RTL8316E-CG
RTL8316E-CG
    REALTEK(瑞昱)
    LQFP128
    RTL8316E-CG
RTL8316E-CG 数据手册
RTL8316E LAYER 2 16-PORT 10/100M SINGLE-CHIP SWITCH CONTROLLER RTL8324E LAYER 2 24-PORT 10/100M SWITCH CONTROLLER WITH ONE XSMII DATASHEET (CONFIDENTIAL: Development Partners Only) Rev. 1.0 24 April 2013 Track ID: JATR-8275-15 Realtek Semiconductor Corp. No. 2, Innovation Road II, Hsinchu Science Park, Hsinchu 300, Taiwan Tel.: +886-3-578-0211 Fax: +886-3-577-6047 www.realtek.com RTL8316E/RTL8324E Datasheet COPYRIGHT ©2013 Realtek Semiconductor Corp. All rights reserved. No part of this document may be reproduced, transmitted, transcribed, stored in a retrieval system, or translated into any language in any form or by any means without the written permission of Realtek Semiconductor Corp. DISCLAIMER Realtek provides this document ‘as is’, without warranty of any kind. Realtek may make improvements and/or changes in this document or in the product described in this document at any time. This document could include technical inaccuracies or typographical errors. TRADEMARKS Realtek is a trademark of Realtek Semiconductor Corporation. Other names mentioned in this document are trademarks/registered trademarks of their respective owners. USING THIS DOCUMENT This document is intended for the hardware and software engineer’s general information on the Realtek RTL8316E/RTL8324E chips. Though every effort has been made to ensure that this document is current and accurate, more information may have become available subsequent to the production of this guide. REVISION HISTORY Revision 1.0 Release Date 2013/04/24 Summary First release. Layer 2 16-Port & 24-Port 10/100M Switch Controllers ii Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet Table of Contents 1. GENERAL DESCRIPTION ..............................................................................................................................................1 2. FEATURES .........................................................................................................................................................................2 3. BLOCK DIAGRAMS.........................................................................................................................................................3 3.1. 3.2. 4. SYSTEM APPLICATIONS...............................................................................................................................................5 4.1. 4.2. 5. RTL8316E BLOCK DIAGRAM ......................................................................................................................................3 RTL8324E BLOCK DIAGRAM ......................................................................................................................................4 RTL8316E: 16*10/100M SWITCH ...............................................................................................................................5 RTL8324E: 24*10/100M SWITCH ...............................................................................................................................6 PIN ASSIGNMENTS AND DESCRIPTIONS (RTL8316E)...........................................................................................7 5.1. PIN ASSIGNMENTS FIGURE (RTL8316E) .....................................................................................................................7 5.2. PACKAGE IDENTIFICATION ...........................................................................................................................................7 5.3. PIN ASSIGNMENTS TABLE DEFINITIONS (RTL8316E)..................................................................................................8 5.4. PIN ASSIGNMENTS TABLE (RTL8316E).......................................................................................................................8 5.5. PIN DESCRIPTIONS (RTL8316E) ................................................................................................................................10 5.5.1. Media Connection Pins (RTL8316E)....................................................................................................................10 5.5.2. Serial LED/LED IC Interface Pins (RTL8316E) ..................................................................................................11 5.5.3. SCAN LED Interface Pins (RTL8316E) ...............................................................................................................11 5.5.4. Miscellaneous Interface Pins (RTL8316E)...........................................................................................................11 5.5.5. Configuration Strapping Pins (RTL8316E)..........................................................................................................12 5.5.6. Power and GND Pins (RTL8316E) ......................................................................................................................13 6. PIN ASSIGNMENTS AND DESCRIPTIONS (RTL8324E).........................................................................................14 6.1. PIN ASSIGNMENTS FIGURE (RTL8324E) ...................................................................................................................14 6.2. PACKAGE IDENTIFICATION .........................................................................................................................................14 6.3. PIN ASSIGNMENTS TABLE DEFINITIONS (RTL8324E)................................................................................................15 6.4. PIN ASSIGNMENTS TABLE (RTL8324E).....................................................................................................................15 6.5. PIN DESCRIPTIONS (RTL8324E) ................................................................................................................................17 6.5.1. Media Connection Pins (RTL8324E)....................................................................................................................17 6.5.2. Serial LED Interface Pins (RTL8324E)................................................................................................................18 6.5.3. Miscellaneous Interface Pins (RTL8324E)...........................................................................................................18 6.5.4. Configuration Strapping Pins (RTL8324E)..........................................................................................................18 6.5.5. XSMII Interface Pins (RTL8324E) .......................................................................................................................19 6.5.6. Power and GND Pins (RTL8324E) ......................................................................................................................19 7. PHYSICAL LAYER FUNCTIONAL OVERVIEW......................................................................................................20 7.1. 7.2. 7.3. 7.4. 7.5. 7.6. 7.7. 7.8. 8. MDI INTERFACE ........................................................................................................................................................20 100BASE-TX TRANSMIT FUNCTION...........................................................................................................................20 100BASE-TX RECEIVE FUNCTION .............................................................................................................................20 10BASE-T TRANSMIT FUNCTION ...............................................................................................................................20 10BASE-T RECEIVE FUNCTION ..................................................................................................................................20 AUTO-NEGOTIATION FOR UTP ..................................................................................................................................21 CROSSOVER DETECTION AND AUTO CORRECTION .....................................................................................................21 POLARITY CORRECTION .............................................................................................................................................21 SWITCH FUNCTION DESCRIPTION .........................................................................................................................22 8.1. HARDWARE RESET AND SOFTWARE RESET ................................................................................................................22 8.1.1. Hardware Reset ....................................................................................................................................................22 8.1.2. Software Reset ......................................................................................................................................................22 Layer 2 16-Port & 24-Port 10/100M Switch Controllers iii Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 8.2. LAYER 2 LEARNING AND FORWARDING .....................................................................................................................22 8.2.1. Learning ...............................................................................................................................................................22 8.2.2. Forwarding...........................................................................................................................................................22 8.2.3. Address Table