“Stay Connected” with
Strain Relief Bushings
Heyco ST Lockit Strain Relief Bushings
Snap onto Round Cables for Faster Assembly into Rectangular Mounting Holes –
Semi-Automatic Equipment Available
• Assembly friendly! Independent of
insertion into the panel, Lockit Strain
Reliefs self-lock onto the cable.
Preassemble off line for final
assembly at a later time or remote
location, for lower installed cost!
• Lockit Strain Reliefs hold so well they
pass the UL pull-out test requirements
with or without panel support.
• Protect the lifeline of your
electric/electronic products by
absorbing the forces of push and pull
that may be exerted on the flexible
power cord. Rectangular design
eliminates the possibility of part
rotation under forces of twist.
• Lockit’s three finger design securely
anchors into panels as thin as
.032˝ (0,8 mm) and as thick as
.157˝ (4,0 mm) for a neat, clean
appearance. Five locking steps
accommodate a wide range of panel
thicknesses. Low profile head satisfies
design aesthetics!
• Heyco’s automated Pre-Assembly
Equipment speeds assembly of the
Lockit onto the cable and thus lowers
costs while greatly reducing risk of
carpal tunnel syndrome.
See pages 4-15 & 4-16.
• Consult Heyco for other wire types
and sizes.
• See page 4-38 for corresponding
Mounting Hole Plugs which can be
used to fill blank/unused Mounting
Holes and thus allow for a single panel
design for multiple applications.
WILL FIT THESE CABLES
UL Type
AWG/
Approximate
Conductors
Size
in.
mm.
See
table
on page
4-10
See
table
on page
4-10
See
table
on page
4-10
PANEL DIMENSIONS
ST LOCKIT STRAIN RELIEF
Corresponding
Mounting Hole
Thickness
for Faster Assembly
Mounting Hole Plug
Size
PART NO.
DESC.
PART
in.
mm.
in. mm. Black White
NO.
DESC.
various
.032
.040
.220 - .290 5,6 - 7,4 .453 x .512 11,5 x 13,0 .048
.063
.099
0,8
1,1
1,2 1832
1,6
2,5
1833
ST 101N
1890 RP 115-130
various
.032
.063
.290 - .360 7,4 - 9,1 .689 x .689 17,5 x 17,5 .099
.126
.157
0,8
1,6
2,5 1836
3,2
4,0
1837
ST 201N
1892 RP 175-175
various
.032
.063
.355 - .420 9,0 - 10,6 .689 x .689 17,5 x 17,5 .099
.126
.157
0,8
1,6
2,5 1848
3,2
4,0
1849
ST 301N
1892 RP 175-175
Standard color black. Consult Heyco for white and other colors.
.55
(14,0mm)
.512
(13,0mm)
LOCKING TAB
.453
(11,5mm)
.51
(13,0mm)
MOUNTING HOLE
.56
(14,2mm)
ST 101N
Locking Tab varies with Cable Size
.72
(18,3mm)
.689
(17,5mm)
.689
(17,5mm)
.76
(19,3mm)
ST 201N, ST 301N
Quick
Specs
4-5
Material
Certifications
Flammability Rating
Temperature Range
.76
(19,3mm)
MOUNTING HOLE
Nylon 6/6
Recognized under the Component Program of Underwriters’
Laboratories File E15331
Certified by the Canadian Standards Association File 8919
94V-2
-.04°F (-18°C) to 221°F (105°C).
1-800-526-4182 • 732-286-1800 (NJ) • FAX: 732-244-8843 • www.heyco.com
很抱歉,暂时无法提供与“1848”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 125+0.83224125+0.10067
- 300+0.82835300+0.10020
- 750+0.82833750+0.10020
- 2000+0.828312000+0.10020
- 4000+0.828294000+0.10019
