Eclypse Z7: Zynq-7000 SoC
Development Board with SYZYGYcompatible Expansion
Eclypse Z7 Options:
SKU: 410-393
Eclypse Z7: Just the board
SKU: 471-036
Eclypse Z7 bundled with a Zmod DAC and Zmod ADC
SKU: 471-036-2
Eclypse Z7 bundled with two Zmod DACs
SKU: 471-036-1
Eclypse Z7 bundled with two Zmod ADCs
The Eclypse Z7 product image, displayed at and angle.
Top view product image of the Eclypse Z7.
Bottom view product image of the Eclypse Z7.
Product image of the Eclypse Z7, populated with the Zmod ADC and Zmod DAC. Please
note: Zmods are only included in the bundle options.
Top view product image of the Eclypse Z7, populated with the Zmod ADC and Zmod DAC.
Please note: Zmods are only included in the bundle options.
Overview
The Eclypse Z7 is Digilent's newest FPGA/SoC development board, specifically designed to
enable the rapid prototyping and development of embedded measurement systems. Featuring
high-speed Zmod ports for modular expansion, a Xilinx Zynq®-7020 SoC plus software API from
Digilent, the Eclypse Z7 is fast, flexible and shortens the time it takes for engineers and
researchers to develop innovative and powerful new high-speed instrumentation, control, and
measurement systems for edge-computing, medical, and communications applications. Eclypse
Z7 is the first host board of the Eclypse Platform.
Zmod Expansion
Zmod is Digilent’s new expansion solution using the open-source SYZYGY
standard from Opal Kelly. Faster than the Pmod Standard and more compact and costeffective than FMC, Zmods improve the customizability options for high-speed I/O. Plug
in your application specific Zmods and get up and running in hours or days, instead of
weeks or months. Two Zmods are being released alongside the Eclypse Z7, the Zmod
ADC 1410 and Zmod DAC 1411, both with 100 MSPS, 14-bit converters, with more
planned in the future.
Eclypse Platform Software
The Eclypse Z7 is a component of the Eclypse Platform, which pairs Digilent’s open
software API with Digilent’s novel Eclypse hardware. Petalinux is supported out of the
box, and pre-built Linux images are accompanied by the API for bulk data transfer. This
system allows users to plug in their Zmods of choice and get started prototyping new
high-speed measurement, instrumentation and control systems without directly
interfacing with the FPGA until desired. With this system, embedded Linux developers
can leverage the power of FPGA without possessing hardware expertise. Currently, C
and C++ are supported, with plans to add support for other programming languages in
the future.
Features
Zynq-7000 APSoC
(XC7Z020-1CLG484C)
667 MHz dual-core Cortex-A9 processor
DDR3L memory controller with 8 DMA channels and 4 High
Performance AXI3 Slave ports
High-bandwidth peripheral controllers: 1G Ethernet, USB 2.0,
SDIO
Low-bandwidth peripheral controllers: SPI, UART, CAN, I2C
Programmable from JTAG, Quad-SPI flash, and microSD
Memory
card
Programmable logic equivalent to Artix-7 FPGA
1 GiB DDR3L with 32-bit bus @ 1066 MT/s
16 MB Quad-SPI Flash with factory programmed 128-bit
random number and 48-bit globally unique EUI-48/64™
compatible identifier
microSD card slot
Power
Powered from external 12V 5A supply
Platform MCU for configuration of adjustable power supplies
and temperature management
USB and Ethernet
Gigabit Ethernet PHY
USB-JTAG programming circuitry
USB-UART bridge
USB micro AB port with USB 2.0 PHY with Host/Device/OTG
capabilities
2 ports following the SYZYGY Standard interface
specification
Compatible with a variety of SYZYGY pods, allowing for a
wide variety of applications
Dedicated differential clocks for input and output
8 differential I/Os per port
16 single-ended I/Os per port
DNA interfaces connected to Platform MCU allowing for
various auto-negotiated power supply configurations
Zmod Ports
Pmod Ports
2 twelve-pin ports for a total of 16 FPGA-connected I/Os
High speed voltage translation and protection circuitry
User GPIO
2 push-buttons
2 RGB LEDs
What's
Included:
Eclypse Z7 Development Board
FPGA fan
USB A to Micro B programming cable
USB A to Micro A cable
12V 5A power supply
Digilent custom packaging
Additional contents depend on the option choice:
• Adding one Zmod ADC and one Zmod DAC
• Adding two Zmod DACs
• Adding two Zmod ADCs
https://store.digilentinc.com/eclypse-z7-zynq-7000-soc-development-board-with-syzygy-compatible-expansion//4-22-20
很抱歉,暂时无法提供与“471-036”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5962.911081+723.31924
