KSMAJ Series -E3/61
TRANSIENT VOLTAGE SUPPRESSOR
FEATURE
Plastic package.
Glass passivated chip junction in SMA Package
Excellent clamping capability.
Low zener impedance.
400W peak pulse power capability on 10/1000μs waveform.
Typical IR less than 1μA above 13V.
Fast response time: typically less than 1.0ps from 0 Volts to BV min.
High temperature soldering guaranteed: 265℃/10 seconds
MECHANICAL DATE
Case: JEDEC SMA Molded Plastic.
Terminals: Axial leads, solderable per MIL-STD-750, Method 2026.
Polarity: Color band denoted cathode except bidirectional.
Mounting Position: Any.
MAXIMUM RATINGS AND CHRACTERISTICS
Ratings at 25ć ambient temperature unless otherwise specified.
RATING
SYMBOL
VALUE
UNITS
Peak Pulse Power Dissipation on 10/1000us waveform
(Note1, Fig.1).
PPPM
Minimum 400
Watts
Peak Pulse Current of on 10/1000us waveform.(Note1,Fig.3)
IPPM
See Table
Amps
Steady State Power Dissipation at TL =75℃,Lead lengths.375",
(9.5mm) (Fig.5).
PM(AV)
3.3
Watts
Peak Forward Surge Current,8.3ms Single Half Sine-Wave
Superimposed on Rated Load, (JEDEC Method) (Note 2,Fig.6).
IFSM
40
Amps
Operating junction and Storage Temperature Range.
TJ , TSTG
-55 to +150
Notes:
1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25℃ per Fig. 2.
2. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per
minutes maximum.
1/4
KSMAJ Series -E3/61
Item
A
B
C
D
E
F
G
H
I
J
K
L
Millimeters
Min.
Max.
1.25
1.65
3.99
4.5
2.54
2.79
1.98
2.29
0.78
1.52
0.203
4.93
5.28
0.152
0.305
1.8
2.1
2.3
2.1
Inches
Min.
Max.
0.049
0.065
0.157
0.177
0.1
0.11
0.078
0.09
0.03
0.06
0.008
0.194
0.208
0.006
0.012
0.07
0.082
0.09
0.082
ELECTRICAL CHARACTERISTICS
Part Number
Marking
Reverse
Breakdown
Breakdown
Reverse
Test
Peak
Maximum
Stand-Off
Voltage
Voltage
Leakage
Current
Pulse
Voltage
NIN.@IT
MAX.@IT
@VRWM
Clamping
Voltage
@IPP
Current
UNT
BI
UNT
BI
VR(V)
VBL(V)
VBH(V)
IR(uA)
IT(mA)
IPP(A)
VCH(V)
K SMAJ5.0A
KSMAJ5.0CA
AE
WE
5.0
6.40
7.00
800
10
43.5
9.2
KSMAJ6.0A
KSMAJ6.0CA
AG
WG
6.0
6.67
7.37
800
10
38.8
10.3
KSMAJ6.5A
KSMAJ6.5CA
AK
WK
6.5
7.22
7.98
500
10
35.7
11.2
KSMAJ7.0A
KSMAJ7.0CA
AM
WM
7.0
7.78
8.60
200
10
33.3
12.0
KSMAJ7.5A
KSMAJ7.5CA
AP
WP
7.5
8.33
9.21
100
1
31.0
12.9
KSMAJ8.0A
KSMAJ8.0CA
AR
WR
8.0
8.89
9.83
50
1
29.4
13.6
KSMAJ8.5A
KSMAJ8.5CA
AT
WT
8.5
9.44
10.40
27.8
14.4
KSMAJ9.0A
KSMAJ9.0CA
AV
WV
9.0
10.00
11.10
10
1
26.0
15.4
KSMAJ10A
KSMAJ10CA
AX
WX
10
11.10
12.30
5
1
23.5
17.0
KSMAJ11A
KSMAJ11CA
AZ
WZ
11
12.20
13.50
1
1
22.0
18.2
KSMAJ12A
KSMAJ12CA
BE
XE
12
13.30
14.70
1
1
20.1
19.9
KSMAJ13A
KSMAJ13CA
BG
XG
13
14.40
15.90
1
1
18.6
21.5
2/4
KSMAJ Series -E3/61
Part Number
Breakdown
Breakdown
Reverse
Test
Peak
Maximum
Stand-Off
Voltage
Voltage
Leakage
Current
Pulse
Voltage
NIN.@IT
MAX.@IT
@VRWM
Current
Clamping
Voltage
@IPP
BI
VR(V)
VBL(V)
VBH(V)
IR(uA)
IT(mA)
IPP(A)
VCH(V)
KSMAJ14A
KSMAJ14CA
BK
XK
14
15.60
17.20
1
1
17.2
23.2
KSMAJ15A
KSMAJ15CA
BM