Aging.............................................................................................................................................22 8.3. RESERVED MULTICAST ADDRESS HANDLING ............................................................................................................23 8.4. IEEE 802.3X FLOW CONTROL ...................................................................................................................................23 8.5. HALF DUPLEX BACKPRESSURE ..................................................................................................................................24 8.5.1. Collision-Based Backpressure (Jam Mode) .........................................................................................................24 8.5.2. Carrier-Based Backpressure (Defer Mode) .........................................................................................................25 8.6. IEEE 802.3AZ ENERGY EFFICIENT ETHERNET (EEE) ................................................................................................25 8.7. GREEN ETHERNET ......................................................................................................................................................25 8.7.1. Link Down Power Saving .....................................................................................................................................25 8.8. IEEE 802.1P AND IEEE 802.1Q (VLAN) ..................................................................................................................25 8.9. LOOP DETECTION .......................................................................................................................................................26 8.10. LAYER 2 TRAFFIC SUPPRESSION (STORM CONTROL) .................................................................................................26 8.11. IEEE 802.3AD LINK AGGREGATION PROTOCOL ........................................................................................................26 8.12. BANDWIDTH CONTROL ..............................................................................................................................................26 8.12.1. Input Bandwidth Control .................................................................................................................................26 8.12.2. Output Bandwidth Control...............................................................................................................................26 8.13. QUALITY OF SERVICE (QOS)......................................................................................................................................27 8.13.1. Priority Arbitration..........................................................................................................................................27 8.13.2. Port-Based Priority Assignment ......................................................................................................................27 8.13.3. IEEE 802.1Q-Based Priority Assignment........................................................................................................27 8.13.4. DSCP-Based Priority Assignment ...................................................................................................................27 8.13.5. Internal Priority to Queue ID Table ................................................................................................................27 8.14. PACKET SCHEDULING (WRR AND WFQ)...................................................................................................................28 8.15. EGRESS PACKET REMARKING ....................................................................................................................................28 8.16. INGRESS AND EGRESS PORT MIRROR .........................................................................................................................28 8.17. MANAGEMENT INFORMATION BASE (MIB) ...............................................................................................................28 8.18. REALTEK CABLE TESTER ...........................................................................................................................................29 8.19. EEPROM CONFIGURATION .......................................................................................................................................29 9. INTERFACE DESCRIPTIONS ......................................................................................................................................30 9.1. 9.2. 9.3. 9.4. 9.5. 9.6. 10. XSMII INTERCONNECTION ........................................................................................................................................30 I2C-LIKE LED ...........................................................................................................................................................30 SERIAL LED CONNECTION.........................................................................................................................................31 SCAN LED FOR RTL8316E (NOT SUPPORTED IN THE RTL8324E)............................................................................32 I2C MASTER FOR EEPROM ......................................................................................................................................33 SERIAL CPU INTERFACE ............................................................................................................................................33 ELECTRICAL AC/DC CHARACTERISTICS ........................................................................................................34 10.1. ABSOLUTE MAXIMUM RATINGS ................................................................................................................................34 10.2. OPERATING RANGE ....................................................................................................................................................34 10.3. DC CHARACTERISTICS ...............................................................................................................................................34 10.4. AC CHARACTERISTICS ...............................................................................................................................................35 10.4.1. XSMII Transmitter Signal Electrical Characteristics......................................................................................35 10.4.2. XSMII Receiver Signal Electrical Characteristics...........................................................................................35 10.4.3. Serial LED Signal Timing................................................................................................................................35 10.4.4. Scan LED Mode Signal Timing (RTL8316E)...................................................................................................36 10.4.5. I2C Master for EEPROM Timing ....................................................................................................................36 10.4.6. SCK/SDA Power on Timing.............................................................................................................................37 10.4.7. EEPROM Auto-Load Timing ...........................................................................................................................37 10.4.8. I2C Master Mode Timing Characteristics .......................................................................................................37 10.4.9. Serial CPU Interface Timing ...........................................................................................................................38 10.4.10. Serial CPU Interface Timing Characteristics..................................................................................................38 Layer 2 16-Port & 24-Port 10/100M Switch Controllers iv Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 10.5. SMI TIMING CHARACTERISTICS (RTL8324E ONLY) .................................................................................................38 11. MECHANICAL DIMENSIONS.................................................................................................................................39 12. ORDERING INFORMATION ...................................................................................................................................40 List of Tables TABLE 1. PIN ASSIGNMENTS TABLE (RTL8316E).........................................................................................................................8 TABLE 2. MEDIA CONNECTION PINS (RTL8316E) ......................................................................................................................10 TABLE 3. SERIAL LED/LED IC INTERFACE PINS (RTL8316E) ...................................................................................................11 TABLE 4. SCAN LED INTERFACE PINS (RTL8316E)..................................................................................................................11 TABLE 5. MISCELLANEOUS INTERFACE PINS (RTL8316E)..........................................................................................................11 TABLE 6. CONFIGURATION STRAPPING PINS (RTL8316E) ..........................................................................................................12 TABLE 7. POWER AND GND PINS (RTL8316E)...........................................................................................................................13 TABLE 8. RTL8324E PIN ASSIGNMENTS TABLE (RTL8324E) ....................................................................................................15 TABLE 9. MEDIA CONNECTION PINS (RTL8324E) ......................................................................................................................17 TABLE 10. LED INTERFACE PINS (RTL8324E).............................................................................................................................18 TABLE 11. MISCELLANEOUS INTERFACE PINS (RTL8324E) .........................................................................................................18 TABLE 12. CONFIGURATION STRAPPING PINS (RTL8324E)..........................................................................................................18 TABLE 13. XSMII INTERFACE PINS (RTL8324E) .........................................................................................................................19 TABLE 14. POWER AND GND PINS (RTL8324E) ..........................................................................................................................19 TABLE 15. RESERVED MULTICAST ADDRESS DEFAULT ACTIONS .................................................................................................23 TABLE 16. ABSOLUTE MAXIMUM RATINGS ..................................................................................................................................34 TABLE 17. RECOMMENDED OPERATING RANGE ...........................................................................................................................34 TABLE 18. DC CHARACTERISTICS .................................................................................................................................................34 TABLE 19. XSMII TRANSMITTER SIGNAL ELECTRICAL CHARACTERISTICS ..................................................................................35 TABLE 20. XSMII RECEIVER SIGNAL ELECTRICAL CHARACTERISTICS ........................................................................................35 TABLE 21. I2C MASTER MODE TIMING CHARACTERISTICS ..........................................................................................................37 TABLE 22. SERIAL CPU INTERFACE TIMING CHARACTERISTICS ...................................................................................................38 TABLE 23. SMI TIMING CHARACTERISTICS (RTL8324E ONLY)...................................................................................................38 TABLE 24. ORDERING INFORMATION ............................................................................................................................................40 Layer 2 16-Port & 24-Port 10/100M Switch Controllers v Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet List of Figures FIGURE 1. RTL8316E BLOCK DIAGRAM .......................................................................................................................................3 FIGURE 2. RTL8324E BLOCK DIAGRAM .......................................................................................................................................4 FIGURE 3. RTL8316E: 16*10/100M SWITCH ................................................................................................................................5 FIGURE 4. RTL8324E: 24*10/100M SWITCH ................................................................................................................................6 FIGURE 5. PIN ASSIGNMENTS (RTL8316E) ...................................................................................................................................7 FIGURE 6. PIN ASSIGNMENTS (RTL8324E) .................................................................................................................................14 FIGURE 7. CONCEPTUAL EXAMPLE OF POLARITY CORRECTION ..................................................................................................21 FIGURE 8. TX PAUSE FRAME FORMAT ........................................................................................................................................23 FIGURE 9. FLOW CONTROL STATE MACHINE ..............................................................................................................................24 FIGURE 10. COLLISION-BASED BACKPRESSURE SIGNAL TIMING ..................................................................................................24 FIGURE 11. XSMII INTERCONNECTION .........................................................................................................................................30 FIGURE 12. SERIAL LED CONNECTION .........................................................................................................................................31 FIGURE 13. SCAN LED MODE CONNECTION .................................................................................................................................32 FIGURE 14. LARGE SIZE (32KB~512KB) EEPROM READ/WRITE TIMING ...................................................................................33 FIGURE 15. SMALL SIZE (4KB~8KB) EEPROM READ/WRITE TIMING .........................................................................................33 FIGURE 16. SERIAL CPU INTERFACE ACCESS DATA SEQUENCE ...................................................................................................33 FIGURE 17. SERIAL LED SIGNAL TIMING......................................................................................................................................35 FIGURE 18. SCAN LED MODE SIGNAL TIMING (RTL8316E) ........................................................................................................36 FIGURE 19. I2C MASTER MODE TIMING .......................................................................................................................................36 FIGURE 20. SCK/SDA POWER ON TIMING ....................................................................................................................................37 FIGURE 21. EEPROM AUTO-LOAD TIMING..................................................................................................................................37 FIGURE 22. SERIAL CPU INTERFACE TIMING ................................................................................................................................38 Layer 2 16-Port & 24-Port 10/100M Switch Controllers vi Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 1. General Description The RTL8316E and RTL8324E are Layer 2 16/24-port 10/100M switch controllers that integrate 16/24 MACs and 16 physical layer transceivers for 100Base-TX and 10Base-T operation. The RTL8324E (only) supports one XSMII (Eight Serial Media Independent Interface), which can be connected to an Octal PHY RTL8208D to provide a convenient solution for a 24-port Fast Ethernet switch. The RTL8316E/RTL8324E provides an 8K-entry L2 table with a 4-way hash algorithm for MAC address learning and searching. The RTL8316E/RTL8324E supports IVL (Independent VLAN Learning), SVL (Shared VLAN Learning), and IVL/SVL (Both Independent and Shared VLAN Learning) for flexible network topology architecture. The RTL8316E/RTL8324E has a 512-entry VLAN table and 16-entry VLAN CAM table for VLAN operation. Per-port ingress/egress bandwidth control and per-port/per-queue egress bandwidth control are supported, with four physical queues in each port. The RTL8316E/RTL8324E provides three types of packet scheduling, including SP (Strict Priority), WRR (Weighted Round Robin) and WFQ (Weighted Fair Queuing). A loop-detection function provides notification of network loops. The RTL8316E/RTL8324E also supports port mirror configuration to mirror ingress and egress traffic, and link aggregation to increase link bandwidth and redundancy. Layer 2 16-Port & 24-Port 10/100M Switch Controllers 1 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 2. Features „ Hardware Interface ‹ ‹ „ RTL8316E: 16-port 10/100M high performance Ethernet switch controller, and 16 FE PHYs for 100Base-TX and 10Base-T RTL8324E: 24-port 10/100M high performance Ethernet switch controller, and 16 FE PHYs for 100Base-TX and 10Base-T ‹ RTL8324E (only) supports XSMII interface to connect with octal FE PHY ‹ RTL8316E (only) supports SCAN LED ‹ RTL8316E/RTL8324E Support serial LED interface MAC Function ‹ Supports 2KB jumbo frames ‹ 8K-entry L2 MAC table with 4-way hashing algorithm ‹ Supports source MAC blocking and Destination MAC blocking ‹ Supports Reserved Multicast Addresses processing ‹ „ „ „ „ Supports MAC Address learning constraints on each port L2 Miscellaneous Functions ‹ Supports RLDP (Realtek Loop Detection Protocol) ‹ Supports cable diagnostics technology ‹ Supports broadcast, multicast, unknownmulticast, and unknown-unicast packet suppression control ‹ Supports IEEE 802.3az (Energy Efficient Ethernet, EEE) and Realtek Green Ethernet ‹ Supports TX and RX Port Mirroring ‹ Supports Link Aggregation (IEEE 802.3ad) for 4 groups of link aggregators with up to 8 ports per-group ‹ Port isolation function enhances port security QoS Functions ‹ Four priority queues per port ‹ Supports SP, WRR, WFQ scheduling ‹ Ingress and egress rate limiting per port MIB Functions ‹ RFC2819 -- RMON MIB group 1, 2, 3, 9 ‹ RFC3635/RFC2863/RFC1213/RFC4188 /RFC4363 VLAN Function ‹ ‹ Supports IVL, SVL, and IVL/SVL Supports