iMCU7100EVB User’s Guide
Version 1.1
© 2011 WIZnet Co.,Ltd. All Rights Reserved.
For more information, visit our website at http://www.wiznet.co.kr
© Copyright 2011WIZnet Co.,Ltd. All rights reserved.
1
2
3
Overview ................................................................................................... 3
1.1
Introduction ................................................................................... 3
1.2
Specification .................................................................................. 4
Getting Started ........................................................................................... 5
2.1
Power On ...................................................................................... 5
2.2
Ping Test ....................................................................................... 5
2.3
Programming .................................................................................. 6
2.4
TCP Server Demonstration. ................................................................. 6
Product Description .................................................................................... 10
3.1
Package and Contents ..................................................................... 10
3.2
Board Layout ................................................................................ 11
3.3
Hardware Description ..................................................................... 12
3.4
Physical Specification ..................................................................... 16
© Copyright 2011 WIZnet Co.,Ltd. All rights reserved.
Ver. 1.0
2
Table of Contents
Overview
iMCU7100EVB is an Evaluation Board where the function and performance of W7100A can be
tested. In this document, basic ping and TCP serer test will be tested.
1.1
Introduction
iMCU7100EVB is an Evaluation Board made for testing whole functions of internet embedded MCU
W7100A. iMCU7100EVB can easily build serial-to-Ethernet communication environment by using RS232 port and LAN port; W7100A can also use supported Character LCD and other added ports to
control and test the all functions of the W7100A chip.
The list of Application notes from WIZnet website is as followed.
TCP server, client
UDP
DHCP
DNS client
DDNS
HTTP server, client
Telnet
Serial to Ethernet server, client, UDP
IPRAW
MACRAW
UART
Timer
LCD
I2C
Ver. 1.0
3
1
Specification
Lists of Items Contained in the EVB
Item
MCU
Memory
Details
Internet Embedded MCU - W7100A
Note
8051 compatible
64KBytes Data Memory (RAM)
64KBytes Code Memory (ROM)
Embedded in W7100A
2KBytes Boot code Memory
256Bytes Data Flash
Serial
Ethernet
On board RS-232C 1Port with DB9 Connector
On board RJ-45 with Transformer
LCD
16Character * 2Line Character LCD
LED
General purpose LED 3Ea
Network Status LED 8Ea
Button
Debugger
Expansion Port
Reset Switch 1Ea
On board Debugger Socket
MCU port expansion
32Pin (8pin * 4) 2.54mm Pitch Pin-Header Hole
14Pin (7pin * 2) 2.54mm Pitch Pin-Header Hole
32Pin (8pin * 4) 2.00mm Pitch Pin-Header Hole
14Pin (7pin * 2) 2.00mm Pitch Pin-Header Hole
Dummy Hole
Power
167Pin 2.54mm Pitch Dummy Hole
236Pin 2.00mm Pitch Dummy Hole
DC 5V / 2A Adapter
Built-in
Ver. 1.0
4
1.2
Getting Started
2.1
Power On
2
Connect Character LCD, UTP cable, RS-232C, and the power cable to the iMCU7100EVB.
iMCU7100EVB
Power on the iMCU7100EVB board, and check the following.
1.
Check whether POWER LED(D13) is ON.
2.
Check whether “iMCU7100 EVB” and “192.168.001.002” appears on the Character LCD.
If the above two are checked iMCU7100EVB board is normally working.
Ping Test
2.2
Run the command prompt at thetest PC, and execute the ping command to the IP of the test
PC. Send the ICMP ping request and check the ICMP ping reply from the PC. Note: the test PC
and the iMCU7100EVB board must be placed on the same sub-network.
1.
Confirm the network information of Test PC as the following
Source IP Address : 192.168.1.xxx
Gateway IP Address : 192.168.1.1
Subnet Mask : 255.255.255.0
2.
Execute ping command as the following
“C:\> ping 192.168.1.2”
Ver. 1.0
5
Ping test
2.3
Programming
The iMCU7100EVB uses the WizISP program or W7100A debugger to program the compiled
binary image(firmware). Please refer to the WizISP program guide and W7100A debugger
guide for more detailed information.
2.4
The document for TCP server application note and the sample code are included in the bundle CD. The
application note can also be downloaded from the WIZnet website. User can easily test the TCP
loopback server demonstration by using the sample code.
Lets test a simple TCP server demonstration as followed.
1.
2.
3.
Confirm the testing environment.
o
Connect test PC to iMCUW7100EVB by using UTP cable directly.
o
Connect test PC to iMCUW7100EVB by using Serial able directly.
o
Connect 5V power adaptor to test PC
Confirm the network information of test PC as fallows
o
Source IP Address : 192.168.0.2
o
Gateway IP Address : 192.168.0.1
o
After executing serial terminal program (ex: HyperTerminal),
set up the properties as followed.
