SMAJ30CAHM2G
SMAJ30CAHM2G
    TAIWANSEMICONDUCTOR(台半)
    SMAJ30CAHM2G
SMAJ30CAHM2G 数据手册
SMAJ5.0(A) - SMAJ188(A) Taiwan Semiconductor 400W, 5V - 188V Surface Mount Transient Voltage Suppressor FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS Ideal for automated placement Glass passivated junction Excellent clamping capability Fast response time: Typically less than 1.0ps from 0 V to BV min Typical IR less than 1μA above 10V Moisture sensitivity level: level 1, per J-STD-020 AEC-Q101 qualified available: ordering code with suffix “H” 400 W peak pulse power capability with a 10 / 1000 μs waveform(300W above 78V) Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC PARAMETER VALUE UNIT VWM 5 - 188 V VBR PPPM tp = 10/1000 μs waveform TJ MAX 6.4 - 255 V 400 W 150 °C Package DO-214AC (SMA) Configuration Single die APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter MECHANICAL DATA ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Weight: 0.06g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT Peak power dissipation at TA=25°C, tp=1ms (Note 1) PPK 400 W Steady state power dissipation Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load Maximum instantaneous forward voltage at 25 A for unidirectional only Operating junction temperature range PD 1 W IFSM 40 A VF 3.5 V TJ -55 to +150 °C TSTG -55 to +150 °C Storage temperature range Note: 1. Non-repetitive current pulse per Fig. 3 and derated above TA=25°C per Fig. 2 Devices for Bipolar Applications 1. For bidirectional use C or CA suffix for types SMAJ5.0 - Types SMAJ188 2. Electrical characteristics apply in both directions 1 Version: S1901 SMAJ5.0(A) - SMAJ188(A) Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Breakdown voltage Part number Marking code VBR@IT (1) (V) SMAJ5.0 SMAJ5.0A SMAJ6.0 SMAJ6.0A SMAJ6.5 SMAJ6.5A SMAJ7.0 SMAJ7.0A SMAJ7.5 SMAJ7.5A SMAJ8.0 SMAJ8.0A SMAJ8.5 SMAJ8.5A SMAJ9.0 SMAJ9.0A SMAJ10 SMAJ10A SMAJ11 SMAJ11A SMAJ12 SMAJ12A SMAJ13 SMAJ13A SMAJ14 SMAJ14A SMAJ15 SMAJ15A SMAJ16 SMAJ16A SMAJ17 SMAJ17A SMAJ18 SMAJ18A SMAJ20 SMAJ20A SMAJ22 SMAJ22A SMAJ24 SMAJ24A SMAJ26 SMAJ26A SMAJ28 SMAJ28A SMAJ30 SMAJ30A SMAJ33 SMAJ33A AD AE AF AG AH AK AL AM AN AP AQ AR AS AT AU AV AW AX AY AZ BD BE BF BG BH BK BL BM BN BP BQ BR BS BT BU BV BW BX BY BZ CD CE CF CG CH CK CL CM Min. 6.4 6.4 6.67 6.67 7.22 7.22 7.78 7.78 8.33 8.33 8.89 8.89 9.44 9.44 10.0 10.0 11.1 11.1 12.2 12.2 13.3 13.3 14.4 14.4 15.6 15.6 16.7 16.7 17.8 17.8 18.9 18.9 20.0 20.0 22.2 22.2 24.4 24.4 26.7 26.7 28.9 28.9 31.1 31.1 33.3 33.3 36.7 36.7 Max. 7.30 7.00 8.15 7.37 8.82 7.98 9.51 8.60 10.30 9.21 10.90 9.83 11.50 10.40 12.20 11.10 13.60 12.30 14.90 13.50 16.30 14.70 17.60 15.90 19.10 17.20 20.40 18.50 21.80 19.70 23.10 20.90 24.40 22.10 27.10 24.50 29.80 26.90 32.60 29.50 35.30 31.90 38.00 34.40 40.7 36.8 44.9 40.6 Working Test current IT (mA) 10 10 10 10 10 10 10 10 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 stand-off Maximum reverse voltage leakage current VWM IR@VWM (1) (µA) Maximum peak Maximum clamping impulse current voltage IPPM (A) (2) VC@IPPM (V) (2) 41.7 43.5 35.1 38.8 32.5 35.7 30.1 33.3 28.0 31.0 26.7 29.4 25.2 27.8 23.7 26.0 21.3 23.5 19.9 22.0 18.2 20.1 16.8 18.6 15.5 17.2 14.9 16.4 13.9 15.4 13.1 