DHT22 2 click
PID: MIKROE-2818
Weight: 25 g
DHT22 2 click is used for measuring the environmental temperature and relative humidity. It
uses the CM2322 sensor, with very accurate thermal and humidity measuring capabilities. It can
use either 1-Wire or I2C protocol to communicate with the integrated circuit.
Attributes like the ultra-small size, low power consumption, data signal transmission distance up
to 20 meters, make this sensor the perfect choice for all kinds of applications that require
measurement of the temperature and humidity.
How does the click work?
The sensor used on this click is CM2322. This sensor contains humidity and temperature
measurement elements, compensated and calibrated in the accurate calibration chamber. The
calibration coefficient is saved in the OTP memory of an integrated MCU. The integrated MCU
also proides I2C or 1-Wire interface, selectable by the onboard SMD jumper selectors. The
operating voltage can also be selected by the onboard SMD jumper.
Typical temperature accuracy is ±0.3°C, while relative humidity accuracy is 2% RH, with the
resolution of 0.1 for both measured properties.
I2C/1-Wire interface is used to communicate with the host MCU, sending the measurement data
every 2 seconds. Proprietary data collecting techniques are used to average the sampled values,
after which the result is sent via the I2C/1-Wire bus.
Specifications
Type
Temperature / Humidity
On‐board
modules
CM2322 sensor with very accurate thermal and humidity measuring capabilities
Key Features
Great measuring accuracy: ±0.3°C, ±2%RH at 25°C, ultra‐small size, low power
consumption, signal transmission distance up to 20 meters.
Interface
1‐wire,I2C
Input Voltage 3.3V or 5V
Click board
size
M (42.9 x 25.4 mm)
Pinout diagram
This table shows how the pinout on DHT22 2 click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
1‐wire
NC
1
AN
PWM
16
OW
NC
2
RST
INT
15
NC
NC
3
CS
RX
14
NC
NC
4
SCK
TX
13
NC
NC
5
MISO
SCL
12
SCL
I2C clock
NC
6
MOSI
SDA
11
SDA
I2C data
7
3.3V
5V
10
+5V
Power supply
8
GND
GND
9
GND
Ground
Power supply +3.3V
Ground
GND
DHT22 2 click maximum ratings
Description
Min
Typ
Max
Unit
Logic voltage level
3.3
5
5.5
V
100
kHz
+80
°C
99%
RH
SCL clock frequency
Measuring range (T)
‐40
Measuring range (RH)
0%
Onboard settings and indicators
Label
Name
JP1
OW/SCL
Right Digital interface selection. Left position 1‐Wire, right position I2C.
JP2 OW/SDA
JP3 LOGIC SEL
Left Logic level voltage selection. Left position 3.3V, right position 5V.
PWR Power LED
Default
Description
Power LED indicates that the click is powered on
Software Support
We provide a library for the DHT22 2 click on our LibStock page, as well as a demo application
(example), developed using MikroElektronika compilers. The demo can run on all the main
MikroElektronika development boards.
Library description
Library contains key functions used to read temperature and humidity data from the DHT22 2
click.
float DHT22_2_getTemperature();- Function for reading temperature from sensor
float DHT22_2_getHumidity()- Function for reading humidity from sensor
Examples Description
The example uses the library functions to read the temperature and humidity from the sensor and
sends the data to the user, via the UART interface. The two functions use I2C interface to
communicate with the MCU. Both of these functions return data in floating format, which only
needs to be converted to a string with the compiler function FloatToString, before it is sent to the
UART module. After that, the temperature and the humidity data can be viewed using the UART
terminal.
void applicationTask()
temp = DHT22_2_getTemperature();
humidity = DHT22_2_getHumidity();
FloatToStr(temp,output);
UART1_Write_Text("Temperature: ");
UART1_Write_Text(output);
UART1_Write_Text("°C");
UART1_Write(13);
UART1_Write(10);
UART1_Write_Text("Humidity: ");
FloatToStr(humidity,output);
UART1_Write_Text("%");
UART1_Write(13);
UART1_Write(10);
Delay_ms(1000);
The full application code, and ready to use projects can be found on our LibStock page.
Other mikroE Libraries used in the example:
UART
I2C
Additional notes and information
Depending on the development board you are using, you may need USB UART click, USB
UART 2 click or RS232 click to connect to your PC, for development systems with no UART to
USB interface available on the board. The terminal available in all MikroElektronika compilers,
or any other terminal application of your choice, can be used to read the message.
https://www.mikroe.com/dht22‐2‐click 12‐5‐17
很抱歉,暂时无法提供与“MIKROE-2818”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+184.719701+22.33620
