No.:
Date:
RPCH-K-HTS-0001 /2
2017.4.21
Data sheet
Title:
FIXED THICK FILM CHIP RESISTORS; RECTANGULAR
TYPE AND HIGH POWER ⋅ ANTI SURGE
Style:
RPCH16,20,32,35
AEC-Q200 qualified
RoHS COMPLIANCE ITEM
Halogen and Antimony Free
Note: ・Stock conditions
Temperature: +5°C ∼ +35°C
Relative humidity: 25% ∼ 75%
The period of guarantee: Within 2 year from shipmen t by the company.
Solderability shall be satisfied.
・Product specification contained in this data sheet
are subject to change at any time without notice
・If you have any questions or a Purchasing Specification for any quality
Agreement is necessary, please contact our sales staff.
Hokkaido Research Center
Approval by: T. Sannomiya
Drawing by: M. Shibuya
No: RPCH−K−HTS−0001
Title:
FIXED THICK FILM CHIP RESISTORS; RECTANGULAR TYPE AND
HIGH POWER ⋅ ANTI SURGE RPCH16,20,32,35
Page:
/2
1/10
1. Scope
1.1 This data sheet covers the detail requirements for fixed thick film chip resistors; rectangular type & high power ⋅ anti surge,
style of RPCH16,20,32,35.
1.2 Applicable documents
JIS C 5201−1: 2011, JIS C 5201−8: 2014, JIS C 5201−8−1: 2014
IEC60115−1: 2008, IEC60115−8: 2009, IEC60115−8−1: 2014
EIAJ RC−2134C−2010
2. Classification
Type designation shall be the following form.
(Example)
RPCH
32
123
J
TP
K
1
2
3
4
5
6
Style
1 Fixed thick film chip resistors; rectangular type & & high power ⋅ anti surge
2 Rated dissipation and / or dimension
3 Temperature coefficient of resistance
K
±100×10−6/ °C
Standard
−(Dash)
Style
4 Rated resistance
123
E24 Series, 3 digit, Ex. 123--> 12kΩ,
1000
E96 Series, 4 digit, Ex. 1000-->100Ω
1022--> 10.2kΩ
5 Tolerance on rated resistance
D
±0.5%
F
±1%
J
±5%
6 Packaging form
B
TP
TE
Bulk (loose package)
Paper taping
Embossed taping
Product specification contained in this data sheet are subject to change at any time without notice.
If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff.
Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.4.21
No: RPCH−K−HTS−0001
Title:
Page:
/2
2/10
3. Rating
3.1 The ratings shall be in accordance with Table−1.
Table−1
Rated
dissipation
(W)
Style
RPCH16
K
Standard
K
Standard
K
Standard
K
Standard
K
Standard
K
Standard
K
Standard
K
Standard
0.33
RPCH20
0.5
RPCH32
0.66
RPCH35
0.75
Style
RPCH16
RPCH20
RPCH32
RPCH35
Rated resistance
range (Ω)
resistance (10-6 / °C)
±100
±200
±100
±200
±100
±200
±100
±200
±100
±200
±100
±200
±100
±200
±100
±200
10∼1M
1.0∼9.76
10∼1M
1.0∼9.1
10∼1M
1.0∼9.76
10∼1M
1.0∼9.1
10∼1M
1.0∼9.76
10∼1M
1.0∼9.1
10∼1M
1.0∼9.76
10∼1M
1.0∼9.1
Limiting element voltage
(V)
150
Isolation voltage
(V)
150
200
500
3.2 Climatic category
55/155/56
Tolerance on
rated resistance
E24, 96
D(±0.5%),
F(±1%)
E24
J(±5%)
E24, 96
D(±0.5%),
F(±1%)
E24
J(±5%)
E24, 96
D(±0.5%),
F(±1%)
E24
J(±5%)
E24, 96
D(±0.5%),
F(±1%)
E24
J(±5%)
Category temperature
range(°C)
−55~+155
Lower category temperature
Upper category temperature
Duration of the damp heat, steady state test
3.3 Stability class
5%
Preferred
number series
for resistors
− 55 °C
+155 °C
56days
Limits for change of resistance:
−for long−term tests
±(5%+0.1Ω)
−for short−term tests
±(1%+0.05Ω)
3.4 Derating
The derated values of dissipation at temperature in excess of 70 °C shall be as indicated by the following curve.
