XM25QH32BHIG
XM25QH32BHIG
    XMC
    SOP8
    XM25QH32BHIG
XM25QH32BHIG 数据手册
XM25QH32B 3V 32M-BIT SERIAL NOR FLASH WITH DUAL AND QUAD SPI&QPI Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 XM25QH32B Contents FEATURES ............................................................................................................................................................... 3 GENERAL DESCRIPTION ...................................................................................................................................... 4 1. ORDERING INFORMATION ...................................................................................................................... 5 2. BLOCK DIAGRAM...................................................................................................................................... 6 3. CONNECTION DIAGRAMS ....................................................................................................................... 7 4. SIGNAL DESCRIPTIONS ............................................................................................................................ 8 4.1. Serial Data Input (DI) / IO0 ................................................................................................................ 8 4.2. Serial Data Output (DO) / IO1 ............................................................................................................ 8 4.3. Serial Clock (CLK) ............................................................................................................................. 8 4.4. Chip Select (CS#) ............................................................................................................................... 8 4.5. Write Protect (WP#) / IO2 .................................................................................................................. 9 4.6. HOLD (HOLD#) / IO3 ....................................................................................................................... 9 4.7. RESET (RESET#) / IO3 ..................................................................................................................... 9 5. MEMORY ORGANIZATION ..................................................................................................................... 10 5.1. Flash Memory Array ......................................................................................................................... 10 5.2. Security Registers ............................................................................................................................. 10 5.2.1 Security Register 0 ...................................................................................................................11 5.2.2 Serial Flash Discoverable Parameters (SFDP) Address Map ..................................................11 5.2.3 SFDP Header Field Definitions .............................................................................................. 12 5.2.4 JEDEC SFDP Basic SPI Flash Parameter ............................................................................... 13 6. FUNCTION DESCRIPTION ...................................................................................................................... 18 6.1 SPI Operations ................................................................................................................................... 18 6.1.1 SPI Modes ............................................................................................................................... 18 6.1.2 Dual SPI Modes ...................................................................................................................... 18 6.1.3 Quad SPI Modes ..................................................................................................................... 18 6.1.4 QPI Function ........................................................................................................................... 19 6.1.5 Hold Function ......................................................................................................................... 19 6.1.6 Software Reset & Hardware RESET# pin .............................................................................. 19 6.2. Status Register .................................................................................................................................. 20 6.2.1 BUSY...................................................................................................................................... 22 6.2.2 Write Enable Latch (WEL) ..................................................................................................... 22 6.2.3 Block Protect Bits (BP2, BP1, BP0) ....................................................................................... 22 6.2.4 Top / Bottom Block Protect (TB) ............................................................................................ 22 6.2.5 Sector / Block Protect (SEC) .................................................................................................. 22 6.2.6 Complement Protect (CMP) ................................................................................................... 23 6.2.7 The Status Register Protect (SRP1, SRP0) ............................................................................. 23 6.2.8 Erase / Program Suspend Status (SUS)................................................................................... 23 6.2.9 Security Register Lock Bits (LB3, LB2, LB1, LB0) .............................................................. 23 6.2.10 Quad Enable (QE)................................................................................................................. 24 6.2.11 HOLD# or RESET# Pin Function (HRSW) ......................................................................... 24 6.2.12 Output Driver Strength (DRV1, DRV0)................................................................................ 24 6.2.13 High Frequency Mode Enable Bit (HFM) ............................................................................ 24 6.2.14 Latency Control (LC)............................................................................................................ 24 6.3. Write Protection ................................................................................................................................ 25 6.3.1 Write Protect Features ............................................................................................................. 25 6.3.2 Block Protection Maps............................................................................................................ 27 6.4. Page Program .................................................................................................................................... 29 6.5. Sector Erase, Block Erase and Chip Erase........................................................................................ 29 6.6. Polling during a Write, Program or Erase Cycle ............................................................................... 29 6.7. Active Power, Stand-by Power and Deep Power-Down Modes ....................................................... 29 7. INSTRUCTIONS ........................................................................................................................................ 30 7.1 Configuration and Status Commands ................................................................................................ 35 7.1.1 Read Status Register (05h/35h/15h) ....................................................................................... 35 7.1.2 Write Enable (06h) .................................................................................................................. 35 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 1 XM25QH32B 7.1.3 Write Enable for Volatile Status Register (50h) ...................................................................... 36 7.1.4 Write Disable (04h) ................................................................................................................. 36 7.1.5 Write Status Register (01h/31h/11h) ....................................................................................... 36 7.2 Program and Erase Commands .......................................................................................................... 37 7.2.1 Page Program (PP) (02h) ........................................................................................................ 37 7.2.2 Quad Input Page Program (32h) ............................................................................................. 38 7.2.3 Sector Erase (SE) (20h) .......................................................................................................... 39 7.2.4 Block Erase (BE) (D8h) and Half Block Erase (52h) ............................................................. 39 7.2.5 Chip Erase (CE) (C7h or 60h) ................................................................................................ 40 7.2.6 Erase / Program Suspend (75h)............................................................................................... 41 7.2.7 Erase / Program Resume (7Ah) .............................................................................................. 41 7.3 Read Commands ................................................................................................................................ 42 7.3.1 Read Data (03h) ...................................................................................................................... 42 7.3.2 Fast Read (0Bh) ...................................................................................................................... 42 7.3.3 Fast Read Dual Output (3Bh) ................................................................................................. 43 7.3.4 Fast Read Quad Output (6Bh)................................................................................................. 44 7.3.5 Fast Read Dual I/O (BBh)....................................................................................................... 44 7.3.6 Fast Read Quad I/O (EBh) ...................................................................................................... 45 7.3.7 Word Read Quad I/O (E7h) .................................................................................................... 46 7.3.8 Octal Word Read Quad I/O (E3h) ........................................................................................... 47 7.3.9 Set Burst with Wrap (77h) ...................................................................................................... 48 7.4 Reset Commands ............................................................................................................................... 49 7.4.1 Software Reset Enable (66h) .................................................................................................. 