PESD2CAN
PESD2CAN
    UMW(友台)
    SOT-23
    PESD2CAN
PESD2CAN 数据手册
PESD2CAN Features ■ 250 W peak pulse power (tp = 8/20μs) ■ Bidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ IEC 61000-4-2 ±30kV contact ±30kV air ■ IEC 61000-4-4 (EFT) 40A(5/50ns) ■ IEC 61000-4-5 (Lightning) 5A(8/20μs) 11 11 33 22 22 SOT-23 SOT-23 (Top (TopView) View) Applications ■ Dataline ■ ■ Dataline Teller Machines Automatic ■ Net works ■ ■ Net works Power line ■ Power line 33 Mechanical Data ■ ■ SOT-23 package ■ Molding compound flammability rating: UL 94V-0 SOT-23 package ■ Packaging: Tape and Reel ■ ■ RoHS/WEEE Packaging: Tape andCompliant Reel ■ RoHS/WEEE Compliant Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 250 W Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 5 A VESD 30 30 kV Lead Soldering Temperature TL 260 ℃ Junction Temperature TJ -55 to + 125 ℃ Storage Temperature Tstg -55 to + 125 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) www.umw-ic.com 1 友台半导体有限公司 PESD2CAN Electrical Characteristics Parameter Symbol Reverse Stand-Off Voltage Conditions Min Typical Max VRWM Reverse Breakdown Voltage VBR Reverse Leakage Current IR Peak Pulse Current IT=1mA 26.1 VRWM=24V,T=25℃ 28 0.1 tp =8/20μs IPP Clamping Voltage VC IPP=5A,tp=8/20μs Junction Capacitance Cj VR = 0V, f = 1MHz Units 24.0 V 30.2 V 0.5 μA 6 A 41 V 25 pF Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP V RWM IR V BR IT I IPP Working Peak Reverse Voltage VC VBR VRWM Maximum Reverse Leakage Current @ V RWM Breakdown Voltage @ IT IT IR IR IT VRWM VBR VC V Test Current IPP Note:. 8/20μs pulsewaveform. www.umw-ic.com 2 友台半导体有限公司 PESD2CAN TypicalCharacteristics Figure 2: Power Derating Curve 10 110 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 250w 8/20 sµaveform 1 0.1 0.01 0.1 1 10 100 100 90 80 70 60 50 40 30 20 10 0 1,000 0 25 td – Pulse Duration - µs Figure3: Pulse Waveform Percent Ipp 80 80 Clamping Voltage–VC (V) 90 e-1 50 40 30 td=Ipp/ 2 20 100 125 150 90 Waveform Paramters tr=8µs td=20µs 100 60 75 Figure 4: Clamping Voltage vs.Ipp 110 70 50 Ambient Temperature - TA (℃) Test Waveform Paramters tr=8µs td=20µs 70 60 50 40 30 20 10 10 0 0 0 5 www.umw-ic.com 10 15 Time (µs) 20 25 30 0 1 2 3 4 5 6 Peak Pulse Current–IPP (A) 3 友台半导体有限公司 PESD2CAN Outline Drawing – SOT-23 DIMENSIONS D SYMBOL 3 A E1 E θ 1 b L 2 e 0.25 A INCHES MAX MIN MAX 0.900 1.150 0.035 0.045 A1 0.000 0.100 A2 0.900 1.050 0.035 0.041 D 2.800 3.000 0.110 0.118 0.000 0.004 b 0.300 0.500 0.012 0.020 E 2.250 2.550 0.089 0.100 E1 1.200 1.400 0.047 0.055 e A2 MILLIMETER MIN 0.950 BSC 0.037 BSC L 0.300 0.500 0.012 0.020 θ 0 8○ 0 8○ A1 Marking 6Rt Ordering information Order code UMW PESD2CAN www.umw-ic.com Package SOT-23 Base qty 3000 4 Delivery mode Tape and reel 友台半导体有限公司
PESD2CAN 价格&库存
很抱歉,暂时无法提供与“PESD2CAN”相匹配的价格&库存,您可以联系我们找货
PESD2CAN
    • 1+0.15030
    库存:2724
