UMW
R
UMW AO3415A
SOT-23 Plastic-Encapsulate MOSFETS
UMW AO3415A P-Channel 20-V(D-S) MOSFET
V(BR)DSS
ID
RDS(on)MAX
36mΩ@-4.5V
-20 V
SOT-23
-4A
60mΩ@-2.5V
1. GATE
2. SOURCE
3. DRAIN
FEATURE
z Excellent RDS(ON), low gate charge,low gate voltages
APPLICATION
z Load switch and in PWM applicatopns
Equivalent Circuit
D
G
S
Maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Drain-Source Voltage
VDS
-20
Gate-Source Voltage
VGS
±8
Unit
V
Continuous Drain Current (t≤10s)
ID
-4.0
A
Maximum Power Dissipation (t≤10s)
PD
0.35
W
RθJA
357
℃/W
TJ
150
TSTG
-55 ~+150
Thermal Resistance from Junction to Ambient
Operating Junction Temperature
Storage Temperature
www.umw-ic.com
1
友台半导体有限公司
UMW
R
UMW AO3415A
Ta =25 ℃ unless otherwise specified
Parameter
Symbol
Test Condition
Min
Typ
Max
-0.56
-1
Units
Static Parameters
Drain-source breakdown voltage
Gate threshold voltage
V(BR) DSS
VGS = 0V, ID =-250µA
-20
VGS(th)
VDS =VGS, ID =-250µA
-0.3
Gate-body leakage current
IGSS
Zero gate voltage drain current
IDSS
VDS =0V, VGS =±8V
±10
VDS =0V, VGS =±4.5V
±1
VDS =-16V, VGS =0V
-1
VGS =-4.5V, ID =-4A
34
36
RDS(on)
VGS =-2.5V, I D =-4A
43
60
Forward transconductance(note2)
gFS
VDS =-5V, ID =-4A
Body diode voltage(note2)
VSD
IS=-1A,VGS =0V
Drain-source on-state resistance(note1)
8
V
µA
mΩ
S
-1
V
Dynamic Parameters (note3)
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitance
Crss
Gate resistance
Rg
1450
VDS =-10V,VGS =0V,f =1MHz
205
pF
160
VDS =0V,VGS =0V,f =1MHz
6.5
Ω
Switching Parameters
Total gate charge
Qg
Gate-Source charge
Qgs
Gate-drain charge
Qgd
4.5
Turn-on delay time (note3)
td(on)
9.5
Turn-on rise time(note3)
Turn-off delay time(note3)
Turn-off fall time(note3)
17.2
VDS =-10V,VGS =-4.5V,ID =-4A
1.3
tr
VDS=-10V, VGS=-4.5V
17
td(off)
RGEN =3Ω, RL=2.5Ω,
94
tf
nC
ns
35
Notes:
1. Repetitive rating,pulse width limited by junction temperature.
2. Pulse Test : Pulse width≦300µs, duty cycle≦2%.
3. These parameters have no way to verify.
www.umw-ic.com
2
友台半导体有限公司
UMW
R
UMW AO3415A
Symbol
A
A1
A2
b
c
D
E
E1
e
e1
L
L1
θ
Dimensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.080
0.150
2.800
3.000
1.200
1.400
2.250
2.550
0.950 TYP.
1.800
2.000
0.550 REF.
0.300
0.500
0°
8°
Dimensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.003
0.006
0.110
0.118
0.047
0.055
0.089
0.100
0.037 TYP.
0.071
0.079
0.022 REF.
0.012
0.020
0°
8°
XFDX
17
Marking
U
Ordering information
Order code
Package
Baseqty
Deliverymode
UMW AO3415A
SOT-23
3000
Tape and reel
www.umw-ic.com
3
友台半导体有限公司
很抱歉,暂时无法提供与“AO3415A”相匹配的价格&库存,您可以联系我们找货