IEEE 802.1Q VLAN ƒ 512-entry VLAN Table ƒ Port-based VLAN Layer 2 16-Port & 24-Port 10/100M Switch Controllers „ Others ‹ 55nm CMOS process ‹ 3.3V/1.2V dual-power input ‹ LQFP128 E-PAD package 2 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 3. Block Diagrams 3.1. RTL8316E Block Diagram I2C Serial LED/LED IC Register Controller LED Controller SCAN LED Storm Control 802.1x/STP/VLAN Egress Filter 802.1x/STP/VLAN Ingress Filter 802.3ad 按鈕 Input Bandwidth Control Packet Remarking L2 Table QoS Manager Mirror Process Flow Control Manager MAC0 MAC 0 10/100M Table Manager Packet Buffer Packet Filter MAC2 MAC 0 10/100M MAC4 MAC 0 10/100M VLAN Table Packet Modify MAC6 MAC 0 10/100M PHY0-7 (10Base-T/100Base -TX) MAC8 MAC 0 10/100M MAC10 MAC 0 10/100M MAC12 MAC 0 10/100M MAC14 MAC 0 10/100M PHY8-15 (10Base-T/100Base-TX) Figure 1. RTL8316E Block Diagram Layer 2 16-Port & 24-Port 10/100M Switch Controllers 3 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 3.2. RTL8324E Block Diagram Serial LED/LED IC MDC/MDIO and XSMII MAC16 MAC20 10/100M 10/100M MAC20 MAC 0 10/100M MAC 0 MAC20 10/100M I2C MAC 0 MAC 0 Register Controller LED Controller Storm Control 802.1x/STP/VLAN Egress Filter 802.1x/STP/VLAN Ingress Filter 802.3ad 按鈕 Input Bandwidth Control Packet Remarking QoS Manager Flow Control Manager MAC2 MAC 0 10/100M MAC4 MAC 0 10/100M VLAN Table Table Manager Packet Buffer Packet Filter MAC0 MAC 0 10/100M L2 Table Mirror Process Packet Modify MAC6 MAC 0 10/100M PHY0-7 (10Base-T/100Base -TX) MAC8 MAC 0 10/100M MAC10 MAC 0 10/100M MAC12 MAC 0 10/100M MAC14 MAC 0 10/100M PHY8-15 (10Base-T/100Base-TX) Figure 2. RTL8324E Block Diagram Layer 2 16-Port & 24-Port 10/100M Switch Controllers 4 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 4. System Applications 4.1. RTL8316E: 16*10/100M Switch EEPROM FDR Button RTL8316E SCAN LED 8*MDI 8*MDI LQFP128 E-PAD Magnetics Magnetics FE P0-P7 FE P8-P15 Figure 3. RTL8316E: 16*10/100M Switch Layer 2 16-Port & 24-Port 10/100M Switch Controllers 5 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 4.2. RTL8324E: 24*10/100M Switch EEPROM FDR Button RTL8324E RTL8231 LQFP128 E-PAD 8*MDI Magnetics Magnetics FE P0-P7 RTL8208D 8*MDI 8*MDI XSMII FE P8-P15 Magnetics FE P16-P23 Figure 4. RTL8324E: 24*10/100M Switch Layer 2 16-Port & 24-Port 10/100M Switch Controllers 6 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 5. Pin Assignments and Descriptions (RTL8316E) For RTL8324E Pin Assignments and Descriptions, see section 6, page 14. DVDD33 LED_SCAN2/LED_DEF LED_SCAN3/LED_MODE_0 LED_SCAN4/EEPROMTYPE LED_SCAN5/RESERVED DVDD12 DVDD12 LED_DA I2C_SCK I2C_SDA DVDD33 EN_STORMFILTER PHY_PWRDOWN LED_Mode_1 RESERVED RESERVED RESERVED DVDD12 VDD12_PLL GND_PLL XI XO AVDD33_XTAL GND_REXT DVDD33 LED_STA0 LED_STA1 LED_STA2 LED_STA3 DVDD12 LED_STA4 LED_STA5 LED_SCAN0/DIS_FC LED_SCAN1/EN_ISL FDR# LED_CK 102 101 100 99 98 97 96 95 94 93 92 91 90 89 88 87 86 85 84 83 82 81 80 79 78 77 76 75 74 73 72 71 70 69 68 67 66 65 DVDD12 RESET# 5.1. Pin Assignments Figure (RTL8316E) 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 RTL8316E LLLLLLL GXXXX TAIWAN 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 40 39 AVDD12 RXIP15 RXIN15 TXOP15 TXON15 AVDD33 TXON14 TXOP14 RXIN14 RXIP14 AVDD12 RXIP13 RXIN13 TXOP13 TXON13 AVDD33 TXON12 TXOP12 RXIN12 RXIP12 AVDD12 RXIP11 RXIN11 TXOP11 TXON11 AVDD33 TXON5 TXOP5 RXIN5 RXIP5 AVDD12 RXIP6 RXIN6 TXOP6 TXON6 AVDD33 TXON7 TXOP7 RXIN7 RXIP7 AVDD12 RXIP8 RXIN8 TXOP8 TXON8 AVDD33 TXON9 TXOP9 RXIN9 RXIP9 AVDD12 RXIP10 RXIN10 TXOP10 TXON10 AVDD33 DVDD12 DVDD12 AVDD12 RXIP4 RXIN4 TXOP4 TXON4 AVDD33 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 DVDD12 AVDD33 IBREF AVDD12 RXIP0 RXIN0 TXOP0 TXON0 AVDD33 TXON1 TXOP1 RXIN1 RXIP1 AVDD12 RXIP2 RXIN2 TXOP2 TXON2 AVDD33 TXON3 TXOP3 RXIN3 RXIP3 AVDD12 DVDD12 DVDD12 Figure 5. Pin Assignments (RTL8316E) 5.2. Package Identification Green package is indicated by the ‘G’ in GXXXX (Figure 5). Layer 2 16-Port & 24-Port 10/100M Switch Controllers 7 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 5.3. Pin Assignments Table Definitions (RTL8316E) Upon Reset: Defined as a short time after the end of a hardware reset. After Reset: Defined as the time after the specified ‘Upon Reset’ time. I: Input Pin AI: Analog Input Pin O: Output Pin AO: Analog Output Pin I/O: Bi-Directional Input/Output Pin AI/O: Analog Bi-Directional Input/Output Pin P: Digital Power Pin AP: Analog Power Pin G: Digital Ground Pin AG: Analog Ground Pin IPU: Input Pin With Pull-Up Resistor; (Typical Value is 75KΩ) IPD: Input Pin With Pull-Down Resistor; (Typical Value is 75KΩ) I/OPU: IPU and OPU OPU: Output Pin With Pull-Up Resistor; (Typical Value is 75KΩ) OPD: Output Pin With Pull-Down Resistor; (Typical Value is 75KΩ) I/OPD: IPD and OPD 5.4. Pin Assignments Table (RTL8316E) Name DVDD12 AVDD12 RXIP4 RXIN4 TXOP4 TXON4 AVDD33 TXON5 TXOP5 RXIN5 RXIP5 AVDD12 RXIP6 RXIN6 TXOP6 TXON6 AVDD33 Table 1. Pin Assignments Table (RTL8316E) Pin No. Type Name 1 P TXON7 2 AP TXOP7 3 AI/O RXIN7 4 AI/O RXIP7 5 AI/O AVDD12 6 AI/O RXIP8 7 AP RXIN8 8 AI/O TXOP8 9 AI/O TXON8 10 AI/O AVDD33 11 AI/O TXON9 12 AP TXOP9 13 AI/O RXIN9 14 AI/O RXIP9 15 AI/O AVDD12 16 AI/O RXIP10 17 AP RXIN10 Layer 2 16-Port & 24-Port 10/100M Switch Controllers 8 Pin No. 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 Type AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet Name TXOP10 TXON10 AVDD33 DVDD12 AVDD33 TXON11 TXOP11 RXIN11 RXIP11 AVDD12 RXIP12 RXIN12 TXOP12 TXON12 AVDD33 TXON13 TXOP13 RXIN13 RXIP13 AVDD12 RXIP14 RXIN14 TXOP14 TXON14 AVDD33 TXON15 TXOP15 RXIN15 RXIP15 AVDD12 DVDD12 DVDD12 LED_SCAN5/RESERVED LED_SCAN4/EEPROMTYPE LED_SCAN3/LED_MODE_0 LED_SCAN2/LED_DEF DVDD33 LED_SCAN1/EN_ISL LED_SCAN0/DIS_FC LED_STA5 LED_STA4 DVDD12 LED_STA3 LED_STA2 Pin No. 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 Type AI/O AI/O AP P AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP P P I/OPD I/OPD I/OPD I/OPD P I/OPD I/OPD OPD OPD P OPD OPD Layer 2 16-Port & 24-Port 10/100M Switch Controllers Name LED_STA1 LED_STA0 DVDD33 GND_REXT AVDD33_XTAL XO XI GND_PLL VDD12_PLL DVDD12 RESERVED RESERVED RESERVED LED_MODE_1 PHY_PWRDOWN EN_STORMFILTER DVDD33 I2C_SDA I2C_SCK LED_DA LED_CK FDR# RESET# DVDD12 DVDD12 AVDD33 IBREF AVDD12 RXIP0 RXIN0 TXOP0 TXON0 AVDD33 TXON1 TXOP1 RXIN1 RXIP1 AVDD12 RXIP2 RXIN2 TXOP2 TXON2 AVDD33 TXON3 9 Pin No. 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 Type OPD OPD P AG AP AO AI AG AP P I/OPD I/OPD I/OPD IPD IPD IPD P I/OPU I/OPU I/OPU OPU IPU AIPU P P AP AO AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet Name TXOP3 RXIN3 RXIP3 AVDD12 Pin No. 123 124 125 126 Type AI/O AI/O AI/O AP Name DVDD12 DVDD12 DGND Pin No. 127 128 EPAD Type P P G 5.5. Pin Descriptions (RTL8316E) 5.5.1. Media Connection Pins (RTL8316E) Pin Name RXIP15/RXIN15 RXIP14/RXIN14 RXIP13/RXIN13 RXIP12/RXIN12 RXIP11/RXIN11 RXIP10/RXIN10 RXIP9/RXIN9 RXIP8/RXIN8 RXIP7/RXIN7 RXIP6/RXIN6 RXIP5/RXIN5 RXIP4/RXIN4 RXIP3/RXIN3 RXIP2/RXIN2 RXIP1/RXIN1 RXIP0/RXIN0 TXOP15/TXON15 TXOP14/TXON14 TXOP13/TXON13 TXOP12/TXON12 TXOP11/TXON11 TXOP10/TXON10 TXOP9/TXON9 TXOP8/TXON8 TXOP7/TXON7 TXOP6/TXON6 TXOP5/TXON5 TXOP4/TXON4 TXOP3/TXON3 TXOP2/TXON2 TXOP1/TXON1 TXOP0/TXON0 Table 2. Pin No. 63, 62 55, 56 53, 52 45, 46 43, 42 33, 34 31, 30 23, 24 21, 20 13, 14 11, 10 3, 4 125, 124 117, 118 115, 114 107, 108 61, 60 57, 58 51, 50 47, 48 41, 40 35, 36 29, 28 25, 26 19, 18 15, 16 9, 8 5, 6 123, 122 119, 120 113, 112 109, 110 Media Connection Pins (RTL8316E) Type Drive (mA) Description AI/O Differential Receive Data Input: Port0~15 support 100Base-TX, 10Base-T AI/O Layer 2 16-Port & 24-Port 10/100M Switch Controllers - Differential Transmit Data Output: Port0~15 support 100Base-TX, 10Base-T 10 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 5.5.2. Serial LED/LED IC Interface Pins (RTL8316E) Table 3. Serial LED/LED IC Interface Pins (RTL8316E) Pin No. Type Drive (mA) Description 99 OPU 4 In Serial LED mode: Reference output clock for serial LED interface and Data is latched on the rising of LEDCK. In I2C-like LED mode: Reference output clock for I2C-like interface. 98 I/OPU 4 Serial LED Data Output. In Serial LED mode: Serial bit stream of link status info. In I2C-like LED mode: The data written to LED IC. Pin Name LED_CK LED_DA 5.5.3. SCAN LED Interface Pins (RTL8316E) Pin Name LED_STA[5:0] LED_SCAN5/ RESERVED Table 4. SCAN LED Interface Pins (RTL8316E) Pin No. Type Drive (mA) Description OPD 8 Scan LED Mode Status Pins. 74, 75, 77, 78, 79, 80 8 Scan LED Mode Scan Pins. I/OPD 67 LED_SCAN4/ EEPROMTYPE 68 LED_SCAN3/ LED_MODE_0 69 LED_SCAN2/ LED_DEF 70 LED_SCAN1/ EN_ISL 72 LED_SCAN0/ DIS_FC 73 5.5.4. Pin Name I2C_SCK I2C_SDA FDR# XI Miscellaneous Interface Pins (RTL8316E) Table 5. Miscellaneous Interface Pins (RTL8316E) Pin No. Type Drive (mA) Description 97 I/OPU 4 I2C Interface Clock. For normal mode (100KHz), a cycle time is 10µs. For fast mode (400KHz), it is 2.5µs. 96 I/OPU 4 I2C Interface Data Input/Output. 100 IPU Factory default recovery input pin. Takes effect when asserted low for at least 3 seconds. 85 AI 25MHz Crystal Clock Input and Feedback Pin. Layer 2 16-Port & 24-Port 10/100M Switch Controllers 11 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet Pin Name XO RESET# IBREF Pin No. 84 101 105 Type AO AIPU AO Drive (mA) - RESERVED 91, 90, 89 67 I/OPD - Description 25MHz Crystal Clock Output Pin. System Pin Reset Input. Reference Resistor for PHY Bandgap. A 2.49KΩ (1%) resistor should be connected between IBREF and GND. Reserved for internal use. I/OPD - Reserved for internal use. RESERVED / LED_SCAN5 5.5.5. Configuration Strapping Pins (RTL8316E) Pin Name EEPROMTYPE/ LED_SCAN4 LED_MODE_1 LED_MODE_0/ LED_SCAN3 LED_DEF/ LED_SCAN2 Table 6. Configuration Strapping Pins (RTL8316E) Pin No. Type Default Description 68 I/OPD Select EEPROM Auto-Load Address Byte Size. 0: 2-Byte (default) 1: 1-Byte LED Mode Select. IPD 92 00: Serial LED mode (default) 69 01: I2C-like LED mode 10: SCAN LED mode 11: Reserved 70 I/OPD LED Status Default Mode Select. 