Ver. 1.0
6
Setting of Terminal program
Properties
Setting Value
Bits Per second (Baud Rate)
115200 bps
Data Bits
8 Bits
Stop Bits
1 Bits
Parity
No
Flow Control
None
The serial message that indicates the operation of the TCP server is shown on the
HyperTerminal. In order to check serial messages, the settings for HyperTerminal
connection information must be done as shown in Figure 2.3. Check the COM port since it
differs depending on the user‟s settings.
Setting of HyperTerminal program
4.
Turn on the iMCU7100EVB and check the power LED.
5.
Run AX1 as in the order below. (Please refer to AX1 user‟s manual for more details)
Execute AX1 as shown in Fig 2.4
Ver. 1.0
7
(a) Connecting
(b)set IP and Port
(c) Send data
(d) set data format
Execute AX1
Since iMCU7100EVB is operating in TCP server mode, select „TCP Connect‟ from AX1
program and connect to the board. Enter the IP address and Port number of the
iMCU7100EVB; the „connected‟ message will show and connect to TCP server. If „send‟
button is clicked, the loopback test will start. The data size and base value for the
loopback test can be set by user.
6.
Loopback server Result
(a) Loopback server Result (HyperTerminal)
Ver. 1.0
8
Result of LOOPBACK server Demonstration on HyperTerminal
(b) Loopback server Result(AX1)
Result of LOOPBACK server Demonstration on AX1
If the loopback test successfully starts, the message that was sent from AX1 to
iMCU7100EVB will be sent back to AX1. Continuous loopback test can be operated if user
wishes to.
Ver. 1.0
9
Product Description
3.1
3
3.1 List of items contained in the iMCU7100EVB
Item
Board
Accessory
Quantity
iMCU7100EVB Board
1
16 x 2 Character LCD
1
Power adapter (DC 5V / 2A)
1
UTP Cable
1
Serial Cable
1
Sample codes and documents are available on WIZnet website.
The H/W version of iMCU7100EVB board can change for performance/function improvement.
The fine parts of the component might differ depending on the manufacturer.
3.2 Web Contents
Directory
iMCU7100EVB
Documents
Hardware
Software
Contents
Manual
User‟s Manual
Datasheet
Datasheet of Main Parts
App Note
Application Notes
Schematics
iMCU7100EVB Hardware Schematic
Parts List
iMCU7100EVB Parts List
Firmware
iMCU7100EVB Firmware
Tools
AX1, WizISP
The content of software might differ depending on the version.
Download the latest version of firmware, software, and documents at WIZnet website.
Ver. 1.0
10
Board Layout
3.2
Layout of iMCU7100EVB
The description of each Part is shown inthe Table 3.3 is as below.
Parts Description of iMCU7100EVB
No
Description
No
Description
1
WIZnetiMCUW7100A
2
RJ-45 Jack (integrated transformer)
3
RS-232C DB9 Connector
4
RS-232C 3Pin Header Hole (TTL)
5
DC 5V / 2A Adapter Jack
6
Power Switch
7
Reset Switch
8
Enable Boot Switch
9
PHY mode selection Switch
10
W7100ADebugger Connector
11
User LED * 3Ea
12
Network Status Indicate LED * 8Ea
13
Character LCD Connector
15
MCU Port Expansion Pin Header Hole
17
19
14
16
18
Dummy Pin Header Hole
Ver. 1.0
11
iMCUW7100A (U1)
The W7100A is the one chip solution that includes a hardwired TCP/IP core and an 8-bit
internet microcontroller unit (iMCU), which is 100% compatible to standard embedded 8051
compatible MCU core.Please refer to the W7100A datasheet for more detailed information.
Ethernet Port (P1)
Ethernet Port (P1) is the connector that connects the UTP cable; and the RJ-45 connector
internally includes a transformer to connect iMCU7100EVB board to the network.
RS-232C Serial Port (P2, J11)
RS-232C Serial Port (P2, J11) is a serial interface supported by W7100A. RS-232C Serial Port
is basically structured to use DSUB 9Pin Male type connector (P2). But the RS-232C Serial Port
is also structured to independently connect three pins of TX/RX/GND which are TTL signals,
with the Pin header; allowing the user to use user-produced cable. Fig 2.2 shows the structure.
Simple RS-232C Serial Port
DC Power Input Connector (DC1)
DC Power Input Connector (DC1) is supported by 5V/2A Adaptor of iMCU7100EVB. DC Power
Input Connector (DC1) is structured for a safe and stable environmentby applying
Poly_Fuse(F1); to prevent board damage from excessive electric current caused from misusing
the adaptor.
Power Switch (SW1)
Power Switch (SW1) is a Toggle switch for turning on/off DC.
Reset Switch (SW2)
Reset Switch (SW2) is for manual reset to provide users the ability to reset whenever they
want (ex: during the system is running).
Boot Enable Switch (SW3)
Boot Enable Switch (SW3) is used to select the W7100A booting mode and provides the
Ver. 1.0
12
3.3
following modes.