100
Percentage of the
rated dissipation
Area of recommended
operation
−55
70
155
Ambient temperature (°C)
Figure–1 Derating curve
No: RPCH−K−HTS−0001
Title:
Page:
/2
3/10
3.5 Rated voltage
d.c.or a.c.r.m.s.voltage calculated from the square root of the product of the rated resistance and the rated dissipation.
E: Rated voltage (V)
E =
P · R
P: Rated dissipation (W)
R: Rated resistance (Ω)
Limiting element voltage can only be applied to resistors when the resistance value is equal to or higher than the critical
resistance value.
At high value of resistance, the rated voltage may not be applicable.
4. Packaging form
The standard packaging form shall be in accordance with Table−2.
Table−2
Symbol
B
TP
TE
Packaging form
Paper taping
Embossed taping
8mm width, 4mm pitches
Standard packaging
quantity / units
1,000 pcs.
5,000 pcs.
4,000 pcs.
Application
RPCH16,20,32,35
RPCH16,20,32
RPCH35
W
5. Dimensions
5.1 The resistor shall be of the design and physical dimensions in accordance with Figure−2 and Table−3.
L
c
d
d
H
c
Figure−2
Table−3
+0.15
-0.05
H
0.45±0.10
c
0.3±0.2
Unit: mm
d
0.3±0.1
2.0±0.1
1.25±0.10
0.55±0.10
0.3±0.2
0.4±0.2
RPCH32
3.1±0.1
1.6±0.15
0.55±0.10
0.4±0.25
0.5±0.25
RPCH35
3.1±0.15
2.5±0.15
0.55±0.15
0.4±0.25
0.5±0.25
Style
RPCH16
L
1.6±0.1
RPCH20
W
0.8
5.2 Net weight (Reference)
Style
Net weight(mg)
RPCH16
2
RPCH20
5
RPCH32
9
RPCH35
16
No: RPCH−K−HTS−0001
Title:
Page:
/2
4/10
6. Marking
Resistor
The Rated resistance shall be marked in 3 digits (E24) or 4 digits (E96) and marked on over coat side.
• E24 series: 3 digits, E96 series: 4 digits
In case of the resistance value that E96 overlaps with E24, It is marked by either.
The Rated resistance of RPCH16 should not be marked in 4 digits(E96)
Marking example
Contents
Application
3
E24(RPCH16,20,32,35)
123
12×10 [Ω] → 12 [kΩ]
E24(RPCH 16,20,32,35)
2R2
2. 2 [Ω]
5623
E96(RPCH 20,32,35)
562 ×103 [Ω] → 562 [kΩ]
12R7
E96(RPCH 20,32,35)
12.7 [Ω]
7. Performance
7.1 The standard condition for tests shall be in accordance with Sub−clause 4.2, JIS C 5201−1: 2011.
7.2 The performance shall be satisfied in Table−4.
Table−4(1)
No.
Test items
Performance requirements
Condition of test (JIS C 5201−1)
1
Visual examination
As
in
4.4.1
Sub−clause 4.4.1
The marking shall be legible, as
Checked by visual examination.
checked by visual examination.
2
Dimension
Sub−clause 4.4.2
As specified in Table−3 of this
specification.
Resistance
As in 4.5.2
Sub−clause 4.5
The
resistance
value
shall
correspond with the rated resistance
taking into account the specified
tolerance.
3
Voltage proof
Sub−clause 4.7
No breakdown or flash over
Method: 4.6.1.4
Test voltage: Alternating voltage with a peak
value of 1.42 times the insulation
voltage.
Duration: 60 s ± 5 s
Insulation resistance
R≥1GΩ
Test voltage: Insulation voltage
Duration: 1 min.
4
Solderability
As in 4.17.4.5
Sub−clause 4.17
The terminations shall be covered
Without ageing
Flux: The resistors shall be immersed in a with a smooth and bright solder
coating.
non−activated soldering flux for 2s.
