MA Series Metal Alloy Low-Resistance
Resistor Product Specifications
Metal Alloy Low Resistance Chip Resistor
Document No. S-10-12-05-20
Revision Date 2020/08/12
Page No.
1/10
MA Series
Application
Features
Entertainment product
Low Resistance / Low TCR
Power supply
Excellent long term stability
Measuring instrument
RoHs compliant and halogen free.
Industrial product
Lead free.
Battery management system
High precision current sensing and voltage division.
Parts Number Explanation
Example:
Page No.
2/10
Standard Electrical Specifications
TYPE
Rating
Power
at 70
T.C.R.
(ppm/ )
0.75W
MA1206
1W
±50
1.5W
Max.
Rating
Current
Max.
Overload
Current
3.83
7.66
31.62
63.24
Resistance Range (m
MA2728
Material
0.5% (D)
1.0% (F)
2.0% (G)
5.0% (J)
51~100
51~100
R051~R100 FeCrAl
1~50
R001 MnCuSn
R002~R007 MnCu
7~50
Operating
Temperature
Range ( )
R008~R050 FeCrAl
38.72
77.49
7~10
1~10
1W
±75
44.72
100.00
0.5~0.75
1W
±50
31.62
70.71
7~450
1~450
2W
±75
63.24
141.42
0.5~0.75
2W
±50
44.72
100.00
7~450
1~450
3W
±75
77.45
154.91
0.5~0.75
3W
±50
54.77
109.54
7~100
1~100
±75
126.49
252.98
MA2512
MA2725
4W
0.25~0.3
R001 MnCuSn
R002~R007 MnCu
R008~R010 FeCrAl
R0005~R00075
MnCuSn
R001~R006 MnCu
R007~R450 FeCrAl
R0005~R00075
MnCuSn
R001~R006 MnCu
R007~R450 FeCrAl
R0005~R00075
MnCuSn
R001~R006 MnCu
R007~R100 FeCrAl
R00025~R0003
MnCuSn
0.5~3
R0005~R0025 MnCu
R003 FeCrAl
7~450
4~450
R004~R450 FeCrAl
141.42
0.5
44.72
100.00
7~100
1~100
±75
77.45
173.20
0.5
3W
±50
54.77
122.47
7~60
1~60
5W
±75
100.00
173.20
0.5
5W
±50
70.71
122.47
7~500
1~500
±50
89.44
178.88
4W
±50
31.62
63.24
2W
±75
63.24
2W
±50
3W
MA4527
R0005 MnCuSn
R001~R005 MnCu
R006~R100 FeCrAl
R0005 MnCuSn
R001~R005 MnCu
R006~R060 FeCrAl
R0005 MnCuSn
R001~R005 MnCu
R006~R500 FeCrAl
-55~+170°C
Page No.
3/10
Jumper Specifications
Rating Power
at 70
Max. Rating
Current
MA1206
1W
70.7A
MA2512
2W
100A
Type
Resistance
Operating
Temperature
Range ( )
Material
0.2
Jumper
Cu
-55~+170°C
Type Dimension
FOR MA1206~4527
Dimension
Type
Power
Rating
0.75W
MA1206
1W
1.5W
Unit
Resistance
Range
76~100
1m
2m
3~20m
21~50m
1m
2m
3~10m
0.5m
0.75
L
3.200±0.254
W
1.650±0.254
H
0.400±0.254
0.350±0.254
0.770±0.254
0.650±0.254
0.550±0.254
0.470±0.254
0.770±0.254
0.650±0.254
0.550±0.254
0.770±0.254
0.650±0.254
0.670±0.254
MA2512
1W
2W
2m
2.5~6m
7~10m
11~75
76~100m
101~135m
136~200m
201~450m
mm
T1
T2
0.508±0.254
0.508±0.254
1.15±0.254
2.200±0.254
1.980±0.254
2.200±0.254
1.400 0.254
1.150±0.254
6.350±0.254
3.050±0.254
0.550±0.254
0.600±0.254
0.600±0.254
0.550±0.254
0.470±0.254
0.400±0.254
1.05±0.254
1.100±0.254
0.75±0.254
0.850±0.254
Page No.
4/10
Type
Power
Resistance
Rating
Range
L
W
0.7
H
T1
T2
0.770±0.254
2.200±0.254
0.650±0.254
1.980±0.254
2.200±0.254
1.150±0.254
MA2512
3W
6.350±0.254
3.050±0.254
0.670±0.254
1.400±0.254
1.150±0.254
0.550±0.254
0.600±0.254
0.75±0.254
1.100±0.254
0.550±0.254
0.25m
0.3m
MA2725
0.5m
4W
1m
2.300±0.254
0.770±0.254
6.800±0.254
6.350±0.254
0.650±0.254
1.800±0.254
2.300±0.254
1.15±0.254
1.800±0.254
1.5m
2~3m
MA2728
4W
4~450m
6.600±0.254
6.700±0.254
0.5
2W
1.500±0.254
0.550±0.254
0.580±0.254
0.40±0.254
1.050±0.254
0.770±0.254
0.650±0.254
1.5
3.000±0.254
0.90±0.254
2.000±0.254
0.550±0.254
0.770±0.254
MA4527
3W
11.300±0.500
6.600±0.500
1.5
0.650±0.254
3.000±0.254
0.90±0.254
2.000±0.254
0.550±0.254
0.