Description of Boot Enable switch
SW3
Description
On
Boot Enable. To program by using the WIZISP
Off
Boot Disable. To run the application programmed by the WIZISP
PHY Mode Switch (SW4)
PHY Mode Switch(SW4) is for setting the mode of PHY block inside W7100A.PHY Mode
Switch(SW4) provides the following modes.
Description of PHY Mode selection switch
SW4
Mode
Description
1
2
3
OFF
OFF
OFF
Auto
OFF
OFF
ON
A100
Auto-negotiation with 100 BASE-TX FDX/HDX ability
OFF
ON
OFF
A10
Auto-negotiation with 10 BASE-T FDX/HDX ability
OFF
ON
ON
ON
OFF
OFF
100F
Manual selection of 100 BASE-TX FDX
ON
OFF
ON
100H
Manual selection of 100 BASE-TX HDX
ON
ON
OFF
10F
Manual selection of 10 BASE-T FDX
ON
ON
ON
10H
Manual selection of 10 BASE-T HDX
Normal Operation Mode
Auto-negotiation enable with all capabilities
Reserved
W7100A Debugger Connector (JP2)
W7100A Debugger Connector (JP2) is for monitoring and changing various registers and
internal memory inside W7100A. User can write applications in the Code memory, therefore
allowing efficient debugging of software made by user.
Please refer to W7100A Debugger Guide for more details on W7100A Debugger.
Ver. 1.0
13
General purpose LEDs
There are three User LEDs for the user to control/test the Port and Debugging.
Description of User debugging LED
LED Name
W7100A Pin Name
Direction
LED0
P0_3
O
LED1
P0_4
O
LED2
P0_5
O
Network Status Indicate LEDs
Table 3.7 lists the descriptions for Indicate LEDs that tell the network status.
Description of Status indicate LED
LED Name
W7100A Pin Name
DIR.
10/100
SPDLED
O
Description
Network speed indicate LED
Low : 100Mbps , High : 10Mbps
FDX
FDXLED
O
Full / Half duplex indicate LED
Low : Full duplex , High : Half duplex
COL
COLLED
O
Collision detect LED
Low : Collisions occurred (only in half duplex mode)
RX
RXLED
O
Active Low. Receive activity LED
TX
TXLED
O
Active Low. Transmit activity LED
LINK
LINKLED
O
Active Low. Network link status indicate LED
ACT
ACTLED
O
Active Low. Rx or Tx activity LED
PLOCK
PLOCK
O
Active High. It notifies when internal PLL is locked.
Character LCD Connector (JP1)
Character LCD Connector (JP1) is for Debugging and showing the system status.Pin
descriptions of the Character LCD Interface are as followed.
Character LCD Interface Pin Description
PIN#
iMCU7100EVB Board PIN NAME
/ Character LCD PIN NAME
DIR.
Description
1
GND / VSS
2
5V / VDD
I
LCD Power Supply
3
V0 / V0
I
Voltage for LCD drive
4
P0_0 / RS
I
Data / Instruction register select
5
P0_1 / RW
I
Read / Write
Signal Ground
Ver. 1.0
14
P0_2 / E
7 ~ 14
I
P2_0 ~ P2_7 / DB0~ DB7
I/O
Enable signal,start data read / write
Data Bus Line
15
Not Connect / LED A
O
LED Anode, power supply+
16
Not Connect / LED K
O
LED Cathode,ground 0V
6
Please refer to LCD Datasheet (LC1624-R2.pdf) for more details on driving Character LCD.
MCU Port Expansion Pin header Hole (J1 … J10)
W7100A provides two types of pitches from the total of 32pin (8bit x 4Port) IO pin. User can
select according to their needs between 2.54mm Pin pitch and 2.00mm Pin pitch.
iMCU7100EVB board provides four ports of IO to allow users to use with the general pin
header.The description of port expansion is as followed.
Port Expansion Connector
Dummy pin header holes are not connected with system circuits. The dummy pin header
hole is provided into two types: 2.54mm Hole pitch and 2.00mm Hole pitch. By using dummy
hole, users can test external devices that are in need of additional tests.
Ver. 1.0
15
3.4
iMCU7100EVB Dimension
iMCU7100EVB Board Dimension
Symbols
Dimensions (mm)
Symbols
Dimensions (mm)
A
129.2
F
31.1
B
37.2
G
2.7
C
12.6
H
9.4
D
15.9
I
8.3
E
3.6
J
83.6
Ver. 1.0
16
Document History Information
Revision
Ver. 0.9
Data
Aug 17, 2009
Ver. 1.0
May 12, 2011
Description
Beta release
Modified and added contents with
iMCU7100EVB Rev. 1.1 lunching
Copyright Notice
Copyright 2011 WIZnet Co.,Ltd. All Rights Reserved.
Technical Support: support@wiznet.co.kr
Sales & Distribution: sales@wiznet.co.kr
Ver. 1.0
17