50 7.4.2 Software Reset (99h) .............................................................................................................. 50 7.5 ID and Security Commands ............................................................................................................... 50 7.5.1 Deep Power-down (DP) (B9h)................................................................................................ 50 7.5.2 Release Power-down / Device ID (ABh) ................................................................................ 50 7.5.3 Read Manufacturer / Device ID (90h) .................................................................................... 51 7.5.4 Read Identification (RDID) (9Fh) .......................................................................................... 52 7.5.5 Read SFDP Register (5Ah) ..................................................................................................... 53 7.5.6 Erase Security Registers (44h) ................................................................................................ 53 7.5.7 Program Security Registers (42h) ........................................................................................... 54 7.5.8 Read Security Registers (48h) ................................................................................................ 54 7.5.9 Read Manufacturer / Device ID Dual I/O (92h) ..................................................................... 55 7.5.10 Read Unique ID Number (4Bh) ............................................................................................ 55 7.5.11 Set Read Parameters (C0h) ................................................................................................... 56 7.5.12 Burst Read with Wrap (0Ch)................................................................................................. 56 7.5.13 Enter QPI Mode (38h) .......................................................................................................... 57 7.5.14 Exit QPI Mode (FFh) ............................................................................................................ 57 8. ELECTRICAL CHARACTERISTIC .......................................................................................................... 58 8.1. Absolute Maximum Ratings ............................................................................................................. 59 8.2. Recommended Operating Ranges ..................................................................................................... 59 8.3. DC Characteristics ............................................................................................................................ 60 8.4. AC Measurement Conditions ............................................................................................................ 60 8.5. AC Electrical Characteristics ............................................................................................................ 61 9. PACKAGE MECHANICAL ....................................................................................................................... 63 9.1. SOP 208mil 8L ................................................................................................................................. 63 9.2. SOP 150mil 8L ................................................................................................................................. 63 9.3. WSON 5x6 8L .................................................................................................................................. 64 REVISION LIST ..................................................................................................................................................... 65 Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 2 XM25QH32B FEATURES  Low power supply operation - Single 2.7V-3.6V supply  32 Mbit Serial Flash - 32 M-bit/4M-byte/16,384 pages - 256 bytes per programmable page - Uniform 4K-byte Sectors, 32K/64K-byte Blocks  Package Options - SOP 208mil 8L - SOP 150mil 8L - WSON 5x6 8L - All Pb-free packages are RoHS compliant  New Family of SpiFlash Memories - Standard SPI: CLK, CS#, DI, DO, WP#, HOLD# / RESET# - Dual SPI: CLK, CS#, DI, DO, WP#, HOLD# / RESET# - Quad SPI: CLK, CS#, IO0, IO1, IO2, IO3 - QPI: CLK, CS#, IO0, IO1, IO2, IO3 - Software & Hardware Reset - Auto-increment Read capability  Temperature Ranges - Consumer (-20°C to +85°C) - Industrial (-40°C to +85°C)  Low power consumption - 9 mA typical active current - 2 uA typical power down current  Efficient “Continuous Read” and QPI Mode - Continuous Read with 8/16/32/64-Byte Wrap - As few as 8 clocks to address memory - Quad Peripheral Interface(QPI) reduces instruction overhead  Flexible Architecture with 4KB sectors - Sector Erase (4K-bytes) - Block Erase (32K/64K-bytes) - Page Program up to 256 bytes - Typical 100K erase/program cycles - More than 20-year data retention  Advanced Security Feature - Software and Hardware Write-Protect - Power Supply Lock-Down and OTP protection - Top/Bottom, Complement array protection - 64-Bit Unique ID for each device - Discoverable parameters(SFDP) register - 3X256-Bytes Security Registers with OTP locks - Volatile & Non-volatile Status Register Bits  High performance program/erase speed - Page program time: 500us typical - Sector erase time: 50ms typical - Block erase time: 300ms typical - Chip erase time: 10 Seconds typical Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 3 XM25QH32B GENERAL DESCRIPTION The XM25QH32B of non-volatile flash memory device supports the standard Serial Peripheral Interface (SPI). Traditional SPI single bit serial input and output (Single I/O or SIO) is supported as well as optional two bit (Dual I/O or DIO) and four bit (quad I/O or QIO) serial protocols. This multiple width interface is called SPI Multi-I/O or MIO. The SPI protocols use only 4 to 6 signals:  Chip Select (CS#)  Serial Clock (CLK)  Serial Data - IO0 (DI) - IO1 (DO) - IO2 (WP#) - IO3 (HOLD# / RESET#) The XM25QH32B support the standard Serial Peripheral Interface (SPI), Dual/Quad I/O SPI as well as 2-clocks instruction cycle Quad Peripheral Interface (QPI): Serial Clock, Chip Select, Serial Data I/O0 (DI), I/O1 (DO), I/O2 (WP#), and I/O3 (HOLD# / RESET#). SPI clock frequencies of up to 104MHz are supported allowing equivalent clock rates of 208MHz (104MHz x 2) for Dual I/O and 416MHz (104MHz x 4) for Quad I/O when using the Fast Read Dual/Quad I/O and QPI instructions. These transfer rates can outperform standard Asynchronous 8 and 16-bit Parallel Flash memories. The Continuous Read Mode allows for efficient memory access with as few as 8-clocks of instruction-overhead to read a 24-bit address, allowing true XIP (execute in place) operation. A Hold pin, Write Protect pin and programmable write protection, with top or bottom array control, provide further control flexibility. Additionally, the device supports JEDEC standard manufacturer and device ID and SFDP Register, a 64-bit Unique Serial Number and three 256-bytes Security Registers. The XM25QH32B provides an ideal storage solution for systems with limited space, signal connections, and power. These memories' flexibility and performance is better than ordinary serial flash devices. They are ideal for code shadowing to RAM, executing code directly (XIP), and storing reprogrammable data. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 XM25QH32B 1. ORDERING INFORMATION The ordering part number is formed by a valid combination of the following: XM 25 QH 32 B X X X X -xx [1] SPECIAL OPTIONS xx = for UID, start from 01 to distinguish different UID request Packing Type T: Tape & Reel R: Tray Green Code P: Pb free only green package G: Pb free and halogen free Temperature Range I: Industrial (-40°C to +85°C) E: Extended (-20°C to +85°C) Package Type H: SOP 208mil 8L J: SOP 150mil 8L W: WSON 5x6 8L Version A: A Version B: B Version C: C Version Device Density 128: 128 Mbit 64: 64 Mbit 32: 32 Mbit 16: 16 Mbit 80: 8 Mbit 40: 4 Mbit 20: 2 Mbit Series QH: 3V, 4KB uniform-sector Product Family 25: SPI Interface Flash Wuhan Xinxin Semiconductor Figure 1.1 Ordering Information Notes: 1、This option code is not included on the part marketing. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 5 XM25QH32B 2. BLOCK DIAGRAM Figure 2.1 Block Diagram Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 6 XM25QH32B 3. CONNECTION DIAGRAMS Figure 3.1 8-pin SOP (150/208mil) Figure 3.2 8-Contact 5 x 6 mm WSON Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 7 XM25QH32B 4. SIGNAL DESCRIPTIONS Table 4.1 Pin Descriptions Symbol Pin Name CLK Serial Clock Input DI(IO0) Serial Data Input(Data input output 0) (1) DO(IO1) Serial Data Output(Data input output 1) (1) CS# Chip Enable WP#(IO2)(3) Write Protect (Data input output 2) (2) HOLD# / RESET#(3)(IO3) Hold or Reset input(Data input output 3) (2) VCC Power Supply (2.7-3.6V) GND Ground Notes: (1) IO0 and IO1 are used for Standard and Dual SPI instructions. (2) IO0—IO3 are used for QUAD SPI / QPI instructions. (3) WP# and HOLD# / RESET# functions are only available for Standard and Dual SPI. 4.1. Serial Data Input (DI) / IO0 The SPI Serial Data Input (DI) pin is used to transfer data serially into the device. It receives instructions, address and data to be programmed. Data is latched on the rising edge of the Serial Clock (CLK) input pin. The DI pin becomes IO0 - an input and output during Dual and Quad commands for receiving instructions, address, and data to be programmed (values latched on rising edge of serial CLK clock signal) as well as shifting out data (on the falling edge of CLK). 4.2. Serial Data Output (DO) / IO1 The SPI Serial Data Output (DO) pin is used to transfer data serially out of the device. Data is shifted out on the falling edge of the Serial Clock (CLK) input pin. DO becomes IO1 - an input and output during Dual and Quad commands for receiving instructions, addresses, and data to be programmed (values latched on rising edge of serial CLK clock signal) as well as shifting out data (on the falling edge of CLK). 4.3. Serial Clock (CLK) The SPI Serial Clock Input (CLK) pin provides the timing for serial input and output operations. ("See SPI Mode") 4.4. Chip Select (CS#) The SPI Chip Select (CS#) pin enables and disables device operation. When CS# is high the device is deselected and the Serial Data Output pins are at high impedance. When deselected, the devices power consumption will be at standby levels unless an internal erase, program or status register cycle is in progress. When CS# is brought low the device will be selected, power consumption will increase to active levels and instructions can be written to and data read from the device. After power-up, CS# must transition from high to low before a new instruction will be accepted. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 8 XM25QH32B 4.5. Write Protect (WP#) / IO2 The Write Protect (WP#) pin can be used to prevent the Status Register from being written. Used in conjunction with the Status Register’s Block Protect (BP0, BP1 and BP2, TB, SEC, CMP) bits and Status Register Protect (SRP0) bits, a portion or the entire memory array can be hardware protected. The WP# function is not available when the Quad mode is enabled. The WP# function is replaced by IO2 for input and output during Quad mode for receiving addresses and data to be programmed (values are latched on rising edge of the CLK signal) as well as shifting out data (on the falling edge of CLK). 4.6. HOLD (HOLD#) / IO3 The HOLD# pin allows the device to be paused while it is actively selected. When HRSW bit is ‘0’ (factory default is ‘0’), the HOLD# pin is enabled. When HOLD# is brought low, while CS# is low, the DO pin will be at high impedance and signals on the DI and CLK pins will be ignored (don’t care). When HOLD# is brought high, device operation can resume. The HOLD# function can be useful when multiple devices are sharing the same SPI signals. The HOLD# pin is active low. When the QE bit of Status Register-2 is set for Quad I/O, the HOLD# pin function is not available since this pin is used for IO3. 4.7. RESET (RESET#) / IO3 The RESET# pin allows the device to be reset by the controller. When HRSW bit is ‘1’ (factory default is ‘0’), the RESET# pin is enabled. Drive RESET# low for a minimum period of ~1us (tRESET*) will interrupt any on-going external/internal operations, regardless the status of other SPI signals (CS#, CLK, DI, DO, WP# and/or HOLD#). The Hardware Reset function is only available for standard SPI and Dual SPI operation, when QE=0, the IO3 pin can be configured either as a HOLD# pin or as a RESET# pin depending on Status Register setting, when QE=1, this pin is the Serial Data IO (IO3) for Quad I/O operation. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 9 XM25QH32B 5. MEMORY ORGANIZATION 5.1. Flash Memory Array The memory is organized as: - 4,194,304bytes - Uniform Sector Architecture 64 blocks of 64-Kbyte - 1024 sectors of 4-Kbyte - 16, 384 pages (256 bytes each) Each page can be individually programmed (bits are programmed from 1 to 0). The device is Sector, Block or Chip Erasable but not Page Erasable. (1) Table 5.1 Block/ Security Register/SFDP Security Register 3 Memory Organization Sector Address range - 003000H 0030FFH Security Register 2 - 002000H 0020FFH Security Register 1 Security Register 0 (SFDP) - 001000H 0010FFH - 000000H 0000FFH 1023 3FF000H 3FFFFFH ...... ...... ...... 1008 3F0000H 3F0FFFH 1007 3EF000H 3EFFFFH Block 63 Block 62 ...... ...... Block 2 Block 1 Block 0 ...... ...... ...... 992 3E0000H 3E0FFFH ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... ...... 47 02F000H 02FFFFH ...... ...... ...... 32 020000H 020FFFH 01FFFFH 31 01F000H ...... ...... ...... 16 010000H 010FFFH 15 00F000H 00FFFFH ...... ...... ...... 0 000000H 000FFFH Notes: (1) These are condensed tables that use a couple of sectors as references. There are address ranges that are not explicitly listed. All 4-kB sectors have the pattern XXX000h-XXXFFFh. 5.2. Security Registers The XM25QH32B provides four 256-byte Security Registers. Each register can be used to store information that can be permanently protected by programming One Time Programmable (OTP) lock bits in Status Register-2. Register 0 is used by XMC to store and protect the Serial Flash Discoverable Parameters (SFDP) information that is also accessed by the Read SFDP command. See Table 5.1. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 10 XM25QH32B The three additional Security Registers can be erased, programmed, and protected individually. These registers may be used by system manufacturers to store and permanently protect security or other important information separate from the main memory array. 5.2.1 Security Register 0 Serial Flash Discoverable Parameters (SFDP — JEDEC ): This document defines the Serial Flash Discoverable Parameters (SFDP) revision B data structure for XM25QH32B family. These data structure values are an update to the earlier revision SFDP data structure in the XM25QH32B family devices. The Read SFDP (RSFDP) command (5Ah) reads information from a separate flash memory address space for device identification, feature, and configuration information, in accord with the JEDEC standard for Serial Flash Discoverable Parameters. The SFDP data structure consists of a header table that identifies the revision of the JESD216 header format that is supported and provides a revision number and pointer for each of the SFDP parameter tables that are provided. The parameter tables follow the SFDP header. However, the parameter tables may be placed in any physical location and order within the SFDP address space. The tables are not necessarily adjacent nor in the same order as their header table entries. The SFDP header points to the following parameter tables:  Basic Flash – This is the original SFDP table. The physical order of the tables in the SFDP address space is: SFDP Header, and Basic Flash.The SFDP address space is programmed by XMC and read-only for the host system. 5.2.2 Serial Flash Discoverable Parameters (SFDP) Address Map The SFDP address space has a header starting at address zero that identifies the SFDP data structure and provides a pointer to each parameter. One Basic Flash parameter is mandated by the JEDEC standard. Table 5.2 SFDP Overview Map — Security Register 0 Byte Address 0000h ... 0030h ... 006Fh 0070h to 00FFh Description Location zero within JEDEC SFDP space – start of SFDP header Remainder of SFDP header followed by undefined space Start of SFDP parameter Remainder of SFDP JEDEC parameter followed by undefined space End of SFDP space Reserved space Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 11 XM25QH32B 5.2.3 SFDP Header Field Definitions Table 5.3 SFDP Header (Sheet 1 of 1) Add (h) (Byte) DW Add (Bit) Data SFDP Minor Revision Number SFDP Major Revision Number 00h 01h 02h 03h 04h 05h 07 : 00 15 : 08 23 : 16 31 : 24 07 : 00 15 : 08 53h 46h 44h 50h 00h 01h Number of Parameter Headers (NPH) 06h 23 : 16 01h Unused ID Number(JEDEC) Parameter Table Minor Revision Number Parameter Table Major Revision Number Parameter Table Length (in double word) 07h 08h 31 : 24 07 : 00 FFh 00h Star from 0x00 Star from 0x01 This number is 0-based.Therefore,0 indicates 1 parameter header. Reserved 00h:it indicates a JEDEC specified header. 09h 15 : 08 00h Star from 0x00 0Ah 23 : 16 01h Star from 0x01 0Bh 31 : 24 09h How many DWORDs in the parameter table 0Ch 0Dh 0Eh 0Fh 10h 07 : 00 15 : 08 23 : 16 31 : 24 07 : 00 30h 00h 00h FFh 20h 11h 15 : 08 00h Start from 00h 12h 23 : 16 01h Start from 01h 13h 31 : 24 04h How many DWORDs in the parameter table 14h 15h 16h 17h 07 : 00 15 : 08 23 : 16 31 : 24 60h 00h 00h FFh Description SFDP Signature Parameter Table Pointer (PTP) Unused ID number(Manufacturer ID) Parameter Table Minor Revision Number Parameter Table Major Revision Number Parameter Table Length(in double word) Parameter Table Pointer(PTP) Unused Wuhan Xinxin Semiconductor Manufacturing Corp. Comment Fixed: 50444653h First address of JEDEC Flash Parameter table It indicates manufacture ID First address Parameter table Rev. M Issue Date: 2018/07/17 of VENDOR Flash 12 XM25QH32B 5.2.4 JEDEC SFDP Basic SPI Flash Parameter Table 5.4 Basic SPI Flash Parameter, JEDEC Flash Parameter Tables (Sheet 1 of 9) Add (h) DW Add Description Data Comment (Byte) (Bit) 01 : 00 01b 02 1b 03 0b 04 0b 07 : 05 111b 15 : 08 20h 16 1b 18 : 17 00b 19 0b 20 1b (1-4-4) Fast Read 21 1b (1-1-4) Fast Read 22 1b 23 31 : 24 1b FFh Block / Sector Erase sizes Write Granularity Volatile Status Register Block Protect bits 30h Write Enable Instruction Select for Writing to Volatile Status Registers Unused 31h 4KB Erase Instruction (1-1-2) Fast Read(1) Address Bytes Number addressing flash array used in Double Transfer Rate(DTR) clocking (1-2-2) Fast Read Unused Unused 32h 33h 00:Reserved, 01:4KB erase, 10:Reserved, 11:not supported 4KB erase 0:1Byte,1:64Byte or larger 0: Block Protect bits in device's status register are solely non-volatile or may be programmed either as volatile using the 50h instruction for write enable or non-volatile using the 06h instruction for write enable. 1: Block Protect bits in device's status register are solely volatile. 0:use 50h instruction 1:use 06h instruction Contains 111b and can never be changed 0 = not supported 1 = supported 00:3Byte only, 01:3 or 4Byte 10:4Byte only, 11:Reserved 0 = not supported 1 = supported 0 = not supported 1 = supported 0 = not supported 1 = supported 0 = not supported 1 = supported Table 5.4 Basic SPI Flash Parameter, JEDEC Flash Parameter Tables (Sheet 2 of 9) Add (h) DW Add Description Data Comment (Byte) (Bit) Flash Memory Density 37h : 34h Wuhan Xinxin Semiconductor Manufacturing Corp. 31 : 00 For densities 2 gigabits or less, bit-31 is set to 0b. The field 30:0 defines the size in bits. Example: 00FFFFFFh = 16 megabits For densities 4 gigabits and above, 01FFFFFFh bit-31 is set to 1b. The field 30:0 defines ‘N’ where the density is computed as 2^N bits (N must be >= 32). Example: 80000021h = 2^33 = 8 gigabits Rev. M Issue Date: 2018/07/17 13 XM25QH32B Table 5.4 Basic SPI Flash Parameter, JEDEC Flash Parameter Tables (Sheet 3 of 9) Add (h) DW Add Description Data Comment (Byte) (Bit) (1-4-4)Fast Read number of Wait states(2) (1-4-4)Fast Read number of Mode Clocks(3) 38h (1-4-4)Fast Read instruction 39h (1-1-4)Fast Read Number of Wait states (1-1-4)Fast Read Number of Mode Clocks (1-1-4)Fast Read Instruction 04 : 00 00100b 07 : 05 010b 15 : 08 EBh 20 : 16 01000b 23 : 21 000b 31 : 24 6Bh 3Ah 3Bh 00000b:Not supported;00100b:4 00110b:6 01000b:8 Mode clocks: 000b:Not supported;010: 2 clocks 00000b:Not suppoted;00100b:4 00100b:6; 01000b:8 Mode clocks: 000b:Not supported;010b:2 clocks Table 5.4 Basic SPI Flash Parameter, JEDEC Flash Parameter Tables (Sheet 4 of 9) Add (h) DW Add Description Data Comment (Byte) (Bit) (1-1-2)Fast Read Number of Wait states (1-1-2)Fast Read Number of Mode Clocks (1-1-2)Fast Read Instruction (1-2-2)Fast Read Instruction 01000b 07 : 05 000b 15 : 08 3Bh 20 : 16 00100b 23 : 21 000b 31 : 24 BBh 3Ch 3Dh (1-2-2)Fast Read Number of Wait states (1-2-2)Fast Read Number of Mode Clocks 04 : 00 3Eh 3Fh 00000b:Not supported;00100b:4 00110b:6;01000b:8 Mode clocks: 000b:Not supported;010:2 clocks 00000b:Not supported; 00010b:2; 00100b:4;00110b:6;01000b:8 Mode clocks: 000b:Notsupported;010:2 clocks; 100:4 clocks Table 5.4 Basic SPI Flash Parameter, JEDEC Flash Parameter Tables (Sheet 5 of 9) Add (h) DW Add Description Data Comment (Byte) (Bit) (2-2-2)Fast Read Unused 40h (4-4-4)Fast Read Unused Unused 43h : 41h 00 0b 03 : 01 111b 04 1b 07 : 05 31 : 08 111b FFFFFFh 0 = not supported 1 = supported 0 = not supported 1 = supported Table 5.4 Basic SPI Flash Parameter, JEDEC