1.6*0.8*0.95mm Dome Lens SMD CHIP LED E6Q0603VGAC1UDA
Features:
●Long operating life
●Low Power Consumption
●Low voltage DC operated
●RoHS Compliant
Application:
●Status indicator
●Industrial control panel
●Sensor status indication
●Wearable and portable devices
Part Number
E6Q0603VGAC1UDA
Dice Material
InGaN
Emitted Color
Green
Lens Color
Water Clear
Electro-Optical Characteristics(Ta=25℃, @20mA)
Parameter
Luminous Intensity
Radiation Bandwidth
Forward Voltage
Luminous Flux
Dominant Wavelength
CIE Coordinates CIE
Color Temperature
Viewing Angle
Reverse Current
Symbol
IV
△λ
VF
Φ
λd
x,y
Tc
2θ1/2
IR
Min.
2000
2.90
515
Typ.
35
3.00
520
30
Max.
3000
3.40
527
10
Unit
mcd
nm
v
Lm
nm
k
deg
uA
Absolute Maximum Ratings(Ta=25℃)
Parameter
Peak Forward Current(1/10 Duty Cycle, 0.1ms Pulse Width)
Forward Current
Reverse Voltage
Electrostatic Discharge
Operating Temperature Range
Storage Temperature Range
Reflow Soldering
www.ekingluxs.com
Symbol
IPF
IF
VR
ESD
Topr
Tstg
Tsld
Max.
Unit
100
mA
30
mA
5
v
2000
v
o
-40to+90
C
o
-40to+90
C
260℃for 10secs
Sales@ekingluxs.com
1
Optical & Electrical Characteristics
Spectrum Distribution
Relative Luminous lntensity(%)
100
75
50
25
450
500
550
Wavelength (nm)
50
50
40
40
30
2.0
2.4
2.8
3.2
650
700
Forward Current vs.Ambient Temperature
Forward Current (mA)
Forward Current vs.Forward Voltage
600
30
0 0
3.6
60
80
100
Ambient Temperature
Forward Voltage (V )-volts
Relative Luminous lntensity vs.Forward Currenr
20° 10° 0°
2.5
30°
2.0
40°
1.5
1.0
0.9
0.8
50°
1.0
60°
70°
80°
90°
0.6 0.4 0.2
0.5
40
Forward Currenr(mA)
50
0.7
Radiation Diagram
www.ekingluxs.com
Sales@ekingluxs.com
2
Bin Limits
Bin Range Of Luminous Intensity (Unit:mcd)
Bin Code
L1
L2
L3
Min
2000
2500
Max
2500
3000
Condition
Min
2.9
3.0
3.1
3.2
3.3
Max
3.0
3.1
3.2
3.3
3.4
Condition
IF=20mA
Bin Range Of Forward Voltage (Unit:V)
Bin Code
V1
V2
V3
V4
V5
IF=20mA
Bin Range Of Wavelength (Unit:nm)
Bin Code
G1
G2
G3
G4
G5
G6
Min
515
517
519
521
523
525
Max
517
519
521
523
525
527
Condition
IF=20mA
Notes:
1.Tolerance of Luminous Intensity ±10%
2.Tolerance of Forward Voltage ±0.1V
www.ekingluxs.com
Sales@ekingluxs.com
3
Reliability Test Items And Conditions
Test Items
Reference
Thermal Shock
Test Conditions
Time
-40℃(30min)
100
-100℃(30min) Cycles
-10℃~65℃;
10cycles
0%~90%RH
MIL-STD-202G
Temperature And Humidity
Cyclic
High Temperature Storage
Low Temperature Storage
High Temperature High
Humidity Storage
High Temperature Life Test
JEITA ED-4701 200
203
JEITA ED -4071 200
201
JEITA ED -4071 200
202
JEITA ED -4071 100
103
JESD22-A108D
Life Test
Resistance to Sodering
Heat
GB/T 4937,Ⅱ,
2.2&2.3
Criterion
22
0/22
22
0/22
Ta=100℃
1000H
22
0/22
Ta=-40℃
1000H
22
0/22
1000H
22
0/22
1000H
22
0/22
1000H
22
0/22
2 times
22
0/22
Ta=60℃;
RH=90%
Ta=80℃
Ta=25℃
IF=20mA
Tsol*=(240±5)
℃10secs
JESD22-A108D
Quantity
Criteria For Judging Damage
Test Items
Forward Voltage
Recerse Current
Symbol
VF
IR
Test Conditions
IF=IFT
VR=5V
Luminous Intensity
IV
IF=IFT
Resistance to
Soldering Heat
Initial Data±10%
IR≤10uA
Average IV degradation≤30%;Single LED IV
degradation≤50%
Meterial without internal cracks,no meterial
between stripped,no deaded light
www.ekingluxs.com
Sales@ekingluxs.com
4
Product size (Unit:mm)
NOTES:
1. All dimensions are in millimeters (inches)
2. Tolerances are 0.2mm (0.008inch) unless otherwise noted
Recommended Soldering Pad Design (Unit:mm)
Taping and package Spec
●Tape Specification:4,000pcs Per Reel
www.ekingluxs.com
Sales@ekingluxs.com
5
Packaging
LabelStyle
www.ekingluxs.com
Sales@ekingluxs.com
6
Useful hint
Reflow Soldering Instructions
1. Don't cause stress to the LEDs while it is exposed to high temperature.
2. The maximum number of reflow soldering passes is 2 times.
3. Reflow soldering is recommended. Other soldering methods are not recommended as they might cause damage to the product.
www.ekingluxs.com
Sales@ekingluxs.com
7
Precautions
1. Storage:
●Moisture proof and anti-electrostatic package with moisture absorbent material is used, to keep
moisture to
aminimum.
●Before opening the package, the product should be kept at 30℃ or less and humidity less than 60% RH, and beused
within a year.
●After opening the package, the product should be stored at 30℃ or less and humidity less than 10%RH, and besoldered
within 24 hours (1day). It is recommended that the product be operated at the workshop condition of 30℃ or less and
humidity less than 60%RH.
●If the moisture absorbent material has fade away or the LEDs have exceeded the storage time, baking treatment should
be performed based on the following condition: (70±5)℃ for 24 hours.
2. Static Electricity:
Static electricity or surge voltage damages the LEDs. Damaged LEDs will show some unusual characteristic such as the
forward voltage becomes lower, or the LEDs do not light at the low current. even not light.
All devices, equipment and machinery must be properly grounded. At the same time, it is recommended that wrist bands
or anti-electrostatic gloves, anti-electrostatic containers be used when dealing with the LEDs.
3. Vulcanization:
LED curing is due to sulfur being in bracket and the +1 price of silver in the chemical reaction generated Ag2S in the
process. It will lead to the capacity of reflecting of silver layer reducing, light color temperature drift and serious
decline ,seriously affecting the performance of the product.So we should take corresponding measures to avioding
vulcanization, such as to avoid using sulphur volatile substances and keeping away from high sulphur content of the
material.
www.ekingluxs.com
Sales@ekingluxs.com
8
很抱歉,暂时无法提供与“E6Q0603VGAC1UDA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.20703
- 100+0.16882
- 300+0.14971
- 3000+0.12228
- 6000+0.11081
- 9000+0.10509
