EV5018B_S0_R0
600mA, 40V Synchronous
Step-Down Converter Evaluation Board
Parameters Subject to Change Without Notice
FEATURES
4.7V to 40V operating input range
600mA output current
Up to 93% efficiency
High efficiency (>78%) at light load
Internal Soft-Start
800kHz switching frequency
Input under voltage lockout
Available in SOT23-6 package
Current run-away protection
Short circuit protection
Thermal protection
APPLICATIONS
DESCRIPTION
Distributed Power Systems
Automotive Systems
High Voltage Power Conversion
Industrial Power Systems
Battery Powered Systems
The JW5018B is a current mode monolithic buck
switching regulator. Operating with an input range
of 4.7V~40V, the JW5018B delivers 600mA of
continuous output current with two integrated
N-Channel MOSFETs. The internal synchronous
power switches provide high efficiency without
the use of an external Schottky diode. At light
loads, the regulator operates in low frequency to
maintain high efficiency and low output ripple.
Current mode control provides tight load transient
response and cycle-by-cycle current limit.
The JW5018B guarantees robustness with
short-circuit protection, thermal protection,
current run-away protection, and input under
voltage lockout.
ELECTRICAL SPECIFICATIONS
Parameter
Symbol
Value
Unit
Input Voltage
VIN
7.5~40
V
Output Voltage
VOUT
5
V
Output Current
IOUT
0~0.6
A
EVALUATION BOARD AND TYPICAL PERFORMANCE
Efficiency @ Vout=5V
100.00%
95.00%
90.00%
EFFICIENCY
85.00%
80.00%
75.00%
70.00%
Vin=8V
65.00%
Vin=12V
60.00%
Vin=24V
55.00%
Vin=36V
50.00%
200
300
400
500
600
700
OUTPUT CURRENT(mA)
EV5018B_S0_R0 Rev.0.8
JoulWatt® Proprietary Information. Patent Protected.
Unauthorized Photocopy and Duplication Prohibited.
1
EV5018B_S0_R0
JoulWatt
SCHEMATIC
BILL OF MATERIALS
Qty.
Designator
Value
1
C0
47uF
1
C1
100nF
1
1
C2
4.7uF
Description
Electrolytic capacitor
50V
Ceramic capacitor
50V ,X7R
Ceramic capacitor
50V ,X7R
Ceramic capacitor
Package
Manufacturer
Manufacturer
P/N
RB.1/.2
0603C
CL10B104KO8N
SAMSUNG
1206C
NNC
CL31B475KBHN
SAMSUNG
NNE
C3
10uF
C4
NC
1
L1
10uH/3.2A
Inductor
7332
WE
1
R1
100k
Resistor,5%
0603R
Uniohm
0603J0104T5E
1
R2
100k
Resistor,5%
0603R
Uniohm
0603J0104T5E
1
R3
11.2k
Resistor,1%
0603R
Uniohm
0603F1122T5E
1
R4
2.1k
Resistor,1%
0603R
Uniohm
0603F2101T5E
1
R5
0Ω
Resistor,5%
0603R
Uniohm
0603J0000T5E
16V ,X7R
1210C
2
EV5018B_S0_R0
JoulWatt
Qty
Designator
Value
1
VIN
7.5V~40V
TEST-Pole
1
VOUT
5V/600mA
TEST-Pole
1
JW5018B
40V/600mA
Description
Buck
Package
SOT23-6
Manufacturer
Joulwatt
Manufacturer
P/N
JW5018B
3
EV5018B_S0_R0
JoulWatt
PRINTED CIRCUIT BOARD LAYEROUT
Figure1—
—Top Layer
Figure2—
—Bottom Layer
Figure3—
—Top Silk Layer
Figure4—
—Bottom Silk Layer
QUICK START GUIDE
1. Connect the positive terminal and negative terminal of the load to Vout and GND
of EVB, respectively.
2. Connect a power supply between VIN and GND with the supply in “OFF” state.
Set the output voltage of the power supply to 7.5V~40V.
3. Turn on the power supply and the evaluation board starts operating in normal
condition.
4. The output voltage can be adjusted by varying the R3 and R4 on EVB.
For example:
:Fixed R4 to2.1K,when adjusting the output voltage to 5V,
R3=Vout/0.8*R4-R4.
For more information, please refer to the datasheet ofJW5018B.
4
EV5018B_S0_R0
JoulWatt
TYPICAL PERFORMANCE CHARACTERISTICS
Vin = 12V, Vout = 5V, L = 10µH, Cout = 10µF, TA = +25°C, unless otherwise noted
Steady State Test
Startup through Enable
Shutdown through Enable
VIN=12V, Vout=5V
Iout=600mA
VIN=12V, Vout=5V
Iout=600mA(Resistive load)
VIN=12V, Vout=5V
Light Load Operation
Medium Load Operation
Heavy Load Operation
0 A LOAD
300mA LOAD
600mA LOAD
Short Circuit Protection
VIN=12V, Vout=5V
Iout=600mA- Short
Short Circuit Recovery
VIN=12V, Vout=5V
Iout= Short-600mA
Load Transient
→ 600mA LOAD
→ 300mA LOAD
300mA LOAD
5
EV5018B_S0_R0
JoulWatt
IMPORTANT NOTICE
Joulwatt Technology Inc. reserves the right to make modifications, enhancements, improvements,
corrections or other changes without further notice to this document and any product described herein.
Any unauthorized redistribution or copy of this document for any purpose is strictly forbidden.
Joulwatt Technology Inc. does not warrant or accept any liability whatsoever in respect of any products
purchased through unauthorized sales channel.
Copyright © 2015 EV5018B_S0_R0 Incorporated.
All rights are reserved by Joulwatt Technology Inc.
6
很抱歉,暂时无法提供与“JW5018B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.22092
- 50+1.79000
- 150+1.60532
- 500+1.37495