Flash Parameter Tables (Sheet 6 of 9) Add (h) DW Add Description Data Comment (Byte) (Bit) 45h : 44h 15 : 00 FFh Unused (2-2-2)Fast Read Number of Wait states (2-2-2) Fast Read Number of Mode Clocks (2-2-2)Fast Read Instruction 20 : 16 00000b 23 : 21 000b 31 : 24 FFh 46h 47h Wuhan Xinxin Semiconductor Manufacturing Corp. 00000b:Not supported;00100b:4 00110b:6;01000b:8 Mode Clocks: 000b:Not supported;010:2 clocks Rev. M Issue Date: 2018/07/17 14 XM25QH32B Table 5.4 Basic SPI Flash Parameter, JEDEC Flash Parameter Tables (Sheet 7 of 9) Add (h) DW Add Description Data Comment (Byte) (Bit) 49h : 48h 15 : 00 FFFFh Unused (4-4-4)Fast Read Number of Wait states 20 : 16 00010b 23 : 21 010b 31 : 24 EBh 4Ah (4-4-4) Fast Read Number of Mode Clocks (4-4-4)Fast Read Instruction 4Bh 00000b:Not supported; 00010b:2;00100b:4; 00110b:6;01000b:8 Mode Clocks: 000b:Not supported;010:2 clocks Table 5.4 Basic SPI Flash Parameter, JEDEC Flash Parameter Tables (Sheet 8 of 9) Add (h) DW Add Description Data Comment (Byte) (Bit) Erase Type 1 Size 4Ch 07 : 00 0Ch Erase Type 1 Erase Instruction 4Dh 15 : 08 20h Erase Type 2 Size 4Eh 23 : 16 0Fh Erase Type 2 Erase Instruction 4Fh 31 : 24 52h Sector/block size=2N bytes(4) 0Ch:4KB;0Fh:32KB;10h:64KB Sector/block size=2N bytes 00h:NA;0Fh:32KB;10h:64KB Table 5.4 Basic SPI Flash Parameter, JEDEC Flash Parameter Tables (Sheet 9 of 9) Add (h) DW Add Description Data Comment (Byte) (Bit) Sector/block size=2N bytes 00h:NA;0Fh:32KB;10h:64KB Erase Type 3 Size 50h 07 : 00 10h Erase Type 3 Erase Instruction 51h 15 : 08 D8h Erase Type 4 Size 52h 23 : 16 00h Sector/block size=2N bytes 00h:NA;0Fh:32KB;10h:64KB Erase Type 4 Erase Instruction 53h 31 : 24 FFh Not support Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 15 XM25QH32B Table 5.5 Basic SPI Flash Parameter, XMC Flash Parameter Tables Add (h) DW Add Description Data Comment (Byte) (Bit) 2000h=2.000V 07:00 00h 61h:60h Vcc supply maximum voltage 2700h=2.700V 15:08 36h Vcc supply minimum voltage 23:16 00h 31:24 27h 63h:62h H/W Reset# pin 0 H/W Hold# pin 1 Deep Power Down Mode 2 S/W Reset 3 S/W Reset Instruction 65h:64h 11:04 Program suspend/resume 12 Erase suspend/resume 13 Unused 14 Wrap-Around Read mode 15 Wrap-Around Read mode instruction Wrap-Around Read data length 66h 23:16 67h 31:24 0 = not supported 1 = supported 0Ch 64h 0 Individual block lock Individual block lock bit(Volatile/Nonvolatile) Individual block lock Instruction Individual block lock Volatile protect bit default protect status Secured OTP F99Fh 3600h=3.600V 1650h=1.65V 1750h=1.75V 2250h=2.25V 2300h=2.3V 2350h=2.35V 2650h=2.65V 2700h=2.7V 0 = not supported 1 = supported 0 = not supported 1 = supported 0 = not supported 1 = supported 0 = not supported 1 = supported Reset Enable(66h)should be issued before Reset instruction 0 = not supported 1 = supported 0 = not supported 1 = supported 08h:support 8B wrap-around read 16h:8B&16B 32h:8B&16B&32B 64h:8B&16B&32B&64B 0 = not supported 1 = supported 0:Volatile 1:Nonvolatile 1 09:02 0:Protect 1:Unprotect 10 6Bh:68h F800h 11 Read Lock 12 Permanent Lock 13 0 = not supported 1 = supported 0 = not supported 1 = supported 0 = not supported 1 = supported 15:14 Unused 31:16 FFh Unused 6Fh:6Ch 31:00 FFh Unused Note 1: (x-y-z) means I/O mode nomenclature used to indicate the number of active pins used for the instruction (x), Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 16 XM25QH32B address (y), and data (z). At the present time, the only valid Read SFDP instruction modes are: (1-1-1), (2-2-2),and (4-4-4) Note 2: Wait States is required dummy clock cycles after the address bits or optional mode clocks. Note 3: Mode clocks is optional control bits that follow the address bits. These bits are driven by the system controller if they are specified. (eg,read performance enhance toggling bits) Note 4: 4KB=2^0Ch,32KB=2^0Fh,64KB=2^10h Note 5: All unused and undefined area data is blank FFh. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 17 XM25QH32B 6. FUNCTION DESCRIPTION 6.1 SPI Operations 6.1.1 SPI Modes The XM25QH32B can be driven by an embedded microcontroller (bus master) in either of the two following clocking modes. Mode 0 with Clock Polarity (CPOL) = 0 and, Clock Phase (CPHA) = 0 Mode 3 with CPOL = 1 and, CPHA = 1 For these two modes, input data is always latched in on the rising edge of the CLK signal and the output data is always available on the falling edge of the CLK clock signal. The difference between the two modes is the clock polarity when the bus master is in standby mode and not transferring any data. CLK will stay at logic low state with CPOL = 0, CPHA = 0  CLK will stay at logic high state with CPOL = 1, CPHA = 1 CS# CPOL=0_CPHA=0_CLK CPOL=1_CPHA=1_CLK DI MSB DO MSB Figure 6.1 SPI Modes Timing diagrams throughout the rest of the document are generally shown as both mode 0 and 3 by showing CLK as both high and low at the fall of CS#. In some cases a timing diagram may show only mode 0 with CLK low at the fall of CS#. In such case, mode 3 timing simply means clock is high at the fall of CS# so no CLK rising edge set up or hold time to the falling edge of CS# is needed for mode 3. CLK cycles are measured (counted) from one falling edge of CLK to the next falling edge of CLK. In mode 0 the beginning of the first CLK cycle in a command is measured from the falling edge of CS# to the first falling edge of CLK because CLK is already low at the beginning of a command. 6.1.2 Dual SPI Modes The XM25QH32B supports Dual SPI Operation when using the Fast Read Dual Output (3Bh) and Fast Dual I/O (BBh) instruction. These features allow data to be transferred from the device at twice the rate possible with the standard SPI. These instructions are ideal for quickly downloading code to RAM upon Power-up (code-shadowing) or for executing non-speed-critical code directly from the SPI bus (XIP). When using Dual SPI commands, the DI and DO pins become bidirectional I/O pins: IO0 and IO1. 6.1.3 Quad SPI Modes The XM25QH32B supports Quad SPI operation when using the Fast Read Quad Output (6Bh), Fast Read Quad I/O (EBh) instruction, Word Read Quad I/O(E7h), and Octal Word Read Quad I/O(E3h). These instructions allow data to be transferred to or from the device four times the rate of ordinary Serial Flash. The Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 XM25QH32B Quad Read instructions offer a significant improvement in continuous and random access transfer rates allowing fast code-shadowing to RAM or execution directly from the SPI bus (XIP). When using Quad SPI instructions, the DI and DO pins become bidirectional IO0 and IO1, and the WP# and HOLD# / RESET# pins become IO2 and IO3 respectively. Quad SPI instructions require the non-volatile Quad Enable bit (QE) in Status Register-2 to be set. 6.1.4 QPI Function The XM25QH32B supports Quad Peripheral Interface (QPI) operations when the device is switched from Standard/Dual/Quad SPI mode to QPI mode using the “Enter QPI (38h)” instruction. The typical SPI protocol requires that the byte-long instruction code being shifted into the device only via DI pin in eight serial clocks. The QPI mode utilizes all four IO pins to input the instruction code, thus only two serial clocks are required. This can significantly reduce the SPI instruction overhead and improve system performance in an XIP environment. Standard/Dual/Quad SPI mode and QPI mode are exclusive. Only one mode can be active at any given time. “Enter QPI (38h)” and “Exit QPI (FFh)” instructions are used to switch between these two modes. Upon power-up or after a software reset using “Reset (99h)” instruction, the default state of the device is Standard/Dual/Quad SPI mode. To enable QPI mode, the non-volatile Quad Enable bit (QE) in Status Register-2 is required to be set. When using QPI instructions, the DI and DO pins become bidirectional IO0 and IO1, and the WP# and HOLD# / RESET# pins become IO2 and IO3 respectively. 6.1.5 Hold Function For Standard SPI and Dual SPI operations, the HOLD# / RESET# (IO3) signal allows the device interface operation to be paused while it is actively selected (when CS# is low). The Hold function may be useful in cases where the SPI data and clock signals are shared with other devices. For example, if the page buffer is only partially written when a priority interrupt requires use of the SPI bus, the Hold function can save the state of the interface and the data in the buffer so programming command can resume where it left off once the bus is available again. The Hold function is only available for standard SPI and Dual SPI operation, not during Quad SPI. To initiate a Hold condition, the device must be selected with CS# low. A Hold condition will activate on the falling edge of the HOLD# signal if the CLK signal is already low. If the CLK is not already low the Hold condition will activate after the next falling edge of CLK. The Hold condition will terminate on the rising edge of the HOLD# signal if the CLK signal is already low. If the CLK is not already low the Hold condition will terminate after the next falling edge of CLK. During a Hold condition, the Serial Data Output, (DO) or IO0 and IO1, are high impedance and Serial Data Input, (DI) or IO0 and IO1, and Serial Clock (CLK) are ignored. The Chip Select (CS#) signal should be kept active (low) for the full duration of the Hold operation to avoid resetting the internal logic state of the device. 6.1.6 Software Reset & Hardware RESET# pin The XM25QH32B can be reset to the initial power-on state by a software Reset sequence, either in SPI mode or QPI mode. This sequence must include two consecutive commands: Enable Reset (66h) & Reset (99h). If the command sequence is successfully accepted, the device will take approximately 10us (tRST) to reset. No command will be accepted during the reset period. XM25QH32B can also be configured to utilize a hardware RESET# pin. The HRSW bit in the Status Register-3 is the configuration bit for HOLD# pin function or RESET# pin function. When HRSW=0 (factory default), the pin acts as a HOLD# pin as described above; when HRSW =1, the pin acts as a RESET# pin. Drive the RESET# pin low for a minimum period of ~1us (tRESET*) will reset the device to its initial power-on state. Any on-going Program/Erase operation will be interrupted and data corruption may happen. While RESET# is low, the device will not accept any command input. If QE bit is set to 1, the HOLD# or RESET# function will be disabled, the pin will become one of the four data I/O pins. Hardware RESET# pin has the highest priority among all the input signals. Drive RESET# low for a minimum period of ~1us (tRESET*) will interrupt any on-going external/internal operations, regardless the status of other SPI signals (CS#, CLK, DI, DO, WP# and/or HOLD#). Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 19 XM25QH32B Note: 1. While a faster RESET# pulse (as short as a few hundred nanoseconds) will often reset the device, a 1us minimum is recommended to ensure reliable operation. 