0.800±0.254
5W
0.680±0.254
1.5
3.000±0.254
0.65±0.254
2.000±0.254
6~450m
0.580±0.254
Jumper Dimension
Type
Unit
Power
Resistance
Rating
Range
mm
L
W
H
T1
T2
MA1206
1W
< 0.2m
3.200±0.254
1.650±0.254
0.650±0.254
0.508±0.254
0.508±0.254
MA2512
2W
< 0.2m
6.350±0.254
3.050±0.254
0.650±0.254
1.15±0.254
1.100±0.254
Page No.
5/10
Performance Characteristics
Power Derating Curve
The Operating Temperature Range: -55°C ~+170°C.
For resistors operated in ambient temperatures above 70°C, power rating must be derating in accordance with the
curve below.
Rating Current
The following equation may be used to determine the DC (Direct Current) or AC (Alternating Current) (RMS, root mean
square value) of normal rated power. However, if the result value exceeds the highest current of regulated standards
(paragraph 5), the highest normal rated power is to be used.
I = Rating current (A)
P= Rating Power (W)
R= Resistance( )
Marking Format:
All the other products marking are 4 digits.
the decimal location in ohms
location in milli-ohms
duct marking is 0m25.
ing is 0m50.
product marking is 0R.
The criteria to distinguishing the mark on the surface of products are that characters can be identified.
Page No.
6/10
Reliability test and requirement
Test Item
Temperature
Coefficient of
Resistance (T.C.R)
Test Method
Procedure
JIS-C-5201-1 4.8 At 25
/+150
IEC-60115-1 4.8 temperature
, 25
Requirements
is the reference
The number of rated power are as follows:
MA1206-0.75W: 4 times of rated power
MA1206-1W: 4 times of rated power
MA1206-1.5W: 4 times of rated power
MA2512-1W: 5 times of rated power
MA2512-2W: 5 times of rated power
JIS-C-5201-1 4.13
Short Time Overload
MA2512-3W: 5 times of ratedpower*(Note)*
IEC-60115-1 4.13
MA2725-4W: 4 times of rated power
MA2728-4W: 4 times of rated power
MA4527-2W: 5 times of rated power
MA4527-3W: 5 times of rated power
MA4527-5W: 3 times of rated power
for 5 seconds.
High Temperature
Exposure
JIS-C5201-1 4.25
At 170
IEC 60068-2-2
for 1000 hours.
Resistance to
Soldering Heat
JIS-C-5201-1 4.18
260±5
IEC-60115-1 4.18
for 10 seconds.
Temperature Cycling
Biased Humidity
Load Life
(Endurance)
Solderability
Dielectric
Withstanding
Voltage
Core
Body Strength
Terminal Strength
(SMD)
Bending Strength
Moisture Resistance
As Spec
MA4527 R/R1 ±2.0%
The others: R/R1 ±0.5%
MA
R/R1 ±2.0%
The others: R/R1 ±1.0%
R/R1 ± 0.5%
1000 Cycles (-55°C to +155°C) Measurement at
24±4 hours after test conclusion. 30min maximum R/R1 ± 0.5%
dwell time at each temperature extreme.
1,000 hours; 85°C / 85% RH, 10% of operating
MIL-STD-202
R/R1 ± 0.5%
power. Measurement at 24±4 hours after test
Method 103
conclusion.
70±2 , RCWV or Max. working voltage
MA
R/R1 ±2.0%
JIS-C-5201-1 4.25
whichever is less for 1000 hrs with 1.5 hrs ON
IEC-60115-1 4.25.1
and 0.5 hr OFF .
JESD22 Method
JA-104
JIS-C-5201-1 4.17
245±5
IEC-60115-1 4.17
JIS-C5201-1 4.7
for 3 seconds.
No short or burned on the
appearance.
Applied 500VAC for 1 minute.
JIS-C5201-1 4.15 Central part pressurizing force
AEC Q200-006
>95% coverage
5N , 10 seconds No broken
Pressurizing force 17.7N for 60 seconds
JIS-C-5201-1 4.33
Bending once 2mm for 10 seconds
IEC-60115-1 4.33
MIL-STD 202
Method 106
T=24 hours / Cycle ,10Cycles .
Steps 7a& 7b not required. Unpowered .
(Figure 1)
No broken
R/R1 ± 0.5%
No broken
R/R1 ± 0.5%
*Note: This test is a destructive experiment. The top protective layer is prone to damage and peculiar smell during, in the
50mR~100mR resistance test. The resistance change rate can meets the specifications.
Page No.
7/10
For Jumper
Test Item
Short Time Overload
Test Method
Procedure
JIS-C-5201-1 4.13
4 times of rated power for 5 seconds.
