the item.
Color:
Subject to changes. Please also observe the further product documentation!
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
Phone: +49571 887-0 | Fax: +49571 887-169
Email: info.de@wago.com | Web: www.wago.com
Do you have any questions about our products?
We are always happy to take your call at +49 (571) 887-44222.
19.11.2021 Page 1/9
Dimensions in mm
L = (pole no. x pin spacing) + 2.3 mm
Item description
Compact PCB terminal strips with CAGE CLAMP® connection and screwdriver actuation
parallel or perpendicular to conductor entry
Double solder pins for high mechanical
Custom color combinations
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 2/9
Data
Notes
Variants:
Other pole numbers
Other colors
Mixed-color PCB connector strips
Direct marking
Other versions (or variants) can be requested from WAGO Sales or
configured at https://configurator.wago.com/
Electrical data
Ratings per IEC/EN
Ratings per
IEC/EN 60664-1
Nominal voltage (III/3)
63 V
Rated surge voltage (III/3)
2.5 kV
Rated voltage (III/2)
160 V
Rated surge voltage (III/2)
2.5 kV
Nominal voltage (II/2)
320 V
Rated surge voltage (II/2)
2.5 kV
Rated current
6 A
Legend (ratings)
(III / 2) ≙ Overvoltage category III / Pollution degree 2
Ratings per UL
Approvals per
UL 1059
Rated voltage UL (Use Group B)
150 V
Rated current UL (Use Group B)
4 A
Ratings per CSA
Approvals per
CSA
Rated voltage CSA (Use Group B)
150 V
Rated current CSA (Use Group B)
4 A
Connection data
Total number of connection points
3
Total number of potentials
3
Number of connection types
1
Number of levels
1
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 3/9
Number of levels
1
Connection 1
Connection technology
CAGE CLAMP®
Actuation type
Push-button
Solid conductor
0.08 … 0.5 mm² / 28 … 20 AWG
Fine-stranded conductor
Fine-stranded conductor; with insulated ferrule
0.25 mm²
Fine-stranded conductor; with uninsulated ferrule
0.25 mm²
Note (conductor cross-section)
Terminating 0.75 mm²/18 AWG conductors is possible; however
insulation diameter allows only every other clamping unit to be
terminated with this conductor size.
Strip length
5 … 6 mm / 0.2 … 0.24 inch
Conductor connection direction to PCB
30 °
Pole No.
3
Physical data
Pin spacing
2.54 mm / 0.1 inch
Width
9.92 mm / 0.391 inch
Height
19.5 mm / 0.768 inch
Height from the surface
15.5 mm / 0.61 inch
Depth
13.9 mm / 0.547 inch
Solder pin length
4 mm
Solder pin dimensions
0.5 x 0.75 mm
Drilled hole diameter with tolerance
1.1 (+0.1) mm
PCB contact
PCB Contact
THT
Solder pin arrangement
over the entire terminal strip (in-line)
Number of solder pins per potential
2
Material data
Color
orange
Material group
I
Insulation material
Polyamide (PA66)
Flammability class per UL94
V0
Clamping spring material
Chrome nickel spring steel (CrNi)
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 4/9
Contact material
Electrolytic copper (ECu)
Contact plating
tin-plated
Fire load
0.025 MJ
Weight
1.3 g
Environmental requirements
Limit temperature range
-60 … +105 °C
Commercial data
Product Group
4 (Printed Circuit)
PU (SPU)
500 (125) Stück
Packaging type
box
Country of origin
CH
GTIN
4045454050276
Customs tariff number
85369010000
Approvals / Certificates
Country specific Approvals
Logo
Certificate
name
Approval
Additional Approval Text
CCA
DEKRA Certification B.V.
EN 60998
NTR NL
6946
CCA
EN 60998
2153951.01
CCA
EN 60947-7-4
NTR NL
7786
CSA
C22.2
1465035
KEMA/KEUR
EN 60947-7-4
71-111040
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 5/9
Ship Approvals
Logo
Certificate
name
Approval
ABS
American Bureau of Shipping
19HG1869876PDA
BV
Bureau Veritas S.A.