0: Select mode0 (default) 1: Select mode1 LED Group Mode0 Mode1 LED0 Link/Act Spd100Link/Act LED1 Speed100 Spd10Link/Act LED2 Speed10 Full Duplex EN_ISL/ LED_SCAN1 72 I/OPD - DIS_FC/ LED_SCAN0 73 I/OPD - PHY_PWRDOWN 93 IPD - EN_STORMFILTER 94 IPD - Layer 2 16-Port & 24-Port 10/100M Switch Controllers Enable Port Isolation. 0: Disable port isolation (default) 1: Enable port isolation Enable All Port Flow Control. 0: Enable (default) 1: Disable Enable PHY Power Down When Power On. 0: Normal (default) 1: Enable PHY power down when power on Enable Broadcast Storm Filter. 0: Disable traffic storm filter (default) 1: Enable traffic storm filter 12 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 5.5.6. Power and GND Pins (RTL8316E) Pin Name AVDD33 AVDD12 DVDD33 DVDD12 VDD12_PLL GND_PLL AVDD33_XTAL GND_REXT Table 7. Power and GND Pins (RTL8316E) Pin No. Type Description AP Analog Power 3.3V. 7, 17, 27, 37, 39, 49, 59, 104, 111, 121 AP Analog Power 1.2V. 2, 12, 22, 32, 44, 54, 64, 106, 116, 126 71, 81, 95 P Digital Power 3.3V for IO Pad. P Digital Power 1.2V for Core Voltage. 1, 38, 65, 66, 76, 88, 102, 103, 127, 128 87 AP Power for PLL. 86 AG Ground for PLL. 83 AP Analog Power for Crystal. 82 AG Analog Ground. Layer 2 16-Port & 24-Port 10/100M Switch Controllers 13 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 6. Pin Assignments and Descriptions (RTL8324E) For RTL8316E Pin Assignments and Descriptions, see section 5, page 7. 6.1. Pin Assignments Figure (RTL8324E) DVDD12 AVDD33 IBREF AVDD12 RXIP0 RXIN0 TXOP0 TXON0 AVDD33 TXON1 TXOP1 RXIN1 RXIP1 AVDD12 RXIP2 RXIN2 TXOP2 TXON2 AVDD33 TXON3 TXOP3 RXIN3 RXIP3 AVDD12 DVDD12 DVDD12 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 RTL8324E LLLLLLL GXXXX TAIWAN 64 63 62 61 60 59 58 57 56 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 40 39 AVDD12 RXIP15 RXIN15 TXOP15 TXON15 AVDD33 TXON14 TXOP14 RXIN14 RXIP14 AVDD12 RXIP13 RXIN13 TXOP13 TXON13 AVDD33 TXON12 TXOP12 RXIN12 RXIP12 AVDD12 RXIP11 RXIN11 TXOP11 TXON11 AVDD33 Figure 6. Pin Assignments (RTL8324E) 6.2. Package Identification Green package is indicated by the ‘G’ in GXXXX (Figure 6). Layer 2 16-Port & 24-Port 10/100M Switch Controllers 14 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 6.3. Pin Assignments Table Definitions (RTL8324E) Upon Reset: Defined as a short time after the end of a hardware reset. After Reset: Defined as the time after the specified ‘Upon Reset’ time. I: Input Pin AI: Analog Input Pin O: Output Pin AO: Analog Output Pin I/O: Bi-Directional Input/Output Pin AI/O: Analog Bi-Directional Input/Output Pin P: Digital Power Pin AP: Analog Power Pin G: Digital Ground Pin AG: Analog Ground Pin IPU: Input Pin With Pull-Up Resistor; (Typical Value approximately 75KΩ) IPD: Input Pin With Pull-Down Resistor; (Typical Value approximately 75KΩ) I/OPU: IPU and OPU OPU: Output Pin With Pull-Up Resistor; (Typical Value approximately 75KΩ) OPD: Output Pin With Pull-Down Resistor; (Typical Value approximately 75KΩ) I/OPD: IPD and OPD 6.4. Pin Assignments Table (RTL8324E) Name DVDD12 AVDD12 RXIP4 RXIN4 TXOP4 TXON4 AVDD33 TXON5 TXOP5 RXIN5 RXIP5 AVDD12 RXIP6 RXIN6 TXOP6 TXON6 AVDD33 Table 8. RTL8324E Pin Assignments Table (RTL8324E) Pin No. Type Name 1 P TXON7 2 AP TXOP7 3 AI/O RXIN7 4 AI/O RXIP7 5 AI/O AVDD12 6 AI/O RXIP8 7 AP RXIN8 8 AI/O TXOP8 9 AI/O TXON8 10 AI/O AVDD33 11 AI/O TXON9 12 AP TXOP9 13 AI/O RXIN9 14 AI/O RXIP9 15 AI/O AVDD12 16 AI/O RXIP10 17 AP RXIN10 Layer 2 16-Port & 24-Port 10/100M Switch Controllers 15 Pin No. 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 Type AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet Name TXOP10 TXON10 AVDD33 DVDD12 AVDD33 TXON11 TXOP11 RXIN11 RXIP11 AVDD12 RXIP12 RXIN12 TXOP12 TXON12 AVDD33 TXON13 TXOP13 RXIN13 RXIP13 AVDD12 RXIP14 RXIN14 TXOP14 TXON14 AVDD33 TXON15 TXOP15 RXIN15 RXIP15 AVDD12 DVDD12 DVDD12 RESERVED EEPROMTYPE LED_MODE LED_DEF DVDD33 EN_ISL DIS_FC DVDD12 SAVDD12 SRXN SRXP AVSS Pin No. 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 Type AI/O AI/O AP P AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP P P I/OPD IPD IPD IPD P IPD IPD P AP AI AI AG Layer 2 16-Port & 24-Port 10/100M Switch Controllers Name 25M_CLKO SAVDD12 STXP STXN AVSS NC GND_REXT REXT AVDD33_XTAL XO XI GND_PLL VDD12_PLL DVDD12 MDC MDIO DVDD33 I2C_SDA I2C_SCK LED_DA LED_CK FDR# RESET# DVDD12 DVDD12 AVDD33 IBREF AVDD12 RXIP0 RXIN0 TXOP0 TXON0 AVDD33 TXON1 TXOP1 RXIN1 RXIP1 AVDD12 RXIP2 RXIN2 TXOP2 TXON2 AVDD33 TXON3 16 Pin No. 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 Type O AP AO AO AG AG AO AP AO AI AG AP P OPU I/OPU P I/OPU I/OPU I/OPU OPU IPU AIPU P P AP AO AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O AI/O AI/O AI/O AP AI/O Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet Name TXOP3 RXIN3 RXIP3 AVDD12 Pin No. 123 124 125 126 Type AI/O AI/O AI/O AP Name DVDD12 DVDD12 DGND Pin No. 127 128 EPAD Type P P G 6.5. Pin Descriptions (RTL8324E) 6.5.1. Media Connection Pins (RTL8324E) Pin Name RXIP15/RXIN15 RXIP14/RXIN14 RXIP13/RXIN13 RXIP12/RXIN12 RXIP11/RXIN11 RXIP10/RXIN10 RXIP9/RXIN9 RXIP8/RXIN8 RXIP7/RXIN7 RXIP6/RXIN6 RXIP5/RXIN5 RXIP4/RXIN4 RXIP3/RXIN3 RXIP2/RXIN2 RXIP1/RXIN1 RXIP0/RXIN0 TXOP15/TXON15 TXOP14/TXON14 TXOP13/TXON13 TXOP12/TXON12 TXOP11/TXON11 TXOP10/TXON10 TXOP9/TXON9 TXOP8/TXON8 TXOP7/TXON7 TXOP6/TXON6 TXOP5/TXON5 TXOP4/TXON4 TXOP3/TXON3 TXOP2/TXON2 TXOP1/TXON1 TXOP0/TXON0 Table 9. Pin No. 63, 62 55, 56 53, 52 45, 46 43, 42 33, 34 31, 30 23, 24 21, 20 13, 14 11, 10 3, 4 125, 124 117, 118 115, 114 107, 108 61, 60 57, 58 51, 50 47, 48 41, 40 35, 36 29, 28 25, 26 19, 18 15, 16 9, 8 5, 6 123, 122 119, 120 113, 112 109, 110 Media Connection Pins (RTL8324E) Type Drive (mA) Description AI/O Differential Receive Data Input: Port0~15 supports 100Base-TX, 10Base-T AI/O Layer 2 16-Port & 24-Port 10/100M Switch Controllers - Differential Transmit Data Output: Port0~15 supports 100Base-TX, 10Base-T 17 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 6.5.2. Serial LED Interface Pins (RTL8324E) Pin Name LED_CK Pin No. 99 LED_DA 98 6.5.3. Miscellaneous Interface Pins (RTL8324E) Pin Name I2C_SCK I2C_SDA MDC MDIO FDR# XI XO RESET IBREF RESERVED 6.5.4. Table 10. LED Interface Pins (RTL8324E) Type Drive (mA) Description OPU 4 In Serial LED Mode: Reference output clock for serial LED interface and Data is latched on the rising of LEDCK. In I2C-like LED Mode: Reference output clock for I2C-like interface. I/OPU 4 Serial LED Data Output. In Serial LED Mode: Serial bit stream of link status info. In I2C-like LED mode: The data written to LED IC. Table 11. Miscellaneous Interface Pins (RTL8324E) Pin No. Type Drive (mA) Description 97 I/OPU 4 I2C Interface Clock. For normal mode (100KHz), one cycle time is 10µs. For fast mode (400KHz), it is 2.5µs. 96 I/OPU 4 I2C Interface Data Input/Output. 94 OPU 8 MII Management Interface Clock Pin. 93 I/OPU 8 MII Management Interface Data Pin. 100 IPU Factory Default Recovery Input Pin. Takes effect when pulled down for at least 3 seconds. 89 AI 25MHz Crystal Clock Input and Feedback Pin. 88 AO 25MHz Crystal Clock Output Pin. 101 AIPU System Pin Reset Input. 105 AO Reference Resistor for the Chip. A 2.49KΩ (1%) resistor should be connected between IBREF and GND. 67 I/OPD Reserved for internal use. Configuration Strapping Pins (RTL8324E) Pin Name EEPROMTYPE LED_MODE Table 12. Configuration Strapping Pins (RTL8324E) Pin No. Type Drive (mA) Description 68 IPD Select EEPROM Auto-Load Address Byte Size. 0: 2-Byte (default) 1: 1-Byte 69 IPD LED Mode Select. 0: Serial LED mode (default) 1: I2C-like LED mode Layer 2 16-Port & 24-Port 10/100M Switch Controllers 18 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet Pin Name LED_DEF Pin No. 70 Type IPD Drive (mA) Description LED Status Default Mode Select. 0: Select mode0 (default) 1: Select mode1 LED Group Mode0 LED0 Link/Act LED1 Speed100 LED2 Speed10 EN_ISL 72 IPD - DIS_FC 73 IPD - 6.5.5. Enable Port Isolation. 0: Disable port isolation (default) 1: Enable port isolation Enable All Port Flow Control. 0: Enable (default) 1: Disable XSMII Interface Pins (RTL8324E) Pin Name STXP/STXN SRXP/SRXN 25M_CLKO REXT Pin No. 81, 82 77, 76 79 86 GND_REXT 85 6.5.6. Mode1 Spd100Link/Act Spd10Link/Act Full Duplex Table 13. XSMII Interface Pins (RTL8324E) Type Drive (mA) Description AO XSMII Interface Transmit Data Differential Output Pair. AI XSMII Interface Receive Data Differential Input Pair. O 4 25MHz Clock Output. AO Reference Resistor for XSMII Bandgap. A 12KΩ (1%) resistor should be connected between REXT and GND. AG Ground for XSMII Bandgap. Power and GND Pins (RTL8324E) Table 14. Power and GND Pins (RTL8324E) Pin Name Pin No. Type AVDD33 7, 17, 27, 37, 39, 49, 59, 104, 111, 121 2, 12, 22, 32, 44, 54, 64, 106, 116, 126 71, 95 1, 38, 65, 66, 74, 92, 102, 103, 127, 128 91 90 87 75, 80 78 AP Analog Power 3.3V. AP Analog Power 1.2V. AVDD12 DVDD33 DVDD12 VDD12_PLL GND_PLL AVDD33_XTAL SAVDD12 AVSS P P AP AG AP AP AG Layer 2 16-Port & 24-Port 10/100M Switch Controllers Description Digital Power 3.3V for IO Pad. Digital Power 1.2V for Core Voltage. Power for PLL. Ground for PLL. Analog Power for Crystal. Analog Power for XSMII. Analog Ground for XSMII. 