SFHG60CA002
SFHG60CA002
    WISOL(威盛)
    SMD
    SFHG60CA002
SFHG60CA002 数据手册
SPECIFICATION Surface Acoustic Wave Filter USER USER PART No. WISOL PART No. SFHG60CA002 DOC. No. SMS-51-L-SFT-FX-50 DATE June 29, 2015 REVISION 000 WISOL Ham, Eun-Jin Byun, Kyung-Su Mun. Gil-seop ISSUED APPROVED APPROVED BY BY (R&D) BY (QC) User ISSUED CHECKED APPROVED BY BY BY WISOL CO., LTD. 531-7, Gajang-ro, Osan-si, Gyeonggi-do, KOREA, 447-210 http://www.wisol.co.kr Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 ▶ A TABLE OF CONTENTS 1. REVISION HISTORY ..................................................................................................................................... 3 2. DEFINITION .................................................................................................................................................. 4 3. PRECAUTIONS ............................................................................................................................................. 4 4. OUTLINE DRAWING & DIMENSIONS.......................................................................................................... 5 5. MARKING ...................................................................................................................................................... 6 6. PERFORMANCE ........................................................................................................................................... 7 6-1. MAXIMUM RATINGS .......................................................................................................................... 7 6-2. ELECTRICAL CHARACTERISTICS ................................................................................................... 8 7. RELIABILITY ............................................................................................................................................... 10 7-1. ENGINEERING SAMPLE FLOW CHART ......................................................................................... 10 7-2. TEST ITEM & CONDITION ................................................................................................................ 11 8. REFLOW CONDITION ................................................................................................................................ 12 9. RECOMMENDED PCB DIMENSIONS ....................................................................................................... 12 10. CAUTION ................................................................................................................................................... 13 11. PACKING ................................................................................................................................................... 14 11-1. DIMENSIONS.................................................................................................................................. 14 11-2. REELING QUANTITY ..................................................................................................................... 15 11-3. TAPING STRUCTURE .................................................................................................................... 15 11-4. INNER BOX(Reel Packing) STRUCTURE ...................................................................................... 16 11-5. OUTER BOX STRUCTURE ............................................................................................................ 17 12. TAPE SPECIFICATIONS .......................................................................................................................... 18 13. RoHS DATA ............................................................................................................................................... 19 SMS-51-L-SFT-FX-50 Page 2/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 1. REVISION HISTORY 000 June 29, 2015 SMS-51-L-SFT-FX-50 All Page Make specification Page 3/24 June 29, 2015 Surface Acoustic Wave Filter SFHG60CA002 LTE Rx 1960 MHz Band 2 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 2. DEFINITION 2-1. PART No. SFHG60CA002 ① ② ③ No. ④ ⑤ ⑥ EXPLANATION ① SAW Filter ② Design Type ③ Center Frequency : 1960MHz(1930~1990) ④ Input:50ohm,Output:50ohm ⑤ Package size: 1.1×0.9mm² ⑥ Design Revision (02 : Molding Type) 2-2. APPLICATION : Band-Pass Filter for Band 2 Rx etc. 3. PRECAUTIONS 3-1. This device should not be used in any type of fluid such as water, oil, organic solvent, etc. 3-2. This is a hermetic device. MSL(Moisture Sensitive Level) is the '2a' level. 