IEC 60998
11915/D0
BV
DNV GL
Det Norske Veritas, Germanischer Lloyd
TAE000016Z
UL-Approvals
Logo
Approval
Certificate
name
UL
UL International Germany GmbH
UL 1059
E45172
Optional accessories
Tool
Operating tool
Item no.: 210-648
Operating tool; Blade: 2.5 x 0.4 mm; with a partially insulated shaft; angled; short
www.wago.com/210-648
Item no.: 210-719
www.wago.com/210-719
Item no.: 216-131
Ferrule; Sleeve for 0.25 mm² / AWG 24; uninsulated; electro-tin plated; silver-colored
www.wago.com/216-131
Item no.: 216-151
www.wago.com/216-151
Ferrule
Ferrule
Item no.: 216-301
Ferrule; Sleeve for 0.25 mm² / AWG 24; insulated; electro-tin plated; yellow
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
www.wago.com/216-301
19.11.2021 Page 6/9
Item no.: 216-301
Item no.: 216-321
www.wago.com/216-321
Marking accessories
Marking strip
Item no.: 210-331/250-207
Marking strips; as a DIN A4 sheet; MARKED; 1-48 (100x); Height of marker strip: 2.3 mm/0.091 in; Strip
length 182 mm; Horizontal marking; Self-adhesive; white
www.wago.com/210-331
/250-207
Item no.: 210-331/250-202
Marking strips; as a DIN A4 sheet; MARKED; 1-16 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
/250-202
Item no.: 210-331/254-204
Marking strips; as a DIN A4 sheet; MARKED; 17-32 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
/254-204
Item no.: 210-331/250-204
/250-204
Item no.: 210-331/254-206
Marking strips; as a DIN A4 sheet; MARKED; 33-48 (400x); Height of marker strip: 2.3 mm/0.091 in; Strip
/254-206
Item no.: 210-331/250-206
/250-206
Item no.: 210-331/254-202
/254-202
Item no.: 210-331/254-207
/254-207
Downloads
Documentation
Additional Information
Technical explanations
Apr 3, 2019
pdf
2.0 MB
Download
pdf
125.0 kB
Download
CAD/CAE-Data
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 7/9
CAD/CAE-Data
CAD data
2D/3D Models 233-503
URL
Download
URL
Download
URL
Download
URL
Download
PCB Design
Symbol and Footprint 233-503
CAx data for your PCB design, consisting of "schematic symbols and PCB footprints",
allow easy integration of the WAGO component into your development environment.
Supported formats:
Accel EDA 14 & 15
Altium 6 to current version
Cadence Allegro
DesignSpark
Eagle Libraries
KiCad
Mentor Graphics BoardStation
Mentor Graphics Design Architect
Mentor Graphics Design Expedition 99 and 2000
OrCAD 9.X PCB and Capture
PADS PowerPCB 3, 3.5, 4.X, and 5.X
PADS PowerPCB and PowerLogic 3.0
PCAD 2000, 2001, 2002, 2004, and 2006
Pulsonix 8.5 or newer
STL
3D STEP
TARGET 3001!
View Logic ViewDraw
Quadcept
Zuken CadStar 3 and 4
Zuken CR-5000 and CR-8000
PCB Component Libraries (EDA), PCB CAD Library Ultra Librarian
CAE data
ZUKEN Portal 233-503
EPLAN Data Portal 233-503
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 8/9
URL
Download
URL
Download
Environmental Product Compliance
Compliance Search
Environmental Product Compliance 233-503
PCB terminal block; push-button; 0.5 mm²; Pin spacing 2.54 mm; 3-pole; CAGE
Installation Notes
Conductor termination
Inserting/removing a conductor.
Nominal cross-section: 0.5 mm² (20 AWG),
0.75 mm² (18 AWG) only in every other
position
Marking
Labeling via self-adhesive marking strips or
factory direct marking.
WAGO GmbH & Co. KG
Hansastr. 27
32423 Minden
19.11.2021 Page 9/9
很抱歉,暂时无法提供与“233-503”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 125+11.51241125+1.39756
- 250+11.45862250+1.39102
- 500+11.45836500+1.39099
- 625+11.45811625+1.39096
- 1875+11.457851875+1.39093
- 国内价格
- 10+12.41018
- 500+11.91344
- 2000+11.41774
