Applicable standard
Rating
3
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
Operating Temperature Range
-55to +105C (Note1)
Storage Temperature Range
-10 C to +60C (Note3)
Operating Humidity Range
20% to 80% (Note2)
Storage Humidity Range
40%
Applicable Connector
DF51A-3P-2DSA(##)
DF51-3P-2DS(##)
DF51-3EP-2C(##)
Current
Applicable Contact
DF11-22SC(A)/SCF(A)
DF11-2428SC(A)/SCF(A)
DF11-30SC(A)/SCF(A)
Voltage
UL・C-UL
Rating
to 70% (Note3)
AWG 22 to 26 : 2.0A
AWG 28 : 1.0A
AWG 30 : 0.5A
30 V AC/DC
Voltage
Current
AWG 22
: 2.0A
AWG 24 to 28 : 1.0A
AWG 30
: 0.5A
250 V AC/DC
Specifications
Item
Test method
Requirements
QT
AT
X
X
X
X
1000 M MIN.
X
No flashover or breakdown.
X
X
X
Construction
General Examination
Visually and by measuring instrument.
Marking
Confirmed visually.
According to drawing.
Electric Characteristics 3
Insulation Resistance
500 V DC.
Voltage Proof
650 V AC for 1 min.
Mechanical Characteristics
Mechanical Operation
(Sn Plating)
(Au Plating)
Mating and unmating
Force
(Sn Plating)
Mating and unmating
Force
(Au Plating)
30 times insertion and extraction.
No damage, crack or looseness of parts.
3
50 times insertion and extraction.
It takes out and inserts with a conformity connector.
1.Insertion Force : 26.0N MAX.
2.Extraction Force : 0.75N MIN.
X
1.Insertion Force : 17.7N MAX.
X
Vibration
Frequency 10 to 55 Hz, single amplitude 0.75 mm, at
10 cycles for 3 direction.
X
Shock
Acceleration 490 m/s duration of pulse 11 ms at 3
times for 3 directions.
X
Contact extraction force
Pull out the cable after housing fixation.
11.8N MIN
X
2
3
Environmental Characteristics
Damp Heat
(Steady State)
Exposed at 40 ± 2C , humidity 90 to 95 %, 96 h.
(After leaving the room temperature for 1 to 2h.)
1.Insulation resistance: 500 M MIN. 3
2.No damage, crack or looseness of parts.
X
Rapid Change Of
Temperature
Temperature -55C→ +105C
Time
30min→ 30min
Under 5 Cycles.
(The transferring time of the tank is 2 to 3 MIN)
Exposed at 105±2C, 96h
Exposed at -55±3C, 96h
1.Insulation resistance: 1000 M MIN. 3
X
X
X
Dry Heat
Cold
Remarks
Note 1:Include the temperature rising by current.
Note 2:No condensing
Note 3:Apply to the condition of long term storage for unused products before mount on pcb,
After mounted on pcb, operating temperature and humidity range is applied for interim storage during transportation.
3
COUNT
DESCRIPTION OF REVISIONS
DESIGNED
CHECKED
DATE
6
DIS-H-00004567
TS.MIYAKI
SZ.ONO
20190110
Unless otherwise specified, refer to IEC 60512.
Note QT:Qualification Test AT:Assurance Test
FORM HD0011-2-1
X:Applicable Test
APPROVED
YN.TAKASHITA
20160127
CHECKED
YN.TAKASHITA
20160127
DESIGNED
TT.OHSAKO
20160127
DRAWN
TT.OHSAKO
20160127
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC-363930-00-00
DF51-3S-2C
CL543-5121-0-00
3
1/1
很抱歉,暂时无法提供与“DF51-3S-2C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.81627
- 50+0.80126
- 200+0.79121
