HT317ARDZ
HT317ARDZ
    HTCSEMI(海天芯)
    HT317ARDZ
HT317ARDZ 数据手册
HT317A THREE-TERMINAL ADJUSTABLE OUTPUT POSITIVE VOLTAGE REGULATORS The HT317A is adjustable 3-terminal positive voltage regulator capable of supplying in excess of 1.5 A over an output voltage range of 1.2 V to 37 V. These voltage regulator is exceptionally easy to use and require only two external resistors to set the output voltage. Further, it employ internal current limiting, thermal shutdown and safe area compensation, making them essentially blow-out proof. The HT317A serve a wide variety of applications to make a programmable output regulator, or by connecting a fixed resistor between the adjustment and output, the HT317A series can be used as a precision current requlator. Futures  Output Current in Excess of 1.5 Ampere  Output Adjustable between 1.2 V and 37 V  Internal Thermal Overload Protection  Internal Short - Circuit Current Limiting Constant with Temperature  Output Transistor Safe-Area Compensation  Floating Operation for High Voltage Applications  Standard 3-lead Transistor Packages  Eliminates Stocking Many Fixed ORDERING INFORMATION Device Operating Temperature Range Package Packing TO-220 Tube TO-252 Tape & Reel TO-263 Tape & Reel HT317AD TO-223 Tape & Reel HT317AE ESOP8 Tape & Reel HT317AT HT317AM HT317AS TA = -40to 125 C for all packages for all packages Rev. 00 HT317A Standard application Vin Vout HT317A R1 С 0.1F * in Ad- Сo** 1F R2 = Cin is required if regulator is located an appreciable distance from power supply filter. = Co is not needed for stability ; however, is does improve transient response. Vout 1.25V(1 R2 R1 ) I ADJ R2 Since IADJ is controlled to less then 100 A, the error associated with this term is negligible in most applications. Maximum ratings Rating Symbol Value Unit Vi - Vo 40 Vdc Power Dissipation and Thermal Characteristics PD Internally Limited Operating Junction Temperature Rang TJ -40 to +150 C Tstg -65 to +150 C Input - Output Voltage Differential Storage Junction Temperature Rang * Stresses beyond those listed under “absolute maximum ratings” may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under “recommended operating conditions” is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. Rev. 00 HT317A Electrical characteristics (Vi-Vo= 5.0V, Io = 0.5 A, TJ = Tlow to Thigh (see Note 1); Imax = 1.5 A and Pmax = 20 W unless otherwise noted) Characteristic Line Regulation (TA=+25C) 3.0V Vi - Vo 40 V Load Regulation(TJ=+25C) 10mAIoImax, Vin 5V Vin5 V Thermal Regulation (TA=+25C) 20 ms Pulse Adjustment Pin Current Adjustment Pin Current Change 2.5 Vi - Vo 40 V 10mA ILImax, PD Pmax Reference Voltage (Note 4) 3.0 Vi - Vo 40 V 10mA ILImax, PD Pmax Line Regulation (Note 3) 3.0 V Vi - Vo 40 V Load Regulation (Note 3) 10mAIoImax, Vin 5V Vin5 V Temperature Stability (Tlow Tj Ttigh) Minimum Load Current to Maintain Regulation (Vi - Vo = 40 V) Maximum Output Current Vi - Vo15 V , P 