14.5 12.4 13.7 11.2 12.3 10.2 11.3 9.3 10.3 8.6 9.5 8.0 8.8 7.5 8.3 6.8 7.5 9.6 9.2 11.4 10.3 12.3 11.2 13.3 12.0 14.3 12.9 15.0 13.6 15.9 14.4 16.9 15.4 18.8 17.0 20.1 18.2 22.0 19.9 23.8 21.5 25.8 23.2 26.9 24.4 28.8 26.0 30.5 27.6 32.2 29.2 35.8 32.4 39.4 35.5 43.0 38.9 46.6 42.1 50.0 45.4 53.5 48.4 59.0 53.3 (V) 5 5 6 6 6.5 6.5 7 7 7.5 7.5 8 8 8.5 8.5 9 9 10 10 11 11 12 12 13 13 14 14 15 15 16 16 17 17 18 18 20 20 22 22 24 24 26 26 28 28 30 30 33 33 800 800 800 800 500 500 200 200 100 100 50 50 10 10 5 5 5 5 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 Version: S1901 SMAJ5.0(A) - SMAJ188(A) Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Breakdown voltage Part number Marking code VBR@IT (1) (V) SMAJ36 SMAJ36A SMAJ40 SMAJ40A SMAJ43 SMAJ43A SMAJ45 SMAJ45A SMAJ48 SMAJ48A SMAJ51 SMAJ51A SMAJ54 SMAJ54A SMAJ58 SMAJ58A SMAJ60 SMAJ60A SMAJ64 SMAJ64A SMAJ70 SMAJ70A SMAJ75 SMAJ75A SMAJ78 SMAJ78A SMAJ85 SMAJ85A SMAJ90 SMAJ90A SMAJ100 SMAJ100A SMAJ110 SMAJ110A SMAJ120 SMAJ120A SMAJ130 SMAJ130A SMAJ150 SMAJ150A SMAJ160 SMAJ160A SMAJ170 SMAJ170A SMAJ188 SMAJ188A CN CP CQ CR CS CT CU CV CW CX CY CZ RD RE RF RG RH RK RL RM RN RP RQ RR RS RT RU RV RW RX RY RZ SD SE SF SG SH SK SL SM SN SP SQ SR ST SS Min. 40.0 40.0 44.4 44.4 47.8 47.8 50.0 50.0 53.3 53.3 56.7 56.7 60.0 60.0 64.4 64.4 66.7 66.7 71.1 71.1 77.8 77.8 83.3 83.3 86.7 86.7 94.4 94.4 100 100 111 111 122 122 133 133 144 144 167 167 178 178 189 189 209 209 Max. 48.9 44.2 54.3 49.1 58.4 52.8 61.1 55.3 65.1 58.9 69.3 62.7 73.3 66.3 78.7 71.2 81.5 73.7 86.9 78.6 95.1 86 102 92.1 106 95.8 115 104 122 111 136 123 149 135 163 147 176 159 204 185 218 197 231 209 255 231 Working Test current IT (mA) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 stand-off Maximum reverse voltage leakage current IR@VWM (1) (µA) VWM Maximum peak Maximum clamping impulse current voltage IPPM (A) (2) VC@IPPM (V) (2) (V) 36 36 40 40 43 43 45 45 48 48 51 51 54 54 58 58 60 60 64 64 70 70 75 75 78 78 85 85 90 90 100 100 110 110 120 120 130 130 150 150 160 160 170 170 188 188 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 6.2 6.9 5.6 6.2 5.2 5.8 5.0 5.5 4.7 5.2 4.4 4.9 4.2 4.6 3.9 4.3 3.7 4.1 3.5 3.9 3.2 3.5 3.0 3.3 2.9 3.2 2.0 2.2 1.9 2.1 1.7 1.9 1.6 1.7 1.4 1.6 1.3 1.5 1.1 1.3 1.0 1.2 1.0 1.1 0.9 0.9 64.3 58.1 71.4 64.5 76.7 69.4 80.3 72.7 85.5 77.4 91.1 82.4 96.3 87.1 103 93.6 107 96.8 114 103 125 113 134 121 139 126 151 137 160 146 179 162 196 177 214 193 231 209 266 243 287 259 304 275 344 328 Notes: 1. Pulse test with PW=30 ms 2. Non-repetitive current pulse, per Fig. 3 and derated above TA=25°C per Fig. 2 3. Peak pulse power waveform is 10/1000µs 4. For bi-directional devices having VR of 10 V and under, the IR limit is double. 3 Version: S1901 SMAJ5.0(A) - SMAJ188(A) Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE (Note 1,2,3) PACKAGE PACKING SMAJxxxAHR3G SMA 1,800 / 7” Plastic reel SMAJxxxAHR2G SMA 7,500 / 13” Paper reel SMAJxxxAHM2G SMA 7,500 / 13” Plastic reel SMAJxxxAHF3G Folded SMA 1,800 / 7” Plastic reel SMAJxxxAHF2G Folded SMA 7,500 / 13” Paper reel SMAJxxxAHF4G Folded SMA 7,500 / 13” Plastic reel SMAJxxxAHE3G Clip SMA 1,800 / 7” Plastic reel SMAJxxxAHE2G Clip SMA 7,500 / 13” Plastic reel SMAJxxxA R3G SMA 1,800 / 7” Plastic reel SMAJxxxA R2G SMA 7,500 / 13” Paper reel SMAJxxxA M2G SMA 7,500 / 13” Plastic reel SMAJxxxA F3G Folded SMA 1,800 / 7” Plastic reel SMAJxxxA F2G Folded SMA 7,500 / 13” Paper reel SMAJxxxA F4G Folded SMA 7,500 / 13” Plastic reel SMAJxxxA E3G Clip SMA 1,800 / 7” Plastic reel SMAJxxxA E2G Clip SMA 7,500 / 13” Plastic reel SMAJxxxAHR3 SMA 1,800 / 7” Plastic reel SMAJxxxAHR2 SMA 7,500 / 13” Paper reel SMAJxxxAHM2 SMA 7,500 / 13” Plastic reel SMAJxxxAHF3 Folded SMA 1,800 / 7” Plastic reel SMAJxxxAHF2 Folded SMA 7,500 / 13” Paper reel SMAJxxxAHF4 Folded SMA 7,500 / 13” Plastic reel SMAJxxxAHE3 Clip SMA 1,800 / 7” Plastic reel SMAJxxxAHE2 Clip SMA 7,500 / 13” Plastic reel SMAJxxxA R3 SMA 1,800 / 7” Plastic reel SMAJxxxA R2 SMA 7,500 / 13” Paper reel SMAJxxxA M2 SMA 7,500 / 13” Plastic reel SMAJxxxA F3 Folded SMA 1,800 / 7” Plastic reel SMAJxxxA F2 Folded SMA 7,500 / 13” Paper reel SMAJxxxA F4 Folded SMA 7,500 / 13” Plastic reel SMAJxxxA E3 Clip SMA 1,800 / 7” Plastic reel SMAJxxxA E2 Clip SMA 7,500 / 13” Plastic reel 4 Note 1: "xxx" defines voltage from 5V (SMAJ5.0) to 188V (SMAJ188) Note 2: "H" means AEC-Q101 qualified Note 3: "G" means green compound (halogen free) Version: S1901 SMAJ5.0(A) - SMAJ188(A) Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Peak Pulse Power Rating Curve Fig.2 Pulse Derating Curve PEAK PULSE POWER(PPP) OR CURRENT (IPP) DERATING IN PERCENTAGE (%) PPPM, PEAK PULSE POWER, KW 100 NON-REPETITIVE PULSE WAVEFORM SHOWN in FIG.3 10 1 0.1 0.1 1 10 100 1000 125 100 75 50 25 0 0 10000 Peak value IPPM PEAK PULSE CURRENT (%) Pulse width(td) is defined as the point where the peak current decays to 50% of IPPM 100 Rise time tr=10μs to 100% of IPPM 80 Half value-IPPM/2 60 40 10/1000μs, waveform 20 td 0 0 0.5 1 1.5 2 75 100 125 150 175 200 Fig.4 Maximum Non-repetitive Forward Surge Current IFSM, PEAK FORWARD SURGE CURRENT (A) Fig.3 Clamping Power Pulse Waveform 120 50 TA, AMBIENT TEMPERATURE (°C) tp, PULSE WIDTH, (μs) 140 25 2.5 50 8.3ms single half sine wave 40 30 20 10 0 1 3 t, TIME (ms) 10 100 NUMBER OF CYCLES AT 60 Hz 5 Version: S1901 SMAJ5.0(A) - SMAJ188(A) Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Typical Junction Capacitance CJ, JUNCTION CAPACITANCE (pF) A 10000 MEASURED AT ZERO BIAS 1000 100 f=1.0MHz Vsig=50mVp-p MEASURED at STAND-OFF VOLTAGE,Vwm 10 1 10 100 V(BR), BREAKDOWN VOLTAGE (V) 6 Version: S1901 SMAJ5.0(A) - SMAJ188(A) Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) DIM Unit (mm) Unit (inch) Min Max Min Max A 1.27 1.58 0.050 0.062 B 4.06 4.60 0.160 0.181 C 2.29 2.83 0.090 0.111 D 1.99 2.50 0.078 0.098 E 0.90 1.41 0.035 0.056 F 4.95 5.33 0.195 0.210 G 0.10 0.20 0.004 0.008 H 0.15 0.31 0.006 0.012 SUGGESTED PAD LAYOUT Symbol Unit (mm) Unit (inch) A 1.68 0.066 B 1.52 0.060 C 3.93 0.155 D 2.41 0.095 E 5.45 0.215 MARKING DIAGRAM P/N G YW F = Marking Code = Green Compound = Date Code = Factory Code Note: Cathode band for uni-directional products only 7 Version: S1901 SMAJ5.0(A) - SMAJ188(A) Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 8 Version: S1901
SMAJ30CAHM2G 价格&库存
很抱歉,暂时无法提供与“SMAJ30CAHM2G”相匹配的价格&库存,您可以联系我们找货
SMAJ30CAHM2G
    • 5+0.63684
    • 50+0.51804
    • 150+0.45864
    • 500+0.41409
    • 2500+0.32967