IEC-60115-1 4.13
Requirements
0.2m
Temperature Cycling
JESD22 Method
JA-104
at 24±4 hours after test conclusion. 30min
maximum dwell time at each temperature
extreme.
0.2m
High Temperature
Exposure
JIS-C5201-1 4.25
IEC 60068-2-2
At 170
0.2m
Biased Humidity
MIL-STD-202
Method 103
for 1000 hours.
conclusion.
0.2m
Load Life
(Endurance)
JIS-C-5201-1 4.25
IEC-60115-1 4.25.1
Solderability
JIS-C-5201-1 4.17
245±5
IEC-60115-1 4.17
0.2m
and 0.5 hr OFF .
for 3 seconds.
Figure 1
Recommended Customer Soldering Parameters
Wave solder Temperature condition
>95% coverage
Page No.
8/10
Solder reflow Temperature condition
Recommend Land Pattern Design
Dimension
Unit: mm
TYPE
MA1206
0.75W,1W,1.5W
Resistance Range
Jumper
Jumper
MA2512 -1W, 2W, 3W
45
MA2725 - 4W
0.25m
MA2728 - 4W
MA4527
2W,3W,5W
101m ~50
a
b
i
1.46
2.15
1.68
1.46
2.15
1.68
2.30
3.68
3.15
3.40
3.68
0.95
2.35
3.68
1.35
2.10
3.68
2.55
2.30
3.68
3.15
2.05
3.68
3.65
3.25
6.85
1.70
2.75
6.85
2.70
3.90
2.05
7.20
4.50
8.74
4.50
3.50
8.74
6.50
3.50
8.74
6.50
Page No.
9/10
Packing Quantity
TYPE
PCS /Reel
Parts Number
Explanation
MA1206
5000
Z: 5000PCS
MA1206- 001
MA2512
4000
4000
MA2725
2000 /1000
MA2728
2000 / 1000
MA4527
1000 / 500
Z: 4000PCS
Z: 4000PCS
Z: 2000PCS
1: 1000PCS
Z: 2000PCS
1: 1000PCS
Z: 1000PCS
0: 500PCS
Plating Thickness:
Ni:
2
Sn(Tin):
3
Lable :
Page No.
10/10
Appendix For SMD Chip Resistor
Packaging Information
Reel Dimensions
Unit: mm
Dimension
Reel Type / Tape
reel for 8 mm embossed
(for MA1206)
reel for 12 mm embossed
7 reel for 24 mm embossed
B
A
C
D
M
W
2.0±0.5
13.2±0.5
17.7±0.5
60.0±0.5
12.0±0.5
178±1.0
2.5±0.5
2.0±0.5
13.5±0.5
13.2±0.5
17.7±0.5
17.7±0.5
60.0±0.5
60.0±0.5
16.2±0.5
24.4±2.0
178±1.0
178±1.0
Embossed Dimensions
DIRECTION OF FEED
Dimension
Item
Resistance
Range (m )
Unit: mm
W
P
E
F
D
D1
G
H
A
B
T1
T
MA1206
1m
8.0±0.30
4.0±0.10 1.75±0.10
3.5±0.10
1.0±0.10
4.0±0.10
2.0±0.10
2.03±0.10
3.55±0.10
1.10±0.10
0.20±0.05
MA1206
2~100m
8.0±0.30
4.0±0.10 1.75±0.10
3.5±0.10
1.0±0.10
4.0±0.10
2.0±0.10
2.03±0.10
3.55±0.10
0.85±0.10
0.20±0.05
MA2512
0.5~2m
12.0±0.30
4.0±0.10 1.75±0.10
5.5±0.10
1.55±0.10
4.0±0.10
2.0±0.10
3.50±0.10
6.75±0.10
1.10±0.10
0.20±0.05
MA2512
3~450m
12.0±0.30
4.0±0.10 1.75±0.10
5.5±0.10
1.55±0.10
4.0±0.10
2.0±0.10
3.50±0.10
6.75±0.10
0.90±0.10
0.20±0.05
2.0±0.10
6.81±0.10
7.16±0.10
1.05±0.10
0.25±0.05
2.0±0.10
7.10±0.10
7.05±0.10
0.95±0.10
0.20±0.05
2.0±0.10
7.38±0.10
12.0±0.10
1.05±0.10
0.30±0.10
MA2725
MA2728
MA4527
0.25~3m
4~450m
0.5~500m
12.0±0.30
12.0±0.30
8.0±0.10 1.75±0.10
8.0±0.10 1.75±0.10
5.5±0.10
5.5±0.10
24.0±0.30 12.0±0.10 1.75±0.10 11.5±0.10
1.55±0.10
1.55±0.10
1.50±0.10
4.0±0.10
4.0±0.10
4.0±0.10
Storage Temperature
Storage time at the environment temp: 25 5
& humidity: 60 20% is valid for one year from the date of delivery
很抱歉,暂时无法提供与“MA251230FR030FZ”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.72035
- 50+0.63977
- 150+0.59949
- 500+0.48530
- 2500+0.46112
- 4000+0.44904
