F412R
BRUSHLESS DC FANS
■ FEATURES
RoHS compliant
● Low noise 16 dB (A)
● Light weight (approx. 20 g)
■ STRUCTURE
● Frame and impeller
ABS/PBT alloy
● Bearing
1 ball bearing and 1 sleeve bearing
■ PART NUMBER DESIGNATION
F412R - 12 L B
Series name
Bearing
Power supply
05:DC5 V
12:DC12 V
Air flow
L :0.11 m3/min
M:0.15 m3/min
■ LIST OF PART NUMBERS
Bearing
B
Power supply
Part number
DC5 V
F412R-05LB
DC12 V
F412R-12LB
DC5 V
F412R-05MB
DC12 V
F412R-12MB
※ Verify the above part numbers when placing orders.
BRUSHLESS DC FANS
■ STANDARD SPECIFICATIONS
Item
F412R-05LB
F412R-05MB
F412R-12LB
F412R-12MB
DC5 V
Rated voltage
DC12 V
Voltage range
4.5 ~ 5.7 V
4.2 ~ 5.7 V
10.2 ~ 13.8 V
10.2 ~ 13.8 V
Rated current
0.08 A
0.10 A
0.04 A
0.06 A
Rotating speed
4200 min-1
5400 min-1
4200 min-1
5400 min-1
0.11 m3/min
0.15 m3/min
0.11 m3/min
0.15 m3/min
15 Pa
26 Pa
15 Pa
26 Pa
16 dB (A)
23 dB (A)
16 dB (A)
23 dB (A)
Air flow
Static pressure
Noise
Use environment
–10 ~ +60 °C (35 ~ 85 %RH)
Storage environment
–20 ~ +70 °C (35 ~ 85 %RH)
Approx. 20 g
Net weight
■ AIR FLOW PERFORMANCE CURVES
※ The specifications above are typical values measured on the conditions
of no-loading running with rated voltage in the circumstances of 25 °C
± 2 °C, 35~ 85 %RH. Please contact us if you would liketo check the
specifications in different circumstances.
F412R-05LB
-12LB
30
25
Static pressure(Pa)
F412R-05MB
-12MB
15
10
5
0.04
0.06
0.08
0.10
0.12
0.14
Air flow(m /min)
0.16
0.18
0.2
3
Black : GND
Dimension of mounting hole for recommendation
4 – φ 3.5
φ
4 – φ 3.5
4 – C3
32 ± 0.5
12.2 ± 0.5
□41 ± 0.5
32 ± 0.5
Air flow
(Unit: mm)
39
300 ± 20
■ OUTLINE DIMENSIONS
32 ± 0.5
図
F412R
32 ± 0.5
很抱歉,暂时无法提供与“F412R-12LB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+75.30078
- 10+55.72960
- 50+51.95578