Bath temperature: 235 °C ± 5 °C
Immersion time: 2 s ± 0.5 s
No: RPCH−K−HTS−0001
Title:
No
5
6
5/10
Table−4(2)
Mounting
Sub−clause 4.31
Substrate material: Epoxide woven glass
Sub−clause 4.13
Overload
The applied voltage shall be 2.5 times the rated
(in the mounted state)
voltage or twice the limiting element voltage,
whichever is the less severe.
Duration: 2 s
No visible damage
Visual examination
∆R ≤ ± (1%+0.05Ω)
Resistance
Solvent resistance of the Sub−clause 4.30
Legible marking
marking
Solvent: 2−propanol
Solvent temperature: 23 °C ± 5 °C
Method 1
Rubbing material: cotton wool
Without recovery
Mounting
Sub−clause 4.31
Bound strength of the end Sub−clause 4.33
face plating
Bent value: 3 mm
Test items
Final measurements
7
Page:
/2
Resistance to soldering heat
Component
resistance
Resistance
Sub−clause 4.33.6
Visual examination
Sub−clause 4.18
Solder temperature: 260 °C ± 5 °C
Immersion time: 10 s ± 0.5 s
Visual examination
Resistance
solvent Sub−clause 4.29
Solvent: 2−propanol
Method 2
Recovery: 48 h
Visual examination
Resistance
∆R ≤ ± (1%+0.05Ω)
No visible damage
As in 4.18.3.4
No sign of damage such as cracks.
∆R ≤ ± (1%+0.05Ω)
No visible damage
∆R ≤ ± (1%+0.05Ω)
No: RPCH−K−HTS−0001
Title:
No
8
Test items
Mounting
Adhesion
Rapid change temperature
9
Climatic sequence
−Dry heat
−Damp heat, cycle
(12+12hour cycle)
First cycle
−Cold
−Damp heat, cycle
(12+12hour cycle)
Remaining cycle
−D.C. load
10
Mounting
Endurance at 70 °C
Table−4(3)
Sub−clause 4.31
Sub−clause 4.32
Force: 5 N
Duration: 10 s ± 1 s
Visual examination
Sub−clause 4.19
Lower category temperature:−55 °C
Upper category temperature:+155 °C
Duration of exposure at each temperature:
30 min.
Number of cycles: 5 cycles.
Visual examination
Resistance
Sub−clause 4.23
Sub−clause 4.23.2
Test temperature: +155 °C
Duration: 16 h
Sub−clause 4.23.3
Test method: 2
Test temperature: 55 °C
[Severity(2)]
Sub−clause 4.23.4
Test temperature −55 °C
Duration: 2h
Sub−clause 4.23.6
Test method: 2
[Severity (2)]
Sub−clause 4.23.7
The applied voltage shall be the rated voltage
or the limiting element voltage whichever is the
smaller.
Duration: 1 min.
Visual examination
Resistance
Sub−clause 4.31
Sub−clause 4.25.1
Ambient temperature: 70 °C ± 2 °C
Duration: 1000 h
The voltage shall be applied in cycles of 1.5 h
on and 0.5 h.
smaller.
Examination at 48 h , 500 h and
1000 h:
Visual examination
Resistance
Page:
/2
6/10
No visible damage
No visible damage
∆R ≤ ±(1%+0.05Ω)
No visible damage
∆R ≤ ± (5%+0.1Ω)
No visible damage
∆R ≤ ± (5%+0.1Ω)
No: RPCH−K−HTS−0001
Title:
No
11
12
13
Page:
/2
7/10
Table−4(4)
Mounting
Sub−clause 4.31
Variation of resistance with Sub−clause 4.8
As in Table−1
temperature
−55 °C / +20 °C
+20 °C / +155°C
Mounting
Sub−clause 4.31
Damp heat, steady state
Sub−clause 4.24
Ambient temperature: 40 °C ± 2 °C
Relative humidity : 93 +2
−3 %
a) 1st group: without voltage applied.
b) 2nd group: The d. c. voltage shall be applied
continuously.
