LM339AM/TR
LM339AM/TR
    HGSEMI(华冠)
    SOP14
    LM339AM/TR
LM339AM/TR 数据手册
LM339A QUADRUPLE D IFFERENTIAL COMPARATORS DESCRIPTION The LM339A consists of four independent voltage comparators. These were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage. The outputs can be connected to other open-collector outputs to achieve wired-AND relationships. FEATURES ƒ ƒ ƒ ƒ ƒ ƒ ƒ ƒ ƒ Wide supply voltage range Low supply current drain independent of supply voltage. Low input biasing current Low input offset current Low input offset voltage Input common-mode voltage range includes GND Differential input voltage range equal to the power supply voltage Low output saturation voltage Output voltage compatible with TTL, MOS and CMOS logic PIN1 SOP14 PACKAGE INFORMATION PIN1 DIP14 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing Qty LM339AN DIP14 LM339A TUBE 1000/box LM339AM/TR SOP14 LM339A REEL 2500/reel http://www.hgsemi.com.cn 1 2019 OCT LM339A ELECTRICAL CHARACTERISTICS at specified free-air temperature, VCC=5V (unless otherwise noted) PARAMETER TEST CONDITIONS* MIN VIO VCC=5V to 30V 25 C Input offset voltage VIC= VICRmin, VO=1.4V Full range IlO VO=1.4V TYP MAX UNIT 2 5 50 Full range VO=1.4V IIB Full range VICR 25 C Common-mode input voltage range** Full range AVD Large-signal differential voltage amplification IOH VCC=15V, VO=1.4V to 11.4V, RL 15k to VCC VOH=5V, VID=1V 25 C High-level output current VOH=30V, VID=1V Full range VOL IOL=4mA, VID= -1V 25 C Low-level output voltage 25 ɋ -25 VOL=1.5V, VID= -1V Supply current VCC=5V 25 C VCC=30V Full range nA -400 V 0 to Vcc-2 50 200 0.1 150 V/mV 50 nA 1 A 400 mV 700 6 25 C RL= -250 0 to Vcc-1.5 Full range IOL Low-level output current ICC nA 150 25 C Input bias current mV 9 25 C Input offset current 5 mA 0.8 2 mA 2.5 * Full range (MIN to MAX), for the LM339A is - 40 ɋWR125 ɋ$OOFKDUDFWHULVWLFVDUHPHDVXUHGZLWK]HURFRPPRQ-mode input voltage unless otherwise specified. ** The voltage at either input or common-mode should not be allowed to go negative by more than 0.3V. The upper end of the common-mode voltage range is VCC -1.5V, but either or both inputs can go to 30V without damage. SWITCHING CHARACTERISTICS, VCC 9ɌA=25 C PARAMETER Response time TEST CONDITIONS RL connected to 5V through 5.1k , CL=15pF* (See Note 1) 100-mV input step with 5-mV overdrive TTL-level input step MIN TYP 1.3 0.3 MAX UNIT s * CL includes probe and jig capacitance. NOTE 1: The response time specified is the interval between the input step function and the instant, when the output crosses 1.4V. http://www.hgsemi.com.cn 2 2019 OCT LM339A PACKAGE SOP14 Q A C1 C B D A1 a 0.25 b UNIT:mm DIM. A A1 B C C1 D MIN 4.520 0.100 8.500 5.800 3.800 0.400 TYP 4.570 8.750 6.100 3.900 - MAX 4.620 0.250 9.000 6.250 4.000 0.950 DIM. a b Q MIN 0.400 1.260 0° TYP 0.420 1.270 - MAX 0.440 1.280 8° DIP14                http://www.hgsemi.com.cn 3        2019 OCT LM339A Important statement: Huaguan Semiconductor Co,Ltd. reserves the right to change the products and services provided without notice. Customers should obtain the latest relevant information before ordering, and verify the timeliness and accuracy of this information. Customers are responsible for complying with safety standards and taking safety measures when using our products for system design and machine manufacturing to avoid potential risks that may result in personal injury or property damage. Our products are not licensed for applications in life support, military, aerospace, etc., so we do not bear the consequences of the application of these products in these fields. Our documentation is only permitted to be copied without any tampering with the content, so we do not accept any responsibility or liability for the altered documents. http://www.hgsemi.com.cn 4 2019 OCT
LM339AM/TR 价格&库存
很抱歉,暂时无法提供与“LM339AM/TR”相匹配的价格&库存,您可以联系我们找货
LM339AM/TR
    • 5+0.67251
    • 50+0.54342
    • 150+0.47888
    库存:358
