P6KE15CAR0
P6KE15CAR0
    TAIWANSEMICONDUCTOR(台半)
    P6KE15CAR0
P6KE15CAR0 数据手册
P6KE SERIES Taiwan Semiconductor 600W, 6.8V - 440V Transient Voltage Suppressor FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified available Excellent clamping capability Low dynamic impedance 600W surge capability at 10/1000μs waveform Fast response time: Typically less than 1.0ps from 0 volt to VBR for unidirectional and 5.0ns for bidirectional Typical IR less than 1μA above 10V UL recognized file # E-326243 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VWM 5.5 - 376 V VBR (uni - directional) 6.12 - 462 V VBR (bi - directional) 6.12 - 462 V PPK 600 W TJ MAX 175 Package DO-204AC (DO-15) Configuration Single die APPLICATIONS ● Protect sensitive circuit from damage by high voltage transients ● Lighting, ESD transient voltage protection of IC, system ● Inductive switching load protection of IC, system ● Electrical Fast Transient Immunity protection of IC, system MECHANICAL DATA ● ● ● ● ● ● Case: : DO-204AC (DO-15) Molding compound meets UL 94V-0 flammability rating Terminal: Pure tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.400g (approximately) DO-204AC (DO-15) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Non-repetitive peak impulse power dissipation with (1) 10/1000µs waveform Steady state power dissipation at TA = 75°C (2) lead lengths .375", 9.5mm Peak forward surge current, 8.3ms single half sine-wave (3) superimposed on rated load for Uni-directional only Junction temperature SYMBOL VALUE UNIT PPK 600 W PD 5 W IFSM 100 A TJ - 55 to +175 °C Storage temperature TSTG - 55 to +175 Notes: 1. Non-repetitive current pulse per Fig.3 and derated above TA = 25°C per Fig.2 2. Mounted on 5 x 5 mm copper pads to each terminal 3. 8.3ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum °C Devices for Bipolar Applications 1. For bidirectional use C or CA suffix for types P6KE6.8 - types P6KE440 2. Electrical characteristics apply in both directions 1 Version: P2203 P6KE SERIES Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Part Number P6KE6.8 P6KE6.8A P6KE6V8A P6KE7.5 P6KE7.5A P6KE7V5A P6KE8.2 P6KE8.2A P6KE8V2A P6KE9.1 P6KE9.1A P6KE9V1A P6KE10 P6KE10A P6KE11 P6KE11A P6KE12 P6KE12A P6KE13 P6KE13A P6KE15 P6KE15A P6KE16 P6KE16A P6KE18 P6KE18A P6KE20 P6KE20A P6KE22 P6KE22A P6KE24 P6KE24A P6KE27 P6KE27A P6KE30 P6KE30A P6KE30A P6KE33 P6KE33A P6KE36 P6KE36A P6KE39 P6KE39A P6KE43 P6KE43A P6KE47 P6KE47A P6KE51 P6KE51A P6KE56 P6KE56A P6KE62 P6KE62A P6KE68 Nominal Voltage (V) Breakdown Voltage VBR (V) Test Current IT (mA) Stand-Off Voltage VWM (V) Maximum Reverse Leakage ID@ VWM (μA) Maximum Peak Surge Current IPP (A) Maximum Clamping Voltage VC@ IPPM (V) Maximum Temperature Coefficient of VBR (%/°C) Min Max 6.8 6.12 7.48 10 5.50 1000 58.0 10.8 0.057 6.8 6.46 7.14 10 5.80 1000 60.0 10.5 0.057 7.5 6.75 8.25 10 6.05 500 53.0 11.7 0.061 7.5 7.13 7.88 10 6.40 500 55.0 11.3 0.061 