Technical Data Sheet
BRADY B-351 THERMAL TRANSFER PRINTABLE TAMPER-RESISTANT WHITE VINYL LABEL STOCK
TDS No. B-351
Effective Date: 1/11/2019
Description:
GENERAL
Print Technology: Thermal Transfer
Material Type: Tamper-Resistant Vinyl
Finish: Matte White
Adhesive: Acrylic
APPLICATIONS
Rating and serial plates that require high performance and resistance to product tampering
RECOMMENDED RIBBONS
Brady Series R6200
Brady Series R6000 Halogen Free
REGULATORY APPROVALS
For information on the Weee-RoHS compliance status for a Brady Product go to one of the following websites:
In Canada: www.bradycanada.ca/weee-rohs
In Europe: www.bradyeurope.com/rohs
In Japan: www.brady.co.jp/products/labelsuse/rohs
All other regions: www.bradyid.com/weee-rohs
SPECIAL FEATURES
Brady B-351 is designed to fracture easily in order to show signs of product tampering and to prevent one-piece label removal.
Use caution when removing from liner as material is fragile.
Details:
PHYSICAL PROPERTIES
Thickness
Adhesion to:
-Stainless Steel
-Painted Enamel
-Polypropylene
-Powder coated
-Textured ABS
-Glass
Tack
Tensile Strength and Elongation
Application Temperature
TEST METHODS
ASTM D 1000
Total (excluding liner)
ASTM D 1000
20 minute dwell
24 hour dwell
ASTM D 2979
Polyken™ Probe Tack
0.5 second dwell
ASTM D 1000
Lowest application temperature to
stainless steel
AVERAGE RESULTS
0.0028 inches (0.071mm)
Label destroys upon removal after both
20 minutes and 24 hours for all test
surfaces
45.4 oz (1288 g)
6.3 lbs/in (110 N/100 mm), 2%
50°F (10°C)
Samples were printed with the Brady Series R6200 and Brady Series R6000 Halogen Free ribbons. Samples applied to
aluminum panels and allowed to dwell 24 hours at room temperature prior to testing. Unless noted otherwise, results were the
same for both ribbons.
PERFORMANCE PROPERTIES
TEST METHODS
TYPICAL RESULTS
Long Term Service Temperature
30 days at various temperatures
No visible effect to label at 80°C.
Slight discoloration at 100°C, but is
functional.
Low Service Temperature
30 days at -40°F (-40°C)
No visible effect
Short Term Service Temperature
5 minutes at various temperatures
No visible effect to label at 180°C.
Severe discoloration at 240°C but label
still functional.
Humidity Resistance
30 days at 100°F (37°C), 95% R.H.
No visible effect
UV Light Resistance
30 days in UV SunlighterTM 100
No visible effect
Weatherability
ASTM G155, Cycle 1
30 days in Xenon Arc Weatherometer
No visible effect
Abrasion Resistance
Taber Abraser, CS-10 grinding wheels,
500 g/arm, 100 cycles (Fed. Std. 191A,
Method 5306)
R6200: Moderate print removal and print
smear. Print still legible.
R6000: Slight print removal. Print still
legible.
PERFORMANCE PROPERTY
SOLVENT RESISTANCE
Samples were printed with the Brady Series R6200 and the Brady Series R6000 Halogen Free ribbons. Samples applied to
aluminum panels and allowed to dwell 24 hours at room temperature prior to testing. Testing consisted of 5 cycles of 10 minute
immersions in the specified chemicals followed by 30 minute recovery periods. After final immersion samples rubbed 10 times
with cotton swabs saturated in test fluids.
CHEMICAL REAGENT
SUBJECTIVE OBSERVATION OF VISUAL CHANGE
EFFECT TO LABEL STOCK
R6200
R6000
Halogen Free
Isopropyl Alcohol
No visible effect
No visible effect without/ with No visible effect without/ with
rub.
rub.
No visible effect
No visible effect without rub.
Formula 409® Cleaner
Slight print removal with rub.
No visible effect
Northwoods™ Buzz Saw
rub.
rub.
Citrus Degreaser
JP-8 Jet Fuel
Slight adhesive ooze
rub.
rub.
Mineral Spirits
rub.
rub.
SAE 20 wt Oil @ 70°C
No visible effect
rub.
rub.
Gasoline
No visible effect
Super Agitene®
rub.
rub.
Deionized Water
No visible effect
rub.
rub.
10% Sodium Hydroxide
No visible effect
Solution
rub.
rub.
10% Sulfuric Acid Solution
No visible effect
rub.
rub.
B-351 is not recommended for use in harsh solvents such as MEK, Acetone, and 1,1,1-Trichloroethane.
Shelf life is two years from the date of receipt for this product as long as this product is stored in its original packaging in an
environment below 80° F (27° C) and 60% RH. It remains the responsibility of the user to assess the risk of using this product.
We encourage customers to develop testing protocols that will qualify a product's fitness for use in their actual application
Trademarks:
Formula 409® is a registered trademark of the Clorox Company
Northwoods™ is a trademark of the Superior Chemical Corporation
Polyken™ is a trademark of Testing Machines Inc.
Sunlighter™ is a trademark of the Test Lab Apparatus Company
Super Agitene® is a registered trademark of Graymills Corporation
ASTM: American Society for Testing and Materials (U.S.A.)
SAE: Society of Automotive Engineers (U.S.A.)
All SI units (metric) are mathematically derived from U.S. conventional units.
Note: All values shown are averages and should not be used for specification purposes.
Test data and test results contained in this document are for general information only and shall not be relied upon by Brady
customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to
develop specifications or performance criteria for specific product applications should contact Brady for further information.
Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to
manufacture this product or based on results of testing using recognized analytical methods performed by a third party,
independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and
assumes no liability in connection with the use of this information.
WARRANTY
Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their
adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and
workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have
been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers.
This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of
merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no
circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection
with the use, or inability to use, Brady's products.
Copyright 2019 Brady Worldwide, Inc. | All Rights Reserved
Material may not be reproduced or distributed in any form without written permission.
Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414-358-6600 | Fax: 800-292-2289
很抱歉,暂时无法提供与“TL-PK-3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+270.305681+32.82062
- 3+269.042553+32.66725
- 5+269.036605+32.66652
- 15+269.0306515+32.66580
- 25+269.0247125+32.66508