20 W Vi - Vo = 40 V, P 20W, TA=+25C RMS Nose , % of Vo TA=+25C, 10 Hz f 10 kHz Ripple Rejection, Vo = 10 V, f = 120 Hz (Note 5) Without Cadj Cadj = 10 F Long-Term Stability, Tj = Thigh (Note 6) TA=+25C for Endpoint Measurements Thermal Resistance Junction to Case Symbol Regline Min - Typ 0.01 Max 0.04 Unit /V - - 5.0 0.1 0.03 25 0.5 0.07 mV /Vo /W IAdj IAdj - 50 0.2 100 5.0 A A Vref 1.2 1.25 1.3 V Regline - 0.02 0.07 /V - 20 0.3 0.7 3.5 70 1.5 10 mV /V 1.5 0.15 - 2.2 0.4 0.003 - Regload Regload Ts ILmin A Imax N mA RR /Vo dB S 66 - 65 80 0.3 1.0 RJC - 5.0 - /1.0 k Hrs. C/W Notes: (1) Tlow = -40 C , Thigh = +125 C (2) Imax = 0.5 A , Pmax (3) Load and line regulation are specified at constant junction tempereture. Changes in Vo due to heating effects must be taken into account separately. Pulse testing with low duty cycle is used. (4) Selected devices with tightened tolerance reference voltage available. (5) Cadj , when used, connected between the adjustment pin and ground. (6) Since Long - Term Stability cannot be measured on each device before shipment, this specification is an engineering estimate of average stability from lot to lot. Rev. 00 HT317A TO-220AB PKG OUTLINE DIMENSIONS Rev. 00 HT317A Rev. 00 HT317A TO-263-3L PKG OUTLINE DIMENSIONS Rev. 00 HT317A (DIP8) A Dimension, Dimension, mm mm 5 8 B 1 4 F F C C -T- SEATING SEATING -TPLANE PLANE G G M M K K JJ H H D D MIN MIN MAX MAX A A 8.51 8.51 10.16 10.16 B B 6.1 6.1 7.11 7.11 5.33 5.33 C C L L N N Symbol Symbol D D 0.36 0.36 0.56 0.56 F F 1.14 1.14 1.78 1.78 G G 2.54 2.54 H H 7.62 7.62 JJ 0° 0° 10° 10° K K 2.92 2.92 3.81 3.81 NOTES: NOTES: L L 7.62 7.62 8.26 8.26 1. “B” not include mold flash or or protrusions. 1.Dimensions Dimensions“A”, “A”, “B”dodo not include mold flash protrusions. M M 0.2 0.2 0.36 0.36 N N 0.38 0.38 Dimension, mm 0.25 (0.010) M M T 0.25 (0.010) T Maximum mold flash Maximum mold flash or or protrusions protrusions 0.25 0.25 mm mm (0.010) (0.010) per per side. side. (SOP8) (SOP8) A A 88 55 B B G G MIN MAX A 4.8 5 B 3.8 4 C 1.35 1.75 D 0.33 Dimension,0.51 mm 0.4 1.27 MIN MAX R x 45 H H 11 Symbol PP J F M H B J C 44 C C -T-TK D K D 0.25 (0.010) M T C M K D M F R x 45 SEATING SEATING PLANE PLANE J F 0.25 (0.010) M T C M NOTES: NOTES: Dimensions A and B do not include mold flash or protrusion. 1. 1. Maximum Dimensions A and not include mold orper protrusion. 2. mold flashBordoprotrusion 0.15 mmflash (0.006) side mmor (0.010) per side. A; for Bmold ‑ 0.25 2. for Maximum flash protrusion 0.15 mm (0.006) per side for A; for B ‑ 0.25 mm (0.010) per side. F Symbol G A M P G R H 4.8 1.27 3.8 5.72 0° 1.35 0.1 0.33 5 4 8° 1.75 0.25 0.51 0.25 1.27 0.19 0.4 5.8 1.27 6.2 0.25 5.72 0.5 J 0° 8° K 0.1 0.25 M 0.19 0.25 P 5.8 6.2 R 0.25 0.5 Rev. 00
HT317ARDZ 价格&库存
很抱歉,暂时无法提供与“HT317ARDZ”相匹配的价格&库存,您可以联系我们找货
HT317ARDZ
    • 5+1.81527
    • 50+1.47507
    • 150+1.32927
    • 500+1.14729
    • 2500+0.90720
    • 5000+0.85860
    库存:1144