8.2 7.38 9.02 10 6.63 200 50.0 12.5 0.065 8.2 7.79 8.61 10 7.02 200 52.0 12.1 0.065 9.1 8.19 10.00 1 7.37 50 45.0 13.8 0.068 9.1 8.65 9.55 1 7.78 50 47.0 13.4 0.068 10 10 11 11 12 12 13 13 15 15 16 16 18 18 20 20 22 22 24 24 27 27 30 30 30 33 33 36 36 39 39 43 43 47 47 51 51 56 56 62 62 68 9.00 9.50 9.90 10.5 10.8 11.4 11.7 12.4 13.5 14.3 14.4 15.2 16.2 17.1 18.0 19.0 19.8 20.9 21.6 22.8 24.3 25.7 27.0 28.5 28.5 29.7 31.4 32.4 34.2 35.1 37.1 38.7 40.9 42.3 44.7 45.9 48.5 50.4 53.2 55.8 58.9 61.2 11.00 10.5 12.1 11.6 13.2 12.6 14.3 13.7 16.5 15.8 17.6 16.8 19.8 18.9 22.0 21.0 24.2 23.1 26.4 25.2 29.7 28.4 33.0 31.5 31.5 36.3 34.7 39.6 37.8 42.9 41.0 47.3 45.2 51.7 49.4 56.1 53.6 61.6 58.8 68.2 65.1 74.8 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 8.10 8.55 8.92 9.40 9.72 10.2 10.5 11.1 12.1 12.8 12.9 13.6 14.5 15.3 16.2 17.1 17.8 18.8 19.4 20.5 21.8 23.1 24.3 25.6 25.6 26.8 28.2 29.1 30.8 31.6 33.3 34.8 36.8 38.1 40.2 41.3 43.6 45.4 47.8 50.2 53.0 55.1 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 42.0 43.0 38.0 40.0 36.0 37.0 33.0 34.0 28.0 29.0 26.0 28.0 23.0 25.0 21.0 22.0 19.0 20.0 18.0 19.0 16.0 16.8 14.0 15.0 15.0 13.0 13.8 12.0 12.6 11.1 11.6 10.0 10.6 9.2 9.7 8.5 8.9 7.8 8.1 7.0 7.4 6.4 15.0 14.5 16.2 15.6 17.3 16.7 19.0 18.2 22.0 21.2 23.5 22.5 26.5 25.2 29.1 27.7 31.9 30.6 34.7 33.2 39.1 37.5 43.5 41.4 41.4 47.7 45.7 52.0 49.9 56.4 53.9 61.9 59.3 67.8 64.8 73.5 70.1 80.5 77.0 89.0 85.0 98.0 0.073 0.073 0.075 0.075 0.078 0.078 0.081 0.081 0.084 0.084 0.086 0.086 0.088 0.088 0.090 0.090 0.092 0.092 0.094 0.094 0.096 0.096 0.097 0.097 0.097 0.098 0.098 0.099 0.099 0.100 0.100 0.101 0.101 0.101 0.101 0.102 0.102 0.103 0.103 0.104 0.104 0.104 2 Version: P2203 P6KE SERIES Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Part Number Nominal Voltage (V) Breakdown Voltage VBR (V) Min Max Test Current IT (mA) Stand-Off Voltage VWM (V) Maximum Reverse Leakage ID@ VWM (μA) P6KE68A 68 64.6 71.4 1 58.1 1 P6KE75 75 67.5 82.5 1 60.7 1 P6KE75A 75 71.3 78.8 1 64.1 1 P6KE82 82 73.8 90.2 1 66.4 1 P6KE82A 82 77.9 86.1 1 70.1 1 P6KE91 91 81.9 100 1 73.7 1 P6KE91A 91 86.5 95.5 1 77.8 1 P6KE100 100 90 110 1 81.0 1 P6KE100A 100 95 105 1 85.5 1 P6KE110 110 99 121 1 89.2 1 P6KE110A 110 105 116 1 94.0 1 P6KE120 120 108 132 1 97.2 1 P6KE120A 120 114 126 1 102 1 P6KE130 130 117 143 1 105 1 P6KE130A 130 124 137 1 111 1 P6KE150 150 135 165 1 121 1 P6KE150A 150 143 158 1 128 1 P6KE160 160 144 176 1 130 1 P6KE160A 160 152 168 1 136 1 P6KE170 170 153 187 1 138 1 P6KE170A 170 162 179 1 145 1 P6KE180 180 162 198 1 146 1 P6KE180A 180 171 189 1 154 1 P6KE200 200 180 220 1 162 1 P6KE200A 200 190 210 1 171 1 P6KE220 220 198 242 1 175 1 P6KE220A 220 209 231 1 185 1 P6KE250 250 225 275 1 202 1 P6KE250A 250 237 263 1 214 1 P6KE300 300 270 330 1 243 1 P6KE300A 300 285 315 1 256 1 P6KE350 350 315 385 1 284 1 P6KE350A 350 332 368 1 300 1 P6KE400 400 360 440 1 324 1 P6KE400A 400 380 420 1 342 1 P6KE440 440 396 484 1 356 1 P6KE440A 440 418 462 1 376 1 Notes: 1. VBR measure after IT applied for 300μs, IT = square wave pulse or equivalent. 