19 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 7. Physical Layer Functional Overview 7.1. MDI Interface The RTL8316E/RTL8324E embeds 16 Fast Ethernet PHYs in one chip. Each port uses a single common MDI interface to support 100Base-TX and 10Base-T. This interface consists of two signal pairs RXIP/RXIN, and TXOP/TXON. The MDI interface has internal termination resistors for reduced BOM cost and PCB complexity. 7.2. 100Base-TX Transmit Function The 100Base-TX transmit function performs parallel to serial conversion, 4B/5B coding, scrambling, NRZ/NRZI conversion, and MLT-3 encoding. The 5-bit serial data stream after 4B/5B coding is then scrambled as defined by the TP-PMD Stream Cipher function to flatten the power spectrum energy such that EMI effects can be reduced significantly. The scrambled seed is based on PHY addresses and is unique for each port. After scrambling, the bit stream is driven into the network media in the form of MLT-3 signaling. The MLT-3 multi-level signaling technology moves the power spectrum energy from high frequency to low frequency, which also reduces EMI emissions. 7.3. 100Base-TX Receive Function The receive path includes a receiver composed of an adaptive equalizer and DC restoration circuits (to compensate for an incoming distorted MLT-3 signal), an MLT-3 to NRZI and NRZI to NRZ converter to convert analog signals to digital bit-stream, and a PLL circuit to clock data bits with minimum bit error rate. A De-scrambler, 5B/4B decoder, and serial-to-parallel conversion circuits are followed by the PLL circuit. Finally, the converted parallel data is fed into the MAC. 7.4. 10Base-T Transmit Function The output 10Base-T waveform is Manchester-encoded before it is driven onto the network media. The internal filter shapes the driven signals to reduce EMI emissions, eliminating the need for an external filter. 7.5. 10Base-T Receive Function The Manchester decoder converts the incoming serial stream to NRZ data when the squelch circuit detects the signal level is above squelch level. Layer 2 16-Port & 24-Port 10/100M Switch Controllers 20 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 7.6. Auto-Negotiation for UTP The RTL8316E/RTL8324E obtains the states of duplex, speed, and flow control ability for each port in UTP mode through the auto-negotiation mechanism defined in the IEEE 802.3 specifications. During auto-negotiation, each port advertises its ability to its link partner and compares its ability with advertisements received from its link partner. By default, the RTL8316E/RTL8324E advertises full capabilities (100Full, 100Half, 10Full, 10Half) together with flow control ability. 7.7. Crossover Detection and Auto Correction During the link setup phase, the RTL8316E/RTL8324E checks whether it receives active signals on every port in order to determine if a connection can be established. The RTL8316E/RTL8324E can identify the type of connected cable and sets the port to MDI or MDIX. When in MDI mode, the RTL8316E/RTL8324E uses TXOP/N as transmit pair; when in MDIX mode, the RTL8316E/RTL8324E uses RXIP/N as transmit pair. 7.8. Polarity Correction The RTL8316E/RTL8324E automatically corrects polarity errors on the receiver pairs in 10Base-T mode. In 100Base-TX mode, the polarity does not matter. + RX _ TX + _ + _ _ + RTL8316D/8324D Link Partner In 10Base-T mode, polarity errors are corrected based on the detection of valid spaced link pulses. The detection begins during the MDI crossover detection phase and locks when the 10Base-T link is up. The polarity becomes unlocked when the link is down. TX + _ RX Figure 7. Conceptual Example of Polarity Correction Layer 2 16-Port & 24-Port 10/100M Switch Controllers 21 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 8. Switch Function Description 8.1. Hardware Reset and Software Reset 8.1.1. Hardware Reset A hardware reset forces the RTL8316E/RTL8324E to start the initial power-on sequence. First hardware will strap pins to give all default values when the ‘RESET’ signal terminates. Next the configuration is auto-loaded from EEPROM (if EEPROM is detected), and then the complete SRAM BIST (Built-In Self Test) process is run. 8.1.2. Software Reset The RTL8316E/RTL8324E supports a Switch Soft reset to reset the Switch packet buffer. All reset signals are low active. 8.2. Layer 2 Learning and Forwarding The RTL8316E/RTL8324E supports IVL (Independent VLAN Learning), SVL (Shared VLAN Learning), and IVL/SVL (Both Independent and Shared VLAN Learning). 8.2.1. Learning The RTL8316E/RTL8324E features a Layer 2 hash table (8K-entry). It uses a 4-way hash structure to store L2 entries. The L2 Unicast hash key is {MAC, FID/VID}. 8.2.2. Forwarding When the VLAN egress filtering option is enabled, a received unicast frame will be forwarded to its destination port only if the destination port is in the same VLAN as the source port. If the destination port belongs to a different VLAN, the frame will be discarded. By default the received broadcast/multicast frame will flood to VLAN member ports only, except for the source port. 8.2.3. Address Table Aging In a dynamic network topology, address aging allows the contents of the address table to always be the most recent and correct. A learned source address entry will be cleared (aged out) if it is not updated by the address learning process within an aging time period. The aging timer of the MAC address lookup table can be configured to between 1~65535 seconds (default value is approximately 300s). Layer 2 16-Port & 24-Port 10/100M Switch Controllers 22 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 8.3. Reserved Multicast Address Handling The RTL8316E/RTL8324E supports Reserved Multicast Address (RMA) as defined in the IEEE 802.1 standard. For each RMA, the actions include Forward and Drop. The action priority is higher than the results of a L2 Table lookup. Default actions are shown in Table 15. Table 15. Reserved Multicast Address Default Actions Name Address Bridge Group Address 01-80-C2-00-00-00 IEEE Std 802.3, 1988 Edition, Full Duplex PAUSE Operation 01-80-C2-00-00-01 IEEE Std 802.3ad Slow Protocols-Multicast Address 01-80-C2-00-00-02 IEEE Std 802.1X PAE Address 01-80-C2-00-00-03 Reserved for future protocol standards 01-80-C2-00-00-04~01-80-C2-00-00-0D, 01-80-C2-00-00-0F 01-80-C2-00-00-0E LLDP IEEE Std 802.1AB Link Layer Discovery Protocol Multicast Address All LANs Bridge Management Group Address 01-80-C2-00-00-10 GMRP 01-80-C2-00-00-20 GVRP 01-80-C2-00-00-21 Reserved for use by Multiple Registration 01-80-C2-00-00-22~01-80-C2-00-00-2F Protocol (MRP) applications IEEE 802.1ag PDU CCM/LTM 01-80-C2-00-00-31~01-80-C2-00-00-3F Default Forward Drop Drop Forward Drop Forward Drop Drop Forward Drop Forward 8.4. IEEE 802.3x Flow Control The RTL8316E/RTL8324E supports IEEE 802.3x full duplex flow control. If one port’s receive buffer is over the pause-on threshold, a pause-on frame is sent to the link partner to stop the transmission. When the port’s receive buffer drops below the pause-off threshold, it sends a pause-off frame. The pause frame format is shown in Figure 8. Figure 8. TX Pause Frame Format The flow control mechanism of the RTL8316E/RTL8324E is implemented on the RX side. It counts the received pages on the RX side in order to determine on which port it should send out Pause On/Off packets. When RTL8316E/RTL8324E flow control is enabled, the initial state is ‘Non_Congest’. The state is monitored continuously. If a pause-on trigger condition occurs, it enters the ‘Congest’ state. When in the Layer 2 16-Port & 24-Port 10/100M Switch Controllers 23 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet ‘congest’ state, it is also continuously monitored. When a pause-off trigger condition occurs it re-enters the ‘Non_Congest’ state. Figure 9 shows the flow control state machine. Trigger Condition for Pause-Off Initial state; Flow Control Enabled Non-Congest State Congest State Trigger Condition for Pause-On Figure 9. Flow Control State Machine 8.5. Half Duplex Backpressure There are two mechanisms for half-duplex backpressure: collision-based or carrier-based. 8.5.1. Collision-Based Backpressure (Jam Mode) If the input buffer is ready to overflow, this mechanism will force a collision. When the link partner detects this collision, the transmission is rescheduled. The Reschedule procedure is: • The RTL8316E/RTL8324E will drive TXEN to high and send a 4-byte Jam signal (pattern is 0x55). The RTL8316E/RTL8324E will then drive TXEN to low. • When the link partner receives the Jam signal, it will feedback a 4-byte signal (pattern is 0xFF), then it will drive RXDV to low. • The link partner waits for a random back-off time then re-sends the packet. The timing is shown in Figure 10. Figure 10. Collision-Based Backpressure Signal Timing Layer 2 16-Port & 24-Port 10/100M Switch Controllers 24 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 8.5.2. Carrier-Based Backpressure (Defer Mode) If the input buffer is about to overflow, this mechanism will send a 0x55 pattern to defer the other station’s transmission. The RTL8316E/RTL8324E will continuously send the defer signal until the input buffer overflow is resolved. 