3-3. Ultrasonic cleaning shall be avoided. 3-4. Isopropyl Alcohol and Ethyl Alcohol can be used for cleaning. Contact us before using other cleaning solvents than above 3-5. This is an electrostatic sensitive device. Please avoid static voltage during operation and storage. 3-6. Sudden change of temperature shall be avoided, deterioration of the characteristics can occur. 3-7. If any malfunction due to designing or manufacturing which is out of specification occurs within one year after the products have been delivered, the maker should exchange the defective products. SMS-51-L-SFT-FX-50 Page 4/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 4. OUTLINE DRAWING & DIMENSIONS [Unit: mm] UKX O X SMS-51-L-SFT-FX-50 Page 5/24 No. Function Others Ground 1 Unbalanced Input 4 Unbalanced Output June 29, 2015 Surface Acoustic Wave Filter SFHG60CA002 LTE Rx 1960 MHz Band 2 3 1.1×0.9×0.5mm Version : 000 5pin lay-out 5. MARKING UKX O X 5-1. U K X X st nd - The 1 2 character 'UK' indicates the model name of SAW Filter SFHG60CA002. rd - The 3 character 'X' indicates the year and the month of manufacture. Year Month 1 2 3 4 5 6 7 8 9 10 11 12 2014 1 2 3 4 5 6 7 8 9 A B C 2015 D E F G H I J K L M N O 2016 P Q R S T U V W X Y Z a 2017 1 2 3 4 5 6 7 8 9 A B C ※ This rotates by the 3 years. - The th 4 character 'X' indicates Lot No. 5-2. ○ - This symbol indicates input pin 1. - This indicates the producing center ○ : China 5-3. Marking : Laser Marking SMS-51-L-SFT-FX-50 Page 6/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6. PERFORMANCE 6-1. MAXIMUM RATINGS CHARACTERISTICS RATINGS UNITS DC Permissive Voltage 5 V Maximum Input Power 15 dBm Operating Temperature Range -30 ~ +85 ℃ Storage Temperature Range -40 ~ +85 ℃ SMS-51-L-SFT-FX-50 Page 7/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6-2. ELECTRICAL CHARACTERISTICS 6-2-1. TABLE Ta = -30 ~ +85℃ SPECIFICATION Item FREQUENCY RANGE [MHz] UNIT Insertion Loss 1930 ~ 1990 Inband Ripple Min. Typ. (25℃) dB - 2.0 1930 ~ 1990 dB - 0.9 2.3 Input VSWR 1930 ~ 1990 - - 1.7 2.3 Output VSWR 1930 ~ 1990 - - 1.8 2.3 10 ~ 1850 dB 35 41 - 80 dB 50 60 - 699 ~ 716 dB 35 43 - 824 ~ 849 dB 35 43 - 1770 ~ 1830 dB 35 40 - 1852.4 ~ 1907.6 dB 35 46 - 2005 ~ 2050 dB 2 15 - 2050 ~ 2075 dB 20 27 - 2075 ~ 6000 dB 20 28 - 2400 ~ 2500 dB 35 46 - 3780 ~ 3980 dB 30 40 - 4900 ~ 5950 dB 25 34 - 5630 ~ 5810 dB 25 34 - 5725 ~ 5970 dB 25 34 - Absolute Attenuation Max. 3.4 *1 Input: Unbalanced 50 ohm Output: Unbalanced 50 ohm Termination Impedance *1: JIG loss is de-embedded. 6-2-2. TEST FIXTURE UKX O X [X—Ray Top View] SMS-51-L-SFT-FX-50 Page 8/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 6-2-3. GRAPH SMS-51-L-SFT-FX-50 Page 9/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 7. RELIABILITY 7-1. ENGINEERING SAMPLE FLOW CHART Initial Characteristics Electrical Parametric Data@25℃ Preconditioning (JESD22-A113F) Temp. Drift (n=5) Thermal Shock (n=23) Board Adhesion (n=11) Low Temp. Storage (n=23) PCT (n=23) Bending Test (n=11) High Temp. Storage (n=23) Vib ration (n=23) ESD Test (n=11) Humidity Test (n=23) Drop (n=23) ESD Limit Test (n=11) Final Electrical Data (n=74) Final Electrical Data (n=92) Final Electrical Data (n=44) SMS-51-L-SFT-FX-50 Page 10/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 7-2. TEST ITEM & CONDITION CATEGORY TEST ITEM Preconditioning Environment Test JESD22A113F -30℃ → +25℃→ +85℃ High Temp. Storage +85℃ 240hr JESD22-A103C Low Temp. Storage -40℃ 240hr JESD22-A119 description High Temp. High Humidity Storage +85℃ 85%RH 240hr JESD22-A106B Thermal Shock -40℃/30min ⇔ +85℃/30min , 100cycle JESD22-A106A +121℃ 100%RH 96hr JESD22-A102C Vibration Test (Random) 20 ㎐~2000 ㎐,0.053G²/Hz or 8g's RMS,15min/plane IEC 68-2-36 Fdb Drop Test 152 ㎝ 12times Steel floor JIG(110g~150g) IEC 1178-1.4.8.9 0.5 ㎜/sec 1point push IEC 68-2-21 Ue3 0.5 ㎜/sec 3times -PCB : FR4 , PCB SIZE : 100*40 ㎜ IEC 68-2-21 Ue3 Solder Heat Resistance ±250V,C=100pF,R=1.5 ㏀,1times IEC 