6.2. Status Register The Read and Write Status Registers commands can be used to provide status and control of the flash memory device. Status Register-1 (SR1) and Status Register-2 (SR2) can be used to provide status on the availability of the flash memory array, whether the device is write enabled or disabled, the state of write protection, Quad SPI setting, Security Register lock status, and Erase / Program Suspend status. SR1 and SR2 contain non-volatile bits in locations SR1[7:2] and SR2[6:0] that control sector protection, OTP Register Protection, Status Register Protection, and Quad mode. Bits located in SR2[7], SR1[1], and SR1[0] are read only volatile bits for suspend, write enable, and busy status. These are updated by the memory control logic. The SR1[1] write enable bit is set only by the Write Enable (06h) command and cleared by the memory control logic when an embedded operation is completed. Write access to the non-volatile Status Register bits is controlled by the state of the non-volatile Status Register Protect bits SR1[7] and SR2[0] (SRP0, SRP1), the Write Enable command (06h) preceding a Write Status Registers command, and while Quad mode is not enabled, the WP# pin. A volatile version of bits SR2[6], SR2[1], and SR1[7:2] that control sector protection and Quad Mode is used to control the behavior of these features after power up. During power up or software reset, these volatile bits are loaded from the non-volatile version of the Status Register bits. The Write Enable for Volatile Status Register (50h) command can be used to write these volatile bits when the command is followed by a Write Status Registers (01h/31h) command. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. Write access to the volatile SR1 and SR2 Status Register bits is controlled by the state of the non-volatile Status Register Protect bits SR1[7] and SR2[0] (SRP0, SRP1), the Write Enable for Volatile Status Register command (50h) preceding a Write Status Registers command, and the WP# pin while Quad mode is not enabled. Status Register-3 (SR3) is used to configure and provide status on the variable HOLD# or RESET# function, Output Driver Strength, High Frequency Enable Bitand read latency. Write access to the volatile SR3 Status Register bits is controlled by Write Enable for Volatile Status Register command (50h) preceding a Write Status Register command. The SRP bits do not protect SR3. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 20 XM25QH32B Table 6.1 Status Register-1 (SR1) Bits Field Function 7 SRP0 Status Register Protect 0 6 SEC Sector / Block Protect 5 TB Top / Bottom protect 4 3 2 BP2 BP1 BP0 Block Protect Bits 1 WEL Write Enable Latch 0 BUSY Embedded Operation Status Default State Description 0 0 = WP# input has no effect or Power Supply Lock Down mode 1 = WP# input can protect the Status Register or OTP Lock Down. 0 0 = BP2-BP0 protect 64-kB blocks 1 = BP2-BP0 protect 4-kB sectors 0 0 = BP2-BP0 protect from the Top down 1 = BP2-BP0 protect from the Bottom up 0 0 0 000b = No protection Volatile, Read only 0 0 = Not Write Enabled, no embedded operation can start 1 = Write Enabled, embedded operation can start Volatile, Read only 0 0 = Not Busy, no embedded operation in progress 1 = Busy, embedded operation in progress Type Non-volatile and Volatile versions Table 6.2 Status Register-2 (SR2) Bits Field Function Type Default State 7 SUS Suspend Status Volatile, Read Only 0 0 = Erase / Program not suspended 1 = Erase / Program suspended 6 CMP Complement Protect Non-volatile and Volatile versions 0 0 = Normal Protection Map 1 = Complementary Protection Map 5 LB3 4 LB2 3 LB1 2 LB0 1 QE 0 Security Register Lock Bits 0 OTP 0 0 Quad Enable SRP1 Status Register Protect 1 OTP Lock Bits 3:0 for Security Registers 3:0 0 = Security Register not protected 1 = Security Register protected Security register 0 contains the Serial Flash Discoverable Parameters and is always programmed and locked by XMC. 0 0 = Quad Mode Not Enabled, the WP# pin and HOLD# / RESET# are enabled 1 = Quad Mode Enabled, the IO2 and IO3 pins are enabled, and WP# and HOLD# / RESET# functions are disabled 0 0 = SRP1 selects whether WP# input has effect on protection of the status register 1 = SRP1 selects Power Supply Lock Down or OTP Lock Down mode Non-volatile and Volatile versions 0 Description Note: 1. A Software/Hardware reset or Power Down reset is required before non-volatile Status Register bits writing(06h+01/31h) when writing volatile Status Register command(50h+01h/31h) has been issued earlier within one power up-power down cycle. 2. When write non-volatile Status Register bits(06h+01/31h), please contact XMC sales representative for the application note of polling status bit check. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 21 XM25QH32B Table 6.3 Status Register-3 (SR3) Bits Field 7 HRSW(1) 6 DRV1(1) Function HOLD# or RESET# function Type Default State 0 1 The DRV1 & DRV0 bits are used to determine the output driver strength for the Read operations. Output Driver Strength 5 4 DRV0(1) Volatile HFM High Frequency Mode Enable Bit Latency Control (LC)(2) Variable SPI Read Latency Control 3 2 1 Description When HRSW=0, the pin acts as HOLD#; when HRSW=1, the pin acts as RESET#. HRSW functions are only available when QE=0. 0 0 0 0 0 0 0 0= QPI High Frequency Mode Disabled 1 = QPI High Frequency Mode Enabled Defines the number of read latency cycles in Fast Read, Dual Out, Quad Out, Dual IO, and Quad IO commands. Binary values for 1 to 15 latency cycles. A value of zero disables the variable latency mode. Note: 1.Default state for these three bits could be modified. please contact sales. 2. LC[3:0] only controls SPI read latency and will be reset to default while switching from QPI to SPI. QPI read latency is set by C0 instruction. 6.2.1 BUSY BUSY is a read only bit in the status register (SR1[0]) which is set to a “1” state when the device is executing a Page Program, Sector Erase, Block Erase, Chip Erase or Write Status Register instruction. During this time the device will ignore further instructions except for the Read Status Register instruction (see tW, tPP, tSE, tBE, and tCE in AC Characteristics). When the program, erase or write status register instruction has completed, the BUSY bit will be cleared to a “0” state indicating the device is ready for further instructions. 6.2.2 Write Enable Latch (WEL) Write Enable Latch (WEL) is a read only bit in the status register (SR1[1]) which is set to a 1 after executing a Write Enable Instruction. The WEL status bit is cleared to a 0 when the device is written disabled. A write disable state occurs upon power-up or after any of the following instructions: Write Disable, Page Program, Sector Erase, Block Erase, Chip Erase and Write Status Register. 6.2.3 Block Protect Bits (BP2, BP1, BP0) The Block Protect Bits (BP2, BP1, BP0) are non-volatile read / write bits in the Status Register (SR1[4:2]) that provide Write Protection control and status. Block Protect bits can be set using the Write Status Registers Command (see tW in Section 8.5). All, none or a portion of the memory array can be protected from Program and Erase commands (see Section 6.4.2, Block Protection Maps). The factory default setting for the Block Protection Bits is 0 (none of the array is protected.) 6.2.4 Top / Bottom Block Protect (TB) The non-volatile Top / Bottom bit (TB SR1[5]) controls whether the Block Protect Bits (BP2, BP1, BP0) protect from the Top (TB=0) or the Bottom (TB=1) of the array as shown in Section 6.4.2, Block Protection Maps. The factory default setting is TB=0. The TB bit can be set with the Write Status Registers Command depending on the state of the SRP0, SRP1 and WEL bits. 6.2.5 Sector / Block Protect (SEC) Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 22 XM25QH32B The non-volatile Sector / Block Protect bit (SEC SR1[6]) controls if the Block Protect Bits (BP2, BP1, BP0) protect either 4-kB Sectors (SEC=1) or 64-kB Blocks (SEC=0) of the array as shown in Section 6.4.2, Block Protection Maps. The default setting is SEC=0. 6.2.6 Complement Protect (CMP) The Complement Protect bit (CMP SR2[6]) is a non-volatile read / write bit in the Status Register (SR2[6]). It is used in conjunction with SEC, TB, BP2, BP1 and BP0 bits to provide more flexibility for the array protection. Once CMP is set to 1, previous array protection set by SEC, TB, BP2, BP1 and BP0 will be reversed. For instance, when CMP=0, a top 4-kB sector can be protected while the rest of the array is not; when CMP=1, the top 4-kB sector will become unprotected while the rest of the array become read-only. Refer to Section 6.4.2, Block Protection Maps for details. The default setting is CMP=0. 6.2.7 The Status Register Protect (SRP1, SRP0) The Status Register Protect bits (SRP1 and SRP0) are non-volatile read / write bits in the Status Register (SR2[0] and SR1[7]). The SRP bits control the method of write protection: software protection, hardware protection, power supply lock-down, or one time programmable (OTP) protection. Table 6.4 Status Register Protect SRP1 SRP0 WP# Status Register Description 0 0 X Software Protection WP# pin has no control. SR1 and SR2 can be written to after a Write Enable command, WEL=1. [Factory Default] 0 1 0 Hardware Protected When WP# pin is low the SR1 and SR2 are locked and cannot be written. 0 1 1 Hardware Unprotected When WP# pin is high SR1 and SR2 are unlocked and can be written to after a Write Enable command, WEL=1. 1 0 X Power Supply Lock Down SR1 and SR2 are protected and cannot be written to again until the next power-down, power-up cycle. (1) 1 1 X One Time Program (2) SR1 and SR2 are permanently protected and cannot be written. Notes: 1. When SRP1, SRP0 = (1, 0), a power-down, power-up, or Software Reset cycle will change SRP1, SRP0 to (0, 0) state. 2. The One-Time Program feature is available upon special order. Contact XMC for details. 3. Busy, WEL, and SUS (SR1[1:0] and SR2[7]) are volatile read only status bits that are never affected by the Write Status Registers command. 4. The non-volatile version of CMP, QE, SRP1, SRP0, SEC, TB, and BP2-BP0 (SR2[6,1,0] and SR1[6:2]) bits and the OTP LB3-LB0 bits are not writable when protected by the SRP bits and WP# as shown in the table. The non-volatile version of these Status Register bits is selected for writing when the Write Enable (06h) command precedes the Write Status Registers (01h) command. 5. The volatile version of CMP, QE, SRP1, SRP0, SEC, TB, and BP2-BP0 (SR2[6,1,0] and SR1[6:2]) bits are not writable when protected by the SRP bits and WP# as shown in the table. The volatile version of these Status Register bits is selected for writing when the Write Enable for volatile Status Register (50h) command precedes the Write Status Registers (01h) command. There is no volatile version of the LB3-LB0 bits and these bits are not affected by a volatile Write Status Registers command. 