8.6. IEEE 802.3az Energy Efficient Ethernet (EEE) The RTL8316E/RTL8324E supports IEEE 802.3az Energy Efficient Ethernet (EEE) ability for 100BaseTX in full duplex operation, and supports 10Base-Te for 10Base-T in full/half duplex .The Energy Efficient Ethernet (EEE) operational mode combines the IEEE 802.3 Media Access Control (MAC) Sublayer with a family of Physical Layers defined to support operation in Low Power Idle (LPI) Mode. When the port is in LPI Mode, link partners of both sides can turn off the unnecessary TX/RX circuits to save power consumption during periods of low link utilization. The RTL8316E/RTL8324E EEE operational mode supports the IEEE 802.3 MAC operation at 100Mbps. In addition, the RTL8316E/RTL8324E supports 10Mbps PHY with reduced transmit amplitude requirements in EEE operational mode. This new PHY is fully interoperable with legacy 10Base-T PHY over 100m of Class-D (Category 5) or better cabling. 8.7. Green Ethernet 8.7.1. Link Down Power Saving The RTL8316E/RTL8324E implements link-down power saving on a per-port basis, greatly cutting power consumption when the network cable is disconnected. A port automatically enters link down power saving mode ten seconds after the cable is disconnected from it. Once a port enters link down power saving mode, it transmits normal link pulses on its TXOP/TXON pins and continues to monitor the RXIP/RXIN pins to detect incoming signals, which might be 100Base-TX MLT-3 idle pattern, 10Base-T link pulses, or Auto-Negotiation’s FLP (Fast Link Pulse). After it detects an incoming signal, it wakes up from link down power saving mode and operates in normal mode according to the result of the connection. 8.8. IEEE 802.1p and IEEE 802.1Q (VLAN) The RTL8316E/RTL8324E supports IEEE 802.1p and 802.1Q tag-based, port-based VLAN. It provides a 512-entry VLAN table and 16-entry VLAN CAM table. VLAN table lookup applies a 4-Way hash algorithm, and the CAM table is used to resolve hash collisions. The RTL8316E/RTL8324E uses VID[0:6] as an index to the VLAN table. If the remaining 5-bit VID[7:11] is matched in the entry, it means this entry lookup is a hit. If the VLAN table lookup fails, the chip will perform a lookup in the 16-entry VLAN CAM table. The RTL8316E/RTL8324E features an ingress filter function; packets from an input port that is not in the member set will be dropped. This function can be enabled or disabled via register configuration. Layer 2 16-Port & 24-Port 10/100M Switch Controllers 25 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 8.9. Loop Detection The RTL8316E/RTL8324E periodically transmits a Realtek protocol frame to detect network loop faults. If a port detects a loop, the LED corresponding to the looped port will blink until the loop is resolved. At the same time, the loop event flag will be set. 8.10. Layer 2 Traffic Suppression (Storm Control) The RTL8316E/RTL8324E supports the storm filter function for each port. The storm types are broadcast storm, known multicast storm, unknown multicast storm, and unknown DA unicast storm. The RTL8316E/RTL8324E can control the four storm types via one leaky bucket per port. 8.11. IEEE 802.3ad Link Aggregation Protocol The RTL8316E/RTL8324E supports 802.3ad (Link Aggregation) for 4 groups of link aggregators with up to 8 ports per-group. The chosen ports must be in full duplex mode and they must have the same attributes (for example: All 100Mbps or all 10Mbps). The link aggregation group is regarded as one logical port and has an ID (the lowest port number of the physically aggregated port members is used as its ID). 8.12. Bandwidth Control 8.12.1. Input Bandwidth Control The RTL8316E/RTL8324E has input bandwidth control per port. If the speed of received packets is faster than the bandwidth setting of this port, the switch will send a pause frame to the link partner or drop packets, according to its flow control setting. 8.12.2. Output Bandwidth Control The RTL8316E/RTL8324E has output bandwidth control per port, and has output bandwidth control per queue in WRR mode. The bandwidth granularity is 16Kbps. Layer 2 16-Port & 24-Port 10/100M Switch Controllers 26 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 8.13. Quality of Service (QoS) The RTL8316E/RTL8324E identifies the priority of packets based on three types of QOS priority information: • Port-based • IEEE 802.1Q-based • DSCP-based 8.13.1. Priority Arbitration The RTL8316E/RTL8324E has two priority arbitration weight tables to decide which type of priority should be accepted when multiple types of priority exist. Each port can be set to its own Priority arbitration weight. 8.13.2. Port-Based Priority Assignment Port-based priority assignment specifies a 3-bit priority for each physical port. When a packet is received from a physical port, it is assigned the 3-bit priority of that physical port. 8.13.3. IEEE 802.1Q-Based Priority Assignment In IEEE 802.1Q-based priority assignment, when a packet is VLAN-tagged or priority-tagged, the 3-bit priority is specified by tag. When a packet is untagged, the 802.1Q-based priority is assigned to the default 3-bit priority information of a physical port. Each port must provide a default 3-bit priority (every received packet must be assigned a 3-bit 1Q-Based Priority). When the priority comes from a packet, the 1Q-based priority is acquired by mapping 3-bit tag priority to 3-bit priority though a RTL8316E/RTL8324E 1Q-based Priority Mapping Table. The 1Q-based priority can be disabled. 8.13.4. DSCP-Based Priority Assignment The RTL8316E/RTL8324E has 2 tables to map 6-bit DSCP values to 3-bit internal priorities. Each table has 64 entries. Each port can decide which table to use. The DSCP-based priority assignment can be disabled by setting its weight to 0 in the Priority arbitration weight table. 8.13.5. Internal Priority to Queue ID Table The RTL8316E/RTL8324E can transfer its internal priority to the output queue ID. Each port has a table with 8 entries to map the 3-bit internal priority to 2-bit queue ID. Layer 2 16-Port & 24-Port 10/100M Switch Controllers 27 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 8.14. Packet Scheduling (WRR and WFQ) The RTL8316E/RTL8324E has four queues per port. The Packet Scheduler controls the multiple traffic classes (i.e., controls the packet sending sequence of the priority queue). The RTL8316E/RTL8324E has two scheduling algorithms: Weighted Round-Robin (WRR) and Weighted Fair-Queuing (WFQ). Note that the Strict Priority queue is the highest priority of all queues, and overrides WFQ & WRR. A larger strict priority queue ID indicates the priority is higher. The Scheduler operates as follows: • Weighted Fair-Queuing (WFQ): Byte-count • Weighted Round-Robin (WRR): Packet-count Note that WFQ and WRR cannot exist at the same time. 8.15. Egress Packet Remarking RTL8316E/RTL8324E Remarking can be divided into 1p remarking and DSCP remarking. For 1p remarking, there is an internal priority to user priority table that is used to configure the final user priority value for the whole system. DSCP remarking also has an internal priority to DSCP priority table. 8.16. Ingress and Egress Port Mirror If a frame meets the Ingress and Egress mirroring port conditions, the RTL8316E/RTL8324E duplicates the packet to the mirroring port. The RTL8316E/RTL8324E has one mirror set, and the mirroring port can monitor several mirrored ports simultaneously. For flow control, the mirroring port will send PAUSE frames or backpressure signals to the mirrored port. The QoS output port drop function can be enabled by software on the mirroring port. 8.17. Management Information Base (MIB) The RTL8316E/RTL8324E MIB (Management Information Base) counters include: • RFC2819 – RMON MIB Group 1, 2, 3, 9 • RFC3635 – Ethernet-like MIB • RFC2863 – Interface Group MIB • RFC1213 – MIB II • RFC4188 – Bridge MIB • RFC4363 – Bridge MIB Extension Layer 2 16-Port & 24-Port 10/100M Switch Controllers 28 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 8.18. Realtek Cable Tester The RTL8316E/RTL8324E features the Realtek Cable Tester (RTCT). The Cable Tester function can be used to detect a short (two conductors of a pair have short-circuited) or open (a lack of continuity between the pins at each end of the Ethernet cable, or a disconnected cable) in each differential pair, and report the result in corresponding registers. The RTL8316E/RTL8324E also has an LED to indicate test status and results. 8.19. EEPROM Configuration The EEPROM can be divided into two sizes: 4Kb~8Kb and 32Kb~512Kb. Using the small size EEPROM will reduce the time required to load code, as well as the cost. The address size of the small size EEPROM is 8 bits, while the larger EEPROM size is 16 bits (addressable space up to 64K). The small and large size EEPROM address timing waveform is different, and the auto-load size is shown in the register. • Small Size EEPROM: Uses a control byte to define the EEPROM device address. Each block is 8-bit addressable, and its size is 256*8-bits. A 4Kb EEPROM supports two blocks, and an 8Kb EEPROM supports four blocks. • Large Size EEPROM: Uses a control byte to define a one-block EEPROM device address. This block is addressable by 12~16 bits (i.e., 4K~64K range), and its size is 4K*8-bits =32Kb, to 64K*8-bits =512Kb). 