68-2-21 Ue3 static marginal test C=100pF,R=1.5 ㏀,1times(demand of customer) JESD22-A114F Board Adhesion Bending Test Physical Test +125℃ 24hr Baking → +60℃ 60%RH 120hr → Reflow Test(3times) REMARK Temp. Drift High Temp. Operating Mechanical Test TEST CONDITION SMS-51-L-SFT-FX-50 Page 11/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 8. REFLOW CONDITION 9. RECOMMENDED PCB DIMENSIONS [unit : mm] [SAW, X-ray Top view] SMS-51-L-SFT-FX-50 [PCB, X-ray Top view] Page 12/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 10. CAUTION Moisture Sensitivity Device Caution (MSL LEVEL=2a) 1. Calculated shelf life in sealed bag : 12 month at 〈40℃ and 〈90% relative Humidity(RH) 2. Peak package body temperature : 260℃ 3. After bag is opened, devices that will be subjected to reflow solder or other high temperature process must be (a) Mounted within : 672 hours of factory conditions ≤30℃/60% RH, or (b) Stored per J-STD-033 4. Device require bake, before mounting, if : (a) Humidity Indicator Card reads 〉60% when read at 23±5℃ (b) 3(a) or 3(b) are not met 5. If baking is required, refer to IPC/JEDEC J-STD-033 for bake procedure Note : Level and body temperature defined by IPC/JEDEC J-STD-020 Aluminum Pack (310mmΧ370mm) HIC(Humidity Indication Card) 10 to 60% RH SMS-51-L-SFT-FX-50 Page 13/24 June 29, 2015 Surface Acoustic Wave Filter SFHG60CA002 LTE Rx 1960 MHz Band 2 3 1.1×0.9×0.5mm Version : 000 5pin lay-out 11. PACKING 11-1. DIMENSIONS - Carrier Tape [Unit: mm] A B D0 D1 E F P0 P1 P2 t1 t2 W 1.08 +0.05 -0.05 1.23 +0.05 -0.05 Ø 1.50 +0.10 -0.00 Ø 0.50 +0.01 1.75 +0.10 -0.10 3.50 +0.05 -0.05 4.00 +0.05 -0.05 4.00 +0.05 -0.05 2.00 +0.05 -0.05 0.23 +0.05 -0.05 0.70 +0.05 -0.05 8.00 +0.30 -0.10 - Reel [Unit: mm] A B C D E F G H t1 t2 W Ø 258.0 +1.0 -0.5 Ø 81.0 +1.0 -1.0 Ø 13.0 +0.5 -0.5 50.0 +0.8 -0.8 2.2 +0.3 -0.3 7.0 +0.5 -0.5 30.0 +0.8 -0.8 35.0 +1.0 -1.0 1.8 +0.5 -0.5 1.5 +0.5 -0.5 9.0 +1.0 -0.5 - The product shall be packed properly not to damaged during transportation and storage. SMS-51-L-SFT-FX-50 Page 14/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 11-2. REELING QUANTITY 10 inch reel : 10,000 pcs/reel 11-3. TAPING STRUCTURE 11-3-1. The tape shall be wound around the reel in direction shown below. U K X O X U K X O X 11-3-2. BAR CODE LABEL SMS-51-L-SFT-FX-50 ① MODEL NAME BARCODE ② SFH836AQ101 Model Name ③ RLYC12563 Reel number ④ 8,000 / qAFYU Quantity / Marking Page 15/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 1-3-3. Leader part and vacant position specifications. 11-4. INNER BOX(Reel Packing) STRUCTURE Material: Polycarbonate Material : Polyethylene + Aluminium 2 Size : 310×370mm Material Size: : Paper (D)260×(W)37×(H)265mm SMS-51-L-SFT-FX-50 3 Page 16/24 June 29, 2015 EA . . Surface Acoustic Wave Filter SFHG60CA002 LTE Rx 1960 MHz Band 2 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 11-5. OUTER BOX STRUCTURE Material : Paper TYPE A SIZE(mm) a b c Inner Box # 270 240 275 6 boxes SIDE ① SIDE ② MODEL Q'TY EA USER DATE . . - SIDE is the same as front side. SMS-51-L-SFT-FX-50 Page 17/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 12. TAPE SPECIFICATIONS 12-1. Tensile Strength of Carrier Tape: 4.4N/mm width 12-2. Top Cover Tape Adhesion (See the below figure) - pull of angle: 0~15 degree - speed: 300mm/min. - force: 20~70g SMS-51-L-SFT-FX-50 Page 18/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Version : 000 13. RoHS DATA SMS-51-L-SFT-FX-50 Page 19/24 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SMS-51-L-SFT-FX-50 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Page 20/24 Version : 000 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SMS-51-L-SFT-FX-50 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Page 21/24 Version : 000 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SMS-51-L-SFT-FX-50 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Page 22/24 Version : 000 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SMS-51-L-SFT-FX-50 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Page 23/24 Version : 000 June 29, 2015 Surface Acoustic Wave Filter LTE Rx 1960 MHz Band 2 SMS-51-L-SFT-FX-50 SFHG60CA002 3 1.1×0.9×0.5mm 5pin lay-out Page 24/24 Version : 000 June 29, 2015
SFHG60CA002 价格&库存
很抱歉,暂时无法提供与“SFHG60CA002”相匹配的价格&库存,您可以联系我们找货
