Technical Data Sheet
RFB00035/12.20/6.4
Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG
BNC 50 Straight Jack for PCB
51K101-400A5
All dimensions are in mm; tolerances according to ISO 2768 m-H
Interface
According to
DIN EN 61169-8
Documents
PCB layout
B 32
Material and plating
Connector parts
Center contact
Outer contact
Body
Dielectric
Material
CuBe
Brass
Brass
PTFE
P.O.Box 1260
D-84526 Tittmoning
Germany
http://www.rosenberger.com/
Plating
AuroDur®, gold plated
Nickel, 2.5-5 µm
Nickel, 2.5-5 µm
Tel. : +49 8684 18-0
Email : info@rosenberger.com
Page
1/2
51K101-400A5
RFB00035/12.20/6.4
Electrical data
Impedance
Frequency
Return loss
50
DC to 10 GHz
30 dB, DC to 2 GHz
25 dB, 2 to 4 GHz
Insertion loss
0.05 x
Insulation resistance
Center contact resistance
Outer contact resistance
Test voltage
Working voltage
Power handling (at 20 °C, sea level, VSWR 1.0)
5 x103 M
1.5 m
1 m
1500 V rms
400 V rms
80 W @ 2 GHz
f [GHz] dB, DC to 4 GHz
- Connector only, VSWR in application depends decisive on PCB layout -
Mechanical data
Mating cycles
Center contact captivation: axial
min. 500
15 N
Environmental data
Temperature range
Thermal shock
Corrosion
Vibration
Shock
Moisture resistance
Max. soldering temperature
RoHS
-55°C to +155°C
MIL-STD-202, Meth. 107, Cond. B
MIL-STD-202, Meth. 101, Cond. B
MIL-STD-202, Meth. 204, Cond. B
MIL-STD-202, Meth. 213, Cond. G
MIL-STD-202, Meth. 106
IEC 61760-1, +260°C for 10 sec.
compliant
Tooling
N/A
Suitable cables
N/A
Weight
Weight
6.4 g/pce
While the information has been carefully compiled to the best of our knowledge, nothing is
intended as representation or warranty on our part and no statement herein shall be
construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
For the installation of the
electrotechnical equipment,
particular electrotechnical
expertise is required.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
Chr. Entsfellner
09.07.08
Chr. Janßen
02.12.20
f00
20-1927
S. Huber-Siegl
02.12.20
P.O.Box 1260
D-84526 Tittmoning
Germany
Page
2/2
很抱歉,暂时无法提供与“51K101-400A5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+73.69876
- 10+72.58448
- 25+69.73109
- 50+67.84619
- 100+66.37783