32Kb supports 12-bit addresses, and 512Kb supports 16-bit addresses. The RTL8316E/RTL8324E supports an EEPROM Factory Default Reset function. This function can be triggered by an input pin or FDR register. In order to prevent mis-operation, the FDR pin reset duration should be longer than 3 seconds. Layer 2 16-Port & 24-Port 10/100M Switch Controllers 29 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 9. Interface Descriptions 9.1. XSMII Interconnection XSMII (Eight Serial Media Independent Interface) reduces PCB complexity and IC pin count. This innovative serial interface provides an up to 5 inch MAC to PHY communication path. XSMII can carry the half/full duplex Megabit Ethernet data streams of eight ports simultaneously, using only 4 pins. Port 0 Port 1 MAC PHY TX RX Port 2 Port 3 Port 0 Port 1 Port 2 RS8MII 25MHz RS8MII Port 3 Port 4 Port 4 Port 5 Port 5 Port 6 TX RX Port 7 Port 6 Port 7 Figure 11. XSMII Interconnection 9.2. I2C-Like LED The RTL8316E/RTL8324E supports I2C-like LED by connecting with an LED of the RTL8231, which provides single-color and Bi-color scan LED and extended GPIOs. When powered on or hardware reset, the RTL8316E/RTL8324E initializes the RTL8231, and then writes the LED status to it to turn on/off LEDs. The external CPU can also access the RTL8231 to extend GPIOs via indirect mode. Layer 2 16-Port & 24-Port 10/100M Switch Controllers 30 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 9.3. Serial LED Connection The RTL8316E/RTL8324E has 16/24 MAC ports and supports a serial LED interface to display the link status. The serial LED interface, LED_SCK and LED_DATA provide clock and data to enable/disable the external shift registers. A 74HC164 8-Bit Serial-In, Parallel-Out Shift Register captures the per-port link status and diagnostic information. LED_ DATA 3.3V LED_ CLK A B CLK QA QB P24_ LED[1] QC P24_ LED[0] QD P23_ LED[2] QE P23_ LED[1] QF P23_ LED[0] QG P22_ LED[2] QH P22_ LED[1] 74HC164 LED_ DATA 3.3V LED_ CLK A B CLK 74HC164 LED_ DATA 3.3V LED_ CLK P24_ LED[2] A B CLK 74HC164 QA P22_ LED[0] QB P21_ LED[2] QC P21_ LED[1] QD P21_ LED[0] QE P20_ LED[2] QF P20_ LED[1] QG P20_ LED[0] QH P19_ LED[2] QA P2_LED[1] QB P2_LED[0] QC P1_LED[2] QD P1_LED[1] QE P1_LED[0] QF P0_LED[2] QG P0_LED[1] QH P0_LED[0] 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V 3.3V Figure 12. Serial LED Connection Layer 2 16-Port & 24-Port 10/100M Switch Controllers 31 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 9.4. Scan LED for RTL8316E (Not Supported in the RTL8324E) In order to reduce the external LED circuits, the RTL8316E supports scan LED mode. It covers 16 port’s link status with two LEDs, and provides six scan pins and six status pins to display the link status. Figure 13. Scan LED Mode Connection Layer 2 16-Port & 24-Port 10/100M Switch Controllers 32 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 9.5. I2C Master for EEPROM The EEPROM can be divided into two sizes: 2Kb~8Kb and 32Kb~512Kb. The address of the small size EEPROM is 8-bits, however the larger EEPROM has word-high addressing and word-low addressing, and it is 16-bits (two bytes). Figure 14. Large Size (32Kb~512Kb) EEPROM Read/Write Timing Figure 15. Small Size (4Kb~8Kb) EEPROM Read/Write Timing 9.6. Serial CPU Interface The RTL8316E/RTL8324E supports a serial CPU interface (Slave mode) to access the internal register. It has two I/O pins (i.e., SDA and SCL). SDA is the access data signal, and SCL is the clock signal (typical clock is 1~2MHz). The read/write data sequence is shown in Figure 16. It consists of a control byte (1 byte) + address bytes (2 bytes) + data bytes (4N pieces, N: integer, N≠0). When the external CPU wants to read/write data to the RTL8316E/RTL8324E, it must set the read/write bit (read is 1, and write is 0). 3 ADDRESS BYTES 1 CONTROL BYTE S 1 0 1 0 A2 A1 A0 A R/ C W K Addr [7:0] A A Addr Addr C C [23:16] [15:8] K K LSB to MSB 4N DATA BYTES A C K Data [7:0] A C K Data [15:8] N O A A A Data Data C C C [23:16] [31:24] K K K P Read 1 CONTROL BYTE S 1 0 1 A R/ 0 A2 A1 A0 C W K 3 ADDRESS BYTES Addr [7:0] A A Addr Addr C C [23:16] [15:8] K K LSB to MSB 4N DATA BYTES A C K Data [7:0] A C K Data [15:8] A A Data Data C C [23:16] [31:24] K K A C K P Write Figure 16. Serial CPU Interface Access Data Sequence Layer 2 16-Port & 24-Port 10/100M Switch Controllers 33 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 10. Electrical AC/DC Characteristics 10.1. Absolute Maximum Ratings WARNING: Absolute maximum ratings are limits beyond which permanent damage may be caused to the device, or device reliability will be affected. All voltages are specified reference to GND unless otherwise specified. Table 16. Absolute Maximum Ratings Parameter Min Storage Temperature -55 DVDD33, AVDD33, AVDD33_XTAL Supply Referenced to GND GND-0.3 DVDD12, AVDD12, VDD12_PLL, SAVDD12 Supply Referenced to GND-0.3 GND, GND_PLL, AVSS Max +150 +3.63 Units °C V +1.32 V 10.2. Operating Range Table 17. Recommended Operating Range Parameter Min Ambient Operating Temperature (Ta) 0 DVDD33, AVDD33, AVDD33_XTAL Supply Voltage Range 3.135 DVDD12, AVDD12, VDD12_PLL, SAVDD12 Supply Voltage Range 1.14 Typical 3.3 1.2 Max 70 3.465 1.26 Units °C V V Typical - Max 0.8 0.4 Units V V V V 10.3. DC Characteristics Table 18. DC Characteristics Symbol VIH VIL VOH VOL Parameter (VDDIO=3.3V) TTL Input High Voltage TTL Input Low Voltage Output High Voltage Output Low Voltage Layer 2 16-Port & 24-Port 10/100M Switch Controllers Min 2.0 2.4 - 34 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 10.4. AC Characteristics 10.4.1. XSMII Transmitter Signal Electrical Characteristics Table 19. XSMII Transmitter Signal Electrical Characteristics Parameter Min Typical Differential Peak-to-Peak Output Voltage 0.35 0.4 AC Coupling Capacitor 75 100 Transmit Length in PCB - Symbol VTX-DIFFp-p CTX LTX Max 0.8 200 5 Units V nF Inch Max 1.0 200 Units V nF 10.4.2. XSMII Receiver Signal Electrical Characteristics Table 20. XSMII Receiver Signal Electrical Characteristics Parameter Min Typical Differential Peak-to-Peak Input Voltage 0.3 AC Coupling Capacitor 75 100 Symbol VRX-DIFFp-p CRX 10.4.3. Serial LED Signal Timing 32ms or 128ms >600n s >600n s >600n s >600n s >600n s >600n s >600n s >600n s >600n s >600n s >600n s >600n s LED_CLK 1 2 3 4 5 6 73 74 75 1 2 3 LED_DATA P0_LED0 P0_LED1 P0_LED2 P1_LED0 P1_LED1 P1_LED2 P24_LED1 P24_LED2 P0_LED0 P0_LED1 P0_LED2 P24_LED0 Figure 17. Serial LED Signal Timing Layer 2 16-Port & 24-Port 10/100M Switch Controllers 35 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 10.4.4. Scan LED Mode Signal Timing (RTL8316E) 600 usec 100 usec LED_ SCAN0 LED_ SCAN1 100 usec LED_ SCAN2 LED_ SCAN3 LED_ SCAN4 LED_ SCAN5 > 200ns P0_ LED0 LED_ STA0 LED_ STA1 LED_ STA2 LED_ STA3 LED_ STA4 LED_ STA5 >200ns P1_ LED0 P2_ LED0 P3_ LED0 P4_ LED0 P5_ LED0 98 usec P0_ LED1 P6_ LED0 P1_ LED1 P7_ LED0 P2_ LED1 P8_ LED0 P3_ LED1 P4_ LED1 P5_ LED1 P6_ LED1 P7_ LED1 P8_ LED1 P9_ LED0 P9_ LED1 P10_ LED0 P10_ LED1 P11_ LED0 P12_ LED0 P13_ LED0 P14_ LED0 P15_ LED0 P12_ LED1 P13_ LED1 P11_ LED1 P14_ LED1 P15_ LED1 CPU_LED0 CPU_LED1 CPU_LED2 CPU_LED3 P0_ LED0 P1_ LED0 P2_ LED0 P3_ LED0 P4_ LED0 P5_ LED0 P0_ LED1 P1_ LED1 P2_ LED1 P3_ LED1 P4_ LED1 P5_ LED1 Figure 18. Scan LED Mode Signal Timing (RTL8316E) 10.4.5. I2C Master for EEPROM Timing Figure 19. I2C Master Mode Timing Layer 2 16-Port & 24-Port 10/100M Switch Controllers 36 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 10.4.6. SCK/SDA Power on Timing Figure 20. SCK/SDA Power on Timing 10.4.7. EEPROM Auto-Load Timing Figure 21. EEPROM Auto-Load Timing 10.4.8. I2C Master Mode Timing Characteristics Symbol t1 t2 t3 t4 t5 t6 t7 t8 t9 t10 Description Table 21. I2C Master Mode Timing Characteristics Min Typical SCK High Time SCK Low Time START Condition Setup Time START Condition Hold Time Data In Hold Time Data In Setup Time Data Output Hold Time STOP Condition Setup Time SCK/SDA Active From Power On EEPROM Auto-Load Time (8K bit) Layer 2 16-Port & 24-Port 10/100M Switch Controllers 4.9 4.9 4.9 4.9 0 250 2.4 4.9 97 97 37 5 5 5 5 2.5 5 100 100 Max Units 2.6 185 185 µs µs µs µs µs ns µs ms ms Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 10.4.9. Serial CPU Interface Timing Figure 22. Serial CPU Interface Timing 10.4.10. Serial CPU Interface Timing Characteristics Symbol t1 t2 t3 t4 t5 t6 t7 t8 Table 22. Serial CPU Interface Timing Characteristics Description Min Typical SCK High Time 4.0 SCK Low Time 4.0 START Condition Setup Time 4.0 START Condition Hold Time 4.0 Data Hold Time 0 Data Setup Time 250 Clock to Data Output Delay 9 STOP Condition Setup Time 4.0 - Max - Units µs µs µs µs µs ns ns µs 10.5. SMI Timing Characteristics (RTL8324E Only) Symbol MDC MDIO Setup Time MDIO Hold Time Table 23. SMI Timing Characteristics (RTL8324E Only) Parameter Min Typical MDC Clock Rate 548 Write Cycle 10 Write Cycle 10 - Layer 2 16-Port & 24-Port 10/100M Switch Controllers 38 Max - Units ns ns ns Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 11. Mechanical Dimensions Min Dimension in mm Nom Max Min Dimension in inch Nom Max A — — 1.60 — — 0.063 A1 0.05 — 0.15 0.002 — 0.006 A2 1.35 1.40 1.45 0.053 0.055 0.057 b 0.17 0.2 0.27 0.007 0.009 0.011 Symbol D 22.00BSC 0.866BSC D1 20.00BSC 0.787BSC D2 / E 2 5.60 6.85 7.50 0.220 0.270 E 16.00BSC 0.630BSC E1 14.00BSC 0.551BSC e 0.50BSC 0.020BSC L L1 0.45 0.60 0.75 0.018 1.00 REF 0.024 0.295 0.030 0.039 REF Notes: 1. CONTROLLING DIMENSION: MILLIMETER (mm). 2. REFERENCE DOCUMENT: JEDEC MS-26. Layer 2 16-Port & 24-Port 10/100M Switch Controllers 39 Track ID: JATR-8275-15 Rev. 1.0 RTL8316E/RTL8324E Datasheet 12. Ordering Information Table 24. Ordering Information Part Number Package RTL8316E-CG LQFP 128-Pin E-PAD ‘Green’ Package RTL8324E-CG LQFP 128-Pin E-PAD ‘Green’ Package Note: See page 7 (RTL8316E-CG) and page 14 (RTL8324E-CG) for package identification. Status Production Production Realtek Semiconductor Corp. Headquarters No. 2, Innovation Road II, Hsinchu Science Park, Hsinchu 300, Taiwan, R.O.C. Tel: 886-3-5780211 Fax: 886-3-5776047 www.realtek.com Layer 2 16-Port & 24-Port 10/100M Switch Controllers 40 Track ID: JATR-8275-15 Rev. 1.0
RTL8316E-CG 价格&库存
很抱歉,暂时无法提供与“RTL8316E-CG”相匹配的价格&库存,您可以联系我们找货