2. Surge current waveform per Fig.3 and derate per Fig.2 3. For bipolar types having VWM of 10 volts and under, the ID limit is doubled. 4. All terms and symbols are consistent with ANSI/IEEE C62.35 3 Maximum Peak Surge Current IPP (A) Maximum Clamping Voltage VC@ IPPM (V) Maximum Temperature Coefficient of VBR (%/°C) 6.8 5.8 6.1 5.3 5.5 4.8 5.0 4.3 4.5 3.9 4.1 3.6 3.8 3.3 3.5 2.9 3.0 2.7 2.8 2.5 2.6 2.4 2.5 2.1 2.2 1.8 1.9 1.7 1.8 1.4 1.5 1.2 1.3 1.0 1.1 1.0 1.04 92.0 108 103 118 113 131 125 144 137 158 152 173 165 187 179 215 207 230 219 244 234 258 246 287 274 344 328 360 344 430 414 504 482 574 548 631 602 0.104 0.105 0.105 0.105 0.105 0.106 0.106 0.106 0.106 0.107 0.107 0.107 0.107 0.107 0.107 0.108 0.108 0.108 0.108 0.108 0.108 0.108 0.108 0.108 0.108 0.108 0.108 0.110 0.110 0.110 0.110 0.110 0.110 0.110 0.110 0.110 0.110 Version: P2203 P6KE SERIES Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE(1)(2) PACKAGE P6KEx DO-204AC (DO-15) P6KEx A0G DO-204AC (DO-15) P6KExH DO-204AC (DO-15) P6KExHA0G DO-204AC (DO-15) Notes: 1. "x" defines voltage from 6.8V(P6KE6.8) to 440V(P6KE440) 2. "H" means AEC-Q101 qualified (excluding P6KE6V8A - P6KE9V1A product) 4 PACKING 3,500 / Tape & Reel 1,500 / Ammo box 3,500 / Tape & Reel 1,500 / Ammo box Version: P2203 P6KE SERIES Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Peak Pulse Power Rating Curve Fig.2 Pulse Derating Curve 125 PEAK PULSE POWER(PPP) OR CURRENT (IPP) A DERATING IN PERCENTAGE (%) PPPM, PEAK PULSE POWER, KW 100 NON-REPETITIVE PULSE WAVEFORM SHOWN in Fig.3 10 1 0.1 0.1 1 10 100 1000 100 75 50 25 0 10000 0 tp, PULSE WIDTH, (μs) 25 50 75 100 125 150 175 TA, AMBIENT TEMPERATURE (°C) Fig.3 Clamping Power Pulse Waveform Fig.4 Maximum Non-Repetitive Forward Surge Current 100 Pulse width(td) is defined as the point where the peak current decays to 50% of IPPM 120 PEAK FORWARD SURGE CURRENT (A) IPPM, PEAK PULSE CURRENT (%) 140 Rise time tr=10μs to 100% 100 Peak value IPPM 80 60 Half value-IPPM/2 10/1000μs, waveform 40 20 td 0 0 0.5 1 1.5 2 2.5 3 8.3ms single half sine wave UNIDIRECTIONAL ONLY 10 1 10 100 NUMBER OF CYCLES AT 60 Hz t, TIME (ms) 5 Version: P2203 P6KE SERIES Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Typical Junction Capacitance CJ, JUNCTION CAPACITANCE (pF) 10000 VR=0 1000 VR-rated stand-off voltage 100 f=1.0MHz Vsig=50mVp-p 10 1 10 100 V(BR), BREAKDOWN VOLTAGE (V) 6 Version: P2203 P6KE SERIES Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AC (DO-15) MARKING DIAGRAM Cathode band for uni-directional products only 7 P/N = Marking Code G = Green Compound YWW = Date Code F = Factory Code Version: P2203 P6KE SERIES Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 8 Version: P2203
P6KE15CAR0 价格&库存
很抱歉,暂时无法提供与“P6KE15CAR0”相匹配的价格&库存,您可以联系我们找货
