RC063M331LO13*20H-8A1C 数据手册
MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
RC Series
Low impedance ,high ripple current
For switching power supply
RoHS2.0 Compliant
◆ 规格表 Specifications
项目Items
特性参数Characteristics
使用温度范围
Category
Temperature Range
额定工作电压范围
Rated Voltage Range
静电容量允许偏差
-40 ~ +105℃
6.3 ~ 450V.DC
±20%(M)
Capacitance Tolerance
漏电流
Leakage Current
(at 20℃,120Hz)
I≤0.01CV or 3μA ,二者取大值(施加额定工作电压 2分钟后)
Whichever is greater (After 2 minute application of rated voltage )
I≤0.02CV+10(μA) (施加额定工作电压2分钟后)
Note: I=Max,leakage current (μA), C=Nominal capacitance(μF), V=Rated voltage(V) (at 20℃)
Rated voltage(V)
6.3
损耗角正切值 tanδ
tanδ(Max.)
0.22
10
16
25
Dissipation Factor
标称容量超过1000 μF,则每增加1000 μF,损耗角正切值增加0.02.
0.19 0.16
50
63
100
160
200
250
350
400
450
0.14 0.12 0.10
35
0.09
0.08
0.15
0.15
0.15
0.2
0.2
0.2
When nominal capacitance exceeds 1000μF,add 0.02 to the value above for each 1000μF increase.
(at 20℃,120Hz)
低温特性
阻抗比值不得超过下表中列出的值 The impedance ratio shall not exceed the values listed in the below table.
Low Temperature
Rated voltage(V)
6.3
10
16
25
35
50
63
100
160
Characteristics
Z(-25℃)/Z(+20℃)
4
3
3
3
3
2
2
2
3
5
6
(Max.Impedance Ratio)
Z(-40℃)/Z(+20℃)
8
6
4
4
4
4
4
4
4
7
8
200
(at 120Hz)
250
350
400
450
在105℃环境中,不超过额定电压的范围内叠加最大允许纹波电流 ,连续加载右表时间,经恢复到20℃后,电容器满足以下各项要求 。
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage
with the rated ripple Current is applied for the specified period of time at 105℃
耐久性
Endurance
Capacitance change
≦±20% of the initial value
D.F.(tanδ)
≦200% of the initial specified value
6.3~100v
Load life
Leakage current
≦The initial specified value
160~450v Φ6.3:3000h; ≥Φ8:5000h
Φ5~ Φ8 : 2000h; ≥Φ10:3000h
在105℃环境中,不施加电压条件下储存 1000小时,经恢复到20℃后,电容器满足以下各项要求 。
The following specifications shall be satisfied when the capacitors are restored at 20℃ after exposing them
高温储存特性
for 1000 hours at 105℃ without voltage applied.
Shelf Life
capacitance change
D.F.(tanδ)
Leakage current
◆ 尺寸图(单位:mm)DIMENSIONS (Unit:mm)
L± α.
Safety
Vent
(Φ8up)
15min.
5min.
ΦD
F
Φd
F±0.5
Vinyl sleeve
Rubber
end seal
Φd±0.05 Tinned
copper-ply wire
α
D±0.5
5
2.0
0.5
6.3
2.5
0.5
(L
RC063M331LO13*20H-8A1C 价格&库存
很抱歉,暂时无法提供与“RC063M331LO13*20H-8A1C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.05700
- 10+0.85288
- 30+0.76540
- 100+0.58806