6. The volatile SR3 bits are not protected by the SRP bits and may be written at any time by volatile (50h) Write Enable command preceding the Write Status Registers (01h/11h) command. 6.2.8 Erase / Program Suspend Status (SUS) The Suspend Status bit is a read only bit in the status register (SR2[7]) that is set to 1 after executing an Erase / Program Suspend (75h) command. The SUS status bit is cleared to 0 by Erase / Program Resume (7Ah) command as well as a power-down, power-up cycle. 6.2.9 Security Register Lock Bits (LB3, LB2, LB1, LB0) The Security Register Lock Bits (LB3, LB2, LB1, LB0) are non-volatile One Time Program (OTP) bits in Status Register (SR2[5:2]) that provide the write protect control and status to the Security Registers. The default state of LB[3:1] is 0, Security Registers 1 to 3 are unlocked. LB[3:1] can be set to 1 individually using Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 23 XM25QH32B the Write Status Registers command. LB[3:1] are One Time Programmable (OTP), once it’s set to 1, the corresponding 256-byte Security Register will become read-only permanently. Security Register 0 is programmed with the SFDP parameters and LB0 is programmed to 0 by XMC. 6.2.10 Quad Enable (QE) The Quad Enable (QE) bit is a non-volatile read / write bit in the Status Register (SR2[1]) that allows Quad SPI operation. When the QE bit is set to a 0 state (factory default), the WP# pin and HOLD# / RESET# are enabled. When the QE bit is set to a 1, the Quad IO2 and IO3 pins are enabled, and WP# and HOLD# / RESET# functions are disabled. Note: If the WP# or HOLD# / RESET# pins are tied directly to the power supply or ground during standard SPI or Dual SPI operation, the QE bit should never be set to a 1. 6.2.11 HOLD# or RESET# Pin Function (HRSW) The HRSW bit is used to determine whether HOLD# or RESET# function should be implemented on the hardware pin for 8-pin packages. When HRSW=0, the pin acts as #HOLD; when HRSW=1, the pin acts as RESET#. However, HOLD# or RESET# functions are only available when QE=0. If QE is set to 1, the HOLD# and RESET# functions are disabled, the pin acts as a dedicated data I/O pin. 6.2.12 Output Driver Strength (DRV1, DRV0) The DRV1 & DRV0 bits are used to determine the output driver strength for the Read operations. DRV1, DRV0 0, 0 0, 1 1, 0 1, 1 Driver Strength 50% 25% 75%(default) 100% 6.2.13 High Frequency Mode Enable Bit (HFM) The HFM bit is used to determine whether the device is in QPI High Frequency Mode. When HFM bit sets to 1, it means the device is in QPI High Frequency Mode, when HFM bit sets 0 (default), it means the device is not in QPI High Frequency Mode. This Mode allows pre-charge of internal charge pump, so the voltages required for accessing the flash memory array are readily available for QPI read. After the HFM is executed, the device will maintain a slightly higher standby current (ICC8) than standard SPI operation. 6.2.14 Latency Control (LC) Status Register-3 provides bits (SR3[3:0]) to select the number of read latency cycles used in each Fast Read command(only in SPI mode). The Read Data command is not affected by the latency code. The binary value of this field selects from 1 to 15 latency cycles. The default is 0 to provide backward compatibility to legacy devices. The Latency Control bits may be set to select a number of read cycles optimized for the frequency in use. If the number of latency cycles is not sufficient for the operating frequency, invalid data will be read. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 24 XM25QH32B Table 6.5 Latency Cycles Versus Frequency for -40°C to 85°C/105°C at 2.7V to 3.6V Latency Control Fast Read 0 (legacy read latency) 104 (8 dummy) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 95 104 104 104 104 104 104 104 104 104 104 104 104 104 104 Read Command Maximum Frequency (MHz) Quad Dual I/O Quad I/O Output 104 104 104 104 (4 mode, 0 (2 mode, 4 (8 dummy) (8 dummy) dummy) dummy) 95 104 75 60 104 104 90 75 104 104 104 90 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 104 Dual Output Word Read Quad I/O 104 (2 mode, 2 dummy) 90 104 104 104 104 104 104 104 104 104 104 104 104 104 104 Notes: 1. The default dummy referred in this document is the dummy configuration when LC[3:0]=0. 2.Value guaranteed by design and/or characterization, not 100% tested in production. 6.3. Write Protection Applications that use non-volatile memory must take into consideration the possibility of noise and other adverse system conditions that may compromise data integrity. To address this concern the XM25QH32B provides the following data protection mechanisms: 6.3.1 Write Protect Features  Device resets when VCC is below threshold  Time delay write disable after Power-Up  Write enable / disable commands and automatic write disable after erase or program  Command length protection - All commands that Write, Program or Erase must complete on a byte boundary (CS# driven high after a full 8 bits have been clocked) otherwise the command will be ignored.  Software and Hardware write protection using Status Register control - WP# input protection - Lock Down write protection until next power-up or Software Reset - One-Time Program (OTP) write protection  Write Protection using the Deep Power-Down command Upon power-up or at power-down, the XM25QH32B will maintain a reset condition while VCC is below the threshold value of VWI, (see Figure 8.1). While reset, all operations are disabled and no commands are recognized. During power-up and after the VCC voltage exceeds VWI, all program and erase related commands are further disabled for a time delay of tPUW. This includes the Write Enable, Page Program, Sector Erase, Block Erase, Chip Erase and the Write Status Registers commands. Note that the chip select Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 25 XM25QH32B pin (CS#) must track the VCC supply level at power-up until the VCC-min level and tVSL time delay is reached. If needed a pull-up resistor on CS# can be used to accomplish this. After power-up the device is automatically placed in a write-disabled state with the Status Register Write Enable Latch (WEL) set to a 0. A Write Enable command must be issued before a Page Program, Sector Erase, Block Erase, Chip Erase or Write Status Registers command will be accepted. After completing a program, erase or write command the Write Enable Latch (WEL) is automatically cleared to a write-disabled state of 0. Software controlled main flash array write protection is facilitated using the Write Status Registers command to write the Status Register (SR1,SR2) and Block Protect (SEC, TB, BP2, BP1 and BP0) bits. The BP method allows a portion as small as 4-kB sector or the entire memory array to be configured as read only. Used in conjunction with the Write Protect (WP#) pin, changes to the Status Register can be enabled or disabled under hardware control. See the Table 6.4 for further information. Additionally, the Deep Power-Down (DPD) command offers an alternative means of data protection as all commands are ignored during the DPD state, except for the Release from Deep-Power-Down (RES ABh) command. Thus, preventing any program or erase during the DPD state. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 26 XM25QH32B 6.3.2 Block Protection Maps Table 6.6 Status Register (1) XM25QH32B Block Protection (CMP = 0) XM25QH32B(32 Mbit) Block Protection (CMP=0) (2) Protected Protected Protected Block(s) Protected Addresses Density Portion SEC TB BP2 BP1 BP0 X X 0 0 0 None None None None 0 0 0 0 1 63 3F0000h – 3FFFFFh 64 kB Upper 1/64 0 0 0 1 0 62 and 63 3E0000h – 3FFFFFh 128 kB Upper 1/32 0 0 0 1 1 60 thru 63 3C0000h – 3FFFFFh 256 kB Upper 1/16 0 0 1 0 0 56 thru 63 380000h – 3FFFFFh 512 kB Upper 1/8 0 0 1 0 1 48 thru 63 300000h – 3FFFFFh 1 MB Upper 1/4 0 0 1 1 0 32 thru 63 200000h – 3FFFFFh 2MB Upper 1/2 0 1 0 0 1 0 000000h – 00FFFFh 64 kB Lower 1/64 0 1 0 1 0 0 and 1 000000h – 01FFFFh 128 kB Lower 1/32 0 1 0 1 1 0 thru 3 000000h – 03FFFFh 256 kB Lower 1/16 0 1 1 0 0 0 thru 7 000000h – 07FFFFh 512 kB Lower 1/8 0 1 1 0 1 0 thru 15 000000h – 0FFFFFh 1 MB Lower 1/4 0 1 1 1 0 0 thru 31 000000h – 1FFFFFh 2 MB Lower 1/2 X X 1 1 1 0 thru 63 000000h – 3FFFFFh 4 MB 1 0 0 0 1 63 3FF000h – 3FFFFFh 4 kB 1 0 0 1 0 63 3FE000h – 3FFFFFh 8 kB 1 0 0 1 1 63 3FC000h – 3FFFFFh 16 kB 1 0 1 0 X 63 3F8000h – 3FFFFFh 32 kB 1 0 1 1 0 63 3F8000h – 3FFFFFh 32 kB 1 1 0 0 1 0 000000h – 000FFFh 4 kB 1 1 0 1 0 0 000000h – 001FFFh 8 kB 1 1 0 1 1 0 000000h – 003FFFh 16 kB 1 1 1 0 X 0 000000h – 007FFFh 32 kB 1 1 1 1 0 0 000000h – 007FFFh 32 kB All Upper 1/1024 Upper 1/512 Upper 1/256 Upper 1/128 Upper 1/128 Lower 1/1024 Lower 1/512 Lower 1/256 Lower 1/128 Lower 1/128 Notes: 1. X = don’t care. 2. If any Erase or Program command specifies a memory region that contains protected data portion, this command will be ignored. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 27 XM25QH32B Table 6.7 XM25QH32B Block Protection (CMP = 1) Status Register (1) SEC TB BP2 BP1 BP0 X X 0 0 0 XM25QH32B(32 Mbit) Block Protection (CMP=1) (2) Protected Protected Protected Block(s) Protected Addresses Density Portion 0 thru 63 000000h – 3FFFFFh 4 MB All Lower 63/64 Lower 31/32 Lower 15/16 0 0 0 0 1 0 thru 62 000000h – 3EFFFFh 4032 kB 0 0 0 1 0 0 thru 61 000000h – 3DFFFFh 3986 kB 0 0 0 1 1 0 thru 59 000000h – 3BFFFFh 3840 kB 0 0 1 0 0 0 thru 55 000000h – 37FFFFh 3584 kB Lower 7/8 0 0 1 0 1 0 thru 47 000000h – 2FFFFFh 3 MB Lower 3/4 0 0 1 1 0 0 thru 31 000000h – 1FFFFFh 2 MB Lower 1/2 0 1 0 0 1 1 thru 63 010000h – 3FFFFFh 4032 kB 0 1 0 1 0 2 thru 63 020000h – 3FFFFFh 3986 kB 0 1 0 1 1 4 thru 63 040000h – 3FFFFFh 3840 kB 0 1 1 0 0 8 thru 63 080000h – 3FFFFFh 3584 kB Upper 7/8 0 1 1 0 1 16 thru 63 100000h – 3FFFFFh 3 MB Upper 3/4 0 1 1 1 0 32 thru 63 200000h – 3FFFFFh 2 MB Upper 1/2 X X 1 1 1 None None None None 1 0 0 0 1 0 thru 63 000000h – 3FEFFFh 4092 kB 1 0 0 1 0 0 thru 63 000000h – 3FDFFFh 4088 kB 1 0 0 1 1 0 thru 63 000000h – 3FBFFFh 4080 kB 1 0 1 0 X 0 thru 63 000000h – 3F7FFFh 4064 kB 1 0 1 1 0 0 thru 63 000000h – 3F7FFFh 4064 kB 1 1 0 0 1 0 thru 63 001000h – 3FFFFFh 4092 kB 1 1 0 1 0 0 thru 63 002000h – 3FFFFFh 4088 kB 1 1 0 1 1 0 thru 63 004000h – 3FFFFFh 4080 kB 1 1 1 0 X 0 thru 63 008000h – 3FFFFFh 4064 kB 1 1 1 1 0 0 thru 63 008000h – 3FFFFFh 4064 kB Upper 63/64 Upper 31/32 Upper 15/16 Lower 1023/1024 Lower 511/512 Lower 255/256 Lower 127/128 Lower 127/128 Upper 1023/1024 Upper 511/512 Upper 255/256 Upper 127/128 Upper 127/128 Notes: 1. X = don’t care. 2. If any Erase or Program command specifies a memory region that contains protected data portion, this command will be ignored. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 28 XM25QH32B 6.4. Page Program To program one data byte, two instructions are required: Write Enable (WREN), which is one byte, and a Page Program (PP) sequence, which consists of four bytes plus data. This is followed by the internal Program cycle (of duration tPP). To spread this overhead, the Page Program (PP) instruction allows up to 256 bytes to be programmed at a time (changing bits from 1 to 0), provided that they lie in consecutive addresses on the same page of memory. 