JACK-L-PC-10A-RA(R)
JACK-L-PC-10A-RA(R)
    GLOBTEK
    JACK-L-PC-10A-RA(R)
JACK-L-PC-10A-RA(R) 数据手册
GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  PC mountable jack for 5.5x2.5mm female barrel connector. Unique 10A rating. Model No.  High Power DC Connectors Part No./Ordering No.  JACK-L-PC-10A-RA(R) Rev E In Addition to GlobTek Inc.'s renewed ISO9001:2008 - Quality Management System Certification, GlobTek Inc. is now certified to: ISO13485:2003 - Medical Devices Quality Management System Certification ISO14001:2004 - Environmental Management System Certification ISO Certificates are available online at http://www.globtek.com/iso-certificates/ The acceptance of this specification and use of the product described in this document indicates the acceptance and binding of the customer to Globtek TERMS AND CONDITIONS (attached to the end of this document), which supersede all other agreements, terms, and conditions ( http://en.globtek.com/terms-and-conditions/). Prop 65 Statement:https://en.globtek.com/prop-65-statement.pdf Footnote: GlobTek Inc. will not be liable for the safety and performance of these power supplies if unauthorized access and repair occurs. End user should consult applicable UL, CSA or EN standards for proper installation instruction. Limitation of Use: GlobTek products are intended for use with commercial, medical, and/or industrial equipment only. GlobTek product are not authorized for use as mission critical components in life support hazardous environment, nuclear or aircraft applications without prior written approval from the CEO of GlobTek Inc. Contents of this document are subject to change without prior notice. Customer Approval of Specification: Please approve, sign and send back to GlobTek so we can complete order processing. A delay in receipt of this form will delay delivery schedule. Company Name: Customer P/N: Quote Number: Date: Authorized Representative Name: Authorized Representative Signature: PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2018 - 2022 guest /11/03/2022 7:30:11 AM CLONED FROM JACK-C-PC-10A-RA(R) Page 1 of 8 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  PC mountable jack for 5.5x2.5mm female barrel connector. Unique 10A rating. Model No.  High Power DC Connectors Part No./Ordering No.  JACK-L-PC-10A-RA(R) Rev E REVISION HISTORY REV E DESCRIPTION SUB DATE APPROVED Add tab material and plating  QA 11/03/2021 QA D2 Add packing QA 08/31/2021 QA D1 Update to SF format QA 07/16/2021 QA D Remove contact resistance between terminal in closed circuit QA 03/23/2021 QA C Update drawing with determination the mating depth and the distance of the contacts from the opening QA 02/20/2020 QA B Update drawing from chip to outer spring contact QA 04/09/2019 QA A Initial release QA 03/26/2018 QA 3D CAD FILE: https://en.globtek.com/pdf/JACK-L-PC-10A-RA-R.STP AGENCY ONLINE DOCUMENTS RoHS/RoHS3 Declaration https://www.globtek.com/pdf/rohs_cert/01t0c000008OOv2AAG REACH Declaration https://www.globtek.com/pdf/iso_certificates/REACH.pdf Conflict Minerals Declaration https://www.globtek.com/pdf/conflict-minerals.pdf Prop 65 Statement https://en.globtek.com/prop-65-statement.pdf IPXY rating is based on 3rd party testing and customers should check suitability and test system level IPXY rating before ordering. PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2018 - 2022 guest /11/03/2022 7:30:11 AM CLONED FROM JACK-C-PC-10A-RA(R) Page 2 of 8 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  PC mountable jack for 5.5x2.5mm female barrel connector. Unique 10A rating. Model No.  High Power DC Connectors Part No./Ordering No.  JACK-L-PC-10A-RA(R) Rev E PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2018 - 2022 guest /11/03/2022 7:30:11 AM CLONED FROM JACK-C-PC-10A-RA(R) Page 3 of 8 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  PC mountable jack for 5.5x2.5mm female barrel connector. Unique 10A rating. Model No.  High Power DC Connectors Part No./Ordering No.  JACK-L-PC-10A-RA(R) Rev E PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2018 - 2022 guest /11/03/2022 7:30:11 AM CLONED FROM JACK-C-PC-10A-RA(R) Page 4 of 8 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  PC mountable jack for 5.5x2.5mm female barrel connector. Unique 10A rating. Model No.  High Power DC Connectors Part No./Ordering No.  JACK-L-PC-10A-RA(R) Rev E PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2018 - 2022 guest /11/03/2022 7:30:11 AM CLONED FROM JACK-C-PC-10A-RA(R) Page 5 of 8 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  PC mountable jack for 5.5x2.5mm female barrel connector. Unique 10A rating. Model No.  High Power DC Connectors Part No./Ordering No.  JACK-L-PC-10A-RA(R) Rev E PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2018 - 2022 guest /11/03/2022 7:30:11 AM CLONED FROM JACK-C-PC-10A-RA(R) Page 6 of 8 GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Drawing Title:  PC mountable jack for 5.5x2.5mm female barrel connector. Unique 10A rating. Model No.  High Power DC Connectors Part No./Ordering No.  JACK-L-PC-10A-RA(R) Rev E   Packing: PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2018 - 2022 guest /11/03/2022 7:30:11 AM CLONED FROM JACK-C-PC-10A-RA(R) Page 7 of 8 Drawing Title:  PC mountable jack for 5.5x2.5mm female barrel connector. Unique 10A rating. GlobTek, Inc. www.globtek.com 186 Veterans Drive, Northvale, NJ 07647 Tel. (201) 784-1000 Fax (201) 784-0111 Model No.  High Power DC Connectors Part No./Ordering No.  JACK-L-PC-10A-RA(R) Rev E PACKAGING Packing Spec P/N: Box Qty: 1000 Gift Box Size (mm): Gift Box Color: White Master Carton Size (mm): 243 x 243 x 190 Master Carton Cubic Volume (m³): 0.01 Master GW (Kg): kg wt Ea. (Kg): kg wt Ea. (Kg): LABEL SPECS: kg , PACK SPEC: PROPRIETARY INFORMATION PROPRIETARY OF GLOBTEK, INC. ANY REPRODUCTION, DISCLOSURE OR USE OF THIS DRAWING, IN WHOLE OR IN PART, IS HEREBY PROHIBITED EXCEPT AS SPECIFIED IN WRITING BY GLOBTEK, INC. © GlobTek, Inc. 2018 - 2022 guest /11/03/2022 7:30:11 AM CLONED FROM JACK-C-PC-10A-RA(R) Page 8 of 8
JACK-L-PC-10A-RA(R) 价格&库存
很抱歉,暂时无法提供与“JACK-L-PC-10A-RA(R)”相匹配的价格&库存,您可以联系我们找货