XM
15
16.70
18.50
1
1
16.4
24.4
KSMAJ16A
KSMAJ16CA
BP
XP
16
17.80
19.70
1
1
15.4
26.0
KSMAJ17A
KSMAJ17CA
BR
XR
17
18.90
20.90
1
1
14.5
27.6
KSMAJ18A
KSMAJ18CA
BT
XT
18
20.00
22.10
1
1
13.7
29.2
KSMAJ20A
KSMAJ20CA
BV
XV
24.50
1
1
12.3
32.4
KSMAJ22A
KSMAJ22CA
BX
XX
22
24.40
26.90
1
1
11.3
35.5
KSMAJ24A
KSMAJ24CA
BZ
XZ
24
26.70
29.50
1
1
10.3
38.9
KSMAJ26A
KSMAJ26CA
CE
YE
26
28.90
31.90
1
1
9.5
42.1
KSMAJ28A
KSMAJ28CA
CG
YG
28
31.10
34.40
1
1
8.8
45.4
KSMAJ30A
KSMAJ30CA
CK
YK
30
33.30
36.80
1
1
8.3
48.4
UNT
BI
Marking
Reverse
UNT
KSMAJ33A
KSMAJ33CA
CM
YM
33
40.00
44.20
1
1
6.9
58.1
KSMAJ36A
KSMAJ36CA
CP
YP
36
36.70
40.60
1
1
7.5
53.3
KSMAJ40A
KSMAJ40CA
CR
YR
40
44.40
49.10
1
1
6.2
64.5
KSMAJ43A
KSMAJ43CA
CT
YT
43
47.80
52.80
1
1
5.8
69.4
KSMAJ45A
KSMAJ45CA
CV
YV
45
50.00
55.30
1
1
5.5
72.7
KSMAJ48A
KSMAJ48CA
CX
YX
48
53.30
58.90
1
1
5.2
77.4
KSMAJ51A
KSMAJ51CA
CZ
YZ
51
56.70
62.70
1
1
4.9
82.4
KSMAJ54A
KSMAJ54CA
RE
ZE
54
60.00
66.30
1
1
4.6
87.1
KSMAJ58A
KSMAJ58CA
RG
ZG
58
64.40
71.20
1
1
4.3
93.6
KSMAJ60A
KSMAJ60CA
RK
ZK
60
66.70
73.70
1
1
4.1
96.8
KSMAJ64A
KSMAJ64CA
RM
ZM
64
71.10
78.60
1
1
3.9
103
KSMAJ70A
KSMAJ70CA
RP
ZP
70
77.80
86.00
1
1
3.5
113
KSMAJ75A
KSMAJ75CA
RR
ZR
75
83.30
92.10
1
1
3.3
121
KSMAJ78A
KSMAJ78CA
RT
ZT
78
86.70
95.80
1
1
3.2
126
KSMAJ85A
KSMAJ85CA
RV
ZV
85
94.4
104.0
1
1
2.9
137
KSMAJ90A
KSMAJ90CA
RX
ZX
90
100.0
111.0
1
1
2.7
146
KSMAJ100A
KSMAJ100CA
RZ
ZZ
100
111.0
123.0
1
1
2.5
162
KSMAJ110A
KSMAJ110CA
SE
VE
110
122.0
135.0
1
1
2.3
177
KSMAJ120A
KSMAJ120CA
SG
VG
120
133.0
147.0
1
1
2.1
193
KSMAJ130A
KSMAJ130CA
SK
VK
130
144.0
159.0
1
1
1.9
209
KSMAJ150A
KSMAJ150CA
SM
VM
150
167.0
185.0
1
1
1.6
243
KSMAJ160A
KSMAJ160CA
SP
VP
160
178.0
197.0
1
1
1.5
259
KSMAJ170A
KSMAJ170CA
SR
VR
170
189.0
209.0
1
1
1.5
275
KSMAJ180A
KSMAJ180CA
ST
VT
180
201.0
222.0
1
1
1.4
292
KSMAJ190A
KSMAJ190CA
SU
YU
190
209.0
243.0
1
1
1.3
308
KSMAJ200A
KSMAJ200CA
SW
YW
200
224.0
247.0
1
1
1.2
324
KSMAJ220A
KSMAJ220CA
GE
VX
220
246.0
272.0
1
1
1.1
356
KSMAJ250A
KSMAJ250CA
SZ
VZ
250
279.0
309.0
1
1
1.0
405
KSMAJ300A
KSMAJ300CA
TE
UE
300
335.0
371.0
1
1
0.8
486
KSMAJ350A
KSMAJ350CA
TG
UG
350
391.0
432.0
1
1
0.7
567
KSMAJ400A
KSMAJ400CA
TK
UK
400
447.0
494.0
1
1
0.6
648
KSMAJ440A
KSMAJ440CA
TM
UM
440
492.0
543.0
1
1
0.6
713
Notes: For bidirectional type having VRWM of 10 volts and less, the IR limit is double.
3/4
KSMAJ Series -E3/61
RATINGS AND CHARACTERISTIC CURVES (TA=25℃ unless otherwise noted)
Figure 1 - Peak Pulse Power Rating Curve
Figure 2 - Pulse Derating Curve
Figure 3 - Pulse Waveform
Figure 4 - Typical Junction Capacitance
Uni-Directional
Figure 5 - Steady State Power Dissipation
Derating Curve
Figure 6 - Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
4/4
很抱歉,暂时无法提供与“KSMAJ5.0CA-E3/61”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.21982
- 100+0.17827
- 300+0.15518
- 1800+0.12466
- 5400+0.11266
- 10800+0.10619