6.5. Sector Erase, Block Erase and Chip Erase The Page Program (PP) instruction allows bits to be reset from 1 to 0. Before this can be applied, the bytes of memory need to be erased to all 1s (FFh). This can be achieved a sector at a time, using the Sector Erase (SE) instruction, a block at a time using the Block Erase (BE) instruction or throughout the entire memory, using the Chip Erase (CE) instruction. This starts an internal Erase cycle (of duration t SE tBE or tCE). The Erase instruction must be preceded by a Write Enable (WREN) instruction. 6.6. Polling during a Write, Program or Erase Cycle A further improvement in the time to Write Status Register (WRSR), Program (PP) or Erase (SE, BE or CE) can be achieved by not waiting for the worst case delay (tW , tPP, tSE, tBE or tCE). The Write In Progress (WIP) bit is provided in the Status Register so that the application program can monitor its value, polling it to establish when the previous Write cycle, Program cycle or Erase cycle is complete. 6.7. Active Power, Stand-by Power and Deep Power-Down Modes When Chip Select (CS#) is Low, the device is enabled, and in the Active Power mode. When Chip Select (CS#) is High, the device is disabled, but could remain in the Active Power mode until all internal cycles have completed (Program, Erase, Write Status Register). The device then goes into the Standby Power mode. The device consumption drops to ICC1. The Deep Power-down mode is entered when the specific instruction (the Enter Deep Power-down Mode (DP) instruction) is executed. The device consumption drops further to ICC2. The device remains in this mode until another specific instruction (the Release from Deep Power-down Mode and Read Device ID (RDI) instruction) is executed. All other instructions are ignored while the device is in the Deep Power-down mode. This can be used as an extra software protection mechanism, when the device is not in active use, to protect the device from inadvertent Program or Erase instructions. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 29 XM25QH32B 7. INSTRUCTIONS The instruction set of the XM25QH32B consists of forty basic instructions that are fully controlled through the SPI bus. Instructions are initiated with the falling edge of Chip Select (CS#). The first byte of data clocked into the DI input provides the instruction code. Data on the DI input is sampled on the rising edge of clock with most significant bit (MSB) first. The QPI instruction set of the XM25QH32B consists of 32 basic instructions that are fully controlled through the SPI bus (see Instruction Set Table 7.5). Instructions are initiated with the falling edge of Chip Select (CS#). The first byte of data clocked through IO[3:0] pins provides the instruction code. Data on all four IO pins are sampled on the rising edge of clock with most significant bit (MSB) first. All QPI instructions, addresses, data and dummy bytes are using all four IO pins to transfer every byte of data with every two serial clocks (CLK). Instructions vary in length from a single byte to several bytes and may be followed by address bytes, data bytes, dummy bytes (don’t care), and in some cases, a combination. Instructions are completed with the rising edge of edge CS#. Clock relative timing diagrams for each instruction are included in figures 7.1 through 7.43. All read instructions can be completed after any clocked bit. However, all instructions that Write, Program or Erase must complete on a byte boundary (CS driven high after a full 8-bits have been clocked) otherwise the instruction will be ignored. This feature further protects the device from inadvertent writes. Additionally, while the memory is being programmed or erased, or when the Status Register is being written, all instructions except for Read Status Register and Erase/Program Suspend will be ignored until the program or erase cycle completes. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 30 XM25QH32B (1) Table 7.1 Command Set (Configuration, Status, Erase, Program Instructions , SPI Mode) Command Name BYTE 1 (Instruction) BYTE 2 Read Status Register-1 05h SR1[7:0](2) Read Status Register-2 35h SR2[7:0](2) Read Status Register-3 15h/33h SR3[7:0](2) BYTE 3 BYTE 4 BYTE 5 Write Enable 06h Write Enable for Volatile Status Register 50h Write Disable 04h Write Status Registers-1 01h SR1[7:0](5) Write Status Registers-2 31h SR2[7:0] Write Status Registers-3 11h SR3[7:0] Set Burst with Wrap 77h xxh xxh xxh W[7:0](3) Page Program 02h A23—A16 A15—A8 A7—A0 D7—D0 Quad Page Program 32h A23—A16 A15—A8 A7—A0 D7—D0(4) Sector Erase (4 KB) 20h A23—A16 A15—A8 A7—A0 Block Erase (32 KB) 52h A23—A16 A15—A8 A7—A0 Block Erase (64 KB) D8h A23—A16 A15—A8 A7—A0 Chip Erase BYTE 6 C7h/60h Erase/Program 75h Suspend Erase/Program Resume 7Ah Enter QPI Mode 38h Enable Reset 66h Reset Device 99h Notes: 1. Data bytes are shifted with Most Significant Bit first. Byte fields with data in parenthesis “()” indicate data being read from the device on the DO pin. 2. Status Register contents will repeat continuously until CS# terminates the command. 3. Set Burst with Wrap Input format. IO0 = x, x, x, x, x, x, W4, x] IO1 = x, x, x, x, x, x, W5, x] IO2 = x, x, x, x, x, x, W6 x] IO3 = x, x, x, x, x, x, x,x 4. Quad Page Program Input Data: IO0 =(D4,D0,...) IO1 = ( D5,D1,...) IO2 = ( D6,D2,...) IO3 =( D7,D3,...) 5. The 01h command could continuously write up to three bytes to registers SR1, SR2, SR3. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 31 XM25QH32B (1) Table 7.2 Command Set (Read Instructions , SPI Mode) Command Name BYTE 1 (Instruction) BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 Read Data 03h A23—A16 A15—A8 A7—A0 (D7—D0,…) Fast Read Fast Read Dual Output Fast Read Quad Output 0Bh A23—A16 A15—A8 A7—A0 dummy (D7—D0,…) 3Bh A23—A16 A15—A8 A7—A0 dummy (D7—D0,…)(1) 6Bh A23—A16 A15—A8 A7—A0 dummy (D7—D0,…)(3) Fast Read Dual I/O BBh A23—A8(2) A7—A0,M7 —M0(2) (D7—D0,…)(1) Fast Read Quad I/O EBh A23—A0,M7 —M0(4) (x,x,x,x,D7— D0,...) (D7—D0,…)(3) QUAD I/O WORD FAST READ(5) E7H A23—A0,M7 —M0(4) (x,x,D7—D0, ...) (D7—D0,…)(3) Octal Word Read Quad I/O(5) E3h A23—A0,M7 —M0(4) (D7—D0,…)( 3) (D7—D0,…)(3) Notes: 1. Dual Output data IO0 = (D6, D4, D2, D0) IO1 = (D7, D5, D3, D1) 2. Dual Input Address IO0 = A22, A20, A18, A16, A14, A12, A10, A8 A6, A4, A2, A0, M6, M4, M2, M0 IO1 = A23, A21, A19, A17, A15, A13, A11, A9 A7, A5, A3, A1, M7, M5, M3, M1 3. Quad Output Data IO0 = (D4, D0, …..) IO1 = (D5, D1, …..) IO2 = (D6, D2, …..) IO3 = (D7, D3, …..) 4. Quad Input Address IO0 = A20, A16, A12, A8, A4, A0, M4, M0 IO1 = A21, A17, A13, A9, A5, A1, M5, M1 IO2 = A22, A18, A14, A10, A6, A2, M6, M2 IO3 = A23, A19, A15, A11, A7, A3, M7, M3 5. For Word Read Quad I/O, the lowest address bit must be 0. (A0 = 0),and for Octal Word Read Quad I/O, the lowest four address bits must be 0. (A3, A2, A1, A0 = 0) Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 32 XM25QH32B Table 7.3 Command Set (Read ID, OTP Instructions Command Name BYTE 1 (Instruction) Deep Power-down Release Power down / Device ID Manufacturer/ Device ID(2) Manufacturer/ Device ID by Dual I/O (1) , SPI Mode) BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 ABh dummy dummy dummy Device ID(1) 90h dummy dummy 00h Manufacturer Device ID 92h A23—A8 A7—A0,M[7:0] (MF[7:0],ID[7:0]) 9Fh Manufacturer Memory Type Capacity 5Ah 00h 00h A7—A0 dummy (D7—D0,…) 48h A23—A16 A15—A8 A7—A0 dummy (D7—D0,…) 44h A23—A16 A15—A8 A7—A0 42h A23—A16 A15—A8 A7—A0 D7—D0,… 4Bh dummy dummy dummy dummy B9h JEDEC ID Read SFDP Register Read Security Registers(3) Erase Security Registers(3) Program Security Registers(3) Read Unique ID (ID63-ID0) Notes: 1. The Device ID will repeat continuously until CS# terminates the command. 2. See Section 6.4.1, Legacy Device Identification Commands on page 51 for Device ID information. The 90h instruction is followed by an address. Address = 0 selects Manufacturer ID as the first returned data as shown in the table. Address = 1 selects Device ID as the first returned data followed by Manufacturer ID. 3. Security Register Address: Security Register 0: A23-16 = 00h; A15-8 = 00h; A7-0 = byte address Security Register 1: A23-16 = 00h; A15-8 = 10h; A7-0 = byte address Security Register 2: A23-16 = 00h; A15-8 = 20h; A7-0 = byte address Security Register 3: A23-16 = 00h; A15-8 = 30h; A7-0 = byte address (1) Table 7.4 Manufacturer and Device Identification(SPI and QPI Mode) OP Code Data1 Data2 Data3 ABh Device ID = 15h - - 90h/92h Manufacturer ID = 20h Device ID = 15h 9Fh(SPI Mode) 9Fh(QPI Mode) Manufacturer ID = 20h Manufacturer ID = 20h (2) Capacity = 16h (2) Capacity = 16h Memory Type =40h Memory Type =60h Notes: (1) Please contact sales for more information (2) Data2 40h is for SPI mode and the 60h is for QPI mode. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 33 XM25QH32B Table 7.5 Command Set (QPI Instructions (1) , QPI Mode) BYTE 1 (Instruction) BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 Clock Number (0, 1) (2, 3) (4, 5) (6, 7) (8, 9) (10, 11) Write Enable 06h Write Enable for Volatile Status Register 50h Write Disable 04h Read Status Register-1 05h (S7-S0)(1) Write Status Register-1(3) 01h (S7-S0)(3) Read Status Register-2 35h (S15-S8)(1) Write Status Register-2 31h (S15-S8) Read Status Register-3 15h/33h (S23-S16)(1) Write Status Register-3 11h (S23-S16) Command Name Chip Erase C7h/60h Erase / Program Suspend 75h Erase / Program Resume 7Ah Deep Power-down B9h Set Read Parameters C0h P7-P0 Release Power down / ID ABh Dummy Dummy Dummy (ID7-ID0)(1) Manufacturer/Device ID 90h Dummy Dummy 00h (MF7-MF0) (ID7-ID0) JEDEC ID 9Fh (MF7-MF0) (ID15-ID8) (ID7-ID0) Exit QPI Mode FFh Enable Reset 66h Reset Device 99h Page Program 02h A23-A16 A15-A8 A7-A0 D7-D0(4) D7-D0(2) Sector Erase (4KB) 20h A23-A16 A15-A8 A7-A0 Block Erase (32KB) 52h A23-A16 A15-A8 A7-A0 Block Erase (64KB) D8h A23-A16 A15-A8 A7-A0 Fast Read 0Bh A23-A16 A15-A8 A7-A0 Dummy(5) D7-D0 A7-A0 (5) D7-D0 Burst Read with Wrap(6) Fast Read Quad I/O 0Ch EBh A23-A16 A23-A16 A15-A8 A15-A8 A7-A0 Dummy (5) M7-M0 D7-D0 Notes: 1. The Status Register contents and Device ID will repeat continuously until CS# terminates the instruction. 2. At least one byte of data input is required for Page Program, Quad Page Program and Program Security Registers, up to 256 bytes of data input. If more than 256 bytes of data are sent to the device, the addressing will wrap to the beginning of the page and overwrite previously sent data. 3. Write Status Register-1 (01h) can also be used to program Status Register-1&2&3, see section 7.1.5. 4. Quad SPI data input/output format: IO0 = (D4, D0, …..) IO1 = (D5, D1, …..) IO2 = (D6, D2, …..) IO3 = (D7, D3, …..) 