The voltage shall be accordance with
Sub−clause 4.24.2.1 b). without polarizing
voltage [4.24.2.1, c)]
No visible damage
Visual examination
Legible marking
∆R ≤ ± (5%+0.1Ω)
Resistance
Test items
Dimensions (detail)
Sub−clause 4.4.3
As in Table−3
Mounting
Sub−clause 4.31
Endurance at upper category Sub−clause 4.25.3
temperature
Ambient temperature:155 °C ± 2 °C
Duration: 1000 h
Examination at 48 h, 500 h and
1000 h:
Visual examination
Resistance
No visible damage
∆R ≤ ± (5%+0.1Ω)
No: RPCH−K−HTS−0001
Title:
Page:
/2
8/10
8. Taping
8.1 Applicable documents JIS C 0806−3: 2014, EIAJ ET−7200C: 2010
8.2 Taping dimensions
8.2.1 Taping dimensions shall be in accordance with Figure−3 and Table−5.
Unit: mm
4±0.1
t
φ1.5
Sprocket hole
1
+0.1
2±0.05
1.75±0.1
B
8±0.2
A
t
Carrier cavity
2
4±0.1
3.5±0.05
Direction of unreeling
Style
RPCH16
RPCH20
RPCH32
Figure−3
Table−5
A
B
1.15±0.15
1.9±0.2
1.65±0.15
2.5±0.2
2.00±0.15
3.6±0.2
t1
0.6±0.1
0.8±0.1
0.8±0.1
Unit: mm
t2
0.8max.
1.0max.
1.0max.
8.2.2 Embossed taping dimensions shall be in accordance with Figure−4 and Table−6.
Unit: mm
0.3 max.
2±0.05
Sprocket hole
φ1.5+0.1
1.75±0.1
4±0.1
Carrier cavity
t1
W
B
E
A
4±0.1
Figure−4
Table−6
Style
RPCH35
A
2.85±0.20
B
3.5±0.2
W
8.0±0.3
E
3.5±0.05
Unit: mm
t1
1.0±0.2
No: RPCH−K−HTS−0001
Title:
Page:
/2
9/10
1). The cover tapes shall not cover the sprocket holes.
2). Tapes in adjacent layers shall not stick together in the packing.
3). Components shall not stick to the carrier tape or to the cover tape.
4). Pitch tolerance over any 10 pitches ±0.2mm.
5). The peel strength of the top cover tape shall be with in 0.1N to 0.5N on the test method as shown in the following
RPCH16,20,32:Figure−4,RPCH35:Figure-5.
6). When the tape is bent with the minimum radius for 25 mm, the tape shall not be damaged and the components shall
maintain their position and orientation in the tape.
7). In no case shall there be two or more consecutive components missing.
The maximum number of missing components shall be one or 0.1%, whichever is greater.
8). The resistors shall be faced to upward at the over coating side in the carrier cavity.
Top cover tape
Carrier tape
165°to180°
Peel−off
( About 300mm/ min)
Figure−5
Top cover tape
Carrier tape
165°to180°
Peel−off
(About 300mm/ min)
Figure−6
No: RPCH−K−HTS−0001
Title:
Page:
/2
10/10
8.3 Reel dimension
Reel dimensions shall be in accordance with the following Figure−7 and Table−7.
Plastic reel (Based on EIAJ ET−7200C)
Unit: mm
φ60
φ13±0.2
2±0.5
φ180 −1.5
Marking A
φ21±0.8
Marking B
A
B
Figure−7
Table−7
Unit: mm
A
B
Note
Style
11.4±1.0
Injection molding
RPCH16,20,32,35
9 +1.0
13±1.0
Vacuum forming
Note: Marking label shall be marked on a place of Marking A or two place of marking A and B.
8.4 Leader and trailer tape.
(Example)
400mm min.
100mm min.
160mm min.
End
Start
Trailer
Leader
Figure−8
9. Marking on package
The label of a minimum package shall be legibly marked with follows.
9.1 Marking A
(1) Classification
(Style, Temperature coefficient of resistance, Rated resistance, Tolerance on rated resistance, Packaging form)
(2) Quantity (3) Lot number (4) Manufacturer’s name or trade mark
9.2 Marking B (KAMAYA control label)
(5) Others