5. The number of dummy clocks for QPI Fast Read, QPI Fast Read Quad I/O & QPI Burst Read with Wrap is controlled by read parameter P7 – P4. 6. The wrap around length for QPI Burst Read with Wrap is controlled by read parameter P3 – P0. Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 34 XM25QH32B 7.1 Configuration and Status Commands 7.1.1 Read Status Register (05h/35h/15h) The Read Status Register commands allow the 8-bit Status Registers to be read. The command is entered by driving CS# low and shifting the instruction code “05h” for Status Register-1, “35h” for Status Register-2, “15h” for Status Register-3 into the DI pin on the rising edge of CLK. The Status Register bits are then shifted out on the DO pin at the falling edge of CLK with most significant bit (MSB) first as shown in Figure 7.1. The Status Register bits are shown in Section 6.2, Status Registers. The Read Status Register-1 (05h) command may be used at any time, even during a Program, Erase, or Write Status Registers cycle. This allows the BUSY status bit to be checked to determine when the operation is complete and if the device can accept another command. CS# Mode 3 CLK 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 DI Mode 3 Mode 0 Mode 0 05h/35h/15h DO S7~S0 out Instruction S7~S0 out Status Updated Status Figure 7.1a Read Status Register Instruction(SPI Mode) CS# Mode 3 CLK 0 1 2 3 4 5 Mode 0 IO0 4 0 S4 S0 S4 S0 S4 IO1 5 1 S5 S1 S5 S1 S5 IO2 6 2 S6 S2 S6 S2 S6 7 3 S7 S3 S7 S3 S7 IO3 InstructionSR-1/2/3 SR-1/2/3 05h/35h/15h out out Figure 7.1b Read Status Register Instruction(QPI Mode) 7.1.2 Write Enable (06h) The Write Enable instruction (Figure 7.2) sets the Write Enable Latch (WEL) bit in the Status Register to a 1. The WEL bit must be set prior to every Page Program, Sector Erase, Block Erase, Chip Erase and Write Status Register instruction. The Write Enable instruction is entered by driving CS# low, shifting the instruction code “06h” into the Data Input (DI) pin on the rising edge of CLK, and then driving CS# high. CS# Mode 3 CLK CS# Mode 3 CLK DI 0 1 2 3 4 Mode 0 5 6 7 DO 1 Mode 3 Mode 0 Mode 3 Mode 0 06h 0 Mode 0 IO0 4 0 IO1 5 1 IO2 6 2 IO3 7 3 Instruction Instruction 06h Figure 7.2 Write Enable Instruction(SPI or QPI Mode) Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 35 XM25QH32B 7.1.3 Write Enable for Volatile Status Register (50h) The non-volatile Status Register bits described in section 6.2 can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. To write the volatile values into the Status Register bits, the Write Enable for Volatile Status Register (50h) instruction must be issued prior to a Write Status Register (01h) instruction. Write Enable for Volatile Status Register instruction (Figure 7.3) will not set the Write Enable Latch (WEL)bit, it is only valid for the Write Status Register instruction to change the volatile Status Register bit values. CS# Mode 3 CLK CS# Mode 3 CLK 0 1 2 3 4 5 6 7 Mode 0 1 Mode 3 Mode 0 Mode 3 Mode 0 50h DI 0 Mode 0 DO IO0 4 0 IO1 5 1 IO2 6 2 IO3 7 3 Instruction Instruction 50h Figure 7.3 Write Enable for Volatile Status Register Instruction(SPI or QPI Mode) 7.1.4 Write Disable (04h) The Write Disable instruction (Figure 7.4) resets the Write Enable Latch (WEL) bit in the Status Register to a 0. The Write Disable instruction is entered by driving CS# low, shifting the instruction code “04h” into the DI pin and then driving CS# high. Note that the WEL bit is automatically reset after Power-up and upon completion of the Write Status Register, Page Program, Sector Erase, Block Erase and Chip Erase instructions. CS# Mode 3 CLK CS# Mode 3 CLK 0 1 2 3 4 Mode 0 DI 5 6 7 DO 1 Mode 3 Mode 0 Mode 3 Mode 0 04h 0 Mode 0 IO0 4 0 IO1 5 1 IO2 6 2 7 3 Instruction IO3 Instruction 04h Figure 7.4 Write Disable Instruction(SPI or QPI Mode) 7.1.5 Write Status Register (01h/31h/11h) The Write Status Registers command allows the Status Registers to be written. Only non-volatile Status Register bits SRP0, SEC, TB, BP2, BP1, BP0 (SR1[7:2]) CMP, LB3, LB2, LB1, QE, SRP1 (SR2[6:0]), and the volatile bits SR3[6:0] can be written. All other Status Register bit locations are read-only and will not be affected by the Write Status Registers command. LB[3:0] are non-volatile OTP bits; once each is set to 1, it cannot be cleared to 0. The Status Register bits are shown in Section 6.2, Status Registers. Any reserved bits should only be written to their default value. To write non-volatile Status Register bits, a standard Write Enable (06h) command must previously have been executed for the device to accept the Write Status Registers Command (Status Register bit WEL must equal 1). Once write enabled, the command is entered by driving CS# low, sending the instruction code “01h”, and then writing the Status Register data bytes as illustrated in Figure 7.5. To write volatile Status Register bits, a Write Enable for Volatile Status Register (50h) command must have been executed prior to the Write Status Registers command (Status Register bit WEL remains 0). However, SRP1 and LB3, LB2, LB1, LB0 cannot be changed because of the OTP protection for these bits. Upon power-off, the volatile Status Register bit values will be lost, and the non-volatile Status Register bit Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 36 XM25QH32B values will be restored when power on again. To complete the Write Status Registers command, the CS# pin must be driven high after the eighth bit of a data value is clocked in (CS# must be driven high on an 8-bit boundary). If this is not done the Write Status Registers command will not be executed. The Write Status Register instruction allows the Status Register to be written. A Write Enable instruction must previously have been executed for the device to accept the Write Status Register Instruction (Status Register bit WEL must equal to 1). Once write enabled, the instruction is entered by driving CS# low, sending the instruction code “01h”, and then writing the status register data byte as illustrated in Figure 7.5. During non-volatile Status Register write operation (06h combined with 01h/31h), after CS# is driven high, the self-timed Write Status Register cycle will commence for a time duration of tW (See AC Characteristics). While the Write Status Register cycle is in progress, the Read Status Register instruction may still be accessed to check the status of the BUSY bit. The BUSY bit is a 1 during the Write Status Register cycle and a 0 when the cycle is finished and ready to accept other instructions again. After the Write Status Register cycle has finished, the Write Enable Latch (WEL) bit in the Status Register will be cleared to 0. During volatile Status Register write operation (50h combined with 01h/31h/11h), after CS# is driven high, the Status Register bits will be refreshed to the new values within the time period of t SHSL2 (See AC Characteristics). BUSY bit will remain 0 during the Status Register bit refresh period. If CS# is driven high after the eighth clock, the Write Status Register-1 (01h) instruction will only program the Status Register-1, the Status Register-2 will not be affected. CS# Mode 3 CLK 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Mode 0 DI Mode 3 Mode 0 01h/31h/11h S7~S0 in DO Instruction Input Status Register Figure 7.5a Write Status Register Instruction(SPI Mode) CS# Mode 3 CLK 0 1 2 3 Mode 0 Mode 0 IO0 4 0 S4 S0 IO1 5 1 S5 S1 IO2 6 2 S6 S2 7 3 S7 S3 IO3 Mode 3 InstructionSR-1/2/3 01h/31h/11h in Figure 7.5b Write Status Register Instruction(QPI Mode) 7.2 Program and Erase Commands 7.2.1 Page Program (PP) (02h) The Page Program instruction allows up to 256 bytes of data to be programmed at previously erased to all 1s (FFh) memory locations. A Write Enable instruction must be executed before the device will accept the Page Program Instruction (Status Register bit WEL must equal 1). The instruction is initiated by driving the CS# pin low then shifting the instruction code “02h” followed by a 24-bit address (A23-A0) and at least one data byte, into the DI pin. The CS# pin must be held low for the entire length of the instruction while data is being sent to the device. The Page Program instruction sequence is shown in Figure 7.6. If an entire 256 byte page is to be programmed, the last address byte (the 8 least significant address bits) should be set to 0. If the last address byte is not zero, and the number of clocks exceeds the remaining page length, the addressing will wrap to the beginning of the page. In some cases, less than 256 bytes (a partial page) can be programmed without having any effect on other bytes within the same page. One condition to Wuhan Xinxin Semiconductor Manufacturing Corp. Rev. M Issue Date: 2018/07/17 37 XM25QH32B perform a partial page program is that the number of clocks cannot exceed the remaining page length. If more than 256 bytes are sent to the device the addressing will wrap to the beginning of the page and overwrite previously sent data. As with the write and erase instructions, the CS# pin must be driven high after the eighth bit of the last byte has been latched. If this is not done the Page Program instruction will not be executed. After CS# is driven high, the self-timed Page Program instruction will commence for a time duration of tpp (See AC Characteristics). While the Page Program cycle is in progress, the Read Status Register instruction may still be accessed for checking the status of the BUSY bit. The BUSY bit is a 1 during the Page Program cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions again. After the Page Program cycle has finished the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. The Page Program instruction will not be executed if the addressed page is protected by the Block Protect (TB, SEC, BP2, BP1, and BP0) bits (see Status Register Memory Protection table). CS# Mode 3 CLK 0 1 2 3 4 5 6 7 8 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 Mode 0 DI 02h 24-bit 8-bit 8-bit DO Instruction Input Data 1 Address Input Data 2 Figure 7.6a Page Program Instruction (SPI Mode) CS# Mode 3 CLK 0 1 2 3 4 5 7 8 9 10 11 12 13 14 15 512 513 514 515516 517518 519 Mode 3 Mode 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 4 0 9 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 5 1 6 2 22 18 14 10 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 6 2 7 3 23 19 15 11 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 7 3 IO0 4 0 20 16 12 8 IO1 5 1 21 17 13 IO2 IO3 6 Mode 0 Instruction Address D1 D2 D3 D4 D253 D254 D255 D256 02h Figure 7.6b Page Program Instruction(QPI Mode) 7.2.2 Quad Input Page Program (32h) The Quad Input Page Program instruction allows up to 256 byte of data to be programmed at previously erased (FFh) memory locations using four pins: IO0, IO1, IO2 and IO3. The Quad Input Page Program can improved performance for PROM Programmer and applications that have slow clock speeds
XM25QH32BHIG 价格&库存
很抱歉,暂时无法提供与“XM25QH32BHIG”相匹配的价格&库存,